--- ray/src/common/mesh.h 2004/01/30 00:08:31 2.12 +++ ray/src/common/mesh.h 2004/12/03 18:36:17 2.13 @@ -1,4 +1,4 @@ -/* RCSid $Id: mesh.h,v 2.12 2004/01/30 00:08:31 greg Exp $ */ +/* RCSid $Id: mesh.h,v 2.13 2004/12/03 18:36:17 greg Exp $ */ /* * Header for compact triangle mesh geometry * @@ -30,10 +30,10 @@ extern "C" { * * Vertex ID's are encoded using the bottom 8 bits of a 4-byte integer * to index a vertex in a patch indicated by the 22 bits above (8-29). - * For triangle ID's, the top 22 bits (10-31) indicate the patch, and - * the bit 9 (0x200) indicates whether the triangle joins patches. + * For triangle ID's, the top 22 bits (10-31) indicate the parent patch, + * and the 10th bit (0x200) indicates whether the triangle joins patches. * If not, then the bottom 9 bits index into the local PTri array. - * If it's a joiner, then the 8th bit indicates whether the triangle joins + * If it's a joiner, then the 9th bit indicates whether the triangle joins * two patches, in which case the bottom 8 bits index the PJoin2 array. * Otherwise, the bottom 8 bits index the PJoin1 array. * @@ -43,7 +43,8 @@ extern "C" { * a lot of effort, but it can reduce mesh storage by a factor of 3 * or more. This is important, as the whole point is to model very * complicated geometry with this structure, and memory is the main - * limitation. + * limitation. (This representation is so efficient, that the octree + * structure ends up dominating memory for most compiled meshes.) */ /* A triangle mesh patch */ @@ -81,7 +82,7 @@ typedef struct mesh { RREAL uvlim[2][2]; /* local coordinate extrema */ OBJECT mat0; /* base material index */ OBJECT nmats; /* number of materials */ - MESHPATCH *patch; /* mesh patch list */ + MESHPATCH *patch; /* allocated mesh patch array */ int npatches; /* number of mesh patches */ OBJREC *pseudo; /* mesh pseudo objects */ LUTAB lut; /* vertex lookup table */
