root/radiance/ray/src/common/mgf_context.c
Revision: 3.1
Committed: Fri Feb 18 00:40:25 2011 UTC (14 years, 2 months ago) by greg
# User Rev Content
1 greg 3.1 #ifndef lint
2     static const char RCSid[] = "$Id: context.c,v 1.30 2011/02/03 19:36:10 greg Exp $";
3     #endif
4     /*
5     * Context handlers
6     */
7
8     #include <stdio.h>
9     #include <stdlib.h>
10     #include <string.h>
11     #include "mgf_parser.h"
12     #include "lookup.h"
13
14     /* default context values */
15     static C_MATERIAL c_dfmaterial = C_DEFMATERIAL;
16     static C_VERTEX c_dfvertex = C_DEFVERTEX;
17
18     /* the unnamed contexts */
19     static C_COLOR c_uncolor = C_DEFCOLOR;
20     static C_MATERIAL c_unmaterial = C_DEFMATERIAL;
21     static C_VERTEX c_unvertex = C_DEFVERTEX;
22
23     /* the current contexts */
24     C_COLOR *c_ccolor = &c_uncolor;
25     char *c_ccname = NULL;
26     C_MATERIAL *c_cmaterial = &c_unmaterial;
27     char *c_cmname = NULL;
28     C_VERTEX *c_cvertex = &c_unvertex;
29     char *c_cvname = NULL;
30
31     static LUTAB clr_tab = LU_SINIT(free,free); /* color lookup table */
32     static LUTAB mat_tab = LU_SINIT(free,free); /* material lookup table */
33     static LUTAB vtx_tab = LU_SINIT(free,free); /* vertex lookup table */
34
35     static int setspectrum(C_COLOR *, double wlmin, double wlmax,
36     int ac, char **av);
37
38
39     int
40     c_hcolor(int ac, char **av) /* handle color entity */
41     {
42     double w, wsum;
43     register int i;
44     register LUENT *lp;
45
46     switch (mg_entity(av[0])) {
47     case MG_E_COLOR: /* get/set color context */
48     if (ac > 4)
49     return(MG_EARGC);
50     if (ac == 1) { /* set unnamed color context */
51     c_uncolor = c_dfcolor;
52     c_ccolor = &c_uncolor;
53     c_ccname = NULL;
54     return(MG_OK);
55     }
56     if (!isname(av[1]))
57     return(MG_EILL);
58     lp = lu_find(&clr_tab, av[1]); /* lookup context */
59     if (lp == NULL)
60     return(MG_EMEM);
61     c_ccname = lp->key;
62     c_ccolor = (C_COLOR *)lp->data;
63     if (ac == 2) { /* reestablish previous context */
64     if (c_ccolor == NULL)
65     return(MG_EUNDEF);
66     return(MG_OK);
67     }
68     if (av[2][0] != '=' || av[2][1])
69     return(MG_ETYPE);
70     if (c_ccolor == NULL) { /* create new color context */
71     lp->key = (char *)malloc(strlen(av[1])+1);
72     if (lp->key == NULL)
73     return(MG_EMEM);
74     strcpy(lp->key, av[1]);
75     lp->data = (char *)malloc(sizeof(C_COLOR));
76     if (lp->data == NULL)
77     return(MG_EMEM);
78     c_ccname = lp->key;
79     c_ccolor = (C_COLOR *)lp->data;
80     c_ccolor->clock = 0;
81     c_ccolor->client_data = NULL;
82     }
83     i = c_ccolor->clock;
84     if (ac == 3) { /* use default template */
85     *c_ccolor = c_dfcolor;
86     c_ccolor->clock = i + 1;
87     return(MG_OK);
88     }
89     lp = lu_find(&clr_tab, av[3]); /* lookup template */
90     if (lp == NULL)
91     return(MG_EMEM);
92     if (lp->data == NULL)
93     return(MG_EUNDEF);
94     *c_ccolor = *(C_COLOR *)lp->data;
95     c_ccolor->clock = i + 1;
96     return(MG_OK);
97     case MG_E_CXY: /* assign CIE XY value */
98     if (ac != 3)
99     return(MG_EARGC);
100     if (!isflt(av[1]) | !isflt(av[2]))
101     return(MG_ETYPE);
102     c_ccolor->cx = atof(av[1]);
103     c_ccolor->cy = atof(av[2]);
104     c_ccolor->flags = C_CDXY|C_CSXY;
105     if ((c_ccolor->cx < 0.) | (c_ccolor->cy < 0.) |
106     (c_ccolor->cx + c_ccolor->cy > 1.))
107     return(MG_EILL);
108     c_ccolor->clock++;
109     return(MG_OK);
110     case MG_E_CSPEC: /* assign spectral values */
111     if (ac < 5)
112     return(MG_EARGC);
113     if (!isflt(av[1]) | !isflt(av[2]))
114     return(MG_ETYPE);
115     return(setspectrum(c_ccolor, atof(av[1]), atof(av[2]),
116     ac-3, av+3));
117     case MG_E_CCT: /* assign black body spectrum */
118     if (ac != 2)
119     return(MG_EARGC);
120     if (!isflt(av[1]))
121     return(MG_ETYPE);
122     if (!c_bbtemp(c_ccolor, atof(av[1])))
123     return(MG_EILL);
124     c_ccolor->clock++;
125     return(MG_OK);
126     case MG_E_CMIX: /* mix colors */
127     if (ac < 5 || (ac-1)%2)
128     return(MG_EARGC);
129     if (!isflt(av[1]))
130     return(MG_ETYPE);
131     wsum = atof(av[1]);
132     if ((lp = lu_find(&clr_tab, av[2])) == NULL)
133     return(MG_EMEM);
134     if (lp->data == NULL)
135     return(MG_EUNDEF);
136     *c_ccolor = *(C_COLOR *)lp->data;
137     for (i = 3; i < ac; i += 2) {
138     if (!isflt(av[i]))
139     return(MG_ETYPE);
140     w = atof(av[i]);
141     if ((lp = lu_find(&clr_tab, av[i+1])) == NULL)
142     return(MG_EMEM);
143     if (lp->data == NULL)
144     return(MG_EUNDEF);
145     c_cmix(c_ccolor, wsum, c_ccolor,
146     w, (C_COLOR *)lp->data);
147     wsum += w;
148     }
149     if (wsum <= 0.)
150     return(MG_EILL);
151     c_ccolor->clock++;
152     return(MG_OK);
153     }
154     return(MG_EUNK);
155     }
156
157
158     int
159     c_hmaterial(int ac, char **av) /* handle material entity */
160     {
161     int i;
162     register LUENT *lp;
163
164     switch (mg_entity(av[0])) {
165     case MG_E_MATERIAL: /* get/set material context */
166     if (ac > 4)
167     return(MG_EARGC);
168     if (ac == 1) { /* set unnamed material context */
169     c_unmaterial = c_dfmaterial;
170     c_cmaterial = &c_unmaterial;
171     c_cmname = NULL;
172     return(MG_OK);
173     }
174     if (!isname(av[1]))
175     return(MG_EILL);
176     lp = lu_find(&mat_tab, av[1]); /* lookup context */
177     if (lp == NULL)
178     return(MG_EMEM);
179     c_cmname = lp->key;
180     c_cmaterial = (C_MATERIAL *)lp->data;
181     if (ac == 2) { /* reestablish previous context */
182     if (c_cmaterial == NULL)
183     return(MG_EUNDEF);
184     return(MG_OK);
185     }
186     if (av[2][0] != '=' || av[2][1])
187     return(MG_ETYPE);
188     if (c_cmaterial == NULL) { /* create new material */
189     lp->key = (char *)malloc(strlen(av[1])+1);
190     if (lp->key == NULL)
191     return(MG_EMEM);
192     strcpy(lp->key, av[1]);
193     lp->data = (char *)malloc(sizeof(C_MATERIAL));
194     if (lp->data == NULL)
195     return(MG_EMEM);
196     c_cmname = lp->key;
197     c_cmaterial = (C_MATERIAL *)lp->data;
198     c_cmaterial->clock = 0;
199     c_cmaterial->client_data = NULL;
200     }
201     i = c_cmaterial->clock;
202     if (ac == 3) { /* use default template */
203     *c_cmaterial = c_dfmaterial;
204     c_cmaterial->clock = i + 1;
205     return(MG_OK);
206     }
207     lp = lu_find(&mat_tab, av[3]); /* lookup template */
208     if (lp == NULL)
209     return(MG_EMEM);
210     if (lp->data == NULL)
211     return(MG_EUNDEF);
212     *c_cmaterial = *(C_MATERIAL *)lp->data;
213     c_cmaterial->clock = i + 1;
214     return(MG_OK);
215     case MG_E_IR: /* set index of refraction */
216     if (ac != 3)
217     return(MG_EARGC);
218     if (!isflt(av[1]) | !isflt(av[2]))
219     return(MG_ETYPE);
220     c_cmaterial->nr = atof(av[1]);
221     c_cmaterial->ni = atof(av[2]);
222     if (c_cmaterial->nr <= FTINY)
223     return(MG_EILL);
224     c_cmaterial->clock++;
225     return(MG_OK);
226     case MG_E_RD: /* set diffuse reflectance */
227     if (ac != 2)
228     return(MG_EARGC);
229     if (!isflt(av[1]))
230     return(MG_ETYPE);
231     c_cmaterial->rd = atof(av[1]);
232     if ((c_cmaterial->rd < 0.) | (c_cmaterial->rd > 1.))
233     return(MG_EILL);
234     c_cmaterial->rd_c = *c_ccolor;
235     c_cmaterial->clock++;
236     return(MG_OK);
237     case MG_E_ED: /* set diffuse emittance */
238     if (ac != 2)
239     return(MG_EARGC);
240     if (!isflt(av[1]))
241     return(MG_ETYPE);
242     c_cmaterial->ed = atof(av[1]);
243     if (c_cmaterial->ed < 0.)
244     return(MG_EILL);
245     c_cmaterial->ed_c = *c_ccolor;
246     c_cmaterial->clock++;
247     return(MG_OK);
248     case MG_E_TD: /* set diffuse transmittance */
249     if (ac != 2)
250     return(MG_EARGC);
251     if (!isflt(av[1]))
252     return(MG_ETYPE);
253     c_cmaterial->td = atof(av[1]);
254     if ((c_cmaterial->td < 0.) | (c_cmaterial->td > 1.))
255     return(MG_EILL);
256     c_cmaterial->td_c = *c_ccolor;
257     c_cmaterial->clock++;
258     return(MG_OK);
259     case MG_E_RS: /* set specular reflectance */
260     if (ac != 3)
261     return(MG_EARGC);
262     if (!isflt(av[1]) | !isflt(av[2]))
263     return(MG_ETYPE);
264     c_cmaterial->rs = atof(av[1]);
265     c_cmaterial->rs_a = atof(av[2]);
266     if ((c_cmaterial->rs < 0.) | (c_cmaterial->rs > 1.) |
267     (c_cmaterial->rs_a < 0.))
268     return(MG_EILL);
269     c_cmaterial->rs_c = *c_ccolor;
270     c_cmaterial->clock++;
271     return(MG_OK);
272     case MG_E_TS: /* set specular transmittance */
273     if (ac != 3)
274     return(MG_EARGC);
275     if (!isflt(av[1]) | !isflt(av[2]))
276     return(MG_ETYPE);
277     c_cmaterial->ts = atof(av[1]);
278     c_cmaterial->ts_a = atof(av[2]);
279     if ((c_cmaterial->ts < 0.) | (c_cmaterial->ts > 1.) |
280     (c_cmaterial->ts_a < 0.))
281     return(MG_EILL);
282     c_cmaterial->ts_c = *c_ccolor;
283     c_cmaterial->clock++;
284     return(MG_OK);
285     case MG_E_SIDES: /* set number of sides */
286     if (ac != 2)
287     return(MG_EARGC);
288     if (!isint(av[1]))
289     return(MG_ETYPE);
290     i = atoi(av[1]);
291     if (i == 1)
292     c_cmaterial->sided = 1;
293     else if (i == 2)
294     c_cmaterial->sided = 0;
295     else
296     return(MG_EILL);
297     c_cmaterial->clock++;
298     return(MG_OK);
299     }
300     return(MG_EUNK);
301     }
302
303
304     int
305     c_hvertex(int ac, char **av) /* handle a vertex entity */
306     {
307     int i;
308     register LUENT *lp;
309
310     switch (mg_entity(av[0])) {
311     case MG_E_VERTEX: /* get/set vertex context */
312     if (ac > 4)
313     return(MG_EARGC);
314     if (ac == 1) { /* set unnamed vertex context */
315     c_unvertex = c_dfvertex;
316     c_cvertex = &c_unvertex;
317     c_cvname = NULL;
318     return(MG_OK);
319     }
320     if (!isname(av[1]))
321     return(MG_EILL);
322     lp = lu_find(&vtx_tab, av[1]); /* lookup context */
323     if (lp == NULL)
324     return(MG_EMEM);
325     c_cvname = lp->key;
326     c_cvertex = (C_VERTEX *)lp->data;
327     if (ac == 2) { /* reestablish previous context */
328     if (c_cvertex == NULL)
329     return(MG_EUNDEF);
330     return(MG_OK);
331     }
332     if (av[2][0] != '=' || av[2][1])
333     return(MG_ETYPE);
334     if (c_cvertex == NULL) { /* create new vertex context */
335     lp->key = (char *)malloc(strlen(av[1])+1);
336     if (lp->key == NULL)
337     return(MG_EMEM);
338     strcpy(lp->key, av[1]);
339     lp->data = (char *)malloc(sizeof(C_VERTEX));
340     if (lp->data == NULL)
341     return(MG_EMEM);
342     c_cvname = lp->key;
343     c_cvertex = (C_VERTEX *)lp->data;
344     c_cvertex->clock = 0;
345     c_cvertex->client_data = NULL;
346     }
347     i = c_cvertex->clock;
348     if (ac == 3) { /* use default template */
349     *c_cvertex = c_dfvertex;
350     c_cvertex->clock = i + 1;
351     return(MG_OK);
352     }
353     lp = lu_find(&vtx_tab, av[3]); /* lookup template */
354     if (lp == NULL)
355     return(MG_EMEM);
356     if (lp->data == NULL)
357     return(MG_EUNDEF);
358     *c_cvertex = *(C_VERTEX *)lp->data;
359     c_cvertex->clock = i + 1;
360     return(MG_OK);
361     case MG_E_POINT: /* set point */
362     if (ac != 4)
363     return(MG_EARGC);
364     if (!isflt(av[1]) | !isflt(av[2]) | !isflt(av[3]))
365     return(MG_ETYPE);
366     c_cvertex->p[0] = atof(av[1]);
367     c_cvertex->p[1] = atof(av[2]);
368     c_cvertex->p[2] = atof(av[3]);
369     c_cvertex->clock++;
370     return(MG_OK);
371     case MG_E_NORMAL: /* set normal */
372     if (ac != 4)
373     return(MG_EARGC);
374     if (!isflt(av[1]) | !isflt(av[2]) | !isflt(av[3]))
375     return(MG_ETYPE);
376     c_cvertex->n[0] = atof(av[1]);
377     c_cvertex->n[1] = atof(av[2]);
378     c_cvertex->n[2] = atof(av[3]);
379     (void)normalize(c_cvertex->n);
380     c_cvertex->clock++;
381     return(MG_OK);
382     }
383     return(MG_EUNK);
384     }
385
386
387     void
388     c_clearall(void) /* empty context tables */
389     {
390     c_uncolor = c_dfcolor;
391     c_ccolor = &c_uncolor;
392     c_ccname = NULL;
393     lu_done(&clr_tab);
394     c_unmaterial = c_dfmaterial;
395     c_cmaterial = &c_unmaterial;
396     c_cmname = NULL;
397     lu_done(&mat_tab);
398     c_unvertex = c_dfvertex;
399     c_cvertex = &c_unvertex;
400     c_cvname = NULL;
401     lu_done(&vtx_tab);
402     }
403
404
405     C_MATERIAL *
406     c_getmaterial(char *name) /* get a named material */
407     {
408     register LUENT *lp;
409
410     if ((lp = lu_find(&mat_tab, name)) == NULL)
411     return(NULL);
412     return((C_MATERIAL *)lp->data);
413     }
414
415
416     C_VERTEX *
417     c_getvert(char *name) /* get a named vertex */
418     {
419     register LUENT *lp;
420
421     if ((lp = lu_find(&vtx_tab, name)) == NULL)
422     return(NULL);
423     return((C_VERTEX *)lp->data);
424     }
425
426
427     C_COLOR *
428     c_getcolor(char *name) /* get a named color */
429     {
430     register LUENT *lp;
431
432     if ((lp = lu_find(&clr_tab, name)) == NULL)
433     return(NULL);
434     return((C_COLOR *)lp->data);
435     }
436
437
438     static int
439     setspectrum( /* convert a spectrum */
440     register C_COLOR *clr,
441     double wlmin,
442     double wlmax,
443     int ac,
444     char **av
445     )
446     {
447     double scale;
448     float va[C_CNSS];
449     register int i, pos;
450     int n, imax;
451     int wl;
452     double wl0, wlstep;
453     double boxpos, boxstep;
454     /* check bounds */
455     if ((wlmax <= C_CMINWL) | (wlmax <= wlmin) | (wlmin >= C_CMAXWL))
456     return(MG_EILL);
457     wlstep = (wlmax - wlmin)/(ac-1);
458     while (wlmin < C_CMINWL) {
459     wlmin += wlstep;
460     ac--; av++;
461     }
462     while (wlmax > C_CMAXWL) {
463     wlmax -= wlstep;
464     ac--;
465     }
466     imax = ac; /* box filter if necessary */
467     boxpos = 0;
468     boxstep = 1;
469     if (wlstep < C_CWLI) {
470     imax = (wlmax - wlmin)/C_CWLI + (1-FTINY);
471     boxpos = (wlmin - C_CMINWL)/C_CWLI;
472     boxstep = wlstep/C_CWLI;
473     wlstep = C_CWLI;
474     }
475     scale = 0.; /* get values and maximum */
476     pos = 0;
477     for (i = 0; i < imax; i++) {
478     va[i] = 0.; n = 0;
479     while (boxpos < i+.5 && pos < ac) {
480     if (!isflt(av[pos]))
481     return(MG_ETYPE);
482     va[i] += atof(av[pos++]);
483     n++;
484     boxpos += boxstep;
485     }
486     if (n > 1)
487     va[i] /= (double)n;
488     if (va[i] > scale)
489     scale = va[i];
490     else if (va[i] < -scale)
491     scale = -va[i];
492     }
493     if (scale <= FTINY)
494     return(MG_EILL);
495     scale = C_CMAXV / scale;
496     clr->ssum = 0; /* convert to our spacing */
497     wl0 = wlmin;
498     pos = 0;
499     for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI)
500     if ((wl < wlmin) | (wl > wlmax))
501     clr->ssamp[i] = 0;
502     else {
503     while (wl0 + wlstep < wl+FTINY) {
504     wl0 += wlstep;
505     pos++;
506     }
507     if ((wl+FTINY >= wl0) & (wl-FTINY <= wl0))
508     clr->ssamp[i] = scale*va[pos] + .5;
509     else /* interpolate if necessary */
510     clr->ssamp[i] = .5 + scale / wlstep *
511     ( va[pos]*(wl0+wlstep - wl) +
512     va[pos+1]*(wl - wl0) );
513     clr->ssum += clr->ssamp[i];
514     }
515     clr->flags = C_CDSPEC|C_CSSPEC;
516     clr->clock++;
517     return(MG_OK);
518     }
