root/radiance/ray/src/common/mgf_context.c
Revision: 3.1
Committed: Fri Feb 18 00:40:25 2011 UTC (13 years, 3 months ago) by greg
2 static const char RCSid[] = "$Id: context.c,v 1.30 2011/02/03 19:36:10 greg Exp $";
5 * Context handlers
6 */
7
8 #include <stdio.h>
9 #include <stdlib.h>
10 #include <string.h>
11 #include "mgf_parser.h"
12 #include "lookup.h"
13
14 /* default context values */
15 static C_MATERIAL c_dfmaterial = C_DEFMATERIAL;
16 static C_VERTEX c_dfvertex = C_DEFVERTEX;
17
18 /* the unnamed contexts */
19 static C_COLOR c_uncolor = C_DEFCOLOR;
20 static C_MATERIAL c_unmaterial = C_DEFMATERIAL;
21 static C_VERTEX c_unvertex = C_DEFVERTEX;
22
23 /* the current contexts */
24 C_COLOR *c_ccolor = &c_uncolor;
25 char *c_ccname = NULL;
26 C_MATERIAL *c_cmaterial = &c_unmaterial;
27 char *c_cmname = NULL;
28 C_VERTEX *c_cvertex = &c_unvertex;
29 char *c_cvname = NULL;
30
31 static LUTAB clr_tab = LU_SINIT(free,free); /* color lookup table */
32 static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */
33 static LUTAB vtx_tab = LU_SINIT(free,free); /* vertex lookup table */
34
35 static int setspectrum(C_COLOR *, double wlmin, double wlmax,
36 int ac, char **av);
37
38
39 int
40 c_hcolor(int ac, char **av) /* handle color entity */
41 {
42 double w, wsum;
43 register int i;
44 register LUENT *lp;
45
46 switch (mg_entity(av[0])) {
47 case MG_E_COLOR: /* get/set color context */
48 if (ac > 4)
49 return(MG_EARGC);
50 if (ac == 1) { /* set unnamed color context */
51 c_uncolor = c_dfcolor;
52 c_ccolor = &c_uncolor;
53 c_ccname = NULL;
54 return(MG_OK);
55 }
56 if (!isname(av[1]))
57 return(MG_EILL);
58 lp = lu_find(&clr_tab, av[1]); /* lookup context */
59 if (lp == NULL)
60 return(MG_EMEM);
61 c_ccname = lp->key;
62 c_ccolor = (C_COLOR *)lp->data;
63 if (ac == 2) { /* reestablish previous context */
64 if (c_ccolor == NULL)
65 return(MG_EUNDEF);
66 return(MG_OK);
67 }
68 if (av[2][0] != '=' || av[2][1])
69 return(MG_ETYPE);
70 if (c_ccolor == NULL) { /* create new color context */
71 lp->key = (char *)malloc(strlen(av[1])+1);
72 if (lp->key == NULL)
73 return(MG_EMEM);
74 strcpy(lp->key, av[1]);
75 lp->data = (char *)malloc(sizeof(C_COLOR));
76 if (lp->data == NULL)
77 return(MG_EMEM);
78 c_ccname = lp->key;
79 c_ccolor = (C_COLOR *)lp->data;
80 c_ccolor->clock = 0;
81 c_ccolor->client_data = NULL;
82 }
83 i = c_ccolor->clock;
84 if (ac == 3) { /* use default template */
85 *c_ccolor = c_dfcolor;
86 c_ccolor->clock = i + 1;
87 return(MG_OK);
88 }
89 lp = lu_find(&clr_tab, av[3]); /* lookup template */
90 if (lp == NULL)
91 return(MG_EMEM);
92 if (lp->data == NULL)
93 return(MG_EUNDEF);
94 *c_ccolor = *(C_COLOR *)lp->data;
95 c_ccolor->clock = i + 1;
96 return(MG_OK);
97 case MG_E_CXY: /* assign CIE XY value */
98 if (ac != 3)
99 return(MG_EARGC);
100 if (!isflt(av[1]) | !isflt(av[2]))
101 return(MG_ETYPE);
102 c_ccolor->cx = atof(av[1]);
103 c_ccolor->cy = atof(av[2]);
104 c_ccolor->flags = C_CDXY|C_CSXY;
105 if ((c_ccolor->cx < 0.) | (c_ccolor->cy < 0.) |
106 (c_ccolor->cx + c_ccolor->cy > 1.))
107 return(MG_EILL);
108 c_ccolor->clock++;
109 return(MG_OK);
110 case MG_E_CSPEC: /* assign spectral values */
111 if (ac < 5)
112 return(MG_EARGC);
113 if (!isflt(av[1]) | !isflt(av[2]))
114 return(MG_ETYPE);
115 return(setspectrum(c_ccolor, atof(av[1]), atof(av[2]),
116 ac-3, av+3));
117 case MG_E_CCT: /* assign black body spectrum */
118 if (ac != 2)
119 return(MG_EARGC);
120 if (!isflt(av[1]))
121 return(MG_ETYPE);
122 if (!c_bbtemp(c_ccolor, atof(av[1])))
123 return(MG_EILL);
124 c_ccolor->clock++;
125 return(MG_OK);
126 case MG_E_CMIX: /* mix colors */
127 if (ac < 5 || (ac-1)%2)
128 return(MG_EARGC);
129 if (!isflt(av[1]))
130 return(MG_ETYPE);
131 wsum = atof(av[1]);
132 if ((lp = lu_find(&clr_tab, av[2])) == NULL)
133 return(MG_EMEM);
134 if (lp->data == NULL)
135 return(MG_EUNDEF);
136 *c_ccolor = *(C_COLOR *)lp->data;
137 for (i = 3; i < ac; i += 2) {
138 if (!isflt(av[i]))
139 return(MG_ETYPE);
140 w = atof(av[i]);
141 if ((lp = lu_find(&clr_tab, av[i+1])) == NULL)
142 return(MG_EMEM);
143 if (lp->data == NULL)
144 return(MG_EUNDEF);
145 c_cmix(c_ccolor, wsum, c_ccolor,
146 w, (C_COLOR *)lp->data);
147 wsum += w;
148 }
149 if (wsum <= 0.)
150 return(MG_EILL);
151 c_ccolor->clock++;
152 return(MG_OK);
153 }
154 return(MG_EUNK);
155 }
156
157
158 int
159 c_hmaterial(int ac, char **av) /* handle material entity */
160 {
161 int i;
162 register LUENT *lp;
163
164 switch (mg_entity(av[0])) {
165 case MG_E_MATERIAL: /* get/set material context */
166 if (ac > 4)
167 return(MG_EARGC);
168 if (ac == 1) { /* set unnamed material context */
169 c_unmaterial = c_dfmaterial;
170 c_cmaterial = &c_unmaterial;
171 c_cmname = NULL;
172 return(MG_OK);
173 }
174 if (!isname(av[1]))
175 return(MG_EILL);
176 lp = lu_find(&mat_tab, av[1]); /* lookup context */
177 if (lp == NULL)
178 return(MG_EMEM);
179 c_cmname = lp->key;
180 c_cmaterial = (C_MATERIAL *)lp->data;
181 if (ac == 2) { /* reestablish previous context */
182 if (c_cmaterial == NULL)
183 return(MG_EUNDEF);
184 return(MG_OK);
185 }
186 if (av[2][0] != '=' || av[2][1])
187 return(MG_ETYPE);
188 if (c_cmaterial == NULL) { /* create new material */
189 lp->key = (char *)malloc(strlen(av[1])+1);
190 if (lp->key == NULL)
191 return(MG_EMEM);
192 strcpy(lp->key, av[1]);
193 lp->data = (char *)malloc(sizeof(C_MATERIAL));
194 if (lp->data == NULL)
195 return(MG_EMEM);
196 c_cmname = lp->key;
197 c_cmaterial = (C_MATERIAL *)lp->data;
198 c_cmaterial->clock = 0;
199 c_cmaterial->client_data = NULL;
200 }
201 i = c_cmaterial->clock;
202 if (ac == 3) { /* use default template */
203 *c_cmaterial = c_dfmaterial;
204 c_cmaterial->clock = i + 1;
205 return(MG_OK);
206 }
207 lp = lu_find(&mat_tab, av[3]); /* lookup template */
208 if (lp == NULL)
209 return(MG_EMEM);
210 if (lp->data == NULL)
211 return(MG_EUNDEF);
212 *c_cmaterial = *(C_MATERIAL *)lp->data;
213 c_cmaterial->clock = i + 1;
214 return(MG_OK);
215 case MG_E_IR: /* set index of refraction */
216 if (ac != 3)
217 return(MG_EARGC);
218 if (!isflt(av[1]) | !isflt(av[2]))
219 return(MG_ETYPE);
220 c_cmaterial->nr = atof(av[1]);
221 c_cmaterial->ni = atof(av[2]);
222 if (c_cmaterial->nr <= FTINY)
223 return(MG_EILL);
224 c_cmaterial->clock++;
225 return(MG_OK);
226 case MG_E_RD: /* set diffuse reflectance */
227 if (ac != 2)
228 return(MG_EARGC);
229 if (!isflt(av[1]))
230 return(MG_ETYPE);
231 c_cmaterial->rd = atof(av[1]);
232 if ((c_cmaterial->rd < 0.) | (c_cmaterial->rd > 1.))
233 return(MG_EILL);
234 c_cmaterial->rd_c = *c_ccolor;
235 c_cmaterial->clock++;
236 return(MG_OK);
237 case MG_E_ED: /* set diffuse emittance */
238 if (ac != 2)
239 return(MG_EARGC);
240 if (!isflt(av[1]))
241 return(MG_ETYPE);
242 c_cmaterial->ed = atof(av[1]);
243 if (c_cmaterial->ed < 0.)
244 return(MG_EILL);
245 c_cmaterial->ed_c = *c_ccolor;
246 c_cmaterial->clock++;
247 return(MG_OK);
248 case MG_E_TD: /* set diffuse transmittance */
249 if (ac != 2)
250 return(MG_EARGC);
251 if (!isflt(av[1]))
252 return(MG_ETYPE);
253 c_cmaterial->td = atof(av[1]);
254 if ((c_cmaterial->td < 0.) | (c_cmaterial->td > 1.))
255 return(MG_EILL);
256 c_cmaterial->td_c = *c_ccolor;
257 c_cmaterial->clock++;
258 return(MG_OK);
259 case MG_E_RS: /* set specular reflectance */
260 if (ac != 3)
261 return(MG_EARGC);
262 if (!isflt(av[1]) | !isflt(av[2]))
263 return(MG_ETYPE);
264 c_cmaterial->rs = atof(av[1]);
265 c_cmaterial->rs_a = atof(av[2]);
266 if ((c_cmaterial->rs < 0.) | (c_cmaterial->rs > 1.) |
267 (c_cmaterial->rs_a < 0.))
268 return(MG_EILL);
269 c_cmaterial->rs_c = *c_ccolor;
270 c_cmaterial->clock++;
271 return(MG_OK);
272 case MG_E_TS: /* set specular transmittance */
273 if (ac != 3)
274 return(MG_EARGC);
275 if (!isflt(av[1]) | !isflt(av[2]))
276 return(MG_ETYPE);
277 c_cmaterial->ts = atof(av[1]);
278 c_cmaterial->ts_a = atof(av[2]);
279 if ((c_cmaterial->ts < 0.) | (c_cmaterial->ts > 1.) |
280 (c_cmaterial->ts_a < 0.))
281 return(MG_EILL);
282 c_cmaterial->ts_c = *c_ccolor;
283 c_cmaterial->clock++;
284 return(MG_OK);
285 case MG_E_SIDES: /* set number of sides */
286 if (ac != 2)
287 return(MG_EARGC);
288 if (!isint(av[1]))
289 return(MG_ETYPE);
290 i = atoi(av[1]);
291 if (i == 1)
292 c_cmaterial->sided = 1;
293 else if (i == 2)
294 c_cmaterial->sided = 0;
295 else
296 return(MG_EILL);
297 c_cmaterial->clock++;
298 return(MG_OK);
299 }
300 return(MG_EUNK);
301 }
302
303
304 int
305 c_hvertex(int ac, char **av) /* handle a vertex entity */
306 {
307 int i;
308 register LUENT *lp;
309
310 switch (mg_entity(av[0])) {
311 case MG_E_VERTEX: /* get/set vertex context */
312 if (ac > 4)
313 return(MG_EARGC);
314 if (ac == 1) { /* set unnamed vertex context */
315 c_unvertex = c_dfvertex;
316 c_cvertex = &c_unvertex;
317 c_cvname = NULL;
318 return(MG_OK);
319 }
320 if (!isname(av[1]))
321 return(MG_EILL);
322 lp = lu_find(&vtx_tab, av[1]); /* lookup context */
323 if (lp == NULL)
324 return(MG_EMEM);
325 c_cvname = lp->key;
326 c_cvertex = (C_VERTEX *)lp->data;
327 if (ac == 2) { /* reestablish previous context */
328 if (c_cvertex == NULL)
329 return(MG_EUNDEF);
330 return(MG_OK);
331 }
332 if (av[2][0] != '=' || av[2][1])
333 return(MG_ETYPE);
334 if (c_cvertex == NULL) { /* create new vertex context */
335 lp->key = (char *)malloc(strlen(av[1])+1);
336 if (lp->key == NULL)
337 return(MG_EMEM);
338 strcpy(lp->key, av[1]);
339 lp->data = (char *)malloc(sizeof(C_VERTEX));
340 if (lp->data == NULL)
341 return(MG_EMEM);
342 c_cvname = lp->key;
343 c_cvertex = (C_VERTEX *)lp->data;
344 c_cvertex->clock = 0;
345 c_cvertex->client_data = NULL;
346 }
347 i = c_cvertex->clock;
348 if (ac == 3) { /* use default template */
349 *c_cvertex = c_dfvertex;
350 c_cvertex->clock = i + 1;
351 return(MG_OK);
352 }
353 lp = lu_find(&vtx_tab, av[3]); /* lookup template */
354 if (lp == NULL)
355 return(MG_EMEM);
356 if (lp->data == NULL)
357 return(MG_EUNDEF);
358 *c_cvertex = *(C_VERTEX *)lp->data;
359 c_cvertex->clock = i + 1;
360 return(MG_OK);
361 case MG_E_POINT: /* set point */
362 if (ac != 4)
363 return(MG_EARGC);
364 if (!isflt(av[1]) | !isflt(av[2]) | !isflt(av[3]))
365 return(MG_ETYPE);
366 c_cvertex->p[0] = atof(av[1]);
367 c_cvertex->p[1] = atof(av[2]);
368 c_cvertex->p[2] = atof(av[3]);
369 c_cvertex->clock++;
370 return(MG_OK);
371 case MG_E_NORMAL: /* set normal */
372 if (ac != 4)
373 return(MG_EARGC);
374 if (!isflt(av[1]) | !isflt(av[2]) | !isflt(av[3]))
375 return(MG_ETYPE);
376 c_cvertex->n[0] = atof(av[1]);
377 c_cvertex->n[1] = atof(av[2]);
378 c_cvertex->n[2] = atof(av[3]);
379 (void)normalize(c_cvertex->n);
380 c_cvertex->clock++;
381 return(MG_OK);
382 }
383 return(MG_EUNK);
384 }
385
386
387 void
388 c_clearall(void) /* empty context tables */
389 {
390 c_uncolor = c_dfcolor;
391 c_ccolor = &c_uncolor;
392 c_ccname = NULL;
393 lu_done(&clr_tab);
394 c_unmaterial = c_dfmaterial;
395 c_cmaterial = &c_unmaterial;
396 c_cmname = NULL;
397 lu_done(&mat_tab);
398 c_unvertex = c_dfvertex;
399 c_cvertex = &c_unvertex;
400 c_cvname = NULL;
401 lu_done(&vtx_tab);
402 }
403
404
405 C_MATERIAL *
406 c_getmaterial(char *name) /* get a named material */
407 {
408 register LUENT *lp;
409
410 if ((lp = lu_find(&mat_tab, name)) == NULL)
411 return(NULL);
412 return((C_MATERIAL *)lp->data);
413 }
414
415
416 C_VERTEX *
417 c_getvert(char *name) /* get a named vertex */
418 {
419 register LUENT *lp;
420
421 if ((lp = lu_find(&vtx_tab, name)) == NULL)
422 return(NULL);
423 return((C_VERTEX *)lp->data);
424 }
425
426
427 C_COLOR *
428 c_getcolor(char *name) /* get a named color */
429 {
430 register LUENT *lp;
431
432 if ((lp = lu_find(&clr_tab, name)) == NULL)
433 return(NULL);
434 return((C_COLOR *)lp->data);
435 }
436
437
438 static int
439 setspectrum( /* convert a spectrum */
440 register C_COLOR *clr,
441 double wlmin,
442 double wlmax,
443 int ac,
444 char **av
445 )
446 {
447 double scale;
448 float va[C_CNSS];
449 register int i, pos;
450 int n, imax;
451 int wl;
452 double wl0, wlstep;
453 double boxpos, boxstep;
454 /* check bounds */
455 if ((wlmax <= C_CMINWL) | (wlmax <= wlmin) | (wlmin >= C_CMAXWL))
456 return(MG_EILL);
457 wlstep = (wlmax - wlmin)/(ac-1);
458 while (wlmin < C_CMINWL) {
459 wlmin += wlstep;
460 ac--; av++;
461 }
462 while (wlmax > C_CMAXWL) {
463 wlmax -= wlstep;
464 ac--;
465 }
466 imax = ac; /* box filter if necessary */
467 boxpos = 0;
468 boxstep = 1;
469 if (wlstep < C_CWLI) {
470 imax = (wlmax - wlmin)/C_CWLI + (1-FTINY);
471 boxpos = (wlmin - C_CMINWL)/C_CWLI;
472 boxstep = wlstep/C_CWLI;
473 wlstep = C_CWLI;
474 }
475 scale = 0.; /* get values and maximum */
476 pos = 0;
477 for (i = 0; i < imax; i++) {
478 va[i] = 0.; n = 0;
479 while (boxpos < i+.5 && pos < ac) {
480 if (!isflt(av[pos]))
481 return(MG_ETYPE);
482 va[i] += atof(av[pos++]);
483 n++;
484 boxpos += boxstep;
485 }
486 if (n > 1)
487 va[i] /= (double)n;
488 if (va[i] > scale)
489 scale = va[i];
490 else if (va[i] < -scale)
491 scale = -va[i];
492 }
493 if (scale <= FTINY)
494 return(MG_EILL);
495 scale = C_CMAXV / scale;
496 clr->ssum = 0; /* convert to our spacing */
497 wl0 = wlmin;
498 pos = 0;
499 for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI)
500 if ((wl < wlmin) | (wl > wlmax))
501 clr->ssamp[i] = 0;
502 else {
503 while (wl0 + wlstep < wl+FTINY) {
504 wl0 += wlstep;
505 pos++;
506 }
507 if ((wl+FTINY >= wl0) & (wl-FTINY <= wl0))
508 clr->ssamp[i] = scale*va[pos] + .5;
509 else /* interpolate if necessary */
510 clr->ssamp[i] = .5 + scale / wlstep *
511 ( va[pos]*(wl0+wlstep - wl) +
512 va[pos+1]*(wl - wl0) );
513 clr->ssum += clr->ssamp[i];
514 }
515 clr->flags = C_CDSPEC|C_CSSPEC;
516 clr->clock++;
517 return(MG_OK);
518 }
