fix: prophylactic against 64-bit architectures with 32-bit int's
fix: added caution around NULL modifier names
fix: freeing *some* objects now preserves valid modifier lookups
Minor optimization to reference check in eqobjects()
Added check for references to different, identically-named modifiers
Made eqobjects() a little more general and exposed eqreal() to library
Slight efficiency improvement and ansification
Bug fix for alias modifiers -- not exactly right for non-unique modifiers
Added prototypes and includes from patch by Randolph Fritz. Added more required includes and reduced other compile warnings.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
fixed problem with new object block sizing
fixed bug in objndx()
made lastmod() more efficient for singly-defined modifier
added objndx() and lastmod() functions for looking up modifiers
added global free routines
added back in otypes.h include to modobject.c
