root/radiance/ray/src/common/modobject.c
Revision: 2.26
Committed: Sun Jun 22 17:21:37 2025 UTC (7 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.25: +11 -8 lines
perf: Minor code tweaks to speed initial search, check case OVOID==0
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.26 static const char RCSid[] = "$Id: modobject.c,v 2.25 2025/06/21 17:42:17 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Routines for tracking object modifiers
6 greg 2.7 *
7     * External symbols declared in object.h
8     */
9
10 greg 2.8 #include "copyright.h"
11 greg 1.1
12     #include "standard.h"
13     #include "object.h"
14 greg 1.2 #include "otypes.h"
15
16 greg 1.1
17     static struct ohtab {
18 greg 2.22 int hsiz; /* current table size */
19     OBJECT *htab; /* table, if allocated */
20 greg 1.1 } modtab = {100, NULL}, objtab = {1000, NULL}; /* modifiers and objects */
21
22 schorsch 2.10 static int otndx(char *, struct ohtab *);
23 greg 1.3
24 greg 1.1
25 greg 2.9 OBJECT
26 greg 2.13 objndx( /* get object number from pointer */
27     OBJREC *op
28     )
29 greg 1.1 {
30 greg 2.25 #ifndef ONCACHESIZ
31     #define ONCACHESIZ 907 /* keep a cache of previous searches */
32     #endif
33     static OBJECT oncache[ONCACHESIZ];
34 greg 2.26 const int ent = (size_t)op % ONCACHESIZ; /* hash on pointer */
35     int i, lastblock;
36
37     #if OVOID != 0 /* clear cache on first call */
38 greg 2.25 for (i = ONCACHESIZ*(!oncache[0] & !oncache[1]); i--; )
39     oncache[i] = OVOID;
40 greg 2.26 #endif
41 greg 2.25 /* is this pointer in cache? */
42     if ((oncache[ent] != OVOID) & (oncache[ent] < nobjects) &&
43     objptr(oncache[ent]) == op)
44     return(oncache[ent]); /* matches previous search */
45 greg 2.26 /* else search for our block from first */
46     lastblock = (nobjects-1)>>OBJBLKSHFT;
47     for (i = 0; i <= lastblock; i++)
48 greg 2.25 if ((objblock[i] <= op) & (op < objblock[i]+OBJBLKSIZ)) {
49 greg 2.26 /* found it -- cache corresponding index */
50 greg 2.25 oncache[ent] = ((OBJECT)i << OBJBLKSHFT) +
51     (op - objblock[i]);
52     return(oncache[ent]);
53     }
54 greg 2.26 return(OVOID); /* not allocated -- may still be valid */
55 greg 1.1 }
56
57
58 greg 2.9 OBJECT
59 greg 2.13 lastmod( /* find modifier definition before obj */
60     OBJECT obj,
61     char *mname
62     )
63 greg 2.3 {
64 greg 2.13 OBJREC *op;
65 greg 2.22 OBJECT i;
66 greg 2.3
67 greg 2.4 i = modifier(mname); /* try hash table first */
68 greg 2.12 if ((obj == OVOID) | (i < obj))
69 greg 2.4 return(i);
70     for (i = obj; i-- > 0; ) { /* need to search */
71 greg 2.3 op = objptr(i);
72 greg 2.22 if ((ismodifier(op->otype) != 0) & (op->oname[0] == mname[0])
73     && !strcmp(op->oname, mname))
74 greg 2.3 return(i);
75     }
76     return(OVOID);
77     }
78
79
80 greg 2.9 OBJECT
81 greg 2.13 modifier( /* get a modifier number from its name */
82     char *mname
83     )
84 greg 1.1 {
85 greg 2.13 int ndx;
86 greg 1.1
87     ndx = otndx(mname, &modtab);
88     return(modtab.htab[ndx]);
89     }
90
91
92 greg 2.3 #ifdef GETOBJ
93 greg 2.9 OBJECT
94 greg 2.13 object( /* get an object number from its name */
95     char *oname
96     )
97 greg 2.3 {
98 greg 2.13 int ndx;
99 greg 2.3
100     ndx = otndx(oname, &objtab);
101     return(objtab.htab[ndx]);
102     }
103     #endif
104
105
106 greg 2.15 int
107 greg 2.14 eqreal( /* are two real values close enough to equal? */
108     double d1,
109     double d2
110     )
111     {
112     if (d2 != 0.0)
113     d1 = d1/d2 - 1.0;
114     return((-FTINY <= d1) & (d1 <= FTINY));
115     }
116
117
118     int
119     eqobjects( /* check if two objects are equal */
120     OBJECT obj1,
121     OBJECT obj2
122     )
123     {
124     OBJREC *op1, *op2;
125 greg 2.17 int i, n;
126 greg 2.14
127 greg 2.15 while (obj1 != obj2) {
128     if (obj1 == OVOID)
129     return(0);
130     if (obj2 == OVOID)
131     return(0);
132     op1 = objptr(obj1);
133     op2 = objptr(obj2);
134     if (op1->otype != op2->otype)
135     return(0);
136     if (op1->oargs.nsargs != op2->oargs.nsargs)
137     return(0);
138     if (op1->oargs.nfargs != op2->oargs.nfargs)
139     return(0);
140 greg 2.14 #ifdef IARGS
141 greg 2.15 if (op1->oargs.niargs != op2->oargs.niargs)
142 greg 2.14 return(0);
143 greg 2.15 for (i = op1->oargs.niargs; i-- > 0; )
144     if (op1->oargs.iarg[i] != op2->oargs.iarg[i])
145     return(0);
146 greg 2.14 #endif
147 greg 2.15 for (i = op1->oargs.nfargs; i-- > 0; )
148     if (!eqreal(op1->oargs.farg[i], op2->oargs.farg[i]))
149     return(0);
150 greg 2.17 n = 0;
151 greg 2.16 switch (op1->otype) { /* special cases (KEEP CONSISTENT!) */
152     case MOD_ALIAS:
153     case MAT_ILLUM:
154     case MAT_MIRROR:
155 greg 2.17 n = (op1->oargs.nsargs > 0);
156 greg 2.16 break;
157     case MIX_FUNC:
158     case MIX_DATA:
159     case MIX_TEXT:
160     case MIX_PICT:
161 greg 2.17 n = 2*(op1->oargs.nsargs >= 2);
162 greg 2.16 break;
163     case MAT_CLIP:
164 greg 2.17 n = op1->oargs.nsargs;
165 greg 2.16 break;
166     }
167 greg 2.17 /* check other string arguments */
168     for (i = op1->oargs.nsargs; i-- > n; )
169     if (strcmp(op1->oargs.sarg[i], op2->oargs.sarg[i]))
170     return(0);
171     while (n-- > 0) /* check modifier references */
172     if (!eqobjects( lastmod(obj1, op1->oargs.sarg[n]),
173     lastmod(obj2, op2->oargs.sarg[n]) ))
174 greg 2.16 return(0);
175 greg 2.15 obj1 = op1->omod;
176     obj2 = op2->omod;
177     }
178 greg 2.14 return(1);
179     }
180
181
182 greg 2.7 void
183 greg 2.13 insertobject( /* insert new object into our list */
184     OBJECT obj
185     )
186 greg 1.1 {
187 greg 2.13 int i;
188 greg 1.1
189     if (ismodifier(objptr(obj)->otype)) {
190     i = otndx(objptr(obj)->oname, &modtab);
191 greg 2.14 if (eqobjects(obj, modtab.htab[i]))
192 greg 2.16 return; /* don't index if same as earlier def. */
193 greg 1.1 modtab.htab[i] = obj;
194     }
195 greg 2.3 #ifdef GETOBJ
196     else {
197     i = otndx(objptr(obj)->oname, &objtab);
198     objtab.htab[i] = obj;
199     }
200     #endif
201 greg 1.1 for (i = 0; addobjnotify[i] != NULL; i++)
202     (*addobjnotify[i])(obj);
203     }
204
205
206 greg 2.7 void
207 greg 2.18 truncobjndx(void) /* remove bogus table entries past end */
208 greg 2.7 {
209 greg 2.18 int ndx;
210
211     if (nobjects <= 0) {
212     if (modtab.htab != NULL) {
213 greg 2.22 free(modtab.htab);
214 greg 2.18 modtab.htab = NULL;
215     modtab.hsiz = 100;
216     }
217     if (objtab.htab != NULL) {
218 greg 2.22 free(objtab.htab);
219 greg 2.18 objtab.htab = NULL;
220     objtab.hsiz = 100;
221     }
222     return;
223 greg 2.7 }
224 greg 2.18 for (ndx = modtab.hsiz*(modtab.htab != NULL); ndx--; )
225     if (modtab.htab[ndx] >= nobjects)
226     modtab.htab[ndx] = OVOID;
227
228     for (ndx = objtab.hsiz*(objtab.htab != NULL); ndx--; )
229     if (objtab.htab[ndx] >= nobjects)
230     objtab.htab[ndx] = OVOID;
231 greg 2.7 }
232
233
234 greg 1.1 static int
235 greg 2.13 nexthsiz( /* return next hash table size */
236     int oldsiz
237     )
238 greg 1.1 {
239     static int hsiztab[] = {
240 greg 2.19 251, 509, 1021, 2039, 4093, 8191, 16381,
241     32749, 65521, 131071, 262139, 0
242 greg 1.1 };
243 greg 2.13 int *hsp;
244 greg 1.1
245     for (hsp = hsiztab; *hsp; hsp++)
246     if (*hsp > oldsiz)
247     return(*hsp);
248     return(oldsiz*2 + 1); /* not always prime */
249     }
250
251
252     static int
253 greg 2.13 otndx( /* get object table index for name */
254     char *name,
255     struct ohtab *tab
256     )
257 greg 1.1 {
258 greg 2.19 char *onm;
259 greg 1.1 OBJECT *oldhtab;
260     int hval, i;
261 greg 2.13 int ndx;
262 greg 1.1
263     if (tab->htab == NULL) { /* new table */
264     tab->hsiz = nexthsiz(tab->hsiz);
265     tab->htab = (OBJECT *)malloc(tab->hsiz*sizeof(OBJECT));
266     if (tab->htab == NULL)
267     error(SYSTEM, "out of memory in otndx");
268     ndx = tab->hsiz;
269     while (ndx--) /* empty it */
270     tab->htab[ndx] = OVOID;
271     }
272     /* look up object */
273     hval = shash(name);
274     tryagain:
275     for (i = 0; i < tab->hsiz; i++) {
276 greg 2.11 ndx = (hval + (unsigned long)i*i) % tab->hsiz;
277 greg 2.19 if (tab->htab[ndx] == OVOID)
278     return(ndx);
279     onm = objptr(tab->htab[ndx])->oname;
280     if (onm != NULL && !strcmp(onm, name))
281 greg 1.1 return(ndx);
282     }
283     /* table is full, reallocate */
284     oldhtab = tab->htab;
285     ndx = tab->hsiz;
286     tab->htab = NULL;
287     while (ndx--)
288     if (oldhtab[ndx] != OVOID) {
289 greg 2.19 onm = objptr(oldhtab[ndx])->oname;
290     if (onm == NULL)
291     continue;
292     i = otndx(onm, tab);
293 greg 1.1 tab->htab[i] = oldhtab[ndx];
294     }
295 greg 2.22 free(oldhtab);
296 greg 1.1 goto tryagain; /* should happen only once! */
297     }
