root/radiance/ray/src/common/mesh.h
Revision: 2.2
Committed: Wed Mar 12 04:59:04 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.1: +4 -4 lines
1 /* RCSid $Id$ */
2 /*
3 * Header for compact triangle mesh geometry
4 *
5 * Include after standard.h, object.h and octree.h
6 */
7
8 #include "copyright.h"
9
10 #ifndef uint4
11 #define uint4 unsigned int4
12 #endif
13 #ifndef BYTE
14 #define BYTE unsigned char
15 #endif
16
17 /*
18 * Vertex space is minimized without compromising accuracy by using a
19 * 4-byte unsigned int to indicate position in the enclosing octree cube.
20 * The same trick is used for any local (u,v) coordinates, whose limits
21 * are recorded separately in the parent MESH structure. The uvlimit's
22 * in the MESH structure are set such that (0,0) is out of range, so
23 * we use this to indicate an unspecified local coordinate.
24 * A vertex normal, if specified, is stored in a single 4-byte
25 * integer using the codec in dircode.c. The encodedir() function
26 * never generates 0, so we can use this for unspecified normals.
27 *
28 * Vertex ID's are encoded using the bottom 8 bits of a 4-byte integer
29 * to index a vertex in a patch indicated by the 22 bits above (8-29).
30 * For triangle ID's, the top 22 bits (10-31) indicate the patch, and
31 * the bit 9 (0x200) indicates whether the triangle joins patches.
32 * If not, then the bottom 9 bits index into the local PTri array.
33 * If it's a joiner, then the 8th bit indicates whether the triangle joins
34 * two patches, in which case the bottom 8 bits index the PJoin2 array.
35 * Otherwise, the bottom 8 bits index the PJoin1 array.
36 *
37 * These shenanigans minimize vertex reference memory requirements
38 * in compiled mesh structures, where the octree leaves contain sets
39 * of triangle ID's rather than the more usual objects. It seems like
40 * a lot of effort, but it can reduce mesh storage by a factor of 3
41 * or more. This is important, as the whole point is to model very
42 * complicated geometry with this structure, and memory is the main
43 * limitation. (We also optimize intersection tests for triangles.)
44 */
45
46 /* A triangle mesh patch */
47 typedef struct {
48 uint4 (*xyz)[3]; /* up to 256 patch vertices */
49 int4 *norm; /* vertex normals */
50 uint4 (*uv)[2]; /* vertex local coordinates */
51 struct PTri {
52 BYTE v1, v2, v3; /* local vertices */
53 } *tri; /* local triangles */
54 struct PJoin1 {
55 int4 v1j; /* non-local vertex */
56 BYTE v2, v3; /* local vertices */
57 } *j1tri; /* joiner triangles */
58 struct PJoin2 {
59 int4 v1j, v2j; /* non-local vertices */
60 BYTE v3; /* local vertex */
61 } *j2tri; /* double joiner triangles */
62 short nverts; /* vertex count */
63 short ntris; /* triangle count */
64 short nj1tris; /* joiner triangle count */
65 short nj2tris; /* double joiner triangle count */
66 } MESHPATCH;
67
68 /* A loaded mesh */
69 typedef struct mesh {
70 char *name; /* mesh file name */
71 int nref; /* reference count */
72 int ldflags; /* what we've loaded */
73 CUBE mcube; /* bounds and octree */
74 FLOAT uvlim[2][2]; /* local coordinate extrema */
75 MESHPATCH *patch; /* mesh patch list */
76 int npatches; /* number of mesh patches */
77 char *cdata; /* opaque client data pointer */
78 struct mesh *next; /* next mesh in list */
79 } MESH;
80
81 /* A mesh instance */
82 typedef struct {
83 FULLXF x; /* forward and backward transforms */
84 MESH *msh; /* mesh object reference */
85 } MESHINST;
86
87 /* vertex flags */
88 #define MT_V 01
89 #define MT_N 02
90 #define MT_UV 04
91 #define MT_ALL 07
92
93 /* A mesh vertex */
94 typedef struct {
95 int fl; /* setting flags */
96 FVECT v; /* vertex location */
97 FVECT n; /* vertex normal */
98 FLOAT uv[2]; /* local coordinates */
99 } MESHVERT;
100
101 /* mesh format identifier */
102 #define MESHFMT "Radiance_tmesh"
103 /* magic number for mesh files */
104 #define MESHMAGIC ( 0 *MAXOBJSIZ+311) /* increment first value */
105
106 #ifdef NOPROTO
107
108 extern MESH *getmesh();
109 extern INSTANCE *getmeshinst();
110 extern int getmeshtrivid();
111 extern int getmeshvert();
112 extern int getmeshtri();
113 extern int4 addmeshvert();
114 extern OBJECT addmeshtri();
115 extern void printmeshstats();
116 extern void freemesh();
117 extern void freemeshinst();
118 extern void readmesh();
119 extern void writemesh();
120
121 #else
122
123 extern MESH *getmesh(char *mname, int flags);
124 extern MESHINST *getmeshinst(OBJREC *o, int flags);
125 extern int getmeshtrivid(int4 tvid[3], MESH *mp, OBJECT ti);
126 extern int getmeshvert(MESHVERT *vp, MESH *mp, int4 vid, int what);
127 extern int getmeshtri(MESHVERT tv[3], MESH *mp, OBJECT ti, int what);
128 extern int4 addmeshvert(MESH *mp, MESHVERT *vp);
129 extern OBJECT addmeshtri(MESH *mp, MESHVERT tv[3]);
130 extern void printmeshstats(MESH *ms, FILE *fp);
131 extern void freemesh(MESH *ms);
132 extern void freemeshinst(OBJREC *o);
133 extern void readmesh(MESH *mp, char *path, int flags);
134 extern void writemesh(MESH *mp, FILE *fp);
135
136 #endif /* NOPROTO */
