1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: modobject.c,v 2.25 2025/06/21 17:42:17 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Routines for tracking object modifiers |
6 |
7 |
* External symbols declared in object.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include "standard.h" |
13 |
#include "object.h" |
14 |
#include "otypes.h" |
15 |
16 |
17 |
static struct ohtab { |
18 |
int hsiz; /* current table size */ |
19 |
OBJECT *htab; /* table, if allocated */ |
20 |
} modtab = {100, NULL}, objtab = {1000, NULL}; /* modifiers and objects */ |
21 |
22 |
static int otndx(char *, struct ohtab *); |
23 |
24 |
25 |
OBJECT |
26 |
objndx( /* get object number from pointer */ |
27 |
OBJREC *op |
28 |
29 |
30 |
#ifndef ONCACHESIZ |
31 |
#define ONCACHESIZ 907 /* keep a cache of previous searches */ |
32 |
#endif |
33 |
static OBJECT oncache[ONCACHESIZ]; |
34 |
const int ent = (size_t)op % ONCACHESIZ; /* hash on pointer */ |
35 |
int i, lastblock; |
36 |
37 |
#if OVOID != 0 /* clear cache on first call */ |
38 |
for (i = ONCACHESIZ*(!oncache[0] & !oncache[1]); i--; ) |
39 |
oncache[i] = OVOID; |
40 |
#endif |
41 |
/* is this pointer in cache? */ |
42 |
if ((oncache[ent] != OVOID) & (oncache[ent] < nobjects) && |
43 |
objptr(oncache[ent]) == op) |
44 |
return(oncache[ent]); /* matches previous search */ |
45 |
/* else search for our block from first */ |
46 |
lastblock = (nobjects-1)>>OBJBLKSHFT; |
47 |
for (i = 0; i <= lastblock; i++) |
48 |
if ((objblock[i] <= op) & (op < objblock[i]+OBJBLKSIZ)) { |
49 |
/* found it -- cache corresponding index */ |
50 |
oncache[ent] = ((OBJECT)i << OBJBLKSHFT) + |
51 |
(op - objblock[i]); |
52 |
return(oncache[ent]); |
53 |
54 |
return(OVOID); /* not allocated -- may still be valid */ |
55 |
56 |
57 |
58 |
OBJECT |
59 |
lastmod( /* find modifier definition before obj */ |
60 |
OBJECT obj, |
61 |
char *mname |
62 |
63 |
64 |
OBJREC *op; |
65 |
OBJECT i; |
66 |
67 |
i = modifier(mname); /* try hash table first */ |
68 |
if ((obj == OVOID) | (i < obj)) |
69 |
return(i); |
70 |
for (i = obj; i-- > 0; ) { /* need to search */ |
71 |
op = objptr(i); |
72 |
if ((ismodifier(op->otype) != 0) & (op->oname[0] == mname[0]) |
73 |
&& !strcmp(op->oname, mname)) |
74 |
return(i); |
75 |
76 |
return(OVOID); |
77 |
78 |
79 |
80 |
OBJECT |
81 |
modifier( /* get a modifier number from its name */ |
82 |
char *mname |
83 |
84 |
85 |
int ndx; |
86 |
87 |
ndx = otndx(mname, &modtab); |
88 |
return(modtab.htab[ndx]); |
89 |
90 |
91 |
92 |
#ifdef GETOBJ |
93 |
OBJECT |
94 |
object( /* get an object number from its name */ |
95 |
char *oname |
96 |
97 |
98 |
int ndx; |
99 |
100 |
ndx = otndx(oname, &objtab); |
101 |
return(objtab.htab[ndx]); |
102 |
103 |
#endif |
104 |
105 |
106 |
int |
107 |
eqreal( /* are two real values close enough to equal? */ |
108 |
double d1, |
109 |
double d2 |
110 |
111 |
112 |
if (d2 != 0.0) |
113 |
d1 = d1/d2 - 1.0; |
114 |
return((-FTINY <= d1) & (d1 <= FTINY)); |
115 |
116 |
117 |
118 |
int |
119 |
eqobjects( /* check if two objects are equal */ |
120 |
OBJECT obj1, |
121 |
OBJECT obj2 |
122 |
123 |
124 |
OBJREC *op1, *op2; |
125 |
int i, n; |
126 |
127 |
while (obj1 != obj2) { |
128 |
if (obj1 == OVOID) |
129 |
return(0); |
130 |
if (obj2 == OVOID) |
131 |
return(0); |
132 |
op1 = objptr(obj1); |
133 |
op2 = objptr(obj2); |
134 |
if (op1->otype != op2->otype) |
135 |
return(0); |
136 |
if (op1->oargs.nsargs != op2->oargs.nsargs) |
137 |
return(0); |
138 |
if (op1->oargs.nfargs != op2->oargs.nfargs) |
139 |
return(0); |
140 |
#ifdef IARGS |
141 |
if (op1->oargs.niargs != op2->oargs.niargs) |
142 |
return(0); |
143 |
for (i = op1->oargs.niargs; i-- > 0; ) |
144 |
if (op1->oargs.iarg[i] != op2->oargs.iarg[i]) |
145 |
return(0); |
146 |
#endif |
147 |
for (i = op1->oargs.nfargs; i-- > 0; ) |
148 |
if (!eqreal(op1->oargs.farg[i], op2->oargs.farg[i])) |
149 |
return(0); |
150 |
n = 0; |
151 |
switch (op1->otype) { /* special cases (KEEP CONSISTENT!) */ |
152 |
case MOD_ALIAS: |
153 |
case MAT_ILLUM: |
154 |
case MAT_MIRROR: |
155 |
n = (op1->oargs.nsargs > 0); |
156 |
break; |
157 |
case MIX_FUNC: |
158 |
case MIX_DATA: |
159 |
case MIX_TEXT: |
160 |
case MIX_PICT: |
161 |
n = 2*(op1->oargs.nsargs >= 2); |
162 |
break; |
163 |
case MAT_CLIP: |
164 |
n = op1->oargs.nsargs; |
165 |
break; |
166 |
167 |
/* check other string arguments */ |
168 |
for (i = op1->oargs.nsargs; i-- > n; ) |
169 |
if (strcmp(op1->oargs.sarg[i], op2->oargs.sarg[i])) |
170 |
return(0); |
171 |
while (n-- > 0) /* check modifier references */ |
172 |
if (!eqobjects( lastmod(obj1, op1->oargs.sarg[n]), |
173 |
lastmod(obj2, op2->oargs.sarg[n]) )) |
174 |
return(0); |
175 |
obj1 = op1->omod; |
176 |
obj2 = op2->omod; |
177 |
178 |
return(1); |
179 |
180 |
181 |
182 |
void |
183 |
insertobject( /* insert new object into our list */ |
184 |
OBJECT obj |
185 |
186 |
187 |
int i; |
188 |
189 |
if (ismodifier(objptr(obj)->otype)) { |
190 |
i = otndx(objptr(obj)->oname, &modtab); |
191 |
if (eqobjects(obj, modtab.htab[i])) |
192 |
return; /* don't index if same as earlier def. */ |
193 |
modtab.htab[i] = obj; |
194 |
195 |
#ifdef GETOBJ |
196 |
else { |
197 |
i = otndx(objptr(obj)->oname, &objtab); |
198 |
objtab.htab[i] = obj; |
199 |
200 |
#endif |
201 |
for (i = 0; addobjnotify[i] != NULL; i++) |
202 |
(*addobjnotify[i])(obj); |
203 |
204 |
205 |
206 |
void |
207 |
truncobjndx(void) /* remove bogus table entries past end */ |
208 |
209 |
int ndx; |
210 |
211 |
if (nobjects <= 0) { |
212 |
if (modtab.htab != NULL) { |
213 |
free(modtab.htab); |
214 |
modtab.htab = NULL; |
215 |
modtab.hsiz = 100; |
216 |
217 |
if (objtab.htab != NULL) { |
218 |
free(objtab.htab); |
219 |
objtab.htab = NULL; |
220 |
objtab.hsiz = 100; |
221 |
222 |
return; |
223 |
224 |
for (ndx = modtab.hsiz*(modtab.htab != NULL); ndx--; ) |
225 |
if (modtab.htab[ndx] >= nobjects) |
226 |
modtab.htab[ndx] = OVOID; |
227 |
228 |
for (ndx = objtab.hsiz*(objtab.htab != NULL); ndx--; ) |
229 |
if (objtab.htab[ndx] >= nobjects) |
230 |
objtab.htab[ndx] = OVOID; |
231 |
232 |
233 |
234 |
static int |
235 |
nexthsiz( /* return next hash table size */ |
236 |
int oldsiz |
237 |
238 |
239 |
static int hsiztab[] = { |
240 |
251, 509, 1021, 2039, 4093, 8191, 16381, |
241 |
32749, 65521, 131071, 262139, 0 |
242 |
243 |
int *hsp; |
244 |
245 |
for (hsp = hsiztab; *hsp; hsp++) |
246 |
if (*hsp > oldsiz) |
247 |
return(*hsp); |
248 |
return(oldsiz*2 + 1); /* not always prime */ |
249 |
250 |
251 |
252 |
static int |
253 |
otndx( /* get object table index for name */ |
254 |
char *name, |
255 |
struct ohtab *tab |
256 |
257 |
258 |
char *onm; |
259 |
OBJECT *oldhtab; |
260 |
int hval, i; |
261 |
int ndx; |
262 |
263 |
if (tab->htab == NULL) { /* new table */ |
264 |
tab->hsiz = nexthsiz(tab->hsiz); |
265 |
tab->htab = (OBJECT *)malloc(tab->hsiz*sizeof(OBJECT)); |
266 |
if (tab->htab == NULL) |
267 |
error(SYSTEM, "out of memory in otndx"); |
268 |
ndx = tab->hsiz; |
269 |
while (ndx--) /* empty it */ |
270 |
tab->htab[ndx] = OVOID; |
271 |
272 |
/* look up object */ |
273 |
hval = shash(name); |
274 |
tryagain: |
275 |
for (i = 0; i < tab->hsiz; i++) { |
276 |
ndx = (hval + (unsigned long)i*i) % tab->hsiz; |
277 |
if (tab->htab[ndx] == OVOID) |
278 |
return(ndx); |
279 |
onm = objptr(tab->htab[ndx])->oname; |
280 |
if (onm != NULL && !strcmp(onm, name)) |
281 |
return(ndx); |
282 |
283 |
/* table is full, reallocate */ |
284 |
oldhtab = tab->htab; |
285 |
ndx = tab->hsiz; |
286 |
tab->htab = NULL; |
287 |
while (ndx--) |
288 |
if (oldhtab[ndx] != OVOID) { |
289 |
onm = objptr(oldhtab[ndx])->oname; |
290 |
if (onm == NULL) |
291 |
continue; |
292 |
i = otndx(onm, tab); |
293 |
tab->htab[i] = oldhtab[ndx]; |
294 |
295 |
free(oldhtab); |
296 |
goto tryagain; /* should happen only once! */ |
297 |
