| 1 | #ifndef lint |
| 2 | static const char RCSid[] = "$Id$"; |
| 3 | #endif |
| 4 | /* |
| 5 | * Mesh support routines |
| 6 | */ |
| 7 |  |
| 8 | #include "standard.h" |
| 9 | #include "octree.h" |
| 10 | #include "object.h" |
| 11 | #include "mesh.h" |
| 12 | #include "lookup.h" |
| 13 |  |
| 14 | /* An encoded mesh vertex */ |
| 15 | typedef struct { |
| 16 | int             fl; |
| 17 | uint4           xyz[3]; |
| 18 | int4            norm; |
| 19 | uint4           uv[2]; |
| 20 | } MCVERT; |
| 21 |  |
| 22 | #define  MPATCHBLKSIZ   128             /* patch allocation block size */ |
| 23 |  |
| 24 | #define  IO_LEGAL       (IO_BOUNDS|IO_TREE|IO_SCENE) |
| 25 |  |
| 26 | static MESH     *mlist = NULL;          /* list of loaded meshes */ |
| 27 |  |
| 28 |  |
| 29 | static unsigned long |
| 30 | cvhash(cvp)                             /* hash an encoded vertex */ |
| 31 | MCVERT  *cvp; |
| 32 | { |
| 33 | unsigned long   hval; |
| 34 |  |
| 35 | if (!(cvp->fl & MT_V)) |
| 36 | return(0); |
| 37 | hval = cvp->xyz[0] ^ cvp->xyz[1] << 11 ^ cvp->xyz[2] << 22; |
| 38 | if (cvp->fl & MT_N) |
| 39 | hval ^= cvp->norm; |
| 40 | if (cvp->fl & MT_UV) |
| 41 | hval ^= cvp->uv[0] ^ cvp->uv[1] << 16; |
| 42 | return(hval); |
| 43 | } |
| 44 |  |
| 45 |  |
| 46 | static int |
| 47 | cvcmp(v1, v2)                           /* compare encoded vertices */ |
| 48 | register MCVERT *v1, *v2; |
| 49 | { |
| 50 | if (v1->fl != v2->fl) |
| 51 | return(1); |
| 52 | if (v1->xyz[0] != v2->xyz[0]) |
| 53 | return(1); |
| 54 | if (v1->xyz[1] != v2->xyz[1]) |
| 55 | return(1); |
| 56 | if (v1->xyz[2] != v2->xyz[2]) |
| 57 | return(1); |
| 58 | if (v1->fl & MT_N && v1->norm != v2->norm) |
| 59 | return(1); |
| 60 | if (v1->fl & MT_UV) { |
| 61 | if (v1->uv[0] != v2->uv[0]) |
| 62 | return(1); |
| 63 | if (v1->uv[1] != v2->uv[1]) |
| 64 | return(1); |
| 65 | } |
| 66 | return(0); |
| 67 | } |
| 68 |  |
| 69 |  |
| 70 | MESH * |
| 71 | getmesh(mname, flags)                   /* get mesh data */ |
| 72 | char    *mname; |
| 73 | int     flags; |
| 74 | { |
| 75 | char  *pathname; |
| 76 | register MESH  *ms; |
| 77 |  |
| 78 | flags &= IO_LEGAL; |
| 79 | for (ms = mlist; ms != NULL; ms = ms->next) |
| 80 | if (!strcmp(mname, ms->name)) { |
| 81 | if ((ms->ldflags & flags) == flags) { |
| 82 | ms->nref++; |
| 83 | return(ms);             /* loaded */ |
| 84 | } |
| 85 | break;                  /* load the rest */ |
| 86 | } |
| 87 | if (ms == NULL) { |
| 88 | ms = (MESH *)calloc(1, sizeof(MESH)); |
| 89 | if (ms == NULL) |
| 90 | error(SYSTEM, "out of memory in getmesh"); |
| 91 | ms->name = savestr(mname); |
| 92 | ms->nref = 1; |
| 93 | ms->mcube.cutree = EMPTY; |
| 94 | ms->next = mlist; |
| 95 | mlist = ms; |
| 96 | } |
| 97 | if ((pathname = getpath(mname, getlibpath(), R_OK)) == NULL) { |
| 98 | sprintf(errmsg, "cannot find mesh file \"%s\"", mname); |
| 99 | error(USER, errmsg); |
| 100 | } |
| 101 | flags &= ~ms->ldflags; |
| 102 | if (flags) |
| 103 | readmesh(ms, pathname, flags); |
| 104 | return(ms); |
| 105 | } |
| 106 |  |
| 107 |  |
| 108 | MESHINST * |
| 109 | getmeshinst(o, flags)                   /* create mesh instance */ |
| 110 | OBJREC  *o; |
| 111 | int     flags; |
| 112 | { |
| 113 | register MESHINST  *ins; |
| 114 |  |
| 115 | flags &= IO_LEGAL; |
| 116 | if ((ins = (MESHINST *)o->os) == NULL) { |
| 117 | if ((ins = (MESHINST *)malloc(sizeof(MESHINST))) == NULL) |
| 118 | error(SYSTEM, "out of memory in getmeshinst"); |
| 119 | if (o->oargs.nsargs < 1) |
| 120 | objerror(o, USER, "bad # of arguments"); |
| 121 | if (fullxf(&ins->x, o->oargs.nsargs-1, |
| 122 | o->oargs.sarg+1) != o->oargs.nsargs-1) |
| 123 | objerror(o, USER, "bad transform"); |
| 124 | if (ins->x.f.sca < 0.0) { |
| 125 | ins->x.f.sca = -ins->x.f.sca; |
| 126 | ins->x.b.sca = -ins->x.b.sca; |
| 127 | } |
| 128 | ins->msh = NULL; |
| 129 | o->os = (char *)ins; |
| 130 | } |
| 131 | if (ins->msh == NULL || (ins->msh->ldflags & flags) != flags) |
| 132 | ins->msh = getmesh(o->oargs.sarg[0], flags); |
| 133 | return(ins); |
| 134 | } |
| 135 |  |
| 136 |  |
| 137 | int |
| 138 | getmeshtrivid(tvid, mp, ti)             /* get triangle vertex ID's */ |
| 139 | int4            tvid[3]; |
| 140 | register MESH   *mp; |
| 141 | OBJECT          ti; |
| 142 | { |
| 143 | int             pn = ti >> 10; |
| 144 |  |
| 145 | if (pn >= mp->npatches) |
| 146 | return(0); |
| 147 | ti &= 0x3ff; |
| 148 | if (!(ti & 0x200)) {            /* local triangle */ |
| 149 | struct PTri     *tp; |
| 150 | if (ti >= mp->patch[pn].ntris) |
| 151 | return(0); |
| 152 | tp = &mp->patch[pn].tri[ti]; |
| 153 | tvid[0] = tvid[1] = tvid[2] = pn << 8; |
| 154 | tvid[0] |= tp->v1; |
| 155 | tvid[1] |= tp->v2; |
| 156 | tvid[2] |= tp->v3; |
| 157 | return(1); |
| 158 | } |
| 159 | ti &= ~0x200; |
| 160 | if (!(ti & 0x100)) {            /* single link vertex */ |
| 161 | struct PJoin1   *tp1; |
| 162 | if (ti >= mp->patch[pn].nj1tris) |
| 163 | return(0); |
| 164 | tp1 = &mp->patch[pn].j1tri[ti]; |
| 165 | tvid[0] = tp1->v1j; |
| 166 | tvid[1] = tvid[2] = pn << 8; |
| 167 | tvid[1] |= tp1->v2; |
| 168 | tvid[2] |= tp1->v3; |
| 169 | return(1); |
| 170 | } |
| 171 | ti &= ~0x100; |
| 172 | {                               /* double link vertex */ |
| 173 | struct PJoin2   *tp2; |
| 174 | if (ti >= mp->patch[pn].nj2tris) |
| 175 | return(0); |
| 176 | tp2 = &mp->patch[pn].j2tri[ti]; |
| 177 | tvid[0] = tp2->v1j; |
| 178 | tvid[1] = tp2->v2j; |
| 179 | tvid[2] = pn << 8 | tp2->v3; |
| 180 | } |
| 181 | return(1); |
| 182 | } |
| 183 |  |
| 184 |  |
| 185 | int |
| 186 | getmeshvert(vp, mp, vid, what)  /* get triangle vertex from ID */ |
| 187 | MESHVERT        *vp; |
| 188 | register MESH   *mp; |
| 189 | int4            vid; |
| 190 | int             what; |
| 191 | { |
| 192 | int             pn = vid >> 8; |
| 193 | MESHPATCH       *pp; |
| 194 | double          vres; |
| 195 | register int    i; |
| 196 |  |
| 197 | vp->fl = 0; |
| 198 | if (pn >= mp->npatches) |
| 199 | return(0); |
| 200 | pp = &mp->patch[pn]; |
| 201 | vid &= 0xff; |
| 202 | if (vid >= pp->nverts) |
| 203 | return(0); |
| 204 | /* get location */ |
| 205 | if (what & MT_V) { |
| 206 | vres = (1./4294967296.)*mp->mcube.cusize; |
| 207 | for (i = 0; i < 3; i++) |
| 208 | vp->v[i] = mp->mcube.cuorg[i] + |
| 209 | (pp->xyz[vid][i] + .5)*vres; |
| 210 | vp->fl |= MT_V; |
| 211 | } |
| 212 | /* get normal */ |
| 213 | if (what & MT_N && pp->norm != NULL && pp->norm[vid]) { |
| 214 | decodedir(vp->n, pp->norm[vid]); |
| 215 | vp->fl |= MT_N; |
| 216 | } |
| 217 | /* get (u,v) */ |
| 218 | if (what & MT_UV && pp->uv != NULL && pp->uv[vid][0]) { |
| 219 | for (i = 0; i < 2; i++) |
| 220 | vp->uv[i] = mp->uvlim[0][i] + |
| 221 | (mp->uvlim[1][i] - mp->uvlim[0][i])* |
| 222 | (pp->uv[vid][i] + .5)*(1./4294967296.); |
| 223 | vp->fl |= MT_UV; |
| 224 | } |
| 225 | return(vp->fl); |
| 226 | } |
| 227 |  |
| 228 |  |
| 229 | int |
| 230 | getmeshtri(tv, mp, ti, what)    /* get triangle vertices */ |
| 231 | MESHVERT        tv[3]; |
| 232 | MESH            *mp; |
| 233 | OBJECT          ti; |
| 234 | int             what; |
| 235 | { |
| 236 | int4    tvid[3]; |
| 237 |  |
| 238 | if (!getmeshtrivid(tvid, mp, ti)) |
| 239 | return(0); |
| 240 |  |
| 241 | getmeshvert(&tv[0], mp, tvid[0], what); |
| 242 | getmeshvert(&tv[1], mp, tvid[1], what); |
| 243 | getmeshvert(&tv[2], mp, tvid[2], what); |
| 244 |  |
| 245 | return(tv[0].fl & tv[1].fl & tv[2].fl); |
| 246 | } |
| 247 |  |
| 248 |  |
| 249 | int4 |
| 250 | addmeshvert(mp, vp)             /* find/add a mesh vertex */ |
| 251 | register MESH   *mp; |
| 252 | MESHVERT        *vp; |
| 253 | { |
| 254 | LUTAB           *ltp; |
| 255 | LUENT           *lvp; |
| 256 | MCVERT          cv; |
| 257 | register int    i; |
| 258 |  |
| 259 | if (!(vp->fl & MT_V)) |
| 260 | return(-1); |
| 261 | /* encode vertex */ |
| 262 | for (i = 0; i < 3; i++) { |
| 263 | if (vp->v[i] < mp->mcube.cuorg[i]) |
| 264 | return(-1); |
| 265 | if (vp->v[i] >= mp->mcube.cuorg[i] + mp->mcube.cusize) |
| 266 | return(-1); |
| 267 | cv.xyz[i] = (uint4)(4294967296. * |
| 268 | (vp->v[i] - mp->mcube.cuorg[i]) / |
| 269 | mp->mcube.cusize); |
| 270 | } |
| 271 | if (vp->fl & MT_N) |
| 272 | cv.norm = encodedir(vp->n); |
| 273 | if (vp->fl & MT_UV) |
| 274 | for (i = 0; i < 2; i++) { |
| 275 | if (vp->uv[i] <= mp->uvlim[0][i]) |
| 276 | return(-1); |
| 277 | if (vp->uv[i] >= mp->uvlim[1][i]) |
| 278 | return(-1); |
| 279 | cv.uv[i] = (uint4)(4294967296. * |
| 280 | (vp->uv[i] - mp->uvlim[0][i]) / |
| 281 | (mp->uvlim[1][i] - mp->uvlim[0][i])); |
| 282 | } |
| 283 | cv.fl = vp->fl; |
| 284 | ltp = (LUTAB *)mp->cdata;       /* get lookup table */ |
| 285 | if (ltp == NULL) { |
| 286 | ltp = (LUTAB *)calloc(1, sizeof(LUTAB)); |
| 287 | if (ltp == NULL) |
| 288 | goto nomem; |
| 289 | ltp->hashf = cvhash; |
| 290 | ltp->keycmp = cvcmp; |
| 291 | ltp->freek = free; |
| 292 | if (!lu_init(ltp, 50000)) |
| 293 | goto nomem; |
| 294 | mp->cdata = (char *)ltp; |
| 295 | } |
| 296 | /* find entry */ |
| 297 | lvp = lu_find(ltp, (char *)&cv); |
| 298 | if (lvp == NULL) |
| 299 | goto nomem; |
| 300 | if (lvp->key == NULL) { |
| 301 | lvp->key = (char *)malloc(sizeof(MCVERT)+sizeof(int4)); |
| 302 | bcopy((void *)&cv, (void *)lvp->key, sizeof(MCVERT)); |
| 303 | } |
| 304 | if (lvp->data == NULL) {        /* new vertex */ |
| 305 | register MESHPATCH      *pp; |
| 306 | if (mp->npatches <= 0) { |
| 307 | mp->patch = (MESHPATCH *)calloc(MPATCHBLKSIZ, |
| 308 | sizeof(MESHPATCH)); |
| 309 | if (mp->patch == NULL) |
| 310 | goto nomem; |
| 311 | mp->npatches = 1; |
| 312 | } else if (mp->patch[mp->npatches-1].nverts >= 256) { |
| 313 | if (mp->npatches % MPATCHBLKSIZ == 0) { |
| 314 | mp->patch = (MESHPATCH *)realloc( |
| 315 | (void *)mp->patch, |
| 316 | (mp->npatches + MPATCHBLKSIZ)* |
| 317 | sizeof(MESHPATCH)); |
| 318 | bzero((void *)(mp->patch + mp->npatches), |
| 319 | MPATCHBLKSIZ*sizeof(MESHPATCH)); |
| 320 | } |
| 321 | if (mp->npatches++ >= 1L<<22) |
| 322 | error(INTERNAL, "too many mesh patches"); |
| 323 | } |
| 324 | pp = &mp->patch[mp->npatches-1]; |
| 325 | if (pp->xyz == NULL) { |
| 326 | pp->xyz = (uint4 (*)[3])calloc(256, 3*sizeof(int4)); |
| 327 | if (pp->xyz == NULL) |
| 328 | goto nomem; |
| 329 | } |
| 330 | for (i = 0; i < 3; i++) |
| 331 | pp->xyz[pp->nverts][i] = cv.xyz[i]; |
| 332 | if (cv.fl & MT_N) { |
| 333 | if (pp->norm == NULL) { |
| 334 | pp->norm = (int4 *)calloc(256, sizeof(int4)); |
| 335 | if (pp->norm == NULL) |
| 336 | goto nomem; |
| 337 | } |
| 338 | pp->norm[pp->nverts] = cv.norm; |
| 339 | } |
| 340 | if (cv.fl & MT_UV) { |
| 341 | if (pp->uv == NULL) { |
| 342 | pp->uv = (uint4 (*)[2])calloc(256, |
| 343 | 2*sizeof(uint4)); |
| 344 | if (pp->uv == NULL) |
| 345 | goto nomem; |
| 346 | } |
| 347 | for (i = 0; i < 2; i++) |
| 348 | pp->uv[pp->nverts][i] = cv.uv[i]; |
| 349 | } |
| 350 | pp->nverts++; |
| 351 | lvp->data = lvp->key + sizeof(MCVERT); |
| 352 | *(int4 *)lvp->data = (mp->npatches-1) << 8 | (pp->nverts-1); |
| 353 | } |
| 354 | return(*(int4 *)lvp->data); |
| 355 | nomem: |
| 356 | error(SYSTEM, "out of memory in addmeshvert"); |
| 357 | return(-1); |
| 358 | } |
| 359 |  |
| 360 |  |
| 361 | OBJECT |
| 362 | addmeshtri(mp, tv)              /* add a new mesh triangle */ |
| 363 | MESH            *mp; |
| 364 | MESHVERT        tv[3]; |
| 365 | { |
| 366 | int4                    vid[3], t; |
| 367 | int                     pn[3], i; |
| 368 | register MESHPATCH      *pp; |
| 369 |  |
| 370 | if (!(tv[0].fl & tv[1].fl & tv[2].fl & MT_V)) |
| 371 | return(OVOID); |
| 372 | /* find/allocate patch vertices */ |
| 373 | for (i = 0; i < 3; i++) { |
| 374 | if ((vid[i] = addmeshvert(mp, &tv[i])) < 0) |
| 375 | return(OVOID); |
| 376 | pn[i] = vid[i] >> 8; |
| 377 | } |
| 378 | /* assign triangle */ |
| 379 | if (pn[0] == pn[1] && pn[1] == pn[2]) { /* local case */ |
| 380 | pp = &mp->patch[pn[0]]; |
| 381 | if (pp->tri == NULL) { |
| 382 | pp->tri = (struct PTri *)malloc( |
| 383 | 512*sizeof(struct PTri)); |
| 384 | if (pp->tri == NULL) |
| 385 | goto nomem; |
| 386 | } |
| 387 | if (pp->ntris < 512) { |
| 388 | pp->tri[pp->ntris].v1 = vid[0] & 0xff; |
| 389 | pp->tri[pp->ntris].v2 = vid[1] & 0xff; |
| 390 | pp->tri[pp->ntris].v3 = vid[2] & 0xff; |
| 391 | return(pn[0] << 10 | pp->ntris++); |
| 392 | } |
| 393 | } |
| 394 | if (pn[0] == pn[1]) { |
| 395 | t = vid[2]; vid[2] = vid[1]; vid[1] = vid[0]; vid[0] = t; |
| 396 | i = pn[2]; pn[2] = pn[1]; pn[1] = pn[0]; pn[0] = i; |
| 397 | } else if (pn[0] == pn[2]) { |
| 398 | t = vid[0]; vid[0] = vid[1]; vid[1] = vid[2]; vid[2] = t; |
| 399 | i = pn[0]; pn[0] = pn[1]; pn[1] = pn[2]; pn[2] = i; |
| 400 | } |
| 401 | if (pn[1] == pn[2]) {                   /* single link */ |
| 402 | pp = &mp->patch[pn[1]]; |
| 403 | if (pp->j1tri == NULL) { |
| 404 | pp->j1tri = (struct PJoin1 *)malloc( |
| 405 | 256*sizeof(struct PJoin1)); |
| 406 | if (pp->j1tri == NULL) |
| 407 | goto nomem; |
| 408 | } |
| 409 | if (pp->nj1tris < 256) { |
| 410 | pp->j1tri[pp->nj1tris].v1j = vid[0]; |
| 411 | pp->j1tri[pp->nj1tris].v2 = vid[1] & 0xff; |
| 412 | pp->j1tri[pp->nj1tris].v3 = vid[2] & 0xff; |
| 413 | return(pn[1] << 10 | 0x200 | pp->nj1tris++); |
| 414 | } |
| 415 | } |
| 416 | /* double link */ |
| 417 | pp = &mp->patch[pn[2]]; |
| 418 | if (pp->j2tri == NULL) { |
| 419 | pp->j2tri = (struct PJoin2 *)malloc( |
| 420 | 256*sizeof(struct PJoin2)); |
| 421 | if (pp->j2tri == NULL) |
| 422 | goto nomem; |
| 423 | } |
| 424 | if (pp->nj2tris >= 256) |
| 425 | error(INTERNAL, "too many patch triangles in addmeshtri"); |
| 426 | pp->j2tri[pp->nj2tris].v1j = vid[0]; |
| 427 | pp->j2tri[pp->nj2tris].v2j = vid[1]; |
| 428 | pp->j2tri[pp->nj2tris].v3 = vid[2] & 0xff; |
| 429 | return(pn[2] << 10 | 0x300 | pp->nj2tris++); |
| 430 | nomem: |
| 431 | error(SYSTEM, "out of memory in addmeshtri"); |
| 432 | return(OVOID); |
| 433 | } |
| 434 |  |
| 435 |  |
| 436 | static void |
| 437 | tallyoctree(ot, ecp, lcp, ocp)  /* tally octree size */ |
| 438 | OCTREE  ot; |
| 439 | int     *ecp, *lcp, *ocp; |
| 440 | { |
| 441 | int     i; |
| 442 |  |
| 443 | if (isempty(ot)) { |
| 444 | (*ecp)++; |
| 445 | return; |
| 446 | } |
| 447 | if (isfull(ot)) { |
| 448 | OBJECT  oset[MAXSET+1]; |
| 449 | (*lcp)++; |
| 450 | objset(oset, ot); |
| 451 | *ocp += oset[0]; |
| 452 | return; |
| 453 | } |
| 454 | for (i = 0; i < 8; i++) |
| 455 | tallyoctree(octkid(ot, i), ecp, lcp, ocp); |
| 456 | } |
| 457 |  |
| 458 |  |
| 459 | void |
| 460 | printmeshstats(ms, fp)          /* print out mesh statistics */ |
| 461 | MESH    *ms; |
| 462 | FILE    *fp; |
| 463 | { |
| 464 | int     lfcnt=0, lecnt=0, locnt=0; |
| 465 | int     vcnt=0, ncnt=0, uvcnt=0; |
| 466 | int     nscnt=0, uvscnt=0; |
| 467 | int     tcnt=0, t1cnt=0, t2cnt=0; |
| 468 | int     i, j; |
| 469 |  |
| 470 | tallyoctree(ms->mcube.cutree, &lecnt, &lfcnt, &locnt); |
| 471 | for (i = 0; i < ms->npatches; i++) { |
| 472 | register MESHPATCH      *pp = &ms->patch[i]; |
| 473 | vcnt += pp->nverts; |
| 474 | if (pp->norm != NULL) { |
| 475 | for (j = pp->nverts; j--; ) |
| 476 | if (pp->norm[j]) |
| 477 | ncnt++; |
| 478 | nscnt += pp->nverts; |
| 479 | } |
| 480 | if (pp->uv != NULL) { |
| 481 | for (j = pp->nverts; j--; ) |
| 482 | if (pp->uv[j][0]) |
| 483 | uvcnt++; |
| 484 | uvscnt += pp->nverts; |
| 485 | } |
| 486 | tcnt += pp->ntris; |
| 487 | t1cnt += pp->nj1tris; |
| 488 | t2cnt += pp->nj2tris; |
| 489 | } |
| 490 | fprintf(fp, "Mesh statistics:\n"); |
| 491 | fprintf(fp, "\t%d patches (%.2f MBytes)\n", ms->npatches, |
| 492 | (ms->npatches*sizeof(MESHPATCH) + |
| 493 | vcnt*3*sizeof(uint4) + |
| 494 | nscnt*sizeof(int4) + |
| 495 | uvscnt*2*sizeof(uint4) + |
| 496 | tcnt*sizeof(struct PTri) + |
| 497 | t1cnt*sizeof(struct PJoin1) + |
| 498 | t2cnt*sizeof(struct PJoin2))/(1024.*1024.)); |
| 499 | fprintf(fp, "\t%d vertices (%.1f%% w/ normals, %.1f%% w/ uv)\n", |
| 500 | vcnt, 100.*ncnt/vcnt, 100.*uvcnt/vcnt); |
| 501 | fprintf(fp, "\t%d triangles (%.1f%% local, %.1f%% joiner)\n", |
| 502 | tcnt+t1cnt+t2cnt, |
| 503 | 100.*tcnt/(tcnt+t1cnt+t2cnt), |
| 504 | 100.*t1cnt/(tcnt+t1cnt+t2cnt)); |
| 505 | fprintf(fp, |
| 506 | "\t%d leaves in octree (%.1f%% empty, %.2f avg. set size)\n", |
| 507 | lfcnt+lecnt, 100.*lecnt/(lfcnt+lecnt), |
| 508 | (double)locnt/lfcnt); |
| 509 | } |
| 510 |  |
| 511 |  |
| 512 | void |
| 513 | freemesh(ms)                    /* free mesh data */ |
| 514 | MESH    *ms; |
| 515 | { |
| 516 | MESH    mhead; |
| 517 | MESH    *msp; |
| 518 |  |
| 519 | if (ms == NULL) |
| 520 | return; |
| 521 | if (ms->nref <= 0) |
| 522 | error(CONSISTENCY, "unreferenced mesh in freemesh"); |
| 523 | ms->nref--; |
| 524 | if (ms->nref)           /* still in use */ |
| 525 | return; |
| 526 | /* else remove from list */ |
| 527 | mhead.next = mlist; |
| 528 | for (msp = &mhead; msp->next != NULL; msp = msp->next) |
| 529 | if (msp->next == ms) { |
| 530 | msp->next = ms->next; |
| 531 | ms->next = NULL; |
| 532 | break; |
| 533 | } |
| 534 | if (ms->next != NULL)   /* can't be in list anymore */ |
| 535 | error(CONSISTENCY, "unlisted mesh in freemesh"); |
| 536 | mlist = mhead.next; |
| 537 | /* free mesh data */ |
| 538 | freestr(ms->name); |
| 539 | octfree(ms->mcube.cutree); |
| 540 | if (ms->cdata != NULL) |
| 541 | lu_done((LUTAB *)ms->cdata); |
| 542 | if (ms->npatches > 0) { |
| 543 | register MESHPATCH      *pp = ms->patch + ms->npatches; |
| 544 | while (pp-- > ms->patch) { |
| 545 | if (pp->j2tri != NULL) |
| 546 | free((void *)pp->j2tri); |
| 547 | if (pp->j1tri != NULL) |
| 548 | free((void *)pp->j1tri); |
| 549 | if (pp->tri != NULL) |
| 550 | free((void *)pp->tri); |
| 551 | if (pp->uv != NULL) |
| 552 | free((void *)pp->uv); |
| 553 | if (pp->norm != NULL) |
| 554 | free((void *)pp->norm); |
| 555 | if (pp->xyz != NULL) |
| 556 | free((void *)pp->xyz); |
| 557 | } |
| 558 | free((void *)ms->patch); |
| 559 | } |
| 560 | free((void *)ms); |
| 561 | } |
| 562 |  |
| 563 |  |
| 564 | void |
| 565 | freemeshinst(o)                 /* free mesh instance */ |
| 566 | OBJREC  *o; |
| 567 | { |
| 568 | if (o->os == NULL) |
| 569 | return; |
| 570 | freemesh((*(MESHINST *)o->os).msh); |
| 571 | free((void *)o->os); |
| 572 | o->os = NULL; |
| 573 | } |
