root/radiance/ray/src/common/mesh.h
Tue Nov 6 01:04:23 2012 UTC (11 years, 6 months ago) by greg
Added routine for cycling through all triangles
Fri May 20 02:06:38 2011 UTC (13 years ago) by greg
Changes since 2.13: +6 -6 lines
Fri Dec 3 18:36:17 2004 UTC (19 years, 5 months ago) by greg
Changes since 2.12: +7 -6 lines
Diff to previous 2.12
Improved comments
Fri Jan 30 00:08:31 2004 UTC (20 years, 3 months ago) by greg
Changes since 2.11: +3 -4 lines
Thu Sep 18 16:53:53 2003 UTC (20 years, 8 months ago) by greg
Tue Aug 26 04:24:26 2003 UTC (20 years, 9 months ago) by greg
Minor improvements
Mon Jul 14 22:23:59 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.8: +4 -3 lines
Changes since 2.7: +1 -3 lines
Changes since 2.5: +12 -15 lines
Fri Jun 6 16:38:47 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.4: +12 -20 lines
*** empty log message ***
Tue May 13 17:58:32 2003 UTC (21 years ago) by greg
Fri Mar 14 21:27:45 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.2: +21 -6 lines
Wed Mar 12 04:59:04 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.1: +4 -4 lines
Diff to selected 2.12
