1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: mgf_context.c,v 3.2 2012/05/17 17:10:23 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Context handlers |
6 |
7 |
8 |
#include <stdio.h> |
9 |
#include <stdlib.h> |
10 |
#include <string.h> |
11 |
#include "mgf_parser.h" |
12 |
#include "lookup.h" |
13 |
14 |
/* default context values */ |
15 |
static C_MATERIAL c_dfmaterial = C_DEFMATERIAL; |
16 |
static C_VERTEX c_dfvertex = C_DEFVERTEX; |
17 |
18 |
/* the unnamed contexts */ |
19 |
static C_COLOR c_uncolor = C_DEFCOLOR; |
20 |
static C_MATERIAL c_unmaterial = C_DEFMATERIAL; |
21 |
static C_VERTEX c_unvertex = C_DEFVERTEX; |
22 |
23 |
/* the current contexts */ |
24 |
C_COLOR *c_ccolor = &c_uncolor; |
25 |
char *c_ccname = NULL; |
26 |
C_MATERIAL *c_cmaterial = &c_unmaterial; |
27 |
char *c_cmname = NULL; |
28 |
C_VERTEX *c_cvertex = &c_unvertex; |
29 |
char *c_cvname = NULL; |
30 |
31 |
static LUTAB clr_tab = LU_SINIT(free,free); /* color lookup table */ |
32 |
static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */ |
33 |
static LUTAB vtx_tab = LU_SINIT(free,free); /* vertex lookup table */ |
34 |
35 |
static int setspectrum(C_COLOR *, int ac, char **av); |
36 |
37 |
38 |
int |
39 |
c_hcolor(int ac, char **av) /* handle color entity */ |
40 |
41 |
double w, wsum; |
42 |
int i; |
43 |
LUENT *lp; |
44 |
45 |
switch (mg_entity(av[0])) { |
46 |
case MG_E_COLOR: /* get/set color context */ |
47 |
if (ac > 4) |
48 |
return(MG_EARGC); |
49 |
if (ac == 1) { /* set unnamed color context */ |
50 |
c_uncolor = c_dfcolor; |
51 |
52 |
c_ccname = NULL; |
53 |
return(MG_OK); |
54 |
55 |
if (!isname(av[1])) |
56 |
return(MG_EILL); |
57 |
lp = lu_find(&clr_tab, av[1]); /* lookup context */ |
58 |
if (lp == NULL) |
59 |
return(MG_EMEM); |
60 |
c_ccname = lp->key; |
61 |
c_ccolor = (C_COLOR *)lp->data; |
62 |
if (ac == 2 || (ac == 4 && !strcmp(av[1], av[3]))) { |
63 |
if (c_ccolor == NULL) /* reestablish context */ |
64 |
return(MG_EUNDEF); |
65 |
return(MG_OK); |
66 |
67 |
if (av[2][0] != '=' || av[2][1]) |
68 |
return(MG_ETYPE); |
69 |
if (c_ccolor == NULL) { /* create new color context */ |
70 |
lp->key = (char *)malloc(strlen(av[1])+1); |
71 |
if (lp->key == NULL) |
72 |
return(MG_EMEM); |
73 |
strcpy(lp->key, av[1]); |
74 |
lp->data = (char *)malloc(sizeof(C_COLOR)); |
75 |
if (lp->data == NULL) |
76 |
return(MG_EMEM); |
77 |
78 |
79 |
c_ccolor->clock = 0; |
80 |
c_ccolor->client_data = NULL; |
81 |
82 |
i = c_ccolor->clock; |
83 |
if (ac == 3) { /* use default template */ |
84 |
*c_ccolor = c_dfcolor; |
85 |
c_ccolor->clock = i + 1; |
86 |
return(MG_OK); |
87 |
88 |
lp = lu_find(&clr_tab, av[3]); /* lookup template */ |
89 |
if (lp == NULL) |
90 |
return(MG_EMEM); |
91 |
92 |
93 |
*c_ccolor = *(C_COLOR *)lp->data; |
94 |
95 |
return(MG_OK); |
96 |
case MG_E_CXY: /* assign CIE XY value */ |
97 |
if (ac != 3) |
98 |
return(MG_EARGC); |
99 |
if (!isflt(av[1]) | !isflt(av[2])) |
100 |
return(MG_ETYPE); |
101 |
c_ccolor->cx = atof(av[1]); |
102 |
c_ccolor->cy = atof(av[2]); |
103 |
c_ccolor->flags = C_CDXY|C_CSXY; |
104 |
if ((c_ccolor->cx < 0.) | (c_ccolor->cy < 0.) | |
105 |
(c_ccolor->cx + c_ccolor->cy > 1.)) |
106 |
return(MG_EILL); |
107 |
c_ccolor->clock++; |
108 |
return(MG_OK); |
109 |
case MG_E_CSPEC: /* assign spectral values */ |
110 |
return(setspectrum(c_ccolor, ac-1, av+1)); |
111 |
case MG_E_CCT: /* assign black body spectrum */ |
112 |
if (ac != 2) |
113 |
return(MG_EARGC); |
114 |
if (!isflt(av[1])) |
115 |
return(MG_ETYPE); |
116 |
if (!c_bbtemp(c_ccolor, atof(av[1]))) |
117 |
return(MG_EILL); |
118 |
119 |
return(MG_OK); |
120 |
case MG_E_CMIX: /* mix colors */ |
121 |
if (ac < 5 || (ac-1)%2) |
122 |
return(MG_EARGC); |
123 |
124 |
return(MG_ETYPE); |
125 |
wsum = atof(av[1]); |
126 |
if ((lp = lu_find(&clr_tab, av[2])) == NULL) |
127 |
return(MG_EMEM); |
128 |
129 |
130 |
131 |
for (i = 3; i < ac; i += 2) { |
132 |
if (!isflt(av[i])) |
133 |
return(MG_ETYPE); |
134 |
w = atof(av[i]); |
135 |
if ((lp = lu_find(&clr_tab, av[i+1])) == NULL) |
136 |
return(MG_EMEM); |
137 |
138 |
139 |
c_cmix(c_ccolor, wsum, c_ccolor, |
140 |
w, (C_COLOR *)lp->data); |
141 |
wsum += w; |
142 |
143 |
if (wsum <= 0.) |
144 |
return(MG_EILL); |
145 |
146 |
return(MG_OK); |
147 |
148 |
return(MG_EUNK); |
149 |
150 |
151 |
152 |
int |
153 |
c_hmaterial(int ac, char **av) /* handle material entity */ |
154 |
155 |
int i; |
156 |
LUENT *lp; |
157 |
158 |
159 |
case MG_E_MATERIAL: /* get/set material context */ |
160 |
if (ac > 4) |
161 |
return(MG_EARGC); |
162 |
if (ac == 1) { /* set unnamed material context */ |
163 |
c_unmaterial = c_dfmaterial; |
164 |
165 |
c_cmname = NULL; |
166 |
return(MG_OK); |
167 |
168 |
169 |
return(MG_EILL); |
170 |
lp = lu_find(&mat_tab, av[1]); /* lookup context */ |
171 |
if (lp == NULL) |
172 |
return(MG_EMEM); |
173 |
c_cmname = lp->key; |
174 |
c_cmaterial = (C_MATERIAL *)lp->data; |
175 |
176 |
if (c_cmaterial == NULL) /* reestablish context */ |
177 |
178 |
return(MG_OK); |
179 |
180 |
181 |
return(MG_ETYPE); |
182 |
if (c_cmaterial == NULL) { /* create new material */ |
183 |
184 |
185 |
return(MG_EMEM); |
186 |
187 |
lp->data = (char *)malloc(sizeof(C_MATERIAL)); |
188 |
189 |
return(MG_EMEM); |
190 |
191 |
192 |
c_cmaterial->clock = 0; |
193 |
c_cmaterial->client_data = NULL; |
194 |
195 |
i = c_cmaterial->clock; |
196 |
197 |
*c_cmaterial = c_dfmaterial; |
198 |
c_cmaterial->clock = i + 1; |
199 |
return(MG_OK); |
200 |
201 |
lp = lu_find(&mat_tab, av[3]); /* lookup template */ |
202 |
if (lp == NULL) |
203 |
return(MG_EMEM); |
204 |
205 |
206 |
*c_cmaterial = *(C_MATERIAL *)lp->data; |
207 |
208 |
return(MG_OK); |
209 |
case MG_E_IR: /* set index of refraction */ |
210 |
if (ac != 3) |
211 |
return(MG_EARGC); |
212 |
213 |
return(MG_ETYPE); |
214 |
c_cmaterial->nr = atof(av[1]); |
215 |
c_cmaterial->ni = atof(av[2]); |
216 |
if (c_cmaterial->nr <= FTINY) |
217 |
return(MG_EILL); |
218 |
c_cmaterial->clock++; |
219 |
return(MG_OK); |
220 |
case MG_E_RD: /* set diffuse reflectance */ |
221 |
if (ac != 2) |
222 |
return(MG_EARGC); |
223 |
224 |
return(MG_ETYPE); |
225 |
c_cmaterial->rd = atof(av[1]); |
226 |
if ((c_cmaterial->rd < 0.) | (c_cmaterial->rd > 1.)) |
227 |
return(MG_EILL); |
228 |
c_cmaterial->rd_c = *c_ccolor; |
229 |
230 |
return(MG_OK); |
231 |
case MG_E_ED: /* set diffuse emittance */ |
232 |
if (ac != 2) |
233 |
return(MG_EARGC); |
234 |
235 |
return(MG_ETYPE); |
236 |
c_cmaterial->ed = atof(av[1]); |
237 |
if (c_cmaterial->ed < 0.) |
238 |
return(MG_EILL); |
239 |
c_cmaterial->ed_c = *c_ccolor; |
240 |
241 |
return(MG_OK); |
242 |
case MG_E_TD: /* set diffuse transmittance */ |
243 |
if (ac != 2) |
244 |
return(MG_EARGC); |
245 |
246 |
return(MG_ETYPE); |
247 |
c_cmaterial->td = atof(av[1]); |
248 |
if ((c_cmaterial->td < 0.) | (c_cmaterial->td > 1.)) |
249 |
return(MG_EILL); |
250 |
c_cmaterial->td_c = *c_ccolor; |
251 |
252 |
return(MG_OK); |
253 |
case MG_E_RS: /* set specular reflectance */ |
254 |
if (ac != 3) |
255 |
return(MG_EARGC); |
256 |
257 |
return(MG_ETYPE); |
258 |
c_cmaterial->rs = atof(av[1]); |
259 |
c_cmaterial->rs_a = atof(av[2]); |
260 |
if ((c_cmaterial->rs < 0.) | (c_cmaterial->rs > 1.) | |
261 |
(c_cmaterial->rs_a < 0.)) |
262 |
return(MG_EILL); |
263 |
c_cmaterial->rs_c = *c_ccolor; |
264 |
265 |
return(MG_OK); |
266 |
case MG_E_TS: /* set specular transmittance */ |
267 |
if (ac != 3) |
268 |
return(MG_EARGC); |
269 |
270 |
return(MG_ETYPE); |
271 |
c_cmaterial->ts = atof(av[1]); |
272 |
c_cmaterial->ts_a = atof(av[2]); |
273 |
if ((c_cmaterial->ts < 0.) | (c_cmaterial->ts > 1.) | |
274 |
(c_cmaterial->ts_a < 0.)) |
275 |
return(MG_EILL); |
276 |
c_cmaterial->ts_c = *c_ccolor; |
277 |
278 |
return(MG_OK); |
279 |
case MG_E_SIDES: /* set number of sides */ |
280 |
if (ac != 2) |
281 |
return(MG_EARGC); |
282 |
if (!isint(av[1])) |
283 |
return(MG_ETYPE); |
284 |
i = atoi(av[1]); |
285 |
if (i == 1) |
286 |
c_cmaterial->sided = 1; |
287 |
else if (i == 2) |
288 |
c_cmaterial->sided = 0; |
289 |
else |
290 |
return(MG_EILL); |
291 |
292 |
return(MG_OK); |
293 |
294 |
return(MG_EUNK); |
295 |
296 |
297 |
298 |
int |
299 |
c_hvertex(int ac, char **av) /* handle a vertex entity */ |
300 |
301 |
int i; |
302 |
LUENT *lp; |
303 |
304 |
305 |
case MG_E_VERTEX: /* get/set vertex context */ |
306 |
if (ac > 4) |
307 |
return(MG_EARGC); |
308 |
if (ac == 1) { /* set unnamed vertex context */ |
309 |
c_unvertex = c_dfvertex; |
310 |
311 |
c_cvname = NULL; |
312 |
return(MG_OK); |
313 |
314 |
315 |
return(MG_EILL); |
316 |
lp = lu_find(&vtx_tab, av[1]); /* lookup context */ |
317 |
if (lp == NULL) |
318 |
return(MG_EMEM); |
319 |
c_cvname = lp->key; |
320 |
c_cvertex = (C_VERTEX *)lp->data; |
321 |
322 |
if (c_cvertex == NULL) /* reestablish context */ |
323 |
324 |
return(MG_OK); |
325 |
326 |
327 |
return(MG_ETYPE); |
328 |
if (c_cvertex == NULL) { /* create new vertex context */ |
329 |
330 |
331 |
return(MG_EMEM); |
332 |
333 |
lp->data = (char *)malloc(sizeof(C_VERTEX)); |
334 |
335 |
return(MG_EMEM); |
336 |
337 |
338 |
c_cvertex->clock = 0; |
339 |
c_cvertex->client_data = NULL; |
340 |
341 |
i = c_cvertex->clock; |
342 |
343 |
*c_cvertex = c_dfvertex; |
344 |
c_cvertex->clock = i + 1; |
345 |
return(MG_OK); |
346 |
347 |
lp = lu_find(&vtx_tab, av[3]); /* lookup template */ |
348 |
if (lp == NULL) |
349 |
return(MG_EMEM); |
350 |
351 |
352 |
*c_cvertex = *(C_VERTEX *)lp->data; |
353 |
354 |
return(MG_OK); |
355 |
case MG_E_POINT: /* set point */ |
356 |
if (ac != 4) |
357 |
return(MG_EARGC); |
358 |
if (!isflt(av[1]) | !isflt(av[2]) | !isflt(av[3])) |
359 |
return(MG_ETYPE); |
360 |
c_cvertex->p[0] = atof(av[1]); |
361 |
c_cvertex->p[1] = atof(av[2]); |
362 |
c_cvertex->p[2] = atof(av[3]); |
363 |
c_cvertex->clock++; |
364 |
return(MG_OK); |
365 |
case MG_E_NORMAL: /* set normal */ |
366 |
if (ac != 4) |
367 |
return(MG_EARGC); |
368 |
369 |
return(MG_ETYPE); |
370 |
c_cvertex->n[0] = atof(av[1]); |
371 |
c_cvertex->n[1] = atof(av[2]); |
372 |
c_cvertex->n[2] = atof(av[3]); |
373 |
(void)normalize(c_cvertex->n); |
374 |
375 |
return(MG_OK); |
376 |
377 |
return(MG_EUNK); |
378 |
379 |
380 |
381 |
void |
382 |
c_clearall(void) /* empty context tables */ |
383 |
384 |
385 |
386 |
c_ccname = NULL; |
387 |
lu_done(&clr_tab); |
388 |
389 |
390 |
c_cmname = NULL; |
391 |
lu_done(&mat_tab); |
392 |
393 |
394 |
c_cvname = NULL; |
395 |
lu_done(&vtx_tab); |
396 |
397 |
398 |
399 |
C_MATERIAL * |
400 |
c_getmaterial(char *name) /* get a named material */ |
401 |
402 |
LUENT *lp; |
403 |
404 |
if ((lp = lu_find(&mat_tab, name)) == NULL) |
405 |
return(NULL); |
406 |
return((C_MATERIAL *)lp->data); |
407 |
408 |
409 |
410 |
C_VERTEX * |
411 |
c_getvert(char *name) /* get a named vertex */ |
412 |
413 |
LUENT *lp; |
414 |
415 |
if ((lp = lu_find(&vtx_tab, name)) == NULL) |
416 |
return(NULL); |
417 |
return((C_VERTEX *)lp->data); |
418 |
419 |
420 |
421 |
C_COLOR * |
422 |
c_getcolor(char *name) /* get a named color */ |
423 |
424 |
LUENT *lp; |
425 |
426 |
if ((lp = lu_find(&clr_tab, name)) == NULL) |
427 |
return(NULL); |
428 |
return((C_COLOR *)lp->data); |
429 |
430 |
431 |
432 |
static int |
433 |
setspectrum( /* convert a spectrum */ |
434 |
C_COLOR *clr, |
435 |
int ac, |
436 |
char **av |
437 |
438 |
439 |
double wlmin, wlmax; |
440 |
int i; |
441 |
float *va; |
442 |
/* get bounds */ |
443 |
if (ac < 4) |
444 |
return(MG_EARGC); |
445 |
if (!isflt(av[0]) || !isflt(av[1])) |
446 |
return(MG_ETYPE); |
447 |
wlmin = atof(av[0]); |
448 |
wlmax = atof(av[1]); |
449 |
ac -= 2; av += 2; |
450 |
va = (float *)malloc(sizeof(float)*ac); |
451 |
if (va == NULL) |
452 |
return(MG_EMEM); |
453 |
for (i = ac; i--; ) { |
454 |
455 |
return(MG_ETYPE); |
456 |
va[i] = atof(av[i]); |
457 |
458 |
if (c_sset(clr, wlmin, wlmax, va, ac) <= FTINY) { |
459 |
free(va); |
460 |
return(MG_EILL); |
461 |
462 |
free(va); |
463 |
clr->clock++; |
464 |
return(MG_OK); |
465 |
