root/radiance/ray/src/common/modobject.c
Mon Dec 9 18:17:13 2013 UTC (10 years, 5 months ago) by greg
Diff to previous 2.16 , to selected 2.15
Minor optimization to reference check in eqobjects()
Mon Dec 9 17:57:44 2013 UTC (10 years, 5 months ago) by greg
Changes since 2.15: +23 -2 lines
Diff to previous 2.15
Added check for references to different, identically-named modifiers
Revision 2.15 - (view) (download) (annotate) - [selected]
Sun Dec 8 19:25:36 2013 UTC (10 years, 5 months ago) by greg
Changes since 2.14: +28 -28 lines
Diff to previous 2.14
Made eqobjects() a little more general and exposed eqreal() to library
Sun Dec 8 18:59:53 2013 UTC (10 years, 5 months ago) by greg
Changes since 2.13: +57 -1 lines
Diff to previous 2.13 , to selected 2.15
Sat Mar 9 18:53:05 2013 UTC (11 years, 2 months ago) by greg
Changes since 2.12: +35 -27 lines
Diff to previous 2.12 , to selected 2.15
Slight efficiency improvement and ansification
Wed Jul 14 02:37:23 2004 UTC (19 years, 10 months ago) by greg
Diff to previous 2.11 , to selected 2.15
Bug fix for alias modifiers -- not exactly right for non-unique modifiers
Tue Sep 30 00:13:58 2003 UTC (20 years, 7 months ago) by greg
Diff to previous 2.10 , to selected 2.15
Diff to previous 2.9 , to selected 2.15
Mon Mar 10 17:13:29 2003 UTC (21 years, 2 months ago) by greg
Diff to previous 2.8 , to selected 2.15
Diff to previous 2.7 , to selected 2.15
Changes since 2.6: +78 -7 lines
Diff to previous 2.6 , to selected 2.15
Thu Nov 5 16:51:26 1998 UTC (25 years, 6 months ago) by gwlarson
Diff to previous 2.5 , to selected 2.15
fixed problem with new object block sizing
Tue Aug 11 09:54:34 1998 UTC (25 years, 9 months ago) by gwlarson
Diff to previous 2.4 , to selected 2.15
fixed bug in objndx()
Sun Dec 15 15:45:17 1996 UTC (27 years, 5 months ago) by greg
Diff to previous 2.3 , to selected 2.15
made lastmod() more efficient for singly-defined modifier
Mon Feb 12 17:14:59 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.2: +45 -11 lines
Diff to previous 2.2 , to selected 2.15
added objndx() and lastmod() functions for looking up modifiers
Sat Nov 21 21:35:38 1992 UTC (31 years, 6 months ago) by greg
Changes since 2.1: +1 -13 lines
Diff to previous 2.1 , to selected 2.15
added global free routines
Tue Nov 12 16:56:08 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.3 , to selected 2.15
Mon Oct 28 09:47:24 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.2 , to selected 2.15
Mon Jul 29 15:47:46 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.1 , to selected 2.15
added back in otypes.h include to modobject.c
Wed Jul 24 12:04:52 1991 UTC (32 years, 10 months ago) by greg
Diff to selected 2.15
