--- ray/src/common/mgf_context.c 2011/02/18 00:40:25 3.1 +++ ray/src/common/mgf_context.c 2012/05/17 17:10:23 3.2 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mgf_context.c,v 3.1 2011/02/18 00:40:25 greg Exp $"; +static const char RCSid[] = "$Id: mgf_context.c,v 3.2 2012/05/17 17:10:23 greg Exp $"; #endif /* * Context handlers @@ -32,16 +32,15 @@ static LUTAB clr_tab = LU_SINIT(free,free); /* color l static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */ static LUTAB vtx_tab = LU_SINIT(free,free); /* vertex lookup table */ -static int setspectrum(C_COLOR *, double wlmin, double wlmax, - int ac, char **av); +static int setspectrum(C_COLOR *, int ac, char **av); int c_hcolor(int ac, char **av) /* handle color entity */ { double w, wsum; - register int i; - register LUENT *lp; + int i; + LUENT *lp; switch (mg_entity(av[0])) { case MG_E_COLOR: /* get/set color context */ @@ -108,12 +107,7 @@ c_hcolor(int ac, char **av) /* handle color entity */ c_ccolor->clock++; return(MG_OK); case MG_E_CSPEC: /* assign spectral values */ - if (ac < 5) - return(MG_EARGC); - if (!isflt(av[1]) | !isflt(av[2])) - return(MG_ETYPE); - return(setspectrum(c_ccolor, atof(av[1]), atof(av[2]), - ac-3, av+3)); + return(setspectrum(c_ccolor, ac-1, av+1)); case MG_E_CCT: /* assign black body spectrum */ if (ac != 2) return(MG_EARGC); @@ -159,7 +153,7 @@ int c_hmaterial(int ac, char **av) /* handle material entity */ { int i; - register LUENT *lp; + LUENT *lp; switch (mg_entity(av[0])) { case MG_E_MATERIAL: /* get/set material context */ @@ -305,7 +299,7 @@ int c_hvertex(int ac, char **av) /* handle a vertex entity */ { int i; - register LUENT *lp; + LUENT *lp; switch (mg_entity(av[0])) { case MG_E_VERTEX: /* get/set vertex context */ @@ -405,7 +399,7 @@ c_clearall(void) /* empty context tables */ C_MATERIAL * c_getmaterial(char *name) /* get a named material */ { - register LUENT *lp; + LUENT *lp; if ((lp = lu_find(&mat_tab, name)) == NULL) return(NULL); @@ -416,7 +410,7 @@ c_getmaterial(char *name) /* get a named material */ C_VERTEX * c_getvert(char *name) /* get a named vertex */ { - register LUENT *lp; + LUENT *lp; if ((lp = lu_find(&vtx_tab, name)) == NULL) return(NULL); @@ -427,7 +421,7 @@ c_getvert(char *name) /* get a named vertex */ C_COLOR * c_getcolor(char *name) /* get a named color */ { - register LUENT *lp; + LUENT *lp; if ((lp = lu_find(&clr_tab, name)) == NULL) return(NULL); @@ -436,83 +430,36 @@ c_getcolor(char *name) /* get a named color */ static int -setspectrum( /* convert a spectrum */ - register C_COLOR *clr, - double wlmin, - double wlmax, +setspectrum( /* convert a spectrum */ + C_COLOR *clr, int ac, char **av ) { - double scale; - float va[C_CNSS]; - register int i, pos; - int n, imax; - int wl; - double wl0, wlstep; - double boxpos, boxstep; - /* check bounds */ - if ((wlmax <= C_CMINWL) | (wlmax <= wlmin) | (wlmin >= C_CMAXWL)) - return(MG_EILL); - wlstep = (wlmax - wlmin)/(ac-1); - while (wlmin < C_CMINWL) { - wlmin += wlstep; - ac--; av++; + double wlmin, wlmax; + int i; + float *va; + /* get bounds */ + if (ac < 4) + return(MG_EARGC); + if (!isflt(av[0]) || !isflt(av[1])) + return(MG_ETYPE); + wlmin = atof(av[0]); + wlmax = atof(av[1]); + ac -= 2; av += 2; + va = (float *)malloc(sizeof(float)*ac); + if (va == NULL) + return(MG_EMEM); + for (i = ac; i--; ) { + if (!isflt(av[i])) + return(MG_ETYPE); + va[i] = atof(av[i]); } - while (wlmax > C_CMAXWL) { - wlmax -= wlstep; - ac--; - } - imax = ac; /* box filter if necessary */ - boxpos = 0; - boxstep = 1; - if (wlstep < C_CWLI) { - imax = (wlmax - wlmin)/C_CWLI + (1-FTINY); - boxpos = (wlmin - C_CMINWL)/C_CWLI; - boxstep = wlstep/C_CWLI; - wlstep = C_CWLI; - } - scale = 0.; /* get values and maximum */ - pos = 0; - for (i = 0; i < imax; i++) { - va[i] = 0.; n = 0; - while (boxpos < i+.5 && pos < ac) { - if (!isflt(av[pos])) - return(MG_ETYPE); - va[i] += atof(av[pos++]); - n++; - boxpos += boxstep; - } - if (n > 1) - va[i] /= (double)n; - if (va[i] > scale) - scale = va[i]; - else if (va[i] < -scale) - scale = -va[i]; - } - if (scale <= FTINY) + if (c_sset(clr, wlmin, wlmax, va, ac) <= FTINY) { + free(va); return(MG_EILL); - scale = C_CMAXV / scale; - clr->ssum = 0; /* convert to our spacing */ - wl0 = wlmin; - pos = 0; - for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI) - if ((wl < wlmin) | (wl > wlmax)) - clr->ssamp[i] = 0; - else { - while (wl0 + wlstep < wl+FTINY) { - wl0 += wlstep; - pos++; - } - if ((wl+FTINY >= wl0) & (wl-FTINY <= wl0)) - clr->ssamp[i] = scale*va[pos] + .5; - else /* interpolate if necessary */ - clr->ssamp[i] = .5 + scale / wlstep * - ( va[pos]*(wl0+wlstep - wl) + - va[pos+1]*(wl - wl0) ); - clr->ssum += clr->ssamp[i]; - } - clr->flags = C_CDSPEC|C_CSSPEC; + } + free(va); clr->clock++; return(MG_OK); }
