root/radiance/ray/src/common/modobject.c
Revision: 2.8
Committed: Tue Feb 25 02:47:21 2003 UTC (22 years, 4 months ago) by greg
5 * Routines for tracking object modifiers
6 *
7 * External symbols declared in object.h
8 */
9
10 #include "copyright.h"
11
12 #include "standard.h"
13
14 #include "object.h"
15
16 #include "otypes.h"
17
18
19 static struct ohtab {
20 int hsiz; /* current table size */
21 OBJECT *htab; /* table, if allocated */
22 } modtab = {100, NULL}, objtab = {1000, NULL}; /* modifiers and objects */
23
24 static int otndx();
25
26
27 int
28 objndx(op) /* get object number from pointer */
29 register OBJREC *op;
30 {
31 register int i, j;
32
33 for (i = nobjects>>OBJBLKSHFT; i >= 0; i--) {
34 j = op - objblock[i];
35 if (j >= 0 && j < OBJBLKSIZ)
36 return((i<<OBJBLKSHFT) + j);
37 }
38 return(OVOID);
39 }
40
41
42 int
43 lastmod(obj, mname) /* find modifier definition before obj */
44 OBJECT obj;
45 char *mname;
46 {
47 register OBJREC *op;
48 register int i;
49
50 i = modifier(mname); /* try hash table first */
51 if (i < obj)
52 return(i);
53 for (i = obj; i-- > 0; ) { /* need to search */
54 op = objptr(i);
55 if (ismodifier(op->otype) && !strcmp(op->oname, mname))
56 return(i);
57 }
58 return(OVOID);
59 }
60
61
62 int
63 modifier(mname) /* get a modifier number from its name */
64 char *mname;
65 {
66 register int ndx;
67
68 ndx = otndx(mname, &modtab);
69 return(modtab.htab[ndx]);
70 }
71
72
73 #ifdef GETOBJ
74 int
75 object(oname) /* get an object number from its name */
76 char *oname;
77 {
78 register int ndx;
79
80 ndx = otndx(oname, &objtab);
81 return(objtab.htab[ndx]);
82 }
83 #endif
84
85
86 void
87 insertobject(obj) /* insert new object into our list */
88 register OBJECT obj;
89 {
90 register int i;
91
92 if (ismodifier(objptr(obj)->otype)) {
93 i = otndx(objptr(obj)->oname, &modtab);
94 modtab.htab[i] = obj;
95 }
96 #ifdef GETOBJ
97 else {
98 i = otndx(objptr(obj)->oname, &objtab);
99 objtab.htab[i] = obj;
100 }
101 #endif
102 for (i = 0; addobjnotify[i] != NULL; i++)
103 (*addobjnotify[i])(obj);
104 }
105
106
107 void
108 clearobjndx() /* clear object hash tables */
109 {
110 if (modtab.htab != NULL) {
111 free((void *)modtab.htab);
112 modtab.htab = NULL;
113 modtab.hsiz = 100;
114 }
115 if (objtab.htab != NULL) {
116 free((void *)objtab.htab);
117 objtab.htab = NULL;
118 objtab.hsiz = 100;
119 }
120 }
121
122
123 static int
124 nexthsiz(oldsiz) /* return next hash table size */
125 int oldsiz;
126 {
127 static int hsiztab[] = {
128 251, 509, 1021, 2039, 4093, 8191, 16381, 0
129 };
130 register int *hsp;
131
132 for (hsp = hsiztab; *hsp; hsp++)
133 if (*hsp > oldsiz)
134 return(*hsp);
135 return(oldsiz*2 + 1); /* not always prime */
136 }
137
138
139 static int
140 otndx(name, tab) /* get object table index for name */
141 char *name;
142 register struct ohtab *tab;
143 {
144 OBJECT *oldhtab;
145 int hval, i;
146 register int ndx;
147
148 if (tab->htab == NULL) { /* new table */
149 tab->hsiz = nexthsiz(tab->hsiz);
150 tab->htab = (OBJECT *)malloc(tab->hsiz*sizeof(OBJECT));
151 if (tab->htab == NULL)
152 error(SYSTEM, "out of memory in otndx");
153 ndx = tab->hsiz;
154 while (ndx--) /* empty it */
155 tab->htab[ndx] = OVOID;
156 }
157 /* look up object */
158 hval = shash(name);
159 tryagain:
160 for (i = 0; i < tab->hsiz; i++) {
161 ndx = (hval + i*i) % tab->hsiz;
162 if (tab->htab[ndx] == OVOID ||
163 !strcmp(objptr(tab->htab[ndx])->oname, name))
164 return(ndx);
165 }
166 /* table is full, reallocate */
167 oldhtab = tab->htab;
168 ndx = tab->hsiz;
169 tab->htab = NULL;
170 while (ndx--)
171 if (oldhtab[ndx] != OVOID) {
172 i = otndx(objptr(oldhtab[ndx])->oname, tab);
173 tab->htab[i] = oldhtab[ndx];
174 }
175 free((void *)oldhtab);
176 goto tryagain; /* should happen only once! */
177 }
