root/radiance/ray/src/common/mesh.c
Revision: 2.27
Committed: Tue Mar 22 03:56:17 2016 UTC (9 years, 3 months ago) by greg
Made error messages more consistent when library file not found
2 static const char RCSid[] = "$Id: mesh.c,v 2.26 2012/11/06 17:12:35 greg Exp $";
5 * Mesh support routines
6 */
7
8 #include <string.h>
9
10 #include "rtio.h"
11 #include "rtmath.h"
12 #include "rterror.h"
13 #include "paths.h"
14 #include "octree.h"
15 #include "object.h"
16 #include "otypes.h"
17 #include "mesh.h"
18
19 /* An encoded mesh vertex */
20 typedef struct {
21 int fl;
22 uint32 xyz[3];
23 int32 norm;
24 uint32 uv[2];
25 } MCVERT;
26
27 #define MPATCHBLKSIZ 128 /* patch allocation block size */
28
29 #define IO_LEGAL (IO_BOUNDS|IO_TREE|IO_SCENE)
30
31 static MESH *mlist = NULL; /* list of loaded meshes */
32
33
34 static unsigned long
35 cvhash(const char *p) /* hash an encoded vertex */
36 {
37 const MCVERT *cvp = (const MCVERT *)p;
38 unsigned long hval;
39
40 if (!(cvp->fl & MT_V))
41 return(0);
42 hval = cvp->xyz[0] ^ cvp->xyz[1] << 11 ^ cvp->xyz[2] << 22;
43 if (cvp->fl & MT_N)
44 hval ^= cvp->norm;
45 if (cvp->fl & MT_UV)
46 hval ^= cvp->uv[0] ^ cvp->uv[1] << 16;
47 return(hval);
48 }
49
50
51 static int
52 cvcmp(const char *vv1, const char *vv2) /* compare encoded vertices */
53 {
54 const MCVERT *v1 = (const MCVERT *)vv1, *v2 = (const MCVERT *)vv2;
55 if (v1->fl != v2->fl)
56 return(1);
57 if (v1->xyz[0] != v2->xyz[0])
58 return(1);
59 if (v1->xyz[1] != v2->xyz[1])
60 return(1);
61 if (v1->xyz[2] != v2->xyz[2])
62 return(1);
63 if (v1->fl & MT_N && v1->norm != v2->norm)
64 return(1);
65 if (v1->fl & MT_UV) {
66 if (v1->uv[0] != v2->uv[0])
67 return(1);
68 if (v1->uv[1] != v2->uv[1])
69 return(1);
70 }
71 return(0);
72 }
73
74
75 MESH *
76 getmesh( /* get new mesh data reference */
77 char *mname,
78 int flags
79 )
80 {
81 char *pathname;
82 MESH *ms;
83
84 flags &= IO_LEGAL;
85 for (ms = mlist; ms != NULL; ms = ms->next)
86 if (!strcmp(mname, ms->name)) {
87 ms->nref++; /* increase reference count */
88 break;
89 }
90 if (ms == NULL) { /* load first time */
91 ms = (MESH *)calloc(1, sizeof(MESH));
92 if (ms == NULL)
93 error(SYSTEM, "out of memory in getmesh");
94 ms->name = savestr(mname);
95 ms->nref = 1;
96 ms->mcube.cutree = EMPTY;
97 ms->next = mlist;
98 mlist = ms;
99 }
100 if ((pathname = getpath(mname, getrlibpath(), R_OK)) == NULL) {
101 sprintf(errmsg, "cannot find mesh file \"%s\"", mname);
102 error(SYSTEM, errmsg);
103 }
104 flags &= ~ms->ldflags;
105 if (flags)
106 readmesh(ms, pathname, flags);
107 return(ms);
108 }
109
110
111 MESHINST *
112 getmeshinst( /* create mesh instance */
113 OBJREC *o,
114 int flags
115 )
116 {
117 MESHINST *ins;
118
119 flags &= IO_LEGAL;
120 if ((ins = (MESHINST *)o->os) == NULL) {
121 if ((ins = (MESHINST *)malloc(sizeof(MESHINST))) == NULL)
122 error(SYSTEM, "out of memory in getmeshinst");
123 if (o->oargs.nsargs < 1)
124 objerror(o, USER, "bad # of arguments");
125 if (fullxf(&ins->x, o->oargs.nsargs-1,
126 o->oargs.sarg+1) != o->oargs.nsargs-1)
127 objerror(o, USER, "bad transform");
128 if (ins->x.f.sca < 0.0) {
129 ins->x.f.sca = -ins->x.f.sca;
130 ins->x.b.sca = -ins->x.b.sca;
131 }
132 ins->msh = NULL;
133 o->os = (char *)ins;
134 }
135 if (ins->msh == NULL)
136 ins->msh = getmesh(o->oargs.sarg[0], flags);
137 else if ((flags &= ~ins->msh->ldflags))
138 readmesh(ins->msh,
139 getpath(o->oargs.sarg[0], getrlibpath(), R_OK),
140 flags);
141 return(ins);
142 }
143
144
145 int
146 nextmeshtri( /* get next triangle ID */
147 OBJECT *tip,
148 MESH *mp
149 )
150 {
151 int pn;
152 MESHPATCH *pp;
153
154 pn = ++(*tip) >> 10; /* next triangle (OVOID init) */
155 while (pn < mp->npatches) {
156 pp = &mp->patch[pn];
157 if (!(*tip & 0x200)) { /* local triangle? */
158 if ((*tip & 0x1ff) < pp->ntris)
159 return(1);
160 *tip &= ~0x1ff; /* move on to single-joiners */
161 *tip |= 0x200;
162 }
163 if (!(*tip & 0x100)) { /* single joiner? */
164 if ((*tip & 0xff) < pp->nj1tris)
165 return(1);
166 *tip &= ~0xff; /* move on to double-joiners */
167 *tip |= 0x100;
168 }
169 if ((*tip & 0xff) < pp->nj2tris)
170 return(1);
171 *tip = ++pn << 10; /* first in next patch */
172 }
173 return(0); /* out of patches */
174 }
175
176 int
177 getmeshtrivid( /* get triangle vertex ID's */
178 int32 tvid[3],
179 OBJECT *mo,
180 MESH *mp,
181 OBJECT ti
182 )
183 {
184 int pn = ti >> 10;
185 MESHPATCH *pp;
186
187 if (pn >= mp->npatches)
188 return(0);
189 pp = &mp->patch[pn];
190 ti &= 0x3ff;
191 if (!(ti & 0x200)) { /* local triangle */
192 struct PTri *tp;
193 if (ti >= pp->ntris)
194 return(0);
195 tp = &pp->tri[ti];
196 tvid[0] = tvid[1] = tvid[2] = pn << 8;
197 tvid[0] |= tp->v1;
198 tvid[1] |= tp->v2;
199 tvid[2] |= tp->v3;
200 if (pp->trimat != NULL)
201 *mo = pp->trimat[ti];
202 else
203 *mo = pp->solemat;
204 if (*mo != OVOID)
205 *mo += mp->mat0;
206 return(1);
207 }
208 ti &= ~0x200;
209 if (!(ti & 0x100)) { /* single link vertex */
210 struct PJoin1 *tp1;
211 if (ti >= pp->nj1tris)
212 return(0);
213 tp1 = &pp->j1tri[ti];
214 tvid[0] = tp1->v1j;
215 tvid[1] = tvid[2] = pn << 8;
216 tvid[1] |= tp1->v2;
217 tvid[2] |= tp1->v3;
218 if ((*mo = tp1->mat) != OVOID)
219 *mo += mp->mat0;
220 return(1);
221 }
222 ti &= ~0x100;
223 { /* double link vertex */
224 struct PJoin2 *tp2;
225 if (ti >= pp->nj2tris)
226 return(0);
227 tp2 = &pp->j2tri[ti];
228 tvid[0] = tp2->v1j;
229 tvid[1] = tp2->v2j;
230 tvid[2] = pn << 8 | tp2->v3;
231 if ((*mo = tp2->mat) != OVOID)
232 *mo += mp->mat0;
233 }
234 return(1);
235 }
236
237
238 int
239 getmeshvert( /* get triangle vertex from ID */
240 MESHVERT *vp,
241 MESH *mp,
242 int32 vid,
243 int what
244 )
245 {
246 int pn = vid >> 8;
247 MESHPATCH *pp;
248 double vres;
249 int i;
250
251 vp->fl = 0;
252 if (pn >= mp->npatches)
253 return(0);
254 pp = &mp->patch[pn];
255 vid &= 0xff;
256 if (vid >= pp->nverts)
257 return(0);
258 /* get location */
259 if (what & MT_V) {
260 vres = (1./4294967296.)*mp->mcube.cusize;
261 for (i = 0; i < 3; i++)
262 vp->v[i] = mp->mcube.cuorg[i] +
263 (pp->xyz[vid][i] + .5)*vres;
264 vp->fl |= MT_V;
265 }
266 /* get normal */
267 if (what & MT_N && pp->norm != NULL && pp->norm[vid]) {
268 decodedir(vp->n, pp->norm[vid]);
269 vp->fl |= MT_N;
270 }
271 /* get (u,v) */
272 if (what & MT_UV && pp->uv != NULL && pp->uv[vid][0]) {
273 for (i = 0; i < 2; i++)
274 vp->uv[i] = mp->uvlim[0][i] +
275 (mp->uvlim[1][i] - mp->uvlim[0][i])*
276 (pp->uv[vid][i] + .5)*(1./4294967296.);
277 vp->fl |= MT_UV;
278 }
279 return(vp->fl);
280 }
281
282
283 OBJREC *
284 getmeshpseudo( /* get mesh pseudo object for material */
285 MESH *mp,
286 OBJECT mo
287 )
288 {
289 if (mo < mp->mat0 || mo >= mp->mat0 + mp->nmats)
290 error(INTERNAL, "modifier out of range in getmeshpseudo");
291 if (mp->pseudo == NULL) {
292 int i;
293 mp->pseudo = (OBJREC *)calloc(mp->nmats, sizeof(OBJREC));
294 if (mp->pseudo == NULL)
295 error(SYSTEM, "out of memory in getmeshpseudo");
296 for (i = mp->nmats; i--; ) {
297 mp->pseudo[i].omod = mp->mat0 + i;
298 mp->pseudo[i].otype = OBJ_FACE;
299 mp->pseudo[i].oname = "M-Tri";
300 }
301 }
302 return(&mp->pseudo[mo - mp->mat0]);
303 }
304
305
306 int
307 getmeshtri( /* get triangle vertices */
308 MESHVERT tv[3],
309 OBJECT *mo,
310 MESH *mp,
311 OBJECT ti,
312 int wha
313 )
314 {
315 int32 tvid[3];
316
317 if (!getmeshtrivid(tvid, mo, mp, ti))
318 return(0);
319
320 getmeshvert(&tv[0], mp, tvid[0], wha);
321 getmeshvert(&tv[1], mp, tvid[1], wha);
322 getmeshvert(&tv[2], mp, tvid[2], wha);
323
324 return(tv[0].fl & tv[1].fl & tv[2].fl);
325 }
326
327
328 int32
329 addmeshvert( /* find/add a mesh vertex */
330 MESH *mp,
331 MESHVERT *vp
332 )
333 {
334 LUENT *lvp;
335 MCVERT cv;
336 int i;
337
338 if (!(vp->fl & MT_V))
339 return(-1);
340 /* encode vertex */
341 for (i = 0; i < 3; i++) {
342 if (vp->v[i] < mp->mcube.cuorg[i])
343 return(-1);
344 if (vp->v[i] >= mp->mcube.cuorg[i] + mp->mcube.cusize)
345 return(-1);
346 cv.xyz[i] = (uint32)(4294967296. *
347 (vp->v[i] - mp->mcube.cuorg[i]) /
348 mp->mcube.cusize);
349 }
350 if (vp->fl & MT_N) /* assumes normalized! */
351 cv.norm = encodedir(vp->n);
352 if (vp->fl & MT_UV)
353 for (i = 0; i < 2; i++) {
354 if (vp->uv[i] <= mp->uvlim[0][i])
355 return(-1);
356 if (vp->uv[i] >= mp->uvlim[1][i])
357 return(-1);
358 cv.uv[i] = (uint32)(4294967296. *
359 (vp->uv[i] - mp->uvlim[0][i]) /
360 (mp->uvlim[1][i] - mp->uvlim[0][i]));
361 }
362 cv.fl = vp->fl;
363 if (mp->lut.tsiz == 0) {
364 mp->lut.hashf = cvhash;
365 mp->lut.keycmp = cvcmp;
366 mp->lut.freek = free;
367 if (!lu_init(&mp->lut, 50000))
368 goto nomem;
369 }
370 /* find entry */
371 lvp = lu_find(&mp->lut, (char *)&cv);
372 if (lvp == NULL)
373 goto nomem;
374 if (lvp->key == NULL) {
375 lvp->key = (char *)malloc(sizeof(MCVERT)+sizeof(int32));
376 memcpy((void *)lvp->key, (void *)&cv, sizeof(MCVERT));
377 }
378 if (lvp->data == NULL) { /* new vertex */
379 MESHPATCH *pp;
380 if (mp->npatches <= 0) {
381 mp->patch = (MESHPATCH *)calloc(MPATCHBLKSIZ,
382 sizeof(MESHPATCH));
383 if (mp->patch == NULL)
384 goto nomem;
385 mp->npatches = 1;
386 } else if (mp->patch[mp->npatches-1].nverts >= 256) {
387 if (mp->npatches % MPATCHBLKSIZ == 0) {
388 mp->patch = (MESHPATCH *)realloc(
389 (void *)mp->patch,
390 (mp->npatches + MPATCHBLKSIZ)*
391 sizeof(MESHPATCH));
392 memset((void *)(mp->patch + mp->npatches), '\0',
393 MPATCHBLKSIZ*sizeof(MESHPATCH));
394 }
395 if (mp->npatches++ >= 1L<<22)
396 error(INTERNAL, "too many mesh patches");
397 }
398 pp = &mp->patch[mp->npatches-1];
399 if (pp->xyz == NULL) {
400 pp->xyz = (uint32 (*)[3])calloc(256, 3*sizeof(int32));
401 if (pp->xyz == NULL)
402 goto nomem;
403 }
404 for (i = 0; i < 3; i++)
405 pp->xyz[pp->nverts][i] = cv.xyz[i];
406 if (cv.fl & MT_N) {
407 if (pp->norm == NULL) {
408 pp->norm = (int32 *)calloc(256, sizeof(int32));
409 if (pp->norm == NULL)
410 goto nomem;
411 }
412 pp->norm[pp->nverts] = cv.norm;
413 }
414 if (cv.fl & MT_UV) {
415 if (pp->uv == NULL) {
416 pp->uv = (uint32 (*)[2])calloc(256,
417 2*sizeof(uint32));
418 if (pp->uv == NULL)
419 goto nomem;
420 }
421 for (i = 0; i < 2; i++)
422 pp->uv[pp->nverts][i] = cv.uv[i];
423 }
424 pp->nverts++;
425 lvp->data = lvp->key + sizeof(MCVERT);
426 *(int32 *)lvp->data = (mp->npatches-1) << 8 | (pp->nverts-1);
427 }
428 return(*(int32 *)lvp->data);
429 nomem:
430 error(SYSTEM, "out of memory in addmeshvert");
431 return(-1);
432 }
433
434
435 OBJECT
436 addmeshtri( /* add a new mesh triangle */
437 MESH *mp,
438 MESHVERT tv[3],
439 OBJECT mo
440 )
441 {
442 int32 vid[3], t;
443 int pn[3], i;
444 MESHPATCH *pp;
445
446 if (!(tv[0].fl & tv[1].fl & tv[2].fl & MT_V))
447 return(OVOID);
448 /* find/allocate patch vertices */
449 for (i = 0; i < 3; i++) {
450 if ((vid[i] = addmeshvert(mp, &tv[i])) < 0)
451 return(OVOID);
452 pn[i] = vid[i] >> 8;
453 }
454 /* normalize material index */
455 if (mo != OVOID) {
456 if ((mo -= mp->mat0) >= mp->nmats)
457 mp->nmats = mo+1;
458 else if (mo < 0)
459 error(INTERNAL, "modifier range error in addmeshtri");
460 }
461 /* assign triangle */
462 if (pn[0] == pn[1] && pn[1] == pn[2]) { /* local case */
463 pp = &mp->patch[pn[0]];
464 if (pp->tri == NULL) {
465 pp->tri = (struct PTri *)malloc(
466 512*sizeof(struct PTri));
467 if (pp->tri == NULL)
468 goto nomem;
469 }
470 if (pp->ntris < 512) {
471 pp->tri[pp->ntris].v1 = vid[0] & 0xff;
472 pp->tri[pp->ntris].v2 = vid[1] & 0xff;
473 pp->tri[pp->ntris].v3 = vid[2] & 0xff;
474 if (pp->ntris == 0)
475 pp->solemat = mo;
476 else if (pp->trimat == NULL && mo != pp->solemat) {
477 pp->trimat = (int16 *)malloc(
478 512*sizeof(int16));
479 if (pp->trimat == NULL)
480 goto nomem;
481 for (i = pp->ntris; i--; )
482 pp->trimat[i] = pp->solemat;
483 }
484 if (pp->trimat != NULL)
485 pp->trimat[pp->ntris] = mo;
486 return(pn[0] << 10 | pp->ntris++);
487 }
488 }
489 if (pn[0] == pn[1]) {
490 t = vid[2]; vid[2] = vid[1]; vid[1] = vid[0]; vid[0] = t;
491 i = pn[2]; pn[2] = pn[1]; pn[1] = pn[0]; pn[0] = i;
492 } else if (pn[0] == pn[2]) {
493 t = vid[0]; vid[0] = vid[1]; vid[1] = vid[2]; vid[2] = t;
494 i = pn[0]; pn[0] = pn[1]; pn[1] = pn[2]; pn[2] = i;
495 }
496 if (pn[1] == pn[2]) { /* single link */
497 pp = &mp->patch[pn[1]];
498 if (pp->j1tri == NULL) {
499 pp->j1tri = (struct PJoin1 *)malloc(
500 256*sizeof(struct PJoin1));
501 if (pp->j1tri == NULL)
502 goto nomem;
503 }
504 if (pp->nj1tris < 256) {
505 pp->j1tri[pp->nj1tris].v1j = vid[0];
506 pp->j1tri[pp->nj1tris].v2 = vid[1] & 0xff;
507 pp->j1tri[pp->nj1tris].v3 = vid[2] & 0xff;
508 pp->j1tri[pp->nj1tris].mat = mo;
509 return(pn[1] << 10 | 0x200 | pp->nj1tris++);
510 }
511 }
512 /* double link */
513 pp = &mp->patch[pn[2]];
514 if (pp->j2tri == NULL) {
515 pp->j2tri = (struct PJoin2 *)malloc(
516 256*sizeof(struct PJoin2));
517 if (pp->j2tri == NULL)
518 goto nomem;
519 }
520 if (pp->nj2tris >= 256)
521 error(INTERNAL, "too many patch triangles in addmeshtri");
522 pp->j2tri[pp->nj2tris].v1j = vid[0];
523 pp->j2tri[pp->nj2tris].v2j = vid[1];
524 pp->j2tri[pp->nj2tris].v3 = vid[2] & 0xff;
525 pp->j2tri[pp->nj2tris].mat = mo;
526 return(pn[2] << 10 | 0x300 | pp->nj2tris++);
527 nomem:
528 error(SYSTEM, "out of memory in addmeshtri");
529 return(OVOID);
530 }
531
532
533 char *
534 checkmesh(MESH *mp) /* validate mesh data */
535 {
536 static char embuf[128];
537 int nouvbounds = 1;
538 int i;
539 /* basic checks */
540 if (mp == NULL)
541 return("NULL mesh pointer");
542 if (!mp->ldflags)
543 return("unassigned mesh");
544 if (mp->name == NULL)
545 return("missing mesh name");
546 if (mp->nref <= 0)
547 return("unreferenced mesh");
548 /* check boundaries */
549 if (mp->ldflags & IO_BOUNDS) {
550 if (mp->mcube.cusize <= FTINY)
551 return("illegal octree bounds in mesh");
552 nouvbounds = (mp->uvlim[1][0] - mp->uvlim[0][0] <= FTINY ||
553 mp->uvlim[1][1] - mp->uvlim[0][1] <= FTINY);
554 }
555 /* check octree */
556 if (mp->ldflags & IO_TREE) {
557 if (isempty(mp->mcube.cutree))
558 error(WARNING, "empty mesh octree");
559 }
560 /* check scene data */
561 if (mp->ldflags & IO_SCENE) {
562 if (!(mp->ldflags & IO_BOUNDS))
563 return("unbounded scene in mesh");
564 if (mp->mat0 < 0 || mp->mat0+mp->nmats > nobjects)
565 return("bad mesh modifier range");
566 for (i = mp->mat0+mp->nmats; i-- > mp->mat0; ) {
567 int otyp = objptr(i)->otype;
568 if (!ismodifier(otyp)) {
569 sprintf(embuf,
570 "non-modifier in mesh (%s \"%s\")",
571 ofun[otyp].funame, objptr(i)->oname);
572 return(embuf);
573 }
574 }
575 if (mp->npatches <= 0)
576 error(WARNING, "no patches in mesh");
577 for (i = 0; i < mp->npatches; i++) {
578 MESHPATCH *pp = &mp->patch[i];
579 if (pp->nverts <= 0)
580 error(WARNING, "no vertices in patch");
581 else {
582 if (pp->xyz == NULL)
583 return("missing patch vertex list");
584 if (nouvbounds && pp->uv != NULL)
585 return("unreferenced uv coordinates");
586 }
587 if (pp->ntris > 0 && pp->tri == NULL)
588 return("missing patch triangle list");
589 if (pp->nj1tris > 0 && pp->j1tri == NULL)
590 return("missing patch joiner triangle list");
591 if (pp->nj2tris > 0 && pp->j2tri == NULL)
592 return("missing patch double-joiner list");
593 }
594 }
595 return(NULL); /* seems OK */
596 }
597
598
599 static void
600 tallyoctree( /* tally octree size */
601 OCTREE ot,
602 int *ecp,
603 int *lcp,
604 int *ocp
605 )
606 {
607 int i;
608
609 if (isempty(ot)) {
610 (*ecp)++;
611 return;
612 }
613 if (isfull(ot)) {
614 OBJECT oset[MAXSET+1];
615 (*lcp)++;
616 objset(oset, ot);
617 *ocp += oset[0];
618 return;
619 }
620 for (i = 0; i < 8; i++)
621 tallyoctree(octkid(ot, i), ecp, lcp, ocp);
622 }
623
624
625 void
626 printmeshstats( /* print out mesh statistics */
627 MESH *ms,
628 FILE *fp
629 )
630 {
631 int lfcnt=0, lecnt=0, locnt=0;
632 int vcnt=0, ncnt=0, uvcnt=0;
633 int nscnt=0, uvscnt=0;
634 int tcnt=0, t1cnt=0, t2cnt=0;
635 int i, j;
636
637 tallyoctree(ms->mcube.cutree, &lecnt, &lfcnt, &locnt);
638 for (i = 0; i < ms->npatches; i++) {
639 MESHPATCH *pp = &ms->patch[i];
640 vcnt += pp->nverts;
641 if (pp->norm != NULL) {
642 for (j = pp->nverts; j--; )
643 if (pp->norm[j])
644 ncnt++;
645 nscnt += pp->nverts;
646 }
647 if (pp->uv != NULL) {
648 for (j = pp->nverts; j--; )
649 if (pp->uv[j][0])
650 uvcnt++;
651 uvscnt += pp->nverts;
652 }
653 tcnt += pp->ntris;
654 t1cnt += pp->nj1tris;
655 t2cnt += pp->nj2tris;
656 }
657 fprintf(fp, "Mesh statistics:\n");
658 fprintf(fp, "\t%ld materials\n", (long)ms->nmats);
659 fprintf(fp, "\t%d patches (%.2f MBytes)\n", ms->npatches,
660 (ms->npatches*sizeof(MESHPATCH) +
661 vcnt*3*sizeof(uint32) +
662 nscnt*sizeof(int32) +
663 uvscnt*2*sizeof(uint32) +
664 tcnt*sizeof(struct PTri) +
665 t1cnt*sizeof(struct PJoin1) +
666 t2cnt*sizeof(struct PJoin2))/(1024.*1024.));
667 fprintf(fp, "\t%d vertices (%.1f%% w/ normals, %.1f%% w/ uv)\n",
668 vcnt, 100.*ncnt/vcnt, 100.*uvcnt/vcnt);
669 fprintf(fp, "\t%d triangles (%.1f%% local, %.1f%% joiner)\n",
670 tcnt+t1cnt+t2cnt,
671 100.*tcnt/(tcnt+t1cnt+t2cnt),
672 100.*t1cnt/(tcnt+t1cnt+t2cnt));
673 fprintf(fp,
674 "\t%d leaves in octree (%.1f%% empty, %.2f avg. set size)\n",
675 lfcnt+lecnt, 100.*lecnt/(lfcnt+lecnt),
676 (double)locnt/lfcnt);
677 }
678
679
680 void
681 freemesh(MESH *ms) /* free mesh data */
682 {
683 MESH mhead;
684 MESH *msp;
685
686 if (ms == NULL)
687 return;
688 if (ms->nref <= 0)
689 error(CONSISTENCY, "unreferenced mesh in freemesh");
690 ms->nref--;
691 if (ms->nref) /* still in use */
692 return;
693 /* else remove from list */
694 mhead.next = mlist;
695 for (msp = &mhead; msp->next != NULL; msp = msp->next)
696 if (msp->next == ms) {
697 msp->next = ms->next;
698 ms->next = NULL;
699 break;
700 }
701 if (ms->next != NULL) /* can't be in list anymore */
702 error(CONSISTENCY, "unlisted mesh in freemesh");
703 mlist = mhead.next;
704 /* free mesh data */
705 freestr(ms->name);
706 octfree(ms->mcube.cutree);
707 lu_done(&ms->lut);
708 if (ms->npatches > 0) {
709 MESHPATCH *pp = ms->patch + ms->npatches;
710 while (pp-- > ms->patch) {
711 if (pp->j2tri != NULL)
712 free((void *)pp->j2tri);
713 if (pp->j1tri != NULL)
714 free((void *)pp->j1tri);
715 if (pp->tri != NULL)
716 free((void *)pp->tri);
717 if (pp->uv != NULL)
718 free((void *)pp->uv);
719 if (pp->norm != NULL)
720 free((void *)pp->norm);
721 if (pp->xyz != NULL)
722 free((void *)pp->xyz);
723 }
724 free((void *)ms->patch);
725 }
726 if (ms->pseudo != NULL)
727 free((void *)ms->pseudo);
728 free((void *)ms);
729 }
730
731
732 void
733 freemeshinst(OBJREC *o) /* free mesh instance */
734 {
735 if (o->os == NULL)
736 return;
737 freemesh((*(MESHINST *)o->os).msh);
738 free((void *)o->os);
739 o->os = NULL;
740 }
