root/radiance/ray/src/common/modobject.c
Revision: 2.16
Committed: Mon Dec 9 17:57:44 2013 UTC (11 years, 6 months ago) by greg
Changes since 2.15: +23 -2 lines
Added check for references to different, identically-named modifiers
2 static const char RCSid[] = "$Id: modobject.c,v 2.15 2013/12/08 19:25:36 greg Exp $";
5 * Routines for tracking object modifiers
6 *
7 * External symbols declared in object.h
8 */
9
10 #include "copyright.h"
11
12 #include "standard.h"
13
14 #include "object.h"
15
16 #include "otypes.h"
17
18
19 static struct ohtab {
20 int hsiz; /* current table size */
21 OBJECT *htab; /* table, if allocated */
22 } modtab = {100, NULL}, objtab = {1000, NULL}; /* modifiers and objects */
23
24 static int otndx(char *, struct ohtab *);
25
26
27 OBJECT
28 objndx( /* get object number from pointer */
29 OBJREC *op
30 )
31 {
32 int i, j;
33
34 for (i = nobjects>>OBJBLKSHFT; i >= 0; i--) {
35 j = op - objblock[i];
36 if ((j >= 0) & (j < OBJBLKSIZ))
37 return((i<<OBJBLKSHFT) + j);
38 }
39 return(OVOID);
40 }
41
42
43 OBJECT
44 lastmod( /* find modifier definition before obj */
45 OBJECT obj,
46 char *mname
47 )
48 {
49 OBJREC *op;
50 int i;
51
52 i = modifier(mname); /* try hash table first */
53 if ((obj == OVOID) | (i < obj))
54 return(i);
55 for (i = obj; i-- > 0; ) { /* need to search */
56 op = objptr(i);
57 if (ismodifier(op->otype) && op->oname[0] == mname[0] &&
58 !strcmp(op->oname, mname))
59 return(i);
60 }
61 return(OVOID);
62 }
63
64
65 OBJECT
66 modifier( /* get a modifier number from its name */
67 char *mname
68 )
69 {
70 int ndx;
71
72 ndx = otndx(mname, &modtab);
73 return(modtab.htab[ndx]);
74 }
75
76
77 #ifdef GETOBJ
78 OBJECT
79 object( /* get an object number from its name */
80 char *oname
81 )
82 {
83 int ndx;
84
85 ndx = otndx(oname, &objtab);
86 return(objtab.htab[ndx]);
87 }
88 #endif
89
90
91 int
92 eqreal( /* are two real values close enough to equal? */
93 double d1,
94 double d2
95 )
96 {
97 if (d2 != 0.0)
98 d1 = d1/d2 - 1.0;
99 return((-FTINY <= d1) & (d1 <= FTINY));
100 }
101
102
103 int
104 eqobjects( /* check if two objects are equal */
105 OBJECT obj1,
106 OBJECT obj2
107 )
108 {
109 OBJREC *op1, *op2;
110 int i;
111
112 while (obj1 != obj2) {
113 if (obj1 == OVOID)
114 return(0);
115 if (obj2 == OVOID)
116 return(0);
117 op1 = objptr(obj1);
118 op2 = objptr(obj2);
119 if (op1->otype != op2->otype)
120 return(0);
121 if (op1->oargs.nsargs != op2->oargs.nsargs)
122 return(0);
123 if (op1->oargs.nfargs != op2->oargs.nfargs)
124 return(0);
125 #ifdef IARGS
126 if (op1->oargs.niargs != op2->oargs.niargs)
127 return(0);
128 for (i = op1->oargs.niargs; i-- > 0; )
129 if (op1->oargs.iarg[i] != op2->oargs.iarg[i])
130 return(0);
131 #endif
132 for (i = op1->oargs.nfargs; i-- > 0; )
133 if (!eqreal(op1->oargs.farg[i], op2->oargs.farg[i]))
134 return(0);
135 for (i = op1->oargs.nsargs; i-- > 0; )
136 if (strcmp(op1->oargs.sarg[i], op2->oargs.sarg[i]))
137 return(0);
138 i = 0;
139 switch (op1->otype) { /* special cases (KEEP CONSISTENT!) */
140 case MOD_ALIAS:
141 case MAT_ILLUM:
142 case MAT_MIRROR:
143 i = (op1->oargs.nsargs > 0);
144 break;
145 case MIX_FUNC:
146 case MIX_DATA:
147 case MIX_TEXT:
148 case MIX_PICT:
149 i = 2*(op1->oargs.nsargs >= 2);
150 break;
151 case MAT_CLIP:
152 i = op1->oargs.nsargs;
153 break;
154 }
155 while (i-- > 0) /* check modifier references */
156 if (!eqobjects( lastmod(obj1, op1->oargs.sarg[i]),
157 lastmod(obj2, op2->oargs.sarg[i]) ))
158 return(0);
159 obj1 = op1->omod;
160 obj2 = op2->omod;
161 }
162 return(1);
163 }
164
165
166 void
167 insertobject( /* insert new object into our list */
168 OBJECT obj
169 )
170 {
171 int i;
172
173 if (ismodifier(objptr(obj)->otype)) {
174 i = otndx(objptr(obj)->oname, &modtab);
175 if (eqobjects(obj, modtab.htab[i]))
176 return; /* don't index if same as earlier def. */
177 modtab.htab[i] = obj;
178 }
179 #ifdef GETOBJ
180 else {
181 i = otndx(objptr(obj)->oname, &objtab);
182 objtab.htab[i] = obj;
183 }
184 #endif
185 for (i = 0; addobjnotify[i] != NULL; i++)
186 (*addobjnotify[i])(obj);
187 }
188
189
190 void
191 clearobjndx(void) /* clear object hash tables */
192 {
193 if (modtab.htab != NULL) {
194 free((void *)modtab.htab);
195 modtab.htab = NULL;
196 modtab.hsiz = 100;
197 }
198 if (objtab.htab != NULL) {
199 free((void *)objtab.htab);
200 objtab.htab = NULL;
201 objtab.hsiz = 100;
202 }
203 }
204
205
206 static int
207 nexthsiz( /* return next hash table size */
208 int oldsiz
209 )
210 {
211 static int hsiztab[] = {
212 251, 509, 1021, 2039, 4093, 8191, 16381, 0
213 };
214 int *hsp;
215
216 for (hsp = hsiztab; *hsp; hsp++)
217 if (*hsp > oldsiz)
218 return(*hsp);
219 return(oldsiz*2 + 1); /* not always prime */
220 }
221
222
223 static int
224 otndx( /* get object table index for name */
225 char *name,
226 struct ohtab *tab
227 )
228 {
229 OBJECT *oldhtab;
230 int hval, i;
231 int ndx;
232
233 if (tab->htab == NULL) { /* new table */
234 tab->hsiz = nexthsiz(tab->hsiz);
235 tab->htab = (OBJECT *)malloc(tab->hsiz*sizeof(OBJECT));
236 if (tab->htab == NULL)
237 error(SYSTEM, "out of memory in otndx");
238 ndx = tab->hsiz;
239 while (ndx--) /* empty it */
240 tab->htab[ndx] = OVOID;
241 }
242 /* look up object */
243 hval = shash(name);
244 tryagain:
245 for (i = 0; i < tab->hsiz; i++) {
246 ndx = (hval + (unsigned long)i*i) % tab->hsiz;
247 if (tab->htab[ndx] == OVOID ||
248 !strcmp(objptr(tab->htab[ndx])->oname, name))
249 return(ndx);
250 }
251 /* table is full, reallocate */
252 oldhtab = tab->htab;
253 ndx = tab->hsiz;
254 tab->htab = NULL;
255 while (ndx--)
256 if (oldhtab[ndx] != OVOID) {
257 i = otndx(objptr(oldhtab[ndx])->oname, tab);
258 tab->htab[i] = oldhtab[ndx];
259 }
260 free((void *)oldhtab);
261 goto tryagain; /* should happen only once! */
262 }
