1 |
/* RCSid $Id: mesh.h,v 2.14 2011/05/20 02:06:38 greg Exp $ */ |
2 |
3 |
* Header for compact triangle mesh geometry |
4 |
5 |
* Include after standard.h, object.h and octree.h |
6 |
7 |
#ifndef _RAD_MESH_H_ |
8 |
#define _RAD_MESH_H_ |
9 |
10 |
#include "lookup.h" |
11 |
12 |
#ifdef __cplusplus |
13 |
extern "C" { |
14 |
#endif |
15 |
16 |
#ifndef uby8 |
17 |
#define uby8 unsigned char |
18 |
#endif |
19 |
20 |
21 |
* Vertex space is minimized without compromising accuracy by using a |
22 |
* 4-byte unsigned int to indicate position in the enclosing octree cube. |
23 |
* The same trick is used for any local (u,v) coordinates, whose limits |
24 |
* are recorded separately in the parent MESH structure. The uvlimit's |
25 |
* in the MESH structure are set such that (0,0) is out of range, so |
26 |
* we use this to indicate an unspecified local coordinate. |
27 |
* A vertex normal, if specified, is stored in a single 4-byte |
28 |
* integer using the codec in dircode.c. The encodedir() function |
29 |
* never generates 0, so we can use this for unspecified normals. |
30 |
31 |
* Vertex ID's are encoded using the bottom 8 bits of a 4-byte integer |
32 |
* to index a vertex in a patch indicated by the 22 bits above (8-29). |
33 |
* For triangle ID's, the top 22 bits (10-31) indicate the parent patch, |
34 |
* and the 10th bit (0x200) indicates whether the triangle joins patches. |
35 |
* If not, then the bottom 9 bits index into the local PTri array. |
36 |
* If it's a joiner, then the 9th bit indicates whether the triangle joins |
37 |
* two patches, in which case the bottom 8 bits index the PJoin2 array. |
38 |
* Otherwise, the bottom 8 bits index the PJoin1 array. |
39 |
40 |
* These shenanigans minimize vertex reference memory requirements |
41 |
* in compiled mesh structures, where the octree leaves contain sets |
42 |
* of triangle ID's rather than the more usual objects. It seems like |
43 |
* a lot of effort, but it can reduce mesh storage by a factor of 3 |
44 |
* or more. This is important, as the whole point is to model very |
45 |
* complicated geometry with this structure, and memory is the main |
46 |
* limitation. (This representation is so efficient, that the octree |
47 |
* structure ends up dominating memory for most compiled meshes.) |
48 |
49 |
50 |
/* A triangle mesh patch */ |
51 |
typedef struct { |
52 |
uint32 (*xyz)[3]; /* up to 256 patch vertices */ |
53 |
int32 *norm; /* vertex normals */ |
54 |
uint32 (*uv)[2]; /* vertex local coordinates */ |
55 |
struct PTri { |
56 |
uby8 v1, v2, v3; /* local vertices */ |
57 |
} *tri; /* local triangles */ |
58 |
short solemat; /* sole material */ |
59 |
int16 *trimat; /* or local material indices */ |
60 |
struct PJoin1 { |
61 |
int32 v1j; /* non-local vertex */ |
62 |
int16 mat; /* material index */ |
63 |
uby8 v2, v3; /* local vertices */ |
64 |
} *j1tri; /* joiner triangles */ |
65 |
struct PJoin2 { |
66 |
int32 v1j, v2j; /* non-local vertices */ |
67 |
68 |
uby8 v3; /* local vertex */ |
69 |
} *j2tri; /* double joiner triangles */ |
70 |
short nverts; /* vertex count */ |
71 |
short ntris; /* local triangle count */ |
72 |
short nj1tris; /* joiner triangle count */ |
73 |
short nj2tris; /* double joiner triangle count */ |
74 |
} MESHPATCH; |
75 |
76 |
/* A loaded mesh */ |
77 |
typedef struct mesh { |
78 |
char *name; /* mesh file name */ |
79 |
int nref; /* reference count */ |
80 |
int ldflags; /* what we've loaded */ |
81 |
CUBE mcube; /* bounds and octree */ |
82 |
RREAL uvlim[2][2]; /* local coordinate extrema */ |
83 |
OBJECT mat0; /* base material index */ |
84 |
OBJECT nmats; /* number of materials */ |
85 |
MESHPATCH *patch; /* allocated mesh patch array */ |
86 |
int npatches; /* number of mesh patches */ |
87 |
OBJREC *pseudo; /* mesh pseudo objects */ |
88 |
LUTAB lut; /* vertex lookup table */ |
89 |
struct mesh *next; /* next mesh in list */ |
90 |
} MESH; |
91 |
92 |
/* A mesh instance */ |
93 |
typedef struct { |
94 |
FULLXF x; /* forward and backward transforms */ |
95 |
MESH *msh; /* mesh object reference */ |
96 |
} MESHINST; |
97 |
98 |
/* vertex flags */ |
99 |
#define MT_V 01 |
100 |
#define MT_N 02 |
101 |
#define MT_UV 04 |
102 |
#define MT_ALL 07 |
103 |
104 |
/* A mesh vertex */ |
105 |
typedef struct { |
106 |
int fl; /* setting flags */ |
107 |
FVECT v; /* vertex location */ |
108 |
FVECT n; /* vertex normal */ |
109 |
RREAL uv[2]; /* local coordinates */ |
110 |
} MESHVERT; |
111 |
112 |
/* mesh format identifier */ |
113 |
#define MESHFMT "Radiance_tmesh" |
114 |
/* magic number for mesh files */ |
115 |
#define MESHMAGIC ( 1 *MAXOBJSIZ+311) /* increment first value */ |
116 |
117 |
118 |
extern MESH *getmesh(char *mname, int flags); |
119 |
extern MESHINST *getmeshinst(OBJREC *o, int flags); |
120 |
extern int nextmeshtri(OBJECT *tip, MESH *mp); |
121 |
extern int getmeshtrivid(int32 tvid[3], OBJECT *mo, |
122 |
MESH *mp, OBJECT ti); |
123 |
extern int getmeshvert(MESHVERT *vp, MESH *mp, int32 vid, int what); |
124 |
extern int getmeshtri(MESHVERT tv[3], OBJECT *mo, |
125 |
MESH *mp, OBJECT ti, int what); |
126 |
extern OBJREC *getmeshpseudo(MESH *mp, OBJECT mo); |
127 |
extern int32 addmeshvert(MESH *mp, MESHVERT *vp); |
128 |
extern OBJECT addmeshtri(MESH *mp, MESHVERT tv[3], OBJECT mo); |
129 |
extern char *checkmesh(MESH *mp); |
130 |
extern void printmeshstats(MESH *ms, FILE *fp); |
131 |
extern void freemesh(MESH *ms); |
132 |
extern void freemeshinst(OBJREC *o); |
133 |
extern void readmesh(MESH *mp, char *path, int flags); |
134 |
extern void writemesh(MESH *mp, FILE *fp); |
135 |
136 |
137 |
138 |
139 |
#endif |
140 |
#endif /* _RAD_MESH_H_ */ |
