root/radiance/ray/src/common/mesh.h
Revision 2.15 - (view) (download) (annotate) - [selected]
Tue Nov 6 01:04:23 2012 UTC (11 years, 7 months ago) by greg
Diff to previous 2.14
Added routine for cycling through all triangles
Fri May 20 02:06:38 2011 UTC (13 years, 1 month ago) by greg
Changes since 2.13: +6 -6 lines
Diff to previous 2.13 , to selected 2.15
Fri Dec 3 18:36:17 2004 UTC (19 years, 6 months ago) by greg
Changes since 2.12: +7 -6 lines
Diff to previous 2.12 , to selected 2.15
Improved comments
Fri Jan 30 00:08:31 2004 UTC (20 years, 4 months ago) by greg
Changes since 2.11: +3 -4 lines
Diff to previous 2.11 , to selected 2.15
Thu Sep 18 16:53:53 2003 UTC (20 years, 9 months ago) by greg
Diff to previous 2.10 , to selected 2.15
Tue Aug 26 04:24:26 2003 UTC (20 years, 9 months ago) by greg
Diff to previous 2.9 , to selected 2.15
Minor improvements
Mon Jul 14 22:23:59 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.8: +4 -3 lines
Diff to previous 2.8 , to selected 2.15
Changes since 2.7: +1 -3 lines
Diff to previous 2.7 , to selected 2.15
Diff to previous 2.6 , to selected 2.15
Fri Jun 20 00:25:49 2003 UTC (21 years ago) by greg
Changes since 2.5: +12 -15 lines
Diff to previous 2.5 , to selected 2.15
Fri Jun 6 16:38:47 2003 UTC (21 years ago) by schorsch
Changes since 2.4: +12 -20 lines
Diff to previous 2.4 , to selected 2.15
*** empty log message ***
Tue May 13 17:58:32 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 2.3 , to selected 2.15
Fri Mar 14 21:27:45 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.2: +21 -6 lines
Diff to previous 2.2 , to selected 2.15
Wed Mar 12 04:59:04 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.1: +4 -4 lines
Diff to previous 2.1 , to selected 2.15
Tue Mar 11 17:08:55 2003 UTC (21 years, 3 months ago) by greg
Diff to selected 2.15
