root/Development/ray/src/common/mesh.c
Tue Jul 14 23:13:50 2020 UTC (5 years, 5 months ago) by greg
Diff to previous 2.33 , to selected 2.14
fix(mesh): reverted previous change (2.30) to better accommodate dense meshes
Sat Apr 4 04:34:08 2020 UTC (5 years, 8 months ago) by greg
Changes since 2.32: +3 -1 lines
Diff to previous 2.32 , to selected 2.14
Fixed segmentation error when running parallel processes on meshes with materials
Sat Dec 28 18:05:14 2019 UTC (5 years, 11 months ago) by greg
Changes since 2.31: +1 -3 lines
Diff to previous 2.31 , to selected 2.14
Tue Nov 27 06:20:37 2018 UTC (7 years ago) by greg
Changes since 2.30: +22 -20 lines
Diff to previous 2.30 , to selected 2.14
Added missing free() call
Tue Nov 27 01:04:33 2018 UTC (7 years ago) by greg
Diff to previous 2.29 , to selected 2.14
Realized I didn't need to minimize array size in every patch to avoid overflow
Tue Nov 27 00:42:26 2018 UTC (7 years ago) by greg
Changes since 2.28: +25 -8 lines
Diff to previous 2.28 , to selected 2.14
Made mesh building more robust to long triangles
Wed Mar 1 21:51:38 2017 UTC (8 years, 9 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.27: +10 -10 lines
Diff to previous 2.27 , to selected 2.14
Very minor improvement should not affect behavior
Tue Mar 22 03:56:17 2016 UTC (9 years, 8 months ago) by greg
Diff to previous 2.26 , to selected 2.14
Made error messages more consistent when library file not found
Tue Nov 6 17:12:35 2012 UTC (13 years, 1 month ago) by greg
Changes since 2.25: +5 -19 lines
Diff to previous 2.25 , to selected 2.14
Simplified nextmeshtri() logic considerably
Tue Nov 6 01:56:37 2012 UTC (13 years, 1 month ago) by greg
Changes since 2.24: +27 -27 lines
Diff to previous 2.24 , to selected 2.14
Fixed potential bugs in new routine -- still untested
Tue Nov 6 01:04:23 2012 UTC (13 years, 1 month ago) by greg
Changes since 2.23: +110 -56 lines
Diff to previous 2.23 , to selected 2.14
Added routine for cycling through all triangles
Fri Feb 18 00:40:25 2011 UTC (14 years, 10 months ago) by greg
Changes since 2.22: +4 -11 lines
Diff to previous 2.22 , to selected 2.14
Wed Dec 15 17:27:52 2010 UTC (15 years ago) by greg
Diff to previous 2.21 , to selected 2.14
Minor change to avoid compiler warning
Sat May 1 21:49:42 2010 UTC (15 years, 7 months ago) by greg
Diff to previous 2.20 , to selected 2.14
Removed C++ comments
Tue May 25 22:04:13 2004 UTC (21 years, 6 months ago) by greg
Diff to previous 2.19 , to selected 2.14
Sun Mar 28 20:33:12 2004 UTC (21 years, 8 months ago) by schorsch
Changes since 2.18: +12 -5 lines
Diff to previous 2.18 , to selected 2.14
Tue Mar 16 19:56:27 2004 UTC (21 years, 9 months ago) by greg
Changes since 2.17: +1 -3 lines
Diff to previous 2.17 , to selected 2.14
Removed spurious warning about triangle-less patches
Thu Feb 12 18:55:50 2004 UTC (21 years, 10 months ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16 , to selected 2.14
Fri Jan 30 00:08:31 2004 UTC (21 years, 10 months ago) by greg
Changes since 2.15: +8 -9 lines
Diff to previous 2.15 , to selected 2.14
Fri Nov 14 17:22:06 2003 UTC (22 years, 1 month ago) by schorsch
Diff to previous 2.14
Thu Sep 18 16:53:52 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.13: +7 -7 lines
Diff to previous 2.13
Mon Jul 21 22:30:17 2003 UTC (22 years, 5 months ago) by schorsch
Thu Jul 17 09:21:29 2003 UTC (22 years, 5 months ago) by schorsch
Thu Jul 10 03:47:00 2003 UTC (22 years, 5 months ago) by greg
Thu Jul 10 03:30:11 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.9: +11 -12 lines
Fixed potential bug in reference counting of mesh'es and instance's
Mon Jun 30 14:59:11 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 2.8: +5 -3 lines
Fri Jun 20 00:25:49 2003 UTC (22 years, 6 months ago) by greg
Changes since 2.7: +23 -23 lines
Tue May 13 17:58:32 2003 UTC (22 years, 7 months ago) by greg
Wed Apr 23 00:52:33 2003 UTC (22 years, 8 months ago) by greg
Fri Apr 18 22:10:20 2003 UTC (22 years, 8 months ago) by greg
Bug fix in mesh uv coordinate range checking
Fri Mar 14 21:27:45 2003 UTC (22 years, 9 months ago) by greg
Changes since 2.3: +159 -37 lines
Wed Mar 12 17:26:58 2003 UTC (22 years, 9 months ago) by greg
Changes since 2.2: +0 -0 lines
Wed Mar 12 04:59:04 2003 UTC (22 years, 9 months ago) by greg
Changes since 2.1: +27 -33 lines
Tue Mar 11 17:08:55 2003 UTC (22 years, 9 months ago) by greg
Diff to selected 2.14
