root/radiance/ray/src/common/mesh.h
Revision: 2.5
Committed: Fri Jun 6 16:38:47 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.4: +12 -20 lines
*** empty log message ***
1 /* RCSid $Id: mesh.h,v 2.4 2003/05/13 17:58:32 greg Exp $ */
2 /*
3 * Header for compact triangle mesh geometry
4 *
5 * Include after standard.h, object.h and octree.h
6 */
7 #ifndef _RAD_MESH_H_
8 #define _RAD_MESH_H_
9 #ifdef __cplusplus
10 extern "C" {
11 #endif
12
13 #include "copyright.h"
14
15 #include "lookup.h"
16
17 #ifndef uint4
18 #define uint4 unsigned int4
19 #endif
20 #ifndef BYTE
21 #define BYTE unsigned char
22 #endif
23
24 /*
25 * Vertex space is minimized without compromising accuracy by using a
26 * 4-byte unsigned int to indicate position in the enclosing octree cube.
27 * The same trick is used for any local (u,v) coordinates, whose limits
28 * are recorded separately in the parent MESH structure. The uvlimit's
29 * in the MESH structure are set such that (0,0) is out of range, so
30 * we use this to indicate an unspecified local coordinate.
31 * A vertex normal, if specified, is stored in a single 4-byte
32 * integer using the codec in dircode.c. The encodedir() function
33 * never generates 0, so we can use this for unspecified normals.
34 *
35 * Vertex ID's are encoded using the bottom 8 bits of a 4-byte integer
36 * to index a vertex in a patch indicated by the 22 bits above (8-29).
37 * For triangle ID's, the top 22 bits (10-31) indicate the patch, and
38 * the bit 9 (0x200) indicates whether the triangle joins patches.
39 * If not, then the bottom 9 bits index into the local PTri array.
40 * If it's a joiner, then the 8th bit indicates whether the triangle joins
41 * two patches, in which case the bottom 8 bits index the PJoin2 array.
42 * Otherwise, the bottom 8 bits index the PJoin1 array.
43 *
44 * These shenanigans minimize vertex reference memory requirements
45 * in compiled mesh structures, where the octree leaves contain sets
46 * of triangle ID's rather than the more usual objects. It seems like
47 * a lot of effort, but it can reduce mesh storage by a factor of 3
48 * or more. This is important, as the whole point is to model very
49 * complicated geometry with this structure, and memory is the main
50 * limitation.
51 */
52
53 /* A triangle mesh patch */
54 typedef struct {
55 uint4 (*xyz)[3]; /* up to 256 patch vertices */
56 int4 *norm; /* vertex normals */
57 uint4 (*uv)[2]; /* vertex local coordinates */
58 struct PTri {
59 BYTE v1, v2, v3; /* local vertices */
60 } *tri; /* local triangles */
61 short solemat; /* sole material */
62 int2 *trimat; /* or local material indices */
63 struct PJoin1 {
64 int4 v1j; /* non-local vertex */
65 int2 mat; /* material index */
66 BYTE v2, v3; /* local vertices */
67 } *j1tri; /* joiner triangles */
68 struct PJoin2 {
69 int4 v1j, v2j; /* non-local vertices */
70 int2 mat; /* material index */
71 BYTE v3; /* local vertex */
72 } *j2tri; /* double joiner triangles */
73 short nverts; /* vertex count */
74 short ntris; /* triangle count */
75 short nj1tris; /* joiner triangle count */
76 short nj2tris; /* double joiner triangle count */
77 } MESHPATCH;
78
79 /* A loaded mesh */
80 typedef struct mesh {
81 char *name; /* mesh file name */
82 int nref; /* reference count */
83 int ldflags; /* what we've loaded */
84 CUBE mcube; /* bounds and octree */
85 FLOAT uvlim[2][2]; /* local coordinate extrema */
86 OBJECT mat0; /* base material index */
87 OBJECT nmats; /* number of materials */
88 MESHPATCH *patch; /* mesh patch list */
89 int npatches; /* number of mesh patches */
90 OBJREC *pseudo; /* mesh pseudo objects */
91 LUTAB lut; /* vertex lookup table */
92 struct mesh *next; /* next mesh in list */
93 } MESH;
94
95 /* A mesh instance */
96 typedef struct {
97 FULLXF x; /* forward and backward transforms */
98 MESH *msh; /* mesh object reference */
99 } MESHINST;
100
101 /* vertex flags */
102 #define MT_V 01
103 #define MT_N 02
104 #define MT_UV 04
105 #define MT_ALL 07
106
107 /* A mesh vertex */
108 typedef struct {
109 int fl; /* setting flags */
110 FVECT v; /* vertex location */
111 FVECT n; /* vertex normal */
112 FLOAT uv[2]; /* local coordinates */
113 } MESHVERT;
114
115 /* mesh format identifier */
116 #define MESHFMT "Radiance_tmesh"
117 /* magic number for mesh files */
118 #define MESHMAGIC ( 1 *MAXOBJSIZ+311) /* increment first value */
119
120
121 extern MESH *getmesh(char *mname, int flags);
122 extern MESHINST *getmeshinst(OBJREC *o, int flags);
123 extern int getmeshtrivid(int4 tvid[3], OBJECT *mo,
124 MESH *mp, OBJECT ti);
125 extern int getmeshvert(MESHVERT *vp, MESH *mp, int4 vid, int what);
126 extern int getmeshtri(MESHVERT tv[3], OBJECT *mo,
127 MESH *mp, OBJECT ti, int what);
128 extern OBJREC *getmeshpseudo(MESH *mp, OBJECT mo);
129 extern int4 addmeshvert(MESH *mp, MESHVERT *vp);
130 extern OBJECT addmeshtri(MESH *mp, MESHVERT tv[3], OBJECT mo);
131 extern char *checkmesh(MESH *mp);
132 extern void printmeshstats(MESH *ms, FILE *fp);
133 extern void freemesh(MESH *ms);
134 extern void freemeshinst(OBJREC *o);
135 extern void readmesh(MESH *mp, char *path, int flags);
136 extern void writemesh(MESH *mp, FILE *fp);
137
138
139 #ifdef __cplusplus
140 }
141 #endif
142 #endif /* _RAD_MESH_H_ */
143
