root/radiance/ray/src/common/mesh.h
Revision: 2.4
Committed: Tue May 13 17:58:32 2003 UTC (21 years, 1 month ago) by greg
1 /* RCSid $Id$ */
2 /*
3 * Header for compact triangle mesh geometry
4 *
5 * Include after standard.h, object.h and octree.h
6 */
7
8 #include "copyright.h"
9
10 #include "lookup.h"
11
12 #ifndef uint4
13 #define uint4 unsigned int4
14 #endif
15 #ifndef BYTE
16 #define BYTE unsigned char
17 #endif
18
19 /*
20 * Vertex space is minimized without compromising accuracy by using a
21 * 4-byte unsigned int to indicate position in the enclosing octree cube.
22 * The same trick is used for any local (u,v) coordinates, whose limits
23 * are recorded separately in the parent MESH structure. The uvlimit's
24 * in the MESH structure are set such that (0,0) is out of range, so
25 * we use this to indicate an unspecified local coordinate.
26 * A vertex normal, if specified, is stored in a single 4-byte
27 * integer using the codec in dircode.c. The encodedir() function
28 * never generates 0, so we can use this for unspecified normals.
29 *
30 * Vertex ID's are encoded using the bottom 8 bits of a 4-byte integer
31 * to index a vertex in a patch indicated by the 22 bits above (8-29).
32 * For triangle ID's, the top 22 bits (10-31) indicate the patch, and
33 * the bit 9 (0x200) indicates whether the triangle joins patches.
34 * If not, then the bottom 9 bits index into the local PTri array.
35 * If it's a joiner, then the 8th bit indicates whether the triangle joins
36 * two patches, in which case the bottom 8 bits index the PJoin2 array.
37 * Otherwise, the bottom 8 bits index the PJoin1 array.
38 *
39 * These shenanigans minimize vertex reference memory requirements
40 * in compiled mesh structures, where the octree leaves contain sets
41 * of triangle ID's rather than the more usual objects. It seems like
42 * a lot of effort, but it can reduce mesh storage by a factor of 3
43 * or more. This is important, as the whole point is to model very
44 * complicated geometry with this structure, and memory is the main
45 * limitation.
46 */
47
48 /* A triangle mesh patch */
49 typedef struct {
50 uint4 (*xyz)[3]; /* up to 256 patch vertices */
51 int4 *norm; /* vertex normals */
52 uint4 (*uv)[2]; /* vertex local coordinates */
53 struct PTri {
54 BYTE v1, v2, v3; /* local vertices */
55 } *tri; /* local triangles */
56 short solemat; /* sole material */
57 int2 *trimat; /* or local material indices */
58 struct PJoin1 {
59 int4 v1j; /* non-local vertex */
60 int2 mat; /* material index */
61 BYTE v2, v3; /* local vertices */
62 } *j1tri; /* joiner triangles */
63 struct PJoin2 {
64 int4 v1j, v2j; /* non-local vertices */
65 int2 mat; /* material index */
66 BYTE v3; /* local vertex */
67 } *j2tri; /* double joiner triangles */
68 short nverts; /* vertex count */
69 short ntris; /* triangle count */
70 short nj1tris; /* joiner triangle count */
71 short nj2tris; /* double joiner triangle count */
72 } MESHPATCH;
73
74 /* A loaded mesh */
75 typedef struct mesh {
76 char *name; /* mesh file name */
77 int nref; /* reference count */
78 int ldflags; /* what we've loaded */
79 CUBE mcube; /* bounds and octree */
80 FLOAT uvlim[2][2]; /* local coordinate extrema */
81 OBJECT mat0; /* base material index */
82 OBJECT nmats; /* number of materials */
83 MESHPATCH *patch; /* mesh patch list */
84 int npatches; /* number of mesh patches */
85 OBJREC *pseudo; /* mesh pseudo objects */
86 LUTAB lut; /* vertex lookup table */
87 struct mesh *next; /* next mesh in list */
88 } MESH;
89
90 /* A mesh instance */
91 typedef struct {
92 FULLXF x; /* forward and backward transforms */
93 MESH *msh; /* mesh object reference */
94 } MESHINST;
95
96 /* vertex flags */
97 #define MT_V 01
98 #define MT_N 02
99 #define MT_UV 04
100 #define MT_ALL 07
101
102 /* A mesh vertex */
103 typedef struct {
104 int fl; /* setting flags */
105 FVECT v; /* vertex location */
106 FVECT n; /* vertex normal */
107 FLOAT uv[2]; /* local coordinates */
108 } MESHVERT;
109
110 /* mesh format identifier */
111 #define MESHFMT "Radiance_tmesh"
112 /* magic number for mesh files */
113 #define MESHMAGIC ( 1 *MAXOBJSIZ+311) /* increment first value */
114
115 #ifdef NOPROTO
116
117 extern MESH *getmesh();
118 extern MESHINST *getmeshinst();
119 extern int getmeshtrivid();
120 extern int getmeshvert();
121 extern int getmeshtri();
122 extern OBJREC *getmeshpseudo();
123 extern int4 addmeshvert();
124 extern OBJECT addmeshtri();
125 extern char *checkmesh();
126 extern void printmeshstats();
127 extern void freemesh();
128 extern void freemeshinst();
129 extern void readmesh();
130 extern void writemesh();
131
132 #else
133
134 extern MESH *getmesh(char *mname, int flags);
135 extern MESHINST *getmeshinst(OBJREC *o, int flags);
136 extern int getmeshtrivid(int4 tvid[3], OBJECT *mo,
137 MESH *mp, OBJECT ti);
138 extern int getmeshvert(MESHVERT *vp, MESH *mp, int4 vid, int what);
139 extern int getmeshtri(MESHVERT tv[3], OBJECT *mo,
140 MESH *mp, OBJECT ti, int what);
141 extern OBJREC *getmeshpseudo(MESH *mp, OBJECT mo);
142 extern int4 addmeshvert(MESH *mp, MESHVERT *vp);
143 extern OBJECT addmeshtri(MESH *mp, MESHVERT tv[3], OBJECT mo);
144 extern char *checkmesh(MESH *mp);
145 extern void printmeshstats(MESH *ms, FILE *fp);
146 extern void freemesh(MESH *ms);
147 extern void freemeshinst(OBJREC *o);
148 extern void readmesh(MESH *mp, char *path, int flags);
149 extern void writemesh(MESH *mp, FILE *fp);
150
151 #endif /* NOPROTO */
