1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: mesh.c,v 2.23 2011/02/18 00:40:25 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Mesh support routines |
6 |
7 |
8 |
#include <string.h> |
9 |
10 |
#include "rtio.h" |
11 |
#include "rtmath.h" |
12 |
#include "rterror.h" |
13 |
#include "paths.h" |
14 |
#include "octree.h" |
15 |
#include "object.h" |
16 |
#include "otypes.h" |
17 |
#include "mesh.h" |
18 |
19 |
/* An encoded mesh vertex */ |
20 |
typedef struct { |
21 |
int fl; |
22 |
uint32 xyz[3]; |
23 |
int32 norm; |
24 |
uint32 uv[2]; |
25 |
} MCVERT; |
26 |
27 |
#define MPATCHBLKSIZ 128 /* patch allocation block size */ |
28 |
29 |
#define IO_LEGAL (IO_BOUNDS|IO_TREE|IO_SCENE) |
30 |
31 |
static MESH *mlist = NULL; /* list of loaded meshes */ |
32 |
33 |
34 |
static unsigned long |
35 |
cvhash(const char *p) /* hash an encoded vertex */ |
36 |
37 |
const MCVERT *cvp = (const MCVERT *)p; |
38 |
unsigned long hval; |
39 |
40 |
if (!(cvp->fl & MT_V)) |
41 |
return(0); |
42 |
hval = cvp->xyz[0] ^ cvp->xyz[1] << 11 ^ cvp->xyz[2] << 22; |
43 |
if (cvp->fl & MT_N) |
44 |
hval ^= cvp->norm; |
45 |
if (cvp->fl & MT_UV) |
46 |
hval ^= cvp->uv[0] ^ cvp->uv[1] << 16; |
47 |
return(hval); |
48 |
49 |
50 |
51 |
static int |
52 |
cvcmp(const char *vv1, const char *vv2) /* compare encoded vertices */ |
53 |
54 |
const MCVERT *v1 = (const MCVERT *)vv1, *v2 = (const MCVERT *)vv2; |
55 |
if (v1->fl != v2->fl) |
56 |
return(1); |
57 |
if (v1->xyz[0] != v2->xyz[0]) |
58 |
return(1); |
59 |
if (v1->xyz[1] != v2->xyz[1]) |
60 |
return(1); |
61 |
if (v1->xyz[2] != v2->xyz[2]) |
62 |
return(1); |
63 |
if (v1->fl & MT_N && v1->norm != v2->norm) |
64 |
return(1); |
65 |
if (v1->fl & MT_UV) { |
66 |
if (v1->uv[0] != v2->uv[0]) |
67 |
return(1); |
68 |
if (v1->uv[1] != v2->uv[1]) |
69 |
return(1); |
70 |
71 |
return(0); |
72 |
73 |
74 |
75 |
MESH * |
76 |
getmesh( /* get new mesh data reference */ |
77 |
char *mname, |
78 |
int flags |
79 |
80 |
81 |
char *pathname; |
82 |
MESH *ms; |
83 |
84 |
flags &= IO_LEGAL; |
85 |
for (ms = mlist; ms != NULL; ms = ms->next) |
86 |
if (!strcmp(mname, ms->name)) { |
87 |
ms->nref++; /* increase reference count */ |
88 |
break; |
89 |
90 |
if (ms == NULL) { /* load first time */ |
91 |
ms = (MESH *)calloc(1, sizeof(MESH)); |
92 |
if (ms == NULL) |
93 |
error(SYSTEM, "out of memory in getmesh"); |
94 |
ms->name = savestr(mname); |
95 |
ms->nref = 1; |
96 |
ms->mcube.cutree = EMPTY; |
97 |
ms->next = mlist; |
98 |
mlist = ms; |
99 |
100 |
if ((pathname = getpath(mname, getrlibpath(), R_OK)) == NULL) { |
101 |
sprintf(errmsg, "cannot find mesh file \"%s\"", mname); |
102 |
error(USER, errmsg); |
103 |
104 |
flags &= ~ms->ldflags; |
105 |
if (flags) |
106 |
readmesh(ms, pathname, flags); |
107 |
return(ms); |
108 |
109 |
110 |
111 |
MESHINST * |
112 |
getmeshinst( /* create mesh instance */ |
113 |
OBJREC *o, |
114 |
int flags |
115 |
116 |
117 |
MESHINST *ins; |
118 |
119 |
120 |
if ((ins = (MESHINST *)o->os) == NULL) { |
121 |
if ((ins = (MESHINST *)malloc(sizeof(MESHINST))) == NULL) |
122 |
error(SYSTEM, "out of memory in getmeshinst"); |
123 |
if (o->oargs.nsargs < 1) |
124 |
objerror(o, USER, "bad # of arguments"); |
125 |
if (fullxf(&ins->x, o->oargs.nsargs-1, |
126 |
o->oargs.sarg+1) != o->oargs.nsargs-1) |
127 |
objerror(o, USER, "bad transform"); |
128 |
if (ins->x.f.sca < 0.0) { |
129 |
ins->x.f.sca = -ins->x.f.sca; |
130 |
ins->x.b.sca = -ins->x.b.sca; |
131 |
132 |
ins->msh = NULL; |
133 |
o->os = (char *)ins; |
134 |
135 |
if (ins->msh == NULL) |
136 |
ins->msh = getmesh(o->oargs.sarg[0], flags); |
137 |
else if ((flags &= ~ins->msh->ldflags)) |
138 |
readmesh(ins->msh, |
139 |
getpath(o->oargs.sarg[0], getrlibpath(), R_OK), |
140 |
flags); |
141 |
return(ins); |
142 |
143 |
144 |
145 |
int |
146 |
nextmeshtri( /* get next triangle ID */ |
147 |
OBJECT *tip, |
148 |
MESH *mp |
149 |
150 |
151 |
int pn; |
152 |
MESHPATCH *pp; |
153 |
154 |
if (*tip == OVOID) { /* check for first index */ |
155 |
*tip = 0; |
156 |
return(mp->npatches > 0); /* assumes 1 local triangle */ |
157 |
158 |
pn = *tip >> 10; |
159 |
if (pn >= mp->npatches) /* past end? */ |
160 |
return(0); |
161 |
pp = &mp->patch[pn]; |
162 |
if (!(*tip & 0x200)) { /* local triangle? */ |
163 |
if ((*tip & 0x1ff) < pp->ntris-1) { |
164 |
++*tip; |
165 |
return(1); |
166 |
167 |
*tip &= ~0x1ff; /* move on to single-joiners */ |
168 |
*tip |= 0x200; |
169 |
if (pp->nj1tris) /* is there at least one? */ |
170 |
return(1); |
171 |
172 |
if (!(*tip & 0x100)) { /* single joiner? */ |
173 |
if ((*tip & 0xff) < pp->nj1tris-1) { |
174 |
++*tip; |
175 |
return(1); |
176 |
177 |
*tip &= ~0xff; /* move on to double-joiners */ |
178 |
*tip |= 0x100; |
179 |
if (pp->nj2tris) /* is there one? */ |
180 |
return(1); |
181 |
182 |
if ((*tip & 0xff) < pp->nj2tris-1) { /* double-joiner? */ |
183 |
++*tip; |
184 |
return(1); |
185 |
186 |
*tip = ++pn << 10; /* first in next patch */ |
187 |
return(pn < mp->npatches); |
188 |
189 |
190 |
int |
191 |
getmeshtrivid( /* get triangle vertex ID's */ |
192 |
int32 tvid[3], |
193 |
OBJECT *mo, |
194 |
MESH *mp, |
195 |
OBJECT ti |
196 |
197 |
198 |
int pn = ti >> 10; |
199 |
MESHPATCH *pp; |
200 |
201 |
if (pn >= mp->npatches) |
202 |
return(0); |
203 |
204 |
ti &= 0x3ff; |
205 |
if (!(ti & 0x200)) { /* local triangle */ |
206 |
struct PTri *tp; |
207 |
if (ti >= pp->ntris) |
208 |
return(0); |
209 |
tp = &pp->tri[ti]; |
210 |
tvid[0] = tvid[1] = tvid[2] = pn << 8; |
211 |
tvid[0] |= tp->v1; |
212 |
tvid[1] |= tp->v2; |
213 |
tvid[2] |= tp->v3; |
214 |
if (pp->trimat != NULL) |
215 |
*mo = pp->trimat[ti]; |
216 |
else |
217 |
*mo = pp->solemat; |
218 |
if (*mo != OVOID) |
219 |
*mo += mp->mat0; |
220 |
return(1); |
221 |
222 |
ti &= ~0x200; |
223 |
if (!(ti & 0x100)) { /* single link vertex */ |
224 |
struct PJoin1 *tp1; |
225 |
if (ti >= pp->nj1tris) |
226 |
return(0); |
227 |
tp1 = &pp->j1tri[ti]; |
228 |
tvid[0] = tp1->v1j; |
229 |
230 |
tvid[1] |= tp1->v2; |
231 |
tvid[2] |= tp1->v3; |
232 |
if ((*mo = tp1->mat) != OVOID) |
233 |
*mo += mp->mat0; |
234 |
return(1); |
235 |
236 |
ti &= ~0x100; |
237 |
{ /* double link vertex */ |
238 |
struct PJoin2 *tp2; |
239 |
if (ti >= pp->nj2tris) |
240 |
return(0); |
241 |
tp2 = &pp->j2tri[ti]; |
242 |
tvid[0] = tp2->v1j; |
243 |
tvid[1] = tp2->v2j; |
244 |
tvid[2] = pn << 8 | tp2->v3; |
245 |
if ((*mo = tp2->mat) != OVOID) |
246 |
*mo += mp->mat0; |
247 |
248 |
return(1); |
249 |
250 |
251 |
252 |
int |
253 |
getmeshvert( /* get triangle vertex from ID */ |
254 |
MESHVERT *vp, |
255 |
MESH *mp, |
256 |
int32 vid, |
257 |
int what |
258 |
259 |
260 |
int pn = vid >> 8; |
261 |
MESHPATCH *pp; |
262 |
double vres; |
263 |
int i; |
264 |
265 |
vp->fl = 0; |
266 |
267 |
return(0); |
268 |
269 |
vid &= 0xff; |
270 |
if (vid >= pp->nverts) |
271 |
return(0); |
272 |
/* get location */ |
273 |
if (what & MT_V) { |
274 |
vres = (1./4294967296.)*mp->mcube.cusize; |
275 |
for (i = 0; i < 3; i++) |
276 |
vp->v[i] = mp->mcube.cuorg[i] + |
277 |
(pp->xyz[vid][i] + .5)*vres; |
278 |
vp->fl |= MT_V; |
279 |
280 |
/* get normal */ |
281 |
if (what & MT_N && pp->norm != NULL && pp->norm[vid]) { |
282 |
decodedir(vp->n, pp->norm[vid]); |
283 |
vp->fl |= MT_N; |
284 |
285 |
/* get (u,v) */ |
286 |
if (what & MT_UV && pp->uv != NULL && pp->uv[vid][0]) { |
287 |
for (i = 0; i < 2; i++) |
288 |
vp->uv[i] = mp->uvlim[0][i] + |
289 |
(mp->uvlim[1][i] - mp->uvlim[0][i])* |
290 |
(pp->uv[vid][i] + .5)*(1./4294967296.); |
291 |
vp->fl |= MT_UV; |
292 |
293 |
return(vp->fl); |
294 |
295 |
296 |
297 |
OBJREC * |
298 |
getmeshpseudo( /* get mesh pseudo object for material */ |
299 |
MESH *mp, |
300 |
OBJECT mo |
301 |
302 |
303 |
if (mo < mp->mat0 || mo >= mp->mat0 + mp->nmats) |
304 |
error(INTERNAL, "modifier out of range in getmeshpseudo"); |
305 |
if (mp->pseudo == NULL) { |
306 |
int i; |
307 |
mp->pseudo = (OBJREC *)calloc(mp->nmats, sizeof(OBJREC)); |
308 |
if (mp->pseudo == NULL) |
309 |
error(SYSTEM, "out of memory in getmeshpseudo"); |
310 |
for (i = mp->nmats; i--; ) { |
311 |
mp->pseudo[i].omod = mp->mat0 + i; |
312 |
mp->pseudo[i].otype = OBJ_FACE; |
313 |
mp->pseudo[i].oname = "M-Tri"; |
314 |
315 |
316 |
return(&mp->pseudo[mo - mp->mat0]); |
317 |
318 |
319 |
320 |
int |
321 |
getmeshtri( /* get triangle vertices */ |
322 |
MESHVERT tv[3], |
323 |
OBJECT *mo, |
324 |
MESH *mp, |
325 |
OBJECT ti, |
326 |
int wha |
327 |
328 |
329 |
int32 tvid[3]; |
330 |
331 |
if (!getmeshtrivid(tvid, mo, mp, ti)) |
332 |
return(0); |
333 |
334 |
getmeshvert(&tv[0], mp, tvid[0], wha); |
335 |
getmeshvert(&tv[1], mp, tvid[1], wha); |
336 |
getmeshvert(&tv[2], mp, tvid[2], wha); |
337 |
338 |
return(tv[0].fl & tv[1].fl & tv[2].fl); |
339 |
340 |
341 |
342 |
int32 |
343 |
addmeshvert( /* find/add a mesh vertex */ |
344 |
MESH *mp, |
345 |
MESHVERT *vp |
346 |
347 |
348 |
LUENT *lvp; |
349 |
MCVERT cv; |
350 |
int i; |
351 |
352 |
if (!(vp->fl & MT_V)) |
353 |
return(-1); |
354 |
/* encode vertex */ |
355 |
for (i = 0; i < 3; i++) { |
356 |
if (vp->v[i] < mp->mcube.cuorg[i]) |
357 |
return(-1); |
358 |
if (vp->v[i] >= mp->mcube.cuorg[i] + mp->mcube.cusize) |
359 |
return(-1); |
360 |
cv.xyz[i] = (uint32)(4294967296. * |
361 |
(vp->v[i] - mp->mcube.cuorg[i]) / |
362 |
mp->mcube.cusize); |
363 |
364 |
if (vp->fl & MT_N) /* assumes normalized! */ |
365 |
cv.norm = encodedir(vp->n); |
366 |
if (vp->fl & MT_UV) |
367 |
for (i = 0; i < 2; i++) { |
368 |
if (vp->uv[i] <= mp->uvlim[0][i]) |
369 |
return(-1); |
370 |
if (vp->uv[i] >= mp->uvlim[1][i]) |
371 |
return(-1); |
372 |
cv.uv[i] = (uint32)(4294967296. * |
373 |
(vp->uv[i] - mp->uvlim[0][i]) / |
374 |
(mp->uvlim[1][i] - mp->uvlim[0][i])); |
375 |
376 |
cv.fl = vp->fl; |
377 |
if (mp->lut.tsiz == 0) { |
378 |
mp->lut.hashf = cvhash; |
379 |
mp->lut.keycmp = cvcmp; |
380 |
mp->lut.freek = free; |
381 |
if (!lu_init(&mp->lut, 50000)) |
382 |
goto nomem; |
383 |
384 |
/* find entry */ |
385 |
lvp = lu_find(&mp->lut, (char *)&cv); |
386 |
if (lvp == NULL) |
387 |
goto nomem; |
388 |
if (lvp->key == NULL) { |
389 |
lvp->key = (char *)malloc(sizeof(MCVERT)+sizeof(int32)); |
390 |
memcpy((void *)lvp->key, (void *)&cv, sizeof(MCVERT)); |
391 |
392 |
if (lvp->data == NULL) { /* new vertex */ |
393 |
MESHPATCH *pp; |
394 |
if (mp->npatches <= 0) { |
395 |
mp->patch = (MESHPATCH *)calloc(MPATCHBLKSIZ, |
396 |
sizeof(MESHPATCH)); |
397 |
if (mp->patch == NULL) |
398 |
goto nomem; |
399 |
mp->npatches = 1; |
400 |
} else if (mp->patch[mp->npatches-1].nverts >= 256) { |
401 |
if (mp->npatches % MPATCHBLKSIZ == 0) { |
402 |
mp->patch = (MESHPATCH *)realloc( |
403 |
(void *)mp->patch, |
404 |
(mp->npatches + MPATCHBLKSIZ)* |
405 |
406 |
memset((void *)(mp->patch + mp->npatches), '\0', |
407 |
MPATCHBLKSIZ*sizeof(MESHPATCH)); |
408 |
409 |
if (mp->npatches++ >= 1L<<22) |
410 |
error(INTERNAL, "too many mesh patches"); |
411 |
412 |
pp = &mp->patch[mp->npatches-1]; |
413 |
if (pp->xyz == NULL) { |
414 |
pp->xyz = (uint32 (*)[3])calloc(256, 3*sizeof(int32)); |
415 |
if (pp->xyz == NULL) |
416 |
goto nomem; |
417 |
418 |
419 |
pp->xyz[pp->nverts][i] = cv.xyz[i]; |
420 |
if (cv.fl & MT_N) { |
421 |
if (pp->norm == NULL) { |
422 |
pp->norm = (int32 *)calloc(256, sizeof(int32)); |
423 |
if (pp->norm == NULL) |
424 |
goto nomem; |
425 |
426 |
pp->norm[pp->nverts] = cv.norm; |
427 |
428 |
if (cv.fl & MT_UV) { |
429 |
if (pp->uv == NULL) { |
430 |
pp->uv = (uint32 (*)[2])calloc(256, |
431 |
2*sizeof(uint32)); |
432 |
if (pp->uv == NULL) |
433 |
goto nomem; |
434 |
435 |
436 |
pp->uv[pp->nverts][i] = cv.uv[i]; |
437 |
438 |
pp->nverts++; |
439 |
lvp->data = lvp->key + sizeof(MCVERT); |
440 |
*(int32 *)lvp->data = (mp->npatches-1) << 8 | (pp->nverts-1); |
441 |
442 |
return(*(int32 *)lvp->data); |
443 |
nomem: |
444 |
error(SYSTEM, "out of memory in addmeshvert"); |
445 |
return(-1); |
446 |
447 |
448 |
449 |
OBJECT |
450 |
addmeshtri( /* add a new mesh triangle */ |
451 |
MESH *mp, |
452 |
MESHVERT tv[3], |
453 |
OBJECT mo |
454 |
455 |
456 |
int32 vid[3], t; |
457 |
int pn[3], i; |
458 |
MESHPATCH *pp; |
459 |
460 |
if (!(tv[0].fl & tv[1].fl & tv[2].fl & MT_V)) |
461 |
return(OVOID); |
462 |
/* find/allocate patch vertices */ |
463 |
464 |
if ((vid[i] = addmeshvert(mp, &tv[i])) < 0) |
465 |
return(OVOID); |
466 |
pn[i] = vid[i] >> 8; |
467 |
468 |
/* normalize material index */ |
469 |
if (mo != OVOID) { |
470 |
if ((mo -= mp->mat0) >= mp->nmats) |
471 |
mp->nmats = mo+1; |
472 |
else if (mo < 0) |
473 |
error(INTERNAL, "modifier range error in addmeshtri"); |
474 |
475 |
/* assign triangle */ |
476 |
if (pn[0] == pn[1] && pn[1] == pn[2]) { /* local case */ |
477 |
pp = &mp->patch[pn[0]]; |
478 |
if (pp->tri == NULL) { |
479 |
pp->tri = (struct PTri *)malloc( |
480 |
512*sizeof(struct PTri)); |
481 |
if (pp->tri == NULL) |
482 |
goto nomem; |
483 |
484 |
if (pp->ntris < 512) { |
485 |
pp->tri[pp->ntris].v1 = vid[0] & 0xff; |
486 |
pp->tri[pp->ntris].v2 = vid[1] & 0xff; |
487 |
pp->tri[pp->ntris].v3 = vid[2] & 0xff; |
488 |
if (pp->ntris == 0) |
489 |
pp->solemat = mo; |
490 |
else if (pp->trimat == NULL && mo != pp->solemat) { |
491 |
pp->trimat = (int16 *)malloc( |
492 |
512*sizeof(int16)); |
493 |
if (pp->trimat == NULL) |
494 |
goto nomem; |
495 |
for (i = pp->ntris; i--; ) |
496 |
pp->trimat[i] = pp->solemat; |
497 |
498 |
499 |
pp->trimat[pp->ntris] = mo; |
500 |
return(pn[0] << 10 | pp->ntris++); |
501 |
502 |
503 |
if (pn[0] == pn[1]) { |
504 |
t = vid[2]; vid[2] = vid[1]; vid[1] = vid[0]; vid[0] = t; |
505 |
i = pn[2]; pn[2] = pn[1]; pn[1] = pn[0]; pn[0] = i; |
506 |
} else if (pn[0] == pn[2]) { |
507 |
t = vid[0]; vid[0] = vid[1]; vid[1] = vid[2]; vid[2] = t; |
508 |
i = pn[0]; pn[0] = pn[1]; pn[1] = pn[2]; pn[2] = i; |
509 |
510 |
if (pn[1] == pn[2]) { /* single link */ |
511 |
pp = &mp->patch[pn[1]]; |
512 |
if (pp->j1tri == NULL) { |
513 |
pp->j1tri = (struct PJoin1 *)malloc( |
514 |
256*sizeof(struct PJoin1)); |
515 |
if (pp->j1tri == NULL) |
516 |
goto nomem; |
517 |
518 |
if (pp->nj1tris < 256) { |
519 |
pp->j1tri[pp->nj1tris].v1j = vid[0]; |
520 |
pp->j1tri[pp->nj1tris].v2 = vid[1] & 0xff; |
521 |
pp->j1tri[pp->nj1tris].v3 = vid[2] & 0xff; |
522 |
pp->j1tri[pp->nj1tris].mat = mo; |
523 |
return(pn[1] << 10 | 0x200 | pp->nj1tris++); |
524 |
525 |
526 |
/* double link */ |
527 |
pp = &mp->patch[pn[2]]; |
528 |
if (pp->j2tri == NULL) { |
529 |
pp->j2tri = (struct PJoin2 *)malloc( |
530 |
256*sizeof(struct PJoin2)); |
531 |
if (pp->j2tri == NULL) |
532 |
goto nomem; |
533 |
534 |
if (pp->nj2tris >= 256) |
535 |
error(INTERNAL, "too many patch triangles in addmeshtri"); |
536 |
pp->j2tri[pp->nj2tris].v1j = vid[0]; |
537 |
pp->j2tri[pp->nj2tris].v2j = vid[1]; |
538 |
pp->j2tri[pp->nj2tris].v3 = vid[2] & 0xff; |
539 |
pp->j2tri[pp->nj2tris].mat = mo; |
540 |
return(pn[2] << 10 | 0x300 | pp->nj2tris++); |
541 |
nomem: |
542 |
error(SYSTEM, "out of memory in addmeshtri"); |
543 |
return(OVOID); |
544 |
545 |
546 |
547 |
char * |
548 |
checkmesh(MESH *mp) /* validate mesh data */ |
549 |
550 |
static char embuf[128]; |
551 |
int nouvbounds = 1; |
552 |
int i; |
553 |
/* basic checks */ |
554 |
if (mp == NULL) |
555 |
return("NULL mesh pointer"); |
556 |
if (!mp->ldflags) |
557 |
return("unassigned mesh"); |
558 |
if (mp->name == NULL) |
559 |
return("missing mesh name"); |
560 |
if (mp->nref <= 0) |
561 |
return("unreferenced mesh"); |
562 |
/* check boundaries */ |
563 |
if (mp->ldflags & IO_BOUNDS) { |
564 |
if (mp->mcube.cusize <= FTINY) |
565 |
return("illegal octree bounds in mesh"); |
566 |
nouvbounds = (mp->uvlim[1][0] - mp->uvlim[0][0] <= FTINY || |
567 |
mp->uvlim[1][1] - mp->uvlim[0][1] <= FTINY); |
568 |
569 |
/* check octree */ |
570 |
if (mp->ldflags & IO_TREE) { |
571 |
if (isempty(mp->mcube.cutree)) |
572 |
error(WARNING, "empty mesh octree"); |
573 |
574 |
/* check scene data */ |
575 |
if (mp->ldflags & IO_SCENE) { |
576 |
if (!(mp->ldflags & IO_BOUNDS)) |
577 |
return("unbounded scene in mesh"); |
578 |
if (mp->mat0 < 0 || mp->mat0+mp->nmats > nobjects) |
579 |
return("bad mesh modifier range"); |
580 |
for (i = mp->mat0+mp->nmats; i-- > mp->mat0; ) { |
581 |
int otyp = objptr(i)->otype; |
582 |
if (!ismodifier(otyp)) { |
583 |
sprintf(embuf, |
584 |
"non-modifier in mesh (%s \"%s\")", |
585 |
ofun[otyp].funame, objptr(i)->oname); |
586 |
return(embuf); |
587 |
588 |
589 |
if (mp->npatches <= 0) |
590 |
error(WARNING, "no patches in mesh"); |
591 |
for (i = 0; i < mp->npatches; i++) { |
592 |
MESHPATCH *pp = &mp->patch[i]; |
593 |
if (pp->nverts <= 0) |
594 |
error(WARNING, "no vertices in patch"); |
595 |
else { |
596 |
597 |
return("missing patch vertex list"); |
598 |
if (nouvbounds && pp->uv != NULL) |
599 |
return("unreferenced uv coordinates"); |
600 |
601 |
if (pp->ntris > 0 && pp->tri == NULL) |
602 |
return("missing patch triangle list"); |
603 |
if (pp->nj1tris > 0 && pp->j1tri == NULL) |
604 |
return("missing patch joiner triangle list"); |
605 |
if (pp->nj2tris > 0 && pp->j2tri == NULL) |
606 |
return("missing patch double-joiner list"); |
607 |
608 |
609 |
return(NULL); /* seems OK */ |
610 |
611 |
612 |
613 |
static void |
614 |
tallyoctree( /* tally octree size */ |
615 |
OCTREE ot, |
616 |
int *ecp, |
617 |
int *lcp, |
618 |
int *ocp |
619 |
620 |
621 |
int i; |
622 |
623 |
if (isempty(ot)) { |
624 |
(*ecp)++; |
625 |
return; |
626 |
627 |
if (isfull(ot)) { |
628 |
OBJECT oset[MAXSET+1]; |
629 |
(*lcp)++; |
630 |
objset(oset, ot); |
631 |
*ocp += oset[0]; |
632 |
return; |
633 |
634 |
for (i = 0; i < 8; i++) |
635 |
tallyoctree(octkid(ot, i), ecp, lcp, ocp); |
636 |
637 |
638 |
639 |
void |
640 |
printmeshstats( /* print out mesh statistics */ |
641 |
MESH *ms, |
642 |
FILE *fp |
643 |
644 |
645 |
int lfcnt=0, lecnt=0, locnt=0; |
646 |
int vcnt=0, ncnt=0, uvcnt=0; |
647 |
int nscnt=0, uvscnt=0; |
648 |
int tcnt=0, t1cnt=0, t2cnt=0; |
649 |
int i, j; |
650 |
651 |
tallyoctree(ms->mcube.cutree, &lecnt, &lfcnt, &locnt); |
652 |
for (i = 0; i < ms->npatches; i++) { |
653 |
MESHPATCH *pp = &ms->patch[i]; |
654 |
vcnt += pp->nverts; |
655 |
if (pp->norm != NULL) { |
656 |
for (j = pp->nverts; j--; ) |
657 |
if (pp->norm[j]) |
658 |
ncnt++; |
659 |
nscnt += pp->nverts; |
660 |
661 |
if (pp->uv != NULL) { |
662 |
663 |
if (pp->uv[j][0]) |
664 |
uvcnt++; |
665 |
uvscnt += pp->nverts; |
666 |
667 |
tcnt += pp->ntris; |
668 |
t1cnt += pp->nj1tris; |
669 |
t2cnt += pp->nj2tris; |
670 |
671 |
fprintf(fp, "Mesh statistics:\n"); |
672 |
fprintf(fp, "\t%ld materials\n", (long)ms->nmats); |
673 |
fprintf(fp, "\t%d patches (%.2f MBytes)\n", ms->npatches, |
674 |
(ms->npatches*sizeof(MESHPATCH) + |
675 |
vcnt*3*sizeof(uint32) + |
676 |
nscnt*sizeof(int32) + |
677 |
uvscnt*2*sizeof(uint32) + |
678 |
tcnt*sizeof(struct PTri) + |
679 |
t1cnt*sizeof(struct PJoin1) + |
680 |
t2cnt*sizeof(struct PJoin2))/(1024.*1024.)); |
681 |
fprintf(fp, "\t%d vertices (%.1f%% w/ normals, %.1f%% w/ uv)\n", |
682 |
vcnt, 100.*ncnt/vcnt, 100.*uvcnt/vcnt); |
683 |
fprintf(fp, "\t%d triangles (%.1f%% local, %.1f%% joiner)\n", |
684 |
tcnt+t1cnt+t2cnt, |
685 |
100.*tcnt/(tcnt+t1cnt+t2cnt), |
686 |
100.*t1cnt/(tcnt+t1cnt+t2cnt)); |
687 |
fprintf(fp, |
688 |
"\t%d leaves in octree (%.1f%% empty, %.2f avg. set size)\n", |
689 |
lfcnt+lecnt, 100.*lecnt/(lfcnt+lecnt), |
690 |
(double)locnt/lfcnt); |
691 |
692 |
693 |
694 |
void |
695 |
freemesh(MESH *ms) /* free mesh data */ |
696 |
697 |
MESH mhead; |
698 |
MESH *msp; |
699 |
700 |
if (ms == NULL) |
701 |
return; |
702 |
if (ms->nref <= 0) |
703 |
error(CONSISTENCY, "unreferenced mesh in freemesh"); |
704 |
ms->nref--; |
705 |
if (ms->nref) /* still in use */ |
706 |
return; |
707 |
/* else remove from list */ |
708 |
mhead.next = mlist; |
709 |
for (msp = &mhead; msp->next != NULL; msp = msp->next) |
710 |
if (msp->next == ms) { |
711 |
msp->next = ms->next; |
712 |
ms->next = NULL; |
713 |
break; |
714 |
715 |
if (ms->next != NULL) /* can't be in list anymore */ |
716 |
error(CONSISTENCY, "unlisted mesh in freemesh"); |
717 |
mlist = mhead.next; |
718 |
719 |
freestr(ms->name); |
720 |
octfree(ms->mcube.cutree); |
721 |
lu_done(&ms->lut); |
722 |
if (ms->npatches > 0) { |
723 |
MESHPATCH *pp = ms->patch + ms->npatches; |
724 |
while (pp-- > ms->patch) { |
725 |
if (pp->j2tri != NULL) |
726 |
free((void *)pp->j2tri); |
727 |
if (pp->j1tri != NULL) |
728 |
free((void *)pp->j1tri); |
729 |
if (pp->tri != NULL) |
730 |
free((void *)pp->tri); |
731 |
if (pp->uv != NULL) |
732 |
free((void *)pp->uv); |
733 |
if (pp->norm != NULL) |
734 |
free((void *)pp->norm); |
735 |
if (pp->xyz != NULL) |
736 |
free((void *)pp->xyz); |
737 |
738 |
free((void *)ms->patch); |
739 |
740 |
if (ms->pseudo != NULL) |
741 |
free((void *)ms->pseudo); |
742 |
free((void *)ms); |
743 |
744 |
745 |
746 |
void |
747 |
freemeshinst(OBJREC *o) /* free mesh instance */ |
748 |
749 |
if (o->os == NULL) |
750 |
return; |
751 |
freemesh((*(MESHINST *)o->os).msh); |
752 |
free((void *)o->os); |
753 |
o->os = NULL; |
754 |
