--- ray/src/common/modobject.c 1991/10/28 09:47:24 1.3 +++ ray/src/common/modobject.c 2003/03/10 17:13:29 2.9 @@ -1,13 +1,14 @@ -/* Copyright (c) 1986 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: modobject.c,v 2.9 2003/03/10 17:13:29 greg Exp $"; #endif - /* * Routines for tracking object modifiers + * + * External symbols declared in object.h */ +#include "copyright.h" + #include "standard.h" #include "object.h" @@ -15,8 +16,6 @@ static char SCCSid[] = "$SunId$ LBL"; #include "otypes.h" -extern int (*addobjnotify[])(); /* people to notify of new objects */ - static struct ohtab { int hsiz; /* current table size */ OBJECT *htab; /* table, if allocated */ @@ -25,20 +24,42 @@ static struct ohtab { static int otndx(); -#ifdef GETOBJ -int -object(oname) /* get an object number from its name */ -char *oname; +OBJECT +objndx(op) /* get object number from pointer */ +register OBJREC *op; { - register int ndx; + register int i, j; - ndx = otndx(oname, &objtab); - return(objtab.htab[ndx]); + for (i = nobjects>>OBJBLKSHFT; i >= 0; i--) { + j = op - objblock[i]; + if (j >= 0 && j < OBJBLKSIZ) + return((i< 0; ) { /* need to search */ + op = objptr(i); + if (ismodifier(op->otype) && !strcmp(op->oname, mname)) + return(i); + } + return(OVOID); +} + + +OBJECT modifier(mname) /* get a modifier number from its name */ char *mname; { @@ -49,24 +70,56 @@ char *mname; } +#ifdef GETOBJ +OBJECT +object(oname) /* get an object number from its name */ +char *oname; +{ + register int ndx; + + ndx = otndx(oname, &objtab); + return(objtab.htab[ndx]); +} +#endif + + +void insertobject(obj) /* insert new object into our list */ register OBJECT obj; { register int i; -#ifdef GETOBJ - i = otndx(objptr(obj)->oname, &objtab); - objtab.htab[i] = obj; -#endif if (ismodifier(objptr(obj)->otype)) { i = otndx(objptr(obj)->oname, &modtab); modtab.htab[i] = obj; } +#ifdef GETOBJ + else { + i = otndx(objptr(obj)->oname, &objtab); + objtab.htab[i] = obj; + } +#endif for (i = 0; addobjnotify[i] != NULL; i++) (*addobjnotify[i])(obj); } +void +clearobjndx() /* clear object hash tables */ +{ + if (modtab.htab != NULL) { + free((void *)modtab.htab); + modtab.htab = NULL; + modtab.hsiz = 100; + } + if (objtab.htab != NULL) { + free((void *)objtab.htab); + objtab.htab = NULL; + objtab.hsiz = 100; + } +} + + static int nexthsiz(oldsiz) /* return next hash table size */ int oldsiz; @@ -84,18 +137,6 @@ int oldsiz; static int -shash(s) /* hash a string */ -register char *s; -{ - register int h = 0; - - while (*s) - h = (h<<1 & 0x7fff) ^ *s++; - return(h); -} - - -static int otndx(name, tab) /* get object table index for name */ char *name; register struct ohtab *tab; @@ -131,6 +172,6 @@ tryagain: i = otndx(objptr(oldhtab[ndx])->oname, tab); tab->htab[i] = oldhtab[ndx]; } - free((char *)oldhtab); + free((void *)oldhtab); goto tryagain; /* should happen only once! */ }
