| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: mesh.c,v 2.13 2003/07/21 22:30:17 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Mesh support routines
| 6 |
| 7 |
| 8 |
#include <string.h>
| 9 |
| 10 |
#include "standard.h"
| 11 |
#include "octree.h"
| 12 |
#include "object.h"
| 13 |
#include "otypes.h"
| 14 |
#include "mesh.h"
| 15 |
| 16 |
/* An encoded mesh vertex */
| 17 |
typedef struct {
| 18 |
int fl;
| 19 |
uint32 xyz[3];
| 20 |
int32 norm;
| 21 |
uint16 uv[2];
| 22 |
} MCVERT;
| 23 |
| 24 |
#define MPATCHBLKSIZ 128 /* patch allocation block size */
| 25 |
| 26 |
#define IO_LEGAL (IO_BOUNDS|IO_TREE|IO_SCENE)
| 27 |
| 28 |
static MESH *mlist = NULL; /* list of loaded meshes */
| 29 |
| 30 |
| 31 |
static unsigned long
| 32 |
cvhash(cvp) /* hash an encoded vertex */
| 33 |
MCVERT *cvp;
| 34 |
| 35 |
unsigned long hval;
| 36 |
| 37 |
if (!(cvp->fl & MT_V))
| 38 |
return(0);
| 39 |
hval = cvp->xyz[0] ^ cvp->xyz[1] << 11 ^ cvp->xyz[2] << 22;
| 40 |
if (cvp->fl & MT_N)
| 41 |
hval ^= cvp->norm;
| 42 |
if (cvp->fl & MT_UV)
| 43 |
hval ^= cvp->uv[0] ^ cvp->uv[1] << 16;
| 44 |
return(hval);
| 45 |
| 46 |
| 47 |
| 48 |
static int
| 49 |
cvcmp(v1, v2) /* compare encoded vertices */
| 50 |
register MCVERT *v1, *v2;
| 51 |
| 52 |
if (v1->fl != v2->fl)
| 53 |
return(1);
| 54 |
if (v1->xyz[0] != v2->xyz[0])
| 55 |
return(1);
| 56 |
if (v1->xyz[1] != v2->xyz[1])
| 57 |
return(1);
| 58 |
if (v1->xyz[2] != v2->xyz[2])
| 59 |
return(1);
| 60 |
if (v1->fl & MT_N && v1->norm != v2->norm)
| 61 |
return(1);
| 62 |
if (v1->fl & MT_UV) {
| 63 |
if (v1->uv[0] != v2->uv[0])
| 64 |
return(1);
| 65 |
if (v1->uv[1] != v2->uv[1])
| 66 |
return(1);
| 67 |
| 68 |
return(0);
| 69 |
| 70 |
| 71 |
| 72 |
MESH *
| 73 |
getmesh(mname, flags) /* get new mesh data reference */
| 74 |
char *mname;
| 75 |
int flags;
| 76 |
| 77 |
char *pathname;
| 78 |
register MESH *ms;
| 79 |
| 80 |
flags &= IO_LEGAL;
| 81 |
for (ms = mlist; ms != NULL; ms = ms->next)
| 82 |
if (!strcmp(mname, ms->name)) {
| 83 |
ms->nref++; /* increase reference count */
| 84 |
break;
| 85 |
| 86 |
if (ms == NULL) { /* load first time */
| 87 |
ms = (MESH *)calloc(1, sizeof(MESH));
| 88 |
if (ms == NULL)
| 89 |
error(SYSTEM, "out of memory in getmesh");
| 90 |
ms->name = savestr(mname);
| 91 |
ms->nref = 1;
| 92 |
ms->mcube.cutree = EMPTY;
| 93 |
ms->next = mlist;
| 94 |
mlist = ms;
| 95 |
| 96 |
if ((pathname = getpath(mname, getrlibpath(), R_OK)) == NULL) {
| 97 |
sprintf(errmsg, "cannot find mesh file \"%s\"", mname);
| 98 |
error(USER, errmsg);
| 99 |
| 100 |
flags &= ~ms->ldflags;
| 101 |
if (flags)
| 102 |
readmesh(ms, pathname, flags);
| 103 |
return(ms);
| 104 |
| 105 |
| 106 |
| 107 |
MESHINST *
| 108 |
getmeshinst(o, flags) /* create mesh instance */
| 109 |
OBJREC *o;
| 110 |
int flags;
| 111 |
| 112 |
register MESHINST *ins;
| 113 |
| 114 |
flags &= IO_LEGAL;
| 115 |
if ((ins = (MESHINST *)o->os) == NULL) {
| 116 |
if ((ins = (MESHINST *)malloc(sizeof(MESHINST))) == NULL)
| 117 |
error(SYSTEM, "out of memory in getmeshinst");
| 118 |
if (o->oargs.nsargs < 1)
| 119 |
objerror(o, USER, "bad # of arguments");
| 120 |
if (fullxf(&ins->x, o->oargs.nsargs-1,
| 121 |
o->oargs.sarg+1) != o->oargs.nsargs-1)
| 122 |
objerror(o, USER, "bad transform");
| 123 |
if (ins->x.f.sca < 0.0) {
| 124 |
ins->x.f.sca = -ins->x.f.sca;
| 125 |
ins->x.b.sca = -ins->x.b.sca;
| 126 |
| 127 |
ins->msh = NULL;
| 128 |
o->os = (char *)ins;
| 129 |
| 130 |
if (ins->msh == NULL)
| 131 |
ins->msh = getmesh(o->oargs.sarg[0], flags);
| 132 |
else if ((flags &= ~ins->msh->ldflags))
| 133 |
readmesh(ins->msh,
| 134 |
getpath(o->oargs.sarg[0], getrlibpath(), R_OK),
| 135 |
flags);
| 136 |
return(ins);
| 137 |
| 138 |
| 139 |
| 140 |
int
| 141 |
getmeshtrivid(tvid, mo, mp, ti) /* get triangle vertex ID's */
| 142 |
int32 tvid[3];
| 143 |
OBJECT *mo;
| 144 |
MESH *mp;
| 145 |
OBJECT ti;
| 146 |
| 147 |
int pn = ti >> 10;
| 148 |
MESHPATCH *pp;
| 149 |
| 150 |
if (pn >= mp->npatches)
| 151 |
return(0);
| 152 |
pp = &mp->patch[pn];
| 153 |
ti &= 0x3ff;
| 154 |
if (!(ti & 0x200)) { /* local triangle */
| 155 |
struct PTri *tp;
| 156 |
if (ti >= pp->ntris)
| 157 |
return(0);
| 158 |
tp = &pp->tri[ti];
| 159 |
tvid[0] = tvid[1] = tvid[2] = pn << 8;
| 160 |
tvid[0] |= tp->v1;
| 161 |
tvid[1] |= tp->v2;
| 162 |
tvid[2] |= tp->v3;
| 163 |
if (pp->trimat != NULL)
| 164 |
*mo = pp->trimat[ti];
| 165 |
else
| 166 |
*mo = pp->solemat;
| 167 |
if (*mo != OVOID)
| 168 |
*mo += mp->mat0;
| 169 |
return(1);
| 170 |
| 171 |
ti &= ~0x200;
| 172 |
if (!(ti & 0x100)) { /* single link vertex */
| 173 |
struct PJoin1 *tp1;
| 174 |
if (ti >= pp->nj1tris)
| 175 |
return(0);
| 176 |
tp1 = &pp->j1tri[ti];
| 177 |
tvid[0] = tp1->v1j;
| 178 |
| 179 |
tvid[1] |= tp1->v2;
| 180 |
tvid[2] |= tp1->v3;
| 181 |
if ((*mo = tp1->mat) != OVOID)
| 182 |
*mo += mp->mat0;
| 183 |
return(1);
| 184 |
| 185 |
ti &= ~0x100;
| 186 |
{ /* double link vertex */
| 187 |
struct PJoin2 *tp2;
| 188 |
if (ti >= pp->nj2tris)
| 189 |
return(0);
| 190 |
tp2 = &pp->j2tri[ti];
| 191 |
tvid[0] = tp2->v1j;
| 192 |
tvid[1] = tp2->v2j;
| 193 |
tvid[2] = pn << 8 | tp2->v3;
| 194 |
if ((*mo = tp2->mat) != OVOID)
| 195 |
*mo += mp->mat0;
| 196 |
| 197 |
return(1);
| 198 |
| 199 |
| 200 |
| 201 |
int
| 202 |
getmeshvert(vp, mp, vid, what) /* get triangle vertex from ID */
| 203 |
MESHVERT *vp;
| 204 |
MESH *mp;
| 205 |
int32 vid;
| 206 |
int what;
| 207 |
| 208 |
int pn = vid >> 8;
| 209 |
MESHPATCH *pp;
| 210 |
double vres;
| 211 |
register int i;
| 212 |
| 213 |
vp->fl = 0;
| 214 |
| 215 |
return(0);
| 216 |
| 217 |
vid &= 0xff;
| 218 |
if (vid >= pp->nverts)
| 219 |
return(0);
| 220 |
/* get location */
| 221 |
if (what & MT_V) {
| 222 |
vres = (1./4294967296.)*mp->mcube.cusize;
| 223 |
for (i = 0; i < 3; i++)
| 224 |
vp->v[i] = mp->mcube.cuorg[i] +
| 225 |
(pp->xyz[vid][i] + .5)*vres;
| 226 |
vp->fl |= MT_V;
| 227 |
| 228 |
/* get normal */
| 229 |
if (what & MT_N && pp->norm != NULL && pp->norm[vid]) {
| 230 |
decodedir(vp->n, pp->norm[vid]);
| 231 |
vp->fl |= MT_N;
| 232 |
| 233 |
/* get (u,v) */
| 234 |
if (what & MT_UV && pp->uv != NULL && pp->uv[vid][0]) {
| 235 |
for (i = 0; i < 2; i++)
| 236 |
vp->uv[i] = mp->uvlim[0][i] +
| 237 |
(mp->uvlim[1][i] - mp->uvlim[0][i])*
| 238 |
(pp->uv[vid][i] + .5)*(1./65536.);
| 239 |
vp->fl |= MT_UV;
| 240 |
| 241 |
return(vp->fl);
| 242 |
| 243 |
| 244 |
| 245 |
OBJREC *
| 246 |
getmeshpseudo(mp, mo) /* get mesh pseudo object for material */
| 247 |
MESH *mp;
| 248 |
OBJECT mo;
| 249 |
| 250 |
if (mo < mp->mat0 || mo >= mp->mat0 + mp->nmats)
| 251 |
error(INTERNAL, "modifier out of range in getmeshpseudo");
| 252 |
if (mp->pseudo == NULL) {
| 253 |
register int i;
| 254 |
mp->pseudo = (OBJREC *)calloc(mp->nmats, sizeof(OBJREC));
| 255 |
| 256 |
error(SYSTEM, "out of memory in getmeshpseudo");
| 257 |
for (i = mp->nmats; i--; ) {
| 258 |
mp->pseudo[i].omod = mp->mat0 + i;
| 259 |
mp->pseudo[i].otype = OBJ_FACE;
| 260 |
mp->pseudo[i].oname = "M-Tri";
| 261 |
| 262 |
| 263 |
return(&mp->pseudo[mo - mp->mat0]);
| 264 |
| 265 |
| 266 |
| 267 |
int
| 268 |
getmeshtri(tv, mo, mp, ti, wha) /* get triangle vertices */
| 269 |
MESHVERT tv[3];
| 270 |
OBJECT *mo;
| 271 |
MESH *mp;
| 272 |
OBJECT ti;
| 273 |
int wha;
| 274 |
| 275 |
int32 tvid[3];
| 276 |
| 277 |
if (!getmeshtrivid(tvid, mo, mp, ti))
| 278 |
return(0);
| 279 |
| 280 |
getmeshvert(&tv[0], mp, tvid[0], wha);
| 281 |
getmeshvert(&tv[1], mp, tvid[1], wha);
| 282 |
getmeshvert(&tv[2], mp, tvid[2], wha);
| 283 |
| 284 |
return(tv[0].fl & tv[1].fl & tv[2].fl);
| 285 |
| 286 |
| 287 |
| 288 |
int32
| 289 |
addmeshvert(mp, vp) /* find/add a mesh vertex */
| 290 |
register MESH *mp;
| 291 |
MESHVERT *vp;
| 292 |
| 293 |
LUENT *lvp;
| 294 |
MCVERT cv;
| 295 |
register int i;
| 296 |
| 297 |
if (!(vp->fl & MT_V))
| 298 |
return(-1);
| 299 |
/* encode vertex */
| 300 |
for (i = 0; i < 3; i++) {
| 301 |
if (vp->v[i] < mp->mcube.cuorg[i])
| 302 |
return(-1);
| 303 |
if (vp->v[i] >= mp->mcube.cuorg[i] + mp->mcube.cusize)
| 304 |
return(-1);
| 305 |
cv.xyz[i] = (uint32)(4294967296. *
| 306 |
(vp->v[i] - mp->mcube.cuorg[i]) /
| 307 |
mp->mcube.cusize);
| 308 |
| 309 |
if (vp->fl & MT_N)
| 310 |
cv.norm = encodedir(vp->n);
| 311 |
if (vp->fl & MT_UV)
| 312 |
for (i = 0; i < 2; i++) {
| 313 |
if (vp->uv[i] <= mp->uvlim[0][i])
| 314 |
return(-1);
| 315 |
if (vp->uv[i] >= mp->uvlim[1][i])
| 316 |
return(-1);
| 317 |
cv.uv[i] = (uint32)(65536. *
| 318 |
(vp->uv[i] - mp->uvlim[0][i]) /
| 319 |
(mp->uvlim[1][i] - mp->uvlim[0][i]));
| 320 |
| 321 |
cv.fl = vp->fl;
| 322 |
if (mp->lut.tsiz == 0) {
| 323 |
mp->lut.hashf = cvhash;
| 324 |
mp->lut.keycmp = cvcmp;
| 325 |
mp->lut.freek = free;
| 326 |
if (!lu_init(&mp->lut, 50000))
| 327 |
goto nomem;
| 328 |
| 329 |
/* find entry */
| 330 |
lvp = lu_find(&mp->lut, (char *)&cv);
| 331 |
if (lvp == NULL)
| 332 |
goto nomem;
| 333 |
if (lvp->key == NULL) {
| 334 |
lvp->key = (char *)malloc(sizeof(MCVERT)+sizeof(int32));
| 335 |
memcpy((void *)lvp->key, (void *)&cv, sizeof(MCVERT));
| 336 |
| 337 |
if (lvp->data == NULL) { /* new vertex */
| 338 |
register MESHPATCH *pp;
| 339 |
if (mp->npatches <= 0) {
| 340 |
mp->patch = (MESHPATCH *)calloc(MPATCHBLKSIZ,
| 341 |
sizeof(MESHPATCH));
| 342 |
if (mp->patch == NULL)
| 343 |
goto nomem;
| 344 |
mp->npatches = 1;
| 345 |
} else if (mp->patch[mp->npatches-1].nverts >= 256) {
| 346 |
if (mp->npatches % MPATCHBLKSIZ == 0) {
| 347 |
mp->patch = (MESHPATCH *)realloc(
| 348 |
(void *)mp->patch,
| 349 |
(mp->npatches + MPATCHBLKSIZ)*
| 350 |
sizeof(MESHPATCH));
| 351 |
memset((void *)(mp->patch + mp->npatches), '\0',
| 352 |
MPATCHBLKSIZ*sizeof(MESHPATCH));
| 353 |
| 354 |
if (mp->npatches++ >= 1L<<22)
| 355 |
error(INTERNAL, "too many mesh patches");
| 356 |
| 357 |
pp = &mp->patch[mp->npatches-1];
| 358 |
if (pp->xyz == NULL) {
| 359 |
pp->xyz = (uint32 (*)[3])calloc(256, 3*sizeof(int32));
| 360 |
| 361 |
goto nomem;
| 362 |
| 363 |
| 364 |
pp->xyz[pp->nverts][i] = cv.xyz[i];
| 365 |
if (cv.fl & MT_N) {
| 366 |
if (pp->norm == NULL) {
| 367 |
pp->norm = (int32 *)calloc(256, sizeof(int32));
| 368 |
| 369 |
goto nomem;
| 370 |
| 371 |
pp->norm[pp->nverts] = cv.norm;
| 372 |
| 373 |
if (cv.fl & MT_UV) {
| 374 |
if (pp->uv == NULL) {
| 375 |
pp->uv = (uint16 (*)[2])calloc(256,
| 376 |
2*sizeof(uint16));
| 377 |
if (pp->uv == NULL)
| 378 |
goto nomem;
| 379 |
| 380 |
| 381 |
pp->uv[pp->nverts][i] = cv.uv[i];
| 382 |
| 383 |
pp->nverts++;
| 384 |
lvp->data = lvp->key + sizeof(MCVERT);
| 385 |
*(int32 *)lvp->data = (mp->npatches-1) << 8 | (pp->nverts-1);
| 386 |
| 387 |
return(*(int32 *)lvp->data);
| 388 |
nomem:
| 389 |
error(SYSTEM, "out of memory in addmeshvert");
| 390 |
return(-1);
| 391 |
| 392 |
| 393 |
| 394 |
OBJECT
| 395 |
addmeshtri(mp, tv, mo) /* add a new mesh triangle */
| 396 |
MESH *mp;
| 397 |
MESHVERT tv[3];
| 398 |
OBJECT mo;
| 399 |
| 400 |
int32 vid[3], t;
| 401 |
int pn[3], i;
| 402 |
| 403 |
| 404 |
if (!(tv[0].fl & tv[1].fl & tv[2].fl & MT_V))
| 405 |
return(OVOID);
| 406 |
/* find/allocate patch vertices */
| 407 |
| 408 |
if ((vid[i] = addmeshvert(mp, &tv[i])) < 0)
| 409 |
return(OVOID);
| 410 |
pn[i] = vid[i] >> 8;
| 411 |
| 412 |
/* normalize material index */
| 413 |
if (mo != OVOID) {
| 414 |
if ((mo -= mp->mat0) >= mp->nmats)
| 415 |
mp->nmats = mo+1;
| 416 |
else if (mo < 0)
| 417 |
error(INTERNAL, "modifier range error in addmeshtri");
| 418 |
| 419 |
/* assign triangle */
| 420 |
if (pn[0] == pn[1] && pn[1] == pn[2]) { /* local case */
| 421 |
pp = &mp->patch[pn[0]];
| 422 |
if (pp->tri == NULL) {
| 423 |
pp->tri = (struct PTri *)malloc(
| 424 |
512*sizeof(struct PTri));
| 425 |
| 426 |
goto nomem;
| 427 |
| 428 |
if (pp->ntris < 512) {
| 429 |
pp->tri[pp->ntris].v1 = vid[0] & 0xff;
| 430 |
pp->tri[pp->ntris].v2 = vid[1] & 0xff;
| 431 |
pp->tri[pp->ntris].v3 = vid[2] & 0xff;
| 432 |
if (pp->ntris == 0)
| 433 |
pp->solemat = mo;
| 434 |
else if (pp->trimat == NULL && mo != pp->solemat) {
| 435 |
pp->trimat = (int16 *)malloc(
| 436 |
512*sizeof(int16));
| 437 |
if (pp->trimat == NULL)
| 438 |
goto nomem;
| 439 |
for (i = pp->ntris; i--; )
| 440 |
pp->trimat[i] = pp->solemat;
| 441 |
| 442 |
| 443 |
pp->trimat[pp->ntris] = mo;
| 444 |
return(pn[0] << 10 | pp->ntris++);
| 445 |
| 446 |
| 447 |
if (pn[0] == pn[1]) {
| 448 |
t = vid[2]; vid[2] = vid[1]; vid[1] = vid[0]; vid[0] = t;
| 449 |
i = pn[2]; pn[2] = pn[1]; pn[1] = pn[0]; pn[0] = i;
| 450 |
} else if (pn[0] == pn[2]) {
| 451 |
t = vid[0]; vid[0] = vid[1]; vid[1] = vid[2]; vid[2] = t;
| 452 |
i = pn[0]; pn[0] = pn[1]; pn[1] = pn[2]; pn[2] = i;
| 453 |
| 454 |
if (pn[1] == pn[2]) { /* single link */
| 455 |
pp = &mp->patch[pn[1]];
| 456 |
if (pp->j1tri == NULL) {
| 457 |
pp->j1tri = (struct PJoin1 *)malloc(
| 458 |
256*sizeof(struct PJoin1));
| 459 |
| 460 |
goto nomem;
| 461 |
| 462 |
if (pp->nj1tris < 256) {
| 463 |
pp->j1tri[pp->nj1tris].v1j = vid[0];
| 464 |
pp->j1tri[pp->nj1tris].v2 = vid[1] & 0xff;
| 465 |
pp->j1tri[pp->nj1tris].v3 = vid[2] & 0xff;
| 466 |
pp->j1tri[pp->nj1tris].mat = mo;
| 467 |
return(pn[1] << 10 | 0x200 | pp->nj1tris++);
| 468 |
| 469 |
| 470 |
/* double link */
| 471 |
pp = &mp->patch[pn[2]];
| 472 |
if (pp->j2tri == NULL) {
| 473 |
pp->j2tri = (struct PJoin2 *)malloc(
| 474 |
256*sizeof(struct PJoin2));
| 475 |
| 476 |
goto nomem;
| 477 |
| 478 |
if (pp->nj2tris >= 256)
| 479 |
error(INTERNAL, "too many patch triangles in addmeshtri");
| 480 |
pp->j2tri[pp->nj2tris].v1j = vid[0];
| 481 |
pp->j2tri[pp->nj2tris].v2j = vid[1];
| 482 |
pp->j2tri[pp->nj2tris].v3 = vid[2] & 0xff;
| 483 |
pp->j2tri[pp->nj2tris].mat = mo;
| 484 |
return(pn[2] << 10 | 0x300 | pp->nj2tris++);
| 485 |
nomem:
| 486 |
error(SYSTEM, "out of memory in addmeshtri");
| 487 |
return(OVOID);
| 488 |
| 489 |
| 490 |
| 491 |
char *
| 492 |
checkmesh(mp) /* validate mesh data */
| 493 |
register MESH *mp;
| 494 |
| 495 |
static char embuf[128];
| 496 |
int nouvbounds = 1;
| 497 |
register int i;
| 498 |
/* basic checks */
| 499 |
if (mp == NULL)
| 500 |
return("NULL mesh pointer");
| 501 |
if (!mp->ldflags)
| 502 |
return("unassigned mesh");
| 503 |
if (mp->name == NULL)
| 504 |
return("missing mesh name");
| 505 |
if (mp->nref <= 0)
| 506 |
return("unreferenced mesh");
| 507 |
/* check boundaries */
| 508 |
if (mp->ldflags & IO_BOUNDS) {
| 509 |
if (mp->mcube.cusize <= FTINY)
| 510 |
return("illegal octree bounds in mesh");
| 511 |
nouvbounds = (mp->uvlim[1][0] - mp->uvlim[0][0] <= FTINY ||
| 512 |
mp->uvlim[1][1] - mp->uvlim[0][1] <= FTINY);
| 513 |
| 514 |
/* check octree */
| 515 |
if (mp->ldflags & IO_TREE) {
| 516 |
if (isempty(mp->mcube.cutree))
| 517 |
error(WARNING, "empty mesh octree");
| 518 |
| 519 |
/* check scene data */
| 520 |
if (mp->ldflags & IO_SCENE) {
| 521 |
if (!(mp->ldflags & IO_BOUNDS))
| 522 |
return("unbounded scene in mesh");
| 523 |
if (mp->mat0 < 0 || mp->mat0+mp->nmats > nobjects)
| 524 |
return("bad mesh modifier range");
| 525 |
for (i = mp->mat0+mp->nmats; i-- > mp->mat0; ) {
| 526 |
int otyp = objptr(i)->otype;
| 527 |
if (!ismodifier(otyp)) {
| 528 |
sprintf(embuf,
| 529 |
"non-modifier in mesh (%s \"%s\")",
| 530 |
ofun[otyp].funame, objptr(i)->oname);
| 531 |
return(embuf);
| 532 |
| 533 |
| 534 |
| 535 |
error(WARNING, "no patches in mesh");
| 536 |
for (i = 0; i < mp->npatches; i++) {
| 537 |
register MESHPATCH *pp = &mp->patch[i];
| 538 |
if (pp->nverts <= 0)
| 539 |
error(WARNING, "no vertices in patch");
| 540 |
else {
| 541 |
| 542 |
return("missing patch vertex list");
| 543 |
if (nouvbounds && pp->uv != NULL)
| 544 |
return("unreferenced uv coordinates");
| 545 |
| 546 |
if (pp->ntris + pp->nj1tris + pp->nj2tris <= 0)
| 547 |
error(WARNING, "no triangles in patch");
| 548 |
if (pp->ntris > 0 && pp->tri == NULL)
| 549 |
return("missing patch triangle list");
| 550 |
if (pp->nj1tris > 0 && pp->j1tri == NULL)
| 551 |
return("missing patch joiner triangle list");
| 552 |
if (pp->nj2tris > 0 && pp->j2tri == NULL)
| 553 |
return("missing patch double-joiner list");
| 554 |
| 555 |
| 556 |
return(NULL); /* seems OK */
| 557 |
| 558 |
| 559 |
| 560 |
static void
| 561 |
tallyoctree(ot, ecp, lcp, ocp) /* tally octree size */
| 562 |
OCTREE ot;
| 563 |
int *ecp, *lcp, *ocp;
| 564 |
| 565 |
int i;
| 566 |
| 567 |
if (isempty(ot)) {
| 568 |
(*ecp)++;
| 569 |
return;
| 570 |
| 571 |
if (isfull(ot)) {
| 572 |
OBJECT oset[MAXSET+1];
| 573 |
(*lcp)++;
| 574 |
objset(oset, ot);
| 575 |
*ocp += oset[0];
| 576 |
return;
| 577 |
| 578 |
for (i = 0; i < 8; i++)
| 579 |
tallyoctree(octkid(ot, i), ecp, lcp, ocp);
| 580 |
| 581 |
| 582 |
| 583 |
void
| 584 |
printmeshstats(ms, fp) /* print out mesh statistics */
| 585 |
MESH *ms;
| 586 |
FILE *fp;
| 587 |
| 588 |
int lfcnt=0, lecnt=0, locnt=0;
| 589 |
int vcnt=0, ncnt=0, uvcnt=0;
| 590 |
int nscnt=0, uvscnt=0;
| 591 |
int tcnt=0, t1cnt=0, t2cnt=0;
| 592 |
int i, j;
| 593 |
| 594 |
tallyoctree(ms->mcube.cutree, &lecnt, &lfcnt, &locnt);
| 595 |
for (i = 0; i < ms->npatches; i++) {
| 596 |
register MESHPATCH *pp = &ms->patch[i];
| 597 |
vcnt += pp->nverts;
| 598 |
if (pp->norm != NULL) {
| 599 |
for (j = pp->nverts; j--; )
| 600 |
if (pp->norm[j])
| 601 |
ncnt++;
| 602 |
nscnt += pp->nverts;
| 603 |
| 604 |
if (pp->uv != NULL) {
| 605 |
| 606 |
if (pp->uv[j][0])
| 607 |
uvcnt++;
| 608 |
uvscnt += pp->nverts;
| 609 |
| 610 |
tcnt += pp->ntris;
| 611 |
t1cnt += pp->nj1tris;
| 612 |
t2cnt += pp->nj2tris;
| 613 |
| 614 |
fprintf(fp, "Mesh statistics:\n");
| 615 |
fprintf(fp, "\t%ld materials\n", ms->nmats);
| 616 |
fprintf(fp, "\t%d patches (%.2f MBytes)\n", ms->npatches,
| 617 |
(ms->npatches*sizeof(MESHPATCH) +
| 618 |
vcnt*3*sizeof(uint32) +
| 619 |
nscnt*sizeof(int32) +
| 620 |
uvscnt*2*sizeof(uint16) +
| 621 |
tcnt*sizeof(struct PTri) +
| 622 |
t1cnt*sizeof(struct PJoin1) +
| 623 |
t2cnt*sizeof(struct PJoin2))/(1024.*1024.));
| 624 |
fprintf(fp, "\t%d vertices (%.1f%% w/ normals, %.1f%% w/ uv)\n",
| 625 |
vcnt, 100.*ncnt/vcnt, 100.*uvcnt/vcnt);
| 626 |
fprintf(fp, "\t%d triangles (%.1f%% local, %.1f%% joiner)\n",
| 627 |
tcnt+t1cnt+t2cnt,
| 628 |
100.*tcnt/(tcnt+t1cnt+t2cnt),
| 629 |
100.*t1cnt/(tcnt+t1cnt+t2cnt));
| 630 |
fprintf(fp,
| 631 |
"\t%d leaves in octree (%.1f%% empty, %.2f avg. set size)\n",
| 632 |
lfcnt+lecnt, 100.*lecnt/(lfcnt+lecnt),
| 633 |
(double)locnt/lfcnt);
| 634 |
| 635 |
| 636 |
| 637 |
void
| 638 |
freemesh(ms) /* free mesh data */
| 639 |
register MESH *ms;
| 640 |
| 641 |
MESH mhead;
| 642 |
MESH *msp;
| 643 |
| 644 |
if (ms == NULL)
| 645 |
return;
| 646 |
if (ms->nref <= 0)
| 647 |
error(CONSISTENCY, "unreferenced mesh in freemesh");
| 648 |
ms->nref--;
| 649 |
if (ms->nref) /* still in use */
| 650 |
return;
| 651 |
/* else remove from list */
| 652 |
mhead.next = mlist;
| 653 |
for (msp = &mhead; msp->next != NULL; msp = msp->next)
| 654 |
if (msp->next == ms) {
| 655 |
msp->next = ms->next;
| 656 |
ms->next = NULL;
| 657 |
break;
| 658 |
| 659 |
if (ms->next != NULL) /* can't be in list anymore */
| 660 |
error(CONSISTENCY, "unlisted mesh in freemesh");
| 661 |
mlist = mhead.next;
| 662 |
| 663 |
freestr(ms->name);
| 664 |
octfree(ms->mcube.cutree);
| 665 |
lu_done(&ms->lut);
| 666 |
if (ms->npatches > 0) {
| 667 |
register MESHPATCH *pp = ms->patch + ms->npatches;
| 668 |
while (pp-- > ms->patch) {
| 669 |
if (pp->j2tri != NULL)
| 670 |
free((void *)pp->j2tri);
| 671 |
if (pp->j1tri != NULL)
| 672 |
free((void *)pp->j1tri);
| 673 |
if (pp->tri != NULL)
| 674 |
free((void *)pp->tri);
| 675 |
if (pp->uv != NULL)
| 676 |
free((void *)pp->uv);
| 677 |
| 678 |
free((void *)pp->norm);
| 679 |
if (pp->xyz != NULL)
| 680 |
free((void *)pp->xyz);
| 681 |
| 682 |
free((void *)ms->patch);
| 683 |
| 684 |
if (ms->pseudo != NULL)
| 685 |
free((void *)ms->pseudo);
| 686 |
free((void *)ms);
| 687 |
| 688 |
| 689 |
| 690 |
void
| 691 |
freemeshinst(o) /* free mesh instance */
| 692 |
OBJREC *o;
| 693 |
| 694 |
if (o->os == NULL)
| 695 |
return;
| 696 |
freemesh((*(MESHINST *)o->os).msh);
| 697 |
free((void *)o->os);
| 698 |
o->os = NULL;
| 699 |
