root/radiance/ray/src/common/mesh.c
Wed Mar 1 21:51:38 2017 UTC (7 years, 3 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.27: +10 -10 lines
Diff to previous 2.27 , to selected 2.7
Very minor improvement should not affect behavior
Tue Mar 22 03:56:17 2016 UTC (8 years, 2 months ago) by greg
Diff to previous 2.26 , to selected 2.7
Made error messages more consistent when library file not found
Tue Nov 6 17:12:35 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.25: +5 -19 lines
Diff to previous 2.25 , to selected 2.7
Simplified nextmeshtri() logic considerably
Tue Nov 6 01:56:37 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.24: +27 -27 lines
Diff to previous 2.24 , to selected 2.7
Fixed potential bugs in new routine -- still untested
Tue Nov 6 01:04:23 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.23: +110 -56 lines
Diff to previous 2.23 , to selected 2.7
Added routine for cycling through all triangles
Changes since 2.22: +4 -11 lines
Diff to previous 2.22 , to selected 2.7
Wed Dec 15 17:27:52 2010 UTC (13 years, 5 months ago) by greg
Diff to previous 2.21 , to selected 2.7
Minor change to avoid compiler warning
Sat May 1 21:49:42 2010 UTC (14 years, 1 month ago) by greg
Diff to previous 2.20 , to selected 2.7
Removed C++ comments
Tue May 25 22:04:13 2004 UTC (20 years ago) by greg
Diff to previous 2.19 , to selected 2.7
Changes since 2.18: +12 -5 lines
Diff to previous 2.18 , to selected 2.7
Tue Mar 16 19:56:27 2004 UTC (20 years, 2 months ago) by greg
Changes since 2.17: +1 -3 lines
Diff to previous 2.17 , to selected 2.7
Removed spurious warning about triangle-less patches
Thu Feb 12 18:55:50 2004 UTC (20 years, 3 months ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16 , to selected 2.7
Fri Jan 30 00:08:31 2004 UTC (20 years, 4 months ago) by greg
Changes since 2.15: +8 -9 lines
Diff to previous 2.15 , to selected 2.7
Diff to previous 2.14 , to selected 2.7
Thu Sep 18 16:53:52 2003 UTC (20 years, 8 months ago) by greg
Changes since 2.13: +7 -7 lines
Mon Jul 21 22:30:17 2003 UTC (20 years, 10 months ago) by schorsch
Thu Jul 10 03:47:00 2003 UTC (20 years, 10 months ago) by greg
Thu Jul 10 03:30:11 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.9: +11 -12 lines
Fixed potential bug in reference counting of mesh'es and instance's
Changes since 2.8: +5 -3 lines
Changes since 2.7: +23 -23 lines
Tue May 13 17:58:32 2003 UTC (21 years ago) by greg
Wed Apr 23 00:52:33 2003 UTC (21 years, 1 month ago) by greg
Fri Apr 18 22:10:20 2003 UTC (21 years, 1 month ago) by greg
Bug fix in mesh uv coordinate range checking
Fri Mar 14 21:27:45 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.3: +159 -37 lines
Wed Mar 12 17:26:58 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.2: +0 -0 lines
Wed Mar 12 04:59:04 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.1: +27 -33 lines
Diff to selected 2.7
