| 1 |
greg |
1.1 |
#ifndef lint
| 2 |
greg |
2.20 |
static const char RCSid[] = "$Id: modobject.c,v 2.19 2020/10/17 17:48:46 greg Exp $";
| 3 |
greg |
1.1 |
#endif
| 4 |
| 5 |
* Routines for tracking object modifiers
| 6 |
greg |
2.7 |
| 7 |
* External symbols declared in object.h
| 8 |
| 9 |
| 10 |
greg |
2.8 |
#include "copyright.h"
| 11 |
greg |
1.1 |
| 12 |
#include "standard.h"
| 13 |
| 14 |
#include "object.h"
| 15 |
| 16 |
greg |
1.2 |
#include "otypes.h"
| 17 |
| 18 |
greg |
1.1 |
| 19 |
static struct ohtab {
| 20 |
int hsiz; /* current table size */
| 21 |
OBJECT *htab; /* table, if allocated */
| 22 |
} modtab = {100, NULL}, objtab = {1000, NULL}; /* modifiers and objects */
| 23 |
| 24 |
schorsch |
2.10 |
static int otndx(char *, struct ohtab *);
| 25 |
greg |
1.3 |
| 26 |
greg |
1.1 |
| 27 |
greg |
2.9 |
OBJECT
| 28 |
greg |
2.13 |
objndx( /* get object number from pointer */
| 29 |
OBJREC *op
| 30 |
| 31 |
greg |
1.1 |
| 32 |
greg |
2.20 |
int i;
| 33 |
long j;
| 34 |
greg |
1.1 |
| 35 |
greg |
2.20 |
for (i = (nobjects-1)>>OBJBLKSHFT; i >= 0; i--) {
| 36 |
greg |
2.3 |
j = op - objblock[i];
| 37 |
greg |
2.12 |
if ((j >= 0) & (j < OBJBLKSIZ))
| 38 |
greg |
2.20 |
return(((OBJECT)i<<OBJBLKSHFT) + (OBJECT)j);
| 39 |
greg |
2.3 |
| 40 |
return(OVOID);
| 41 |
greg |
1.1 |
| 42 |
| 43 |
| 44 |
greg |
2.9 |
OBJECT
| 45 |
greg |
2.13 |
lastmod( /* find modifier definition before obj */
| 46 |
OBJECT obj,
| 47 |
char *mname
| 48 |
| 49 |
greg |
2.3 |
| 50 |
greg |
2.13 |
OBJREC *op;
| 51 |
int i;
| 52 |
greg |
2.3 |
| 53 |
greg |
2.4 |
i = modifier(mname); /* try hash table first */
| 54 |
greg |
2.12 |
if ((obj == OVOID) | (i < obj))
| 55 |
greg |
2.4 |
return(i);
| 56 |
for (i = obj; i-- > 0; ) { /* need to search */
| 57 |
greg |
2.3 |
op = objptr(i);
| 58 |
greg |
2.13 |
if (ismodifier(op->otype) && op->oname[0] == mname[0] &&
| 59 |
!strcmp(op->oname, mname))
| 60 |
greg |
2.3 |
return(i);
| 61 |
| 62 |
return(OVOID);
| 63 |
| 64 |
| 65 |
| 66 |
greg |
2.9 |
OBJECT
| 67 |
greg |
2.13 |
modifier( /* get a modifier number from its name */
| 68 |
char *mname
| 69 |
| 70 |
greg |
1.1 |
| 71 |
greg |
2.13 |
int ndx;
| 72 |
greg |
1.1 |
| 73 |
ndx = otndx(mname, &modtab);
| 74 |
return(modtab.htab[ndx]);
| 75 |
| 76 |
| 77 |
| 78 |
greg |
2.3 |
#ifdef GETOBJ
| 79 |
greg |
2.9 |
OBJECT
| 80 |
greg |
2.13 |
object( /* get an object number from its name */
| 81 |
char *oname
| 82 |
| 83 |
greg |
2.3 |
| 84 |
greg |
2.13 |
int ndx;
| 85 |
greg |
2.3 |
| 86 |
ndx = otndx(oname, &objtab);
| 87 |
return(objtab.htab[ndx]);
| 88 |
| 89 |
#endif
| 90 |
| 91 |
| 92 |
greg |
2.15 |
int
| 93 |
greg |
2.14 |
eqreal( /* are two real values close enough to equal? */
| 94 |
double d1,
| 95 |
double d2
| 96 |
| 97 |
| 98 |
if (d2 != 0.0)
| 99 |
d1 = d1/d2 - 1.0;
| 100 |
return((-FTINY <= d1) & (d1 <= FTINY));
| 101 |
| 102 |
| 103 |
| 104 |
int
| 105 |
eqobjects( /* check if two objects are equal */
| 106 |
OBJECT obj1,
| 107 |
OBJECT obj2
| 108 |
| 109 |
| 110 |
OBJREC *op1, *op2;
| 111 |
greg |
2.17 |
int i, n;
| 112 |
greg |
2.14 |
| 113 |
greg |
2.15 |
while (obj1 != obj2) {
| 114 |
if (obj1 == OVOID)
| 115 |
return(0);
| 116 |
if (obj2 == OVOID)
| 117 |
return(0);
| 118 |
op1 = objptr(obj1);
| 119 |
op2 = objptr(obj2);
| 120 |
if (op1->otype != op2->otype)
| 121 |
return(0);
| 122 |
if (op1->oargs.nsargs != op2->oargs.nsargs)
| 123 |
return(0);
| 124 |
if (op1->oargs.nfargs != op2->oargs.nfargs)
| 125 |
return(0);
| 126 |
greg |
2.14 |
#ifdef IARGS
| 127 |
greg |
2.15 |
if (op1->oargs.niargs != op2->oargs.niargs)
| 128 |
greg |
2.14 |
return(0);
| 129 |
greg |
2.15 |
for (i = op1->oargs.niargs; i-- > 0; )
| 130 |
if (op1->oargs.iarg[i] != op2->oargs.iarg[i])
| 131 |
return(0);
| 132 |
greg |
2.14 |
#endif
| 133 |
greg |
2.15 |
for (i = op1->oargs.nfargs; i-- > 0; )
| 134 |
if (!eqreal(op1->oargs.farg[i], op2->oargs.farg[i]))
| 135 |
return(0);
| 136 |
greg |
2.17 |
n = 0;
| 137 |
greg |
2.16 |
switch (op1->otype) { /* special cases (KEEP CONSISTENT!) */
| 138 |
case MOD_ALIAS:
| 139 |
case MAT_ILLUM:
| 140 |
case MAT_MIRROR:
| 141 |
greg |
2.17 |
n = (op1->oargs.nsargs > 0);
| 142 |
greg |
2.16 |
break;
| 143 |
case MIX_FUNC:
| 144 |
case MIX_DATA:
| 145 |
case MIX_TEXT:
| 146 |
case MIX_PICT:
| 147 |
greg |
2.17 |
n = 2*(op1->oargs.nsargs >= 2);
| 148 |
greg |
2.16 |
break;
| 149 |
case MAT_CLIP:
| 150 |
greg |
2.17 |
n = op1->oargs.nsargs;
| 151 |
greg |
2.16 |
break;
| 152 |
| 153 |
greg |
2.17 |
/* check other string arguments */
| 154 |
for (i = op1->oargs.nsargs; i-- > n; )
| 155 |
if (strcmp(op1->oargs.sarg[i], op2->oargs.sarg[i]))
| 156 |
return(0);
| 157 |
while (n-- > 0) /* check modifier references */
| 158 |
if (!eqobjects( lastmod(obj1, op1->oargs.sarg[n]),
| 159 |
lastmod(obj2, op2->oargs.sarg[n]) ))
| 160 |
greg |
2.16 |
return(0);
| 161 |
greg |
2.15 |
obj1 = op1->omod;
| 162 |
obj2 = op2->omod;
| 163 |
| 164 |
greg |
2.14 |
return(1);
| 165 |
| 166 |
| 167 |
| 168 |
greg |
2.7 |
void
| 169 |
greg |
2.13 |
insertobject( /* insert new object into our list */
| 170 |
OBJECT obj
| 171 |
| 172 |
greg |
1.1 |
| 173 |
greg |
2.13 |
int i;
| 174 |
greg |
1.1 |
| 175 |
if (ismodifier(objptr(obj)->otype)) {
| 176 |
i = otndx(objptr(obj)->oname, &modtab);
| 177 |
greg |
2.14 |
if (eqobjects(obj, modtab.htab[i]))
| 178 |
greg |
2.16 |
return; /* don't index if same as earlier def. */
| 179 |
greg |
1.1 |
modtab.htab[i] = obj;
| 180 |
| 181 |
greg |
2.3 |
#ifdef GETOBJ
| 182 |
else {
| 183 |
i = otndx(objptr(obj)->oname, &objtab);
| 184 |
objtab.htab[i] = obj;
| 185 |
| 186 |
#endif
| 187 |
greg |
1.1 |
for (i = 0; addobjnotify[i] != NULL; i++)
| 188 |
(*addobjnotify[i])(obj);
| 189 |
| 190 |
| 191 |
| 192 |
greg |
2.7 |
void
| 193 |
greg |
2.18 |
truncobjndx(void) /* remove bogus table entries past end */
| 194 |
greg |
2.7 |
| 195 |
greg |
2.18 |
int ndx;
| 196 |
| 197 |
if (nobjects <= 0) {
| 198 |
if (modtab.htab != NULL) {
| 199 |
free((void *)modtab.htab);
| 200 |
modtab.htab = NULL;
| 201 |
modtab.hsiz = 100;
| 202 |
| 203 |
if (objtab.htab != NULL) {
| 204 |
free((void *)objtab.htab);
| 205 |
objtab.htab = NULL;
| 206 |
objtab.hsiz = 100;
| 207 |
| 208 |
return;
| 209 |
greg |
2.7 |
| 210 |
greg |
2.18 |
for (ndx = modtab.hsiz*(modtab.htab != NULL); ndx--; )
| 211 |
if (modtab.htab[ndx] >= nobjects)
| 212 |
modtab.htab[ndx] = OVOID;
| 213 |
| 214 |
for (ndx = objtab.hsiz*(objtab.htab != NULL); ndx--; )
| 215 |
if (objtab.htab[ndx] >= nobjects)
| 216 |
objtab.htab[ndx] = OVOID;
| 217 |
greg |
2.7 |
| 218 |
| 219 |
| 220 |
greg |
1.1 |
static int
| 221 |
greg |
2.13 |
nexthsiz( /* return next hash table size */
| 222 |
int oldsiz
| 223 |
| 224 |
greg |
1.1 |
| 225 |
static int hsiztab[] = {
| 226 |
greg |
2.19 |
251, 509, 1021, 2039, 4093, 8191, 16381,
| 227 |
32749, 65521, 131071, 262139, 0
| 228 |
greg |
1.1 |
| 229 |
greg |
2.13 |
int *hsp;
| 230 |
greg |
1.1 |
| 231 |
for (hsp = hsiztab; *hsp; hsp++)
| 232 |
if (*hsp > oldsiz)
| 233 |
return(*hsp);
| 234 |
return(oldsiz*2 + 1); /* not always prime */
| 235 |
| 236 |
| 237 |
| 238 |
static int
| 239 |
greg |
2.13 |
otndx( /* get object table index for name */
| 240 |
char *name,
| 241 |
struct ohtab *tab
| 242 |
| 243 |
greg |
1.1 |
| 244 |
greg |
2.19 |
char *onm;
| 245 |
greg |
1.1 |
OBJECT *oldhtab;
| 246 |
int hval, i;
| 247 |
greg |
2.13 |
int ndx;
| 248 |
greg |
1.1 |
| 249 |
if (tab->htab == NULL) { /* new table */
| 250 |
tab->hsiz = nexthsiz(tab->hsiz);
| 251 |
tab->htab = (OBJECT *)malloc(tab->hsiz*sizeof(OBJECT));
| 252 |
| 253 |
error(SYSTEM, "out of memory in otndx");
| 254 |
ndx = tab->hsiz;
| 255 |
while (ndx--) /* empty it */
| 256 |
tab->htab[ndx] = OVOID;
| 257 |
| 258 |
/* look up object */
| 259 |
hval = shash(name);
| 260 |
tryagain:
| 261 |
for (i = 0; i < tab->hsiz; i++) {
| 262 |
greg |
2.11 |
ndx = (hval + (unsigned long)i*i) % tab->hsiz;
| 263 |
greg |
2.19 |
if (tab->htab[ndx] == OVOID)
| 264 |
return(ndx);
| 265 |
onm = objptr(tab->htab[ndx])->oname;
| 266 |
if (onm != NULL && !strcmp(onm, name))
| 267 |
greg |
1.1 |
return(ndx);
| 268 |
| 269 |
/* table is full, reallocate */
| 270 |
oldhtab = tab->htab;
| 271 |
ndx = tab->hsiz;
| 272 |
tab->htab = NULL;
| 273 |
while (ndx--)
| 274 |
if (oldhtab[ndx] != OVOID) {
| 275 |
greg |
2.19 |
onm = objptr(oldhtab[ndx])->oname;
| 276 |
if (onm == NULL)
| 277 |
continue;
| 278 |
i = otndx(onm, tab);
| 279 |
greg |
1.1 |
tab->htab[i] = oldhtab[ndx];
| 280 |
| 281 |
greg |
2.7 |
free((void *)oldhtab);
| 282 |
greg |
1.1 |
goto tryagain; /* should happen only once! */
| 283 |
