root/Development/ray/src/common/mesh.c
Tue May 25 22:04:13 2004 UTC (21 years, 6 months ago) by greg
Diff to previous 2.19 , to selected 2.2
Sun Mar 28 20:33:12 2004 UTC (21 years, 8 months ago) by schorsch
Changes since 2.18: +12 -5 lines
Diff to previous 2.18 , to selected 2.2
Tue Mar 16 19:56:27 2004 UTC (21 years, 9 months ago) by greg
Changes since 2.17: +1 -3 lines
Removed spurious warning about triangle-less patches
Thu Feb 12 18:55:50 2004 UTC (21 years, 10 months ago) by greg
Changes since 2.16: +2 -1 lines
Fri Jan 30 00:08:31 2004 UTC (21 years, 10 months ago) by greg
Changes since 2.15: +8 -9 lines
Fri Nov 14 17:22:06 2003 UTC (22 years, 1 month ago) by schorsch
Thu Sep 18 16:53:52 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.13: +7 -7 lines
Mon Jul 21 22:30:17 2003 UTC (22 years, 5 months ago) by schorsch
Thu Jul 17 09:21:29 2003 UTC (22 years, 5 months ago) by schorsch
Thu Jul 10 03:47:00 2003 UTC (22 years, 5 months ago) by greg
Thu Jul 10 03:30:11 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.9: +11 -12 lines
Fixed potential bug in reference counting of mesh'es and instance's
Mon Jun 30 14:59:11 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 2.8: +5 -3 lines
Fri Jun 20 00:25:49 2003 UTC (22 years, 6 months ago) by greg
Changes since 2.7: +23 -23 lines
Tue May 13 17:58:32 2003 UTC (22 years, 7 months ago) by greg
Wed Apr 23 00:52:33 2003 UTC (22 years, 8 months ago) by greg
Fri Apr 18 22:10:20 2003 UTC (22 years, 8 months ago) by greg
Bug fix in mesh uv coordinate range checking
Fri Mar 14 21:27:45 2003 UTC (22 years, 9 months ago) by greg
Changes since 2.3: +159 -37 lines
Wed Mar 12 17:26:58 2003 UTC (22 years, 9 months ago) by greg
Changes since 2.2: +0 -0 lines
Wed Mar 12 04:59:04 2003 UTC (22 years, 9 months ago) by greg
Changes since 2.1: +27 -33 lines
Tue Mar 11 17:08:55 2003 UTC (22 years, 9 months ago) by greg
Diff to selected 2.2
