--- ray/src/common/mesh.c 2003/05/13 17:58:32 2.7 +++ ray/src/common/mesh.c 2004/05/25 22:04:13 2.20 @@ -1,11 +1,16 @@ #ifndef lint -static const char RCSid[] = "$Id: mesh.c,v 2.7 2003/05/13 17:58:32 greg Exp $"; +static const char RCSid[] = "$Id: mesh.c,v 2.20 2004/05/25 22:04:13 greg Exp $"; #endif /* * Mesh support routines */ -#include "standard.h" +#include + +#include "rtio.h" +#include "rtmath.h" +#include "rterror.h" +#include "paths.h" #include "octree.h" #include "object.h" #include "otypes.h" @@ -14,9 +19,9 @@ static const char RCSid[] = "$Id: mesh.c,v 2.7 2003/05 /* An encoded mesh vertex */ typedef struct { int fl; - uint4 xyz[3]; - int4 norm; - uint4 uv[2]; + uint32 xyz[3]; + int32 norm; + uint32 uv[2]; } MCVERT; #define MPATCHBLKSIZ 128 /* patch allocation block size */ @@ -25,11 +30,16 @@ typedef struct { static MESH *mlist = NULL; /* list of loaded meshes */ +static lut_keycmpf_t cvcmp; +static lut_hashf_t cvhash; + static unsigned long -cvhash(cvp) /* hash an encoded vertex */ -MCVERT *cvp; +cvhash(p) /* hash an encoded vertex */ +//MCVERT *cvp; +const void *p; { + const MCVERT *cvp = (const MCVERT *)p; unsigned long hval; if (!(cvp->fl & MT_V)) @@ -44,9 +54,11 @@ MCVERT *cvp; static int -cvcmp(v1, v2) /* compare encoded vertices */ -register MCVERT *v1, *v2; +cvcmp(vv1, vv2) /* compare encoded vertices */ +//register MCVERT *v1, *v2; +const void *vv1, *vv2; { + const MCVERT *v1 = vv1, *v2 = vv2; if (v1->fl != v2->fl) return(1); if (v1->xyz[0] != v2->xyz[0]) @@ -68,7 +80,7 @@ register MCVERT *v1, *v2; MESH * -getmesh(mname, flags) /* get mesh data */ +getmesh(mname, flags) /* get new mesh data reference */ char *mname; int flags; { @@ -78,13 +90,10 @@ int flags; flags &= IO_LEGAL; for (ms = mlist; ms != NULL; ms = ms->next) if (!strcmp(mname, ms->name)) { - if ((ms->ldflags & flags) == flags) { - ms->nref++; - return(ms); /* loaded */ - } - break; /* load the rest */ + ms->nref++; /* increase reference count */ + break; } - if (ms == NULL) { + if (ms == NULL) { /* load first time */ ms = (MESH *)calloc(1, sizeof(MESH)); if (ms == NULL) error(SYSTEM, "out of memory in getmesh"); @@ -128,15 +137,19 @@ int flags; ins->msh = NULL; o->os = (char *)ins; } - if (ins->msh == NULL || (ins->msh->ldflags & flags) != flags) + if (ins->msh == NULL) ins->msh = getmesh(o->oargs.sarg[0], flags); + else if ((flags &= ~ins->msh->ldflags)) + readmesh(ins->msh, + getpath(o->oargs.sarg[0], getrlibpath(), R_OK), + flags); return(ins); } int getmeshtrivid(tvid, mo, mp, ti) /* get triangle vertex ID's */ -int4 tvid[3]; +int32 tvid[3]; OBJECT *mo; MESH *mp; OBJECT ti; @@ -199,7 +212,7 @@ int getmeshvert(vp, mp, vid, what) /* get triangle vertex from ID */ MESHVERT *vp; MESH *mp; -int4 vid; +int32 vid; int what; { int pn = vid >> 8; @@ -269,7 +282,7 @@ MESH *mp; OBJECT ti; int wha; { - int4 tvid[3]; + int32 tvid[3]; if (!getmeshtrivid(tvid, mo, mp, ti)) return(0); @@ -282,7 +295,7 @@ int wha; } -int4 +int32 addmeshvert(mp, vp) /* find/add a mesh vertex */ register MESH *mp; MESHVERT *vp; @@ -299,11 +312,11 @@ MESHVERT *vp; return(-1); if (vp->v[i] >= mp->mcube.cuorg[i] + mp->mcube.cusize) return(-1); - cv.xyz[i] = (uint4)(4294967296. * + cv.xyz[i] = (uint32)(4294967296. * (vp->v[i] - mp->mcube.cuorg[i]) / mp->mcube.cusize); } - if (vp->fl & MT_N) + if (vp->fl & MT_N) /* assumes normalized! */ cv.norm = encodedir(vp->n); if (vp->fl & MT_UV) for (i = 0; i < 2; i++) { @@ -311,7 +324,7 @@ MESHVERT *vp; return(-1); if (vp->uv[i] >= mp->uvlim[1][i]) return(-1); - cv.uv[i] = (uint4)(4294967296. * + cv.uv[i] = (uint32)(4294967296. * (vp->uv[i] - mp->uvlim[0][i]) / (mp->uvlim[1][i] - mp->uvlim[0][i])); } @@ -328,8 +341,8 @@ MESHVERT *vp; if (lvp == NULL) goto nomem; if (lvp->key == NULL) { - lvp->key = (char *)malloc(sizeof(MCVERT)+sizeof(int4)); - bcopy((void *)&cv, (void *)lvp->key, sizeof(MCVERT)); + lvp->key = (char *)malloc(sizeof(MCVERT)+sizeof(int32)); + memcpy((void *)lvp->key, (void *)&cv, sizeof(MCVERT)); } if (lvp->data == NULL) { /* new vertex */ register MESHPATCH *pp; @@ -345,7 +358,7 @@ MESHVERT *vp; (void *)mp->patch, (mp->npatches + MPATCHBLKSIZ)* sizeof(MESHPATCH)); - bzero((void *)(mp->patch + mp->npatches), + memset((void *)(mp->patch + mp->npatches), '\0', MPATCHBLKSIZ*sizeof(MESHPATCH)); } if (mp->npatches++ >= 1L<<22) @@ -353,7 +366,7 @@ MESHVERT *vp; } pp = &mp->patch[mp->npatches-1]; if (pp->xyz == NULL) { - pp->xyz = (uint4 (*)[3])calloc(256, 3*sizeof(int4)); + pp->xyz = (uint32 (*)[3])calloc(256, 3*sizeof(int32)); if (pp->xyz == NULL) goto nomem; } @@ -361,7 +374,7 @@ MESHVERT *vp; pp->xyz[pp->nverts][i] = cv.xyz[i]; if (cv.fl & MT_N) { if (pp->norm == NULL) { - pp->norm = (int4 *)calloc(256, sizeof(int4)); + pp->norm = (int32 *)calloc(256, sizeof(int32)); if (pp->norm == NULL) goto nomem; } @@ -369,8 +382,8 @@ MESHVERT *vp; } if (cv.fl & MT_UV) { if (pp->uv == NULL) { - pp->uv = (uint4 (*)[2])calloc(256, - 2*sizeof(uint4)); + pp->uv = (uint32 (*)[2])calloc(256, + 2*sizeof(uint32)); if (pp->uv == NULL) goto nomem; } @@ -379,9 +392,9 @@ MESHVERT *vp; } pp->nverts++; lvp->data = lvp->key + sizeof(MCVERT); - *(int4 *)lvp->data = (mp->npatches-1) << 8 | (pp->nverts-1); + *(int32 *)lvp->data = (mp->npatches-1) << 8 | (pp->nverts-1); } - return(*(int4 *)lvp->data); + return(*(int32 *)lvp->data); nomem: error(SYSTEM, "out of memory in addmeshvert"); return(-1); @@ -394,7 +407,7 @@ MESH *mp; MESHVERT tv[3]; OBJECT mo; { - int4 vid[3], t; + int32 vid[3], t; int pn[3], i; register MESHPATCH *pp; @@ -407,11 +420,12 @@ OBJECT mo; pn[i] = vid[i] >> 8; } /* normalize material index */ - if (mo != OVOID) + if (mo != OVOID) { if ((mo -= mp->mat0) >= mp->nmats) mp->nmats = mo+1; else if (mo < 0) error(INTERNAL, "modifier range error in addmeshtri"); + } /* assign triangle */ if (pn[0] == pn[1] && pn[1] == pn[2]) { /* local case */ pp = &mp->patch[pn[0]]; @@ -428,8 +442,8 @@ OBJECT mo; if (pp->ntris == 0) pp->solemat = mo; else if (pp->trimat == NULL && mo != pp->solemat) { - pp->trimat = (int2 *)malloc( - 512*sizeof(int2)); + pp->trimat = (int16 *)malloc( + 512*sizeof(int16)); if (pp->trimat == NULL) goto nomem; for (i = pp->ntris; i--; ) @@ -539,8 +553,6 @@ register MESH *mp; if (nouvbounds && pp->uv != NULL) return("unreferenced uv coordinates"); } - if (pp->ntris + pp->nj1tris + pp->nj2tris <= 0) - error(WARNING, "no triangles in patch"); if (pp->ntris > 0 && pp->tri == NULL) return("missing patch triangle list"); if (pp->nj1tris > 0 && pp->j1tri == NULL) @@ -608,12 +620,12 @@ FILE *fp; t2cnt += pp->nj2tris; } fprintf(fp, "Mesh statistics:\n"); - fprintf(fp, "\t%d materials\n", ms->nmats); + fprintf(fp, "\t%ld materials\n", ms->nmats); fprintf(fp, "\t%d patches (%.2f MBytes)\n", ms->npatches, (ms->npatches*sizeof(MESHPATCH) + - vcnt*3*sizeof(uint4) + - nscnt*sizeof(int4) + - uvscnt*2*sizeof(uint4) + + vcnt*3*sizeof(uint32) + + nscnt*sizeof(int32) + + uvscnt*2*sizeof(uint32) + tcnt*sizeof(struct PTri) + t1cnt*sizeof(struct PJoin1) + t2cnt*sizeof(struct PJoin2))/(1024.*1024.));
