--- ray/src/common/mesh.h 2003/06/06 16:38:47 2.5 +++ ray/src/common/mesh.h 2003/09/18 16:53:53 2.11 @@ -1,4 +1,4 @@ -/* RCSid $Id: mesh.h,v 2.5 2003/06/06 16:38:47 schorsch Exp $ */ +/* RCSid $Id: mesh.h,v 2.11 2003/09/18 16:53:53 greg Exp $ */ /* * Header for compact triangle mesh geometry * @@ -6,17 +6,13 @@ */ #ifndef _RAD_MESH_H_ #define _RAD_MESH_H_ -#ifdef __cplusplus -extern "C" { -#endif -#include "copyright.h" - #include "lookup.h" -#ifndef uint4 -#define uint4 unsigned int4 +#ifdef __cplusplus +extern "C" { #endif + #ifndef BYTE #define BYTE unsigned char #endif @@ -52,26 +48,26 @@ extern "C" { /* A triangle mesh patch */ typedef struct { - uint4 (*xyz)[3]; /* up to 256 patch vertices */ - int4 *norm; /* vertex normals */ - uint4 (*uv)[2]; /* vertex local coordinates */ + uint32 (*xyz)[3]; /* up to 256 patch vertices */ + int32 *norm; /* vertex normals */ + uint16 (*uv)[2]; /* vertex local coordinates */ struct PTri { BYTE v1, v2, v3; /* local vertices */ } *tri; /* local triangles */ short solemat; /* sole material */ - int2 *trimat; /* or local material indices */ + int16 *trimat; /* or local material indices */ struct PJoin1 { - int4 v1j; /* non-local vertex */ - int2 mat; /* material index */ + int32 v1j; /* non-local vertex */ + int16 mat; /* material index */ BYTE v2, v3; /* local vertices */ } *j1tri; /* joiner triangles */ struct PJoin2 { - int4 v1j, v2j; /* non-local vertices */ - int2 mat; /* material index */ + int32 v1j, v2j; /* non-local vertices */ + int16 mat; /* material index */ BYTE v3; /* local vertex */ } *j2tri; /* double joiner triangles */ short nverts; /* vertex count */ - short ntris; /* triangle count */ + short ntris; /* local triangle count */ short nj1tris; /* joiner triangle count */ short nj2tris; /* double joiner triangle count */ } MESHPATCH; @@ -82,7 +78,7 @@ typedef struct mesh { int nref; /* reference count */ int ldflags; /* what we've loaded */ CUBE mcube; /* bounds and octree */ - FLOAT uvlim[2][2]; /* local coordinate extrema */ + RREAL uvlim[2][2]; /* local coordinate extrema */ OBJECT mat0; /* base material index */ OBJECT nmats; /* number of materials */ MESHPATCH *patch; /* mesh patch list */ @@ -109,24 +105,24 @@ typedef struct { int fl; /* setting flags */ FVECT v; /* vertex location */ FVECT n; /* vertex normal */ - FLOAT uv[2]; /* local coordinates */ + RREAL uv[2]; /* local coordinates */ } MESHVERT; /* mesh format identifier */ #define MESHFMT "Radiance_tmesh" /* magic number for mesh files */ -#define MESHMAGIC ( 1 *MAXOBJSIZ+311) /* increment first value */ +#define MESHMAGIC ( 2 *MAXOBJSIZ+311) /* increment first value */ extern MESH *getmesh(char *mname, int flags); extern MESHINST *getmeshinst(OBJREC *o, int flags); -extern int getmeshtrivid(int4 tvid[3], OBJECT *mo, +extern int getmeshtrivid(int32 tvid[3], OBJECT *mo, MESH *mp, OBJECT ti); -extern int getmeshvert(MESHVERT *vp, MESH *mp, int4 vid, int what); +extern int getmeshvert(MESHVERT *vp, MESH *mp, int32 vid, int what); extern int getmeshtri(MESHVERT tv[3], OBJECT *mo, MESH *mp, OBJECT ti, int what); extern OBJREC *getmeshpseudo(MESH *mp, OBJECT mo); -extern int4 addmeshvert(MESH *mp, MESHVERT *vp); +extern int32 addmeshvert(MESH *mp, MESHVERT *vp); extern OBJECT addmeshtri(MESH *mp, MESHVERT tv[3], OBJECT mo); extern char *checkmesh(MESH *mp); extern void printmeshstats(MESH *ms, FILE *fp);
