--- ray/src/common/mesh.h 2003/03/12 04:59:04 2.2 +++ ray/src/common/mesh.h 2003/05/13 17:58:32 2.4 @@ -1,4 +1,4 @@ -/* RCSid $Id: mesh.h,v 2.2 2003/03/12 04:59:04 greg Exp $ */ +/* RCSid $Id: mesh.h,v 2.4 2003/05/13 17:58:32 greg Exp $ */ /* * Header for compact triangle mesh geometry * @@ -7,6 +7,8 @@ #include "copyright.h" +#include "lookup.h" + #ifndef uint4 #define uint4 unsigned int4 #endif @@ -40,7 +42,7 @@ * a lot of effort, but it can reduce mesh storage by a factor of 3 * or more. This is important, as the whole point is to model very * complicated geometry with this structure, and memory is the main - * limitation. (We also optimize intersection tests for triangles.) + * limitation. */ /* A triangle mesh patch */ @@ -51,12 +53,16 @@ typedef struct { struct PTri { BYTE v1, v2, v3; /* local vertices */ } *tri; /* local triangles */ + short solemat; /* sole material */ + int2 *trimat; /* or local material indices */ struct PJoin1 { int4 v1j; /* non-local vertex */ + int2 mat; /* material index */ BYTE v2, v3; /* local vertices */ } *j1tri; /* joiner triangles */ struct PJoin2 { int4 v1j, v2j; /* non-local vertices */ + int2 mat; /* material index */ BYTE v3; /* local vertex */ } *j2tri; /* double joiner triangles */ short nverts; /* vertex count */ @@ -72,9 +78,12 @@ typedef struct mesh { int ldflags; /* what we've loaded */ CUBE mcube; /* bounds and octree */ FLOAT uvlim[2][2]; /* local coordinate extrema */ + OBJECT mat0; /* base material index */ + OBJECT nmats; /* number of materials */ MESHPATCH *patch; /* mesh patch list */ int npatches; /* number of mesh patches */ - char *cdata; /* opaque client data pointer */ + OBJREC *pseudo; /* mesh pseudo objects */ + LUTAB lut; /* vertex lookup table */ struct mesh *next; /* next mesh in list */ } MESH; @@ -101,17 +110,19 @@ typedef struct { /* mesh format identifier */ #define MESHFMT "Radiance_tmesh" /* magic number for mesh files */ -#define MESHMAGIC ( 0 *MAXOBJSIZ+311) /* increment first value */ +#define MESHMAGIC ( 1 *MAXOBJSIZ+311) /* increment first value */ #ifdef NOPROTO extern MESH *getmesh(); -extern INSTANCE *getmeshinst(); +extern MESHINST *getmeshinst(); extern int getmeshtrivid(); extern int getmeshvert(); extern int getmeshtri(); +extern OBJREC *getmeshpseudo(); extern int4 addmeshvert(); extern OBJECT addmeshtri(); +extern char *checkmesh(); extern void printmeshstats(); extern void freemesh(); extern void freemeshinst(); @@ -122,11 +133,15 @@ extern void writemesh(); extern MESH *getmesh(char *mname, int flags); extern MESHINST *getmeshinst(OBJREC *o, int flags); -extern int getmeshtrivid(int4 tvid[3], MESH *mp, OBJECT ti); +extern int getmeshtrivid(int4 tvid[3], OBJECT *mo, + MESH *mp, OBJECT ti); extern int getmeshvert(MESHVERT *vp, MESH *mp, int4 vid, int what); -extern int getmeshtri(MESHVERT tv[3], MESH *mp, OBJECT ti, int what); +extern int getmeshtri(MESHVERT tv[3], OBJECT *mo, + MESH *mp, OBJECT ti, int what); +extern OBJREC *getmeshpseudo(MESH *mp, OBJECT mo); extern int4 addmeshvert(MESH *mp, MESHVERT *vp); -extern OBJECT addmeshtri(MESH *mp, MESHVERT tv[3]); +extern OBJECT addmeshtri(MESH *mp, MESHVERT tv[3], OBJECT mo); +extern char *checkmesh(MESH *mp); extern void printmeshstats(MESH *ms, FILE *fp); extern void freemesh(MESH *ms); extern void freemeshinst(OBJREC *o);
