--- ray/src/common/mesh.c 2003/03/11 17:08:55 2.1 +++ ray/src/common/mesh.c 2003/04/18 22:10:20 2.5 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mesh.c,v 2.1 2003/03/11 17:08:55 greg Exp $"; +static const char RCSid[] = "$Id: mesh.c,v 2.5 2003/04/18 22:10:20 greg Exp $"; #endif /* * Mesh support routines @@ -8,15 +8,15 @@ static const char RCSid[] = "$Id: mesh.c,v 2.1 2003/03 #include "standard.h" #include "octree.h" #include "object.h" +#include "otypes.h" #include "mesh.h" -#include "lookup.h" /* An encoded mesh vertex */ typedef struct { int fl; uint4 xyz[3]; int4 norm; - int4 uv[2]; + uint4 uv[2]; } MCVERT; #define MPATCHBLKSIZ 128 /* patch allocation block size */ @@ -135,48 +135,61 @@ int flags; int -getmeshtrivid(tvid, mp, ti) /* get triangle vertex ID's */ -int4 tvid[3]; -register MESH *mp; -OBJECT ti; +getmeshtrivid(tvid, mo, mp, ti) /* get triangle vertex ID's */ +int4 tvid[3]; +OBJECT *mo; +MESH *mp; +OBJECT ti; { int pn = ti >> 10; + MESHPATCH *pp; if (pn >= mp->npatches) return(0); + pp = &mp->patch[pn]; ti &= 0x3ff; if (!(ti & 0x200)) { /* local triangle */ struct PTri *tp; - if (ti >= mp->patch[pn].ntris) + if (ti >= pp->ntris) return(0); - tp = &mp->patch[pn].tri[ti]; + tp = &pp->tri[ti]; tvid[0] = tvid[1] = tvid[2] = pn << 8; tvid[0] |= tp->v1; tvid[1] |= tp->v2; tvid[2] |= tp->v3; + if (pp->trimat != NULL) + *mo = pp->trimat[ti]; + else + *mo = pp->solemat; + if (*mo != OVOID) + *mo += mp->mat0; return(1); } ti &= ~0x200; if (!(ti & 0x100)) { /* single link vertex */ struct PJoin1 *tp1; - if (ti >= mp->patch[pn].nj1tris) + if (ti >= pp->nj1tris) return(0); - tp1 = &mp->patch[pn].j1tri[ti]; + tp1 = &pp->j1tri[ti]; tvid[0] = tp1->v1j; tvid[1] = tvid[2] = pn << 8; tvid[1] |= tp1->v2; tvid[2] |= tp1->v3; + if ((*mo = tp1->mat) != OVOID) + *mo += mp->mat0; return(1); } ti &= ~0x100; { /* double link vertex */ struct PJoin2 *tp2; - if (ti >= mp->patch[pn].nj2tris) + if (ti >= pp->nj2tris) return(0); - tp2 = &mp->patch[pn].j2tri[ti]; + tp2 = &pp->j2tri[ti]; tvid[0] = tp2->v1j; tvid[1] = tp2->v2j; tvid[2] = pn << 8 | tp2->v3; + if ((*mo = tp2->mat) != OVOID) + *mo += mp->mat0; } return(1); } @@ -184,10 +197,10 @@ OBJECT ti; int getmeshvert(vp, mp, vid, what) /* get triangle vertex from ID */ -MESHVERT *vp; -register MESH *mp; -int4 vid; -int what; +MESHVERT*vp; +MESH *mp; +int4 vid; +int what; { int pn = vid >> 8; MESHPATCH *pp; @@ -217,8 +230,8 @@ int what; /* get (u,v) */ if (what & MT_UV && pp->uv != NULL && pp->uv[vid][0]) { for (i = 0; i < 2; i++) - vp->uv[i] = mp->uvlim[i][0] + - (mp->uvlim[i][1] - mp->uvlim[i][0])* + vp->uv[i] = mp->uvlim[0][i] + + (mp->uvlim[1][i] - mp->uvlim[0][i])* (pp->uv[vid][i] + .5)*(1./4294967296.); vp->fl |= MT_UV; } @@ -226,21 +239,44 @@ int what; } +OBJREC * +getmeshpseudo(mp, mo) /* get mesh pseudo object for material */ +MESH *mp; +OBJECT mo; +{ + if (mo < mp->mat0 || mo >= mp->mat0 + mp->nmats) + error(INTERNAL, "modifier out of range in getmeshpseudo"); + if (mp->pseudo == NULL) { + register int i; + mp->pseudo = (OBJREC *)calloc(mp->nmats, sizeof(OBJREC)); + if (mp->pseudo == NULL) + error(SYSTEM, "out of memory in getmeshpseudo"); + for (i = mp->nmats; i--; ) { + mp->pseudo[i].omod = mp->mat0 + i; + mp->pseudo[i].otype = OBJ_FACE; + mp->pseudo[i].oname = "M-Tri"; + } + } + return(&mp->pseudo[mo - mp->mat0]); +} + + int -getmeshtri(tv, mp, ti, what) /* get triangle vertices */ +getmeshtri(tv, mo, mp, ti, wha) /* get triangle vertices */ MESHVERT tv[3]; +OBJECT *mo; MESH *mp; OBJECT ti; -int what; +int wha; { int4 tvid[3]; - if (!getmeshtrivid(tvid, mp, ti)) + if (!getmeshtrivid(tvid, mo, mp, ti)) return(0); - getmeshvert(&tv[0], mp, tvid[0], what); - getmeshvert(&tv[1], mp, tvid[1], what); - getmeshvert(&tv[2], mp, tvid[2], what); + getmeshvert(&tv[0], mp, tvid[0], wha); + getmeshvert(&tv[1], mp, tvid[1], wha); + getmeshvert(&tv[2], mp, tvid[2], wha); return(tv[0].fl & tv[1].fl & tv[2].fl); } @@ -251,7 +287,6 @@ addmeshvert(mp, vp) /* find/add a mesh vertex */ register MESH *mp; MESHVERT *vp; { - LUTAB *ltp; LUENT *lvp; MCVERT cv; register int i; @@ -272,29 +307,24 @@ MESHVERT *vp; cv.norm = encodedir(vp->n); if (vp->fl & MT_UV) for (i = 0; i < 2; i++) { - if (vp->uv[i] <= mp->uvlim[i][0]) + if (vp->uv[i] <= mp->uvlim[0][i]) return(-1); - if (vp->uv[i] >= mp->uvlim[i][1]) + if (vp->uv[i] >= mp->uvlim[1][i]) return(-1); cv.uv[i] = (uint4)(4294967296. * - (vp->uv[i] - mp->uvlim[i][0]) / - (mp->uvlim[i][1] - mp->uvlim[i][0])); + (vp->uv[i] - mp->uvlim[0][i]) / + (mp->uvlim[1][i] - mp->uvlim[0][i])); } cv.fl = vp->fl; - ltp = (LUTAB *)mp->cdata; /* get lookup table */ - if (ltp == NULL) { - ltp = (LUTAB *)calloc(1, sizeof(LUTAB)); - if (ltp == NULL) + if (mp->lut.tsiz == 0) { + mp->lut.hashf = cvhash; + mp->lut.keycmp = cvcmp; + mp->lut.freek = free; + if (!lu_init(&mp->lut, 50000)) goto nomem; - ltp->hashf = cvhash; - ltp->keycmp = cvcmp; - ltp->freek = free; - if (!lu_init(ltp, 50000)) - goto nomem; - mp->cdata = (char *)ltp; } /* find entry */ - lvp = lu_find(ltp, (char *)&cv); + lvp = lu_find(&mp->lut, (char *)&cv); if (lvp == NULL) goto nomem; if (lvp->key == NULL) { @@ -318,7 +348,7 @@ MESHVERT *vp; bzero((void *)(mp->patch + mp->npatches), MPATCHBLKSIZ*sizeof(MESHPATCH)); } - if (mp->npatches++ >= 1<<20) + if (mp->npatches++ >= 1L<<22) error(INTERNAL, "too many mesh patches"); } pp = &mp->patch[mp->npatches-1]; @@ -359,9 +389,10 @@ nomem: OBJECT -addmeshtri(mp, tv) /* add a new mesh triangle */ +addmeshtri(mp, tv, mo) /* add a new mesh triangle */ MESH *mp; MESHVERT tv[3]; +OBJECT mo; { int4 vid[3], t; int pn[3], i; @@ -375,6 +406,12 @@ MESHVERT tv[3]; return(OVOID); pn[i] = vid[i] >> 8; } + /* normalize material index */ + if (mo != OVOID) + if ((mo -= mp->mat0) >= mp->nmats) + mp->nmats = mo+1; + else if (mo < 0) + error(INTERNAL, "modifier range error in addmeshtri"); /* assign triangle */ if (pn[0] == pn[1] && pn[1] == pn[2]) { /* local case */ pp = &mp->patch[pn[0]]; @@ -384,20 +421,31 @@ MESHVERT tv[3]; if (pp->tri == NULL) goto nomem; } - if (pp->ntris >= 512) - goto toomany; - pp->tri[pp->ntris].v1 = vid[0] & 0xff; - pp->tri[pp->ntris].v2 = vid[1] & 0xff; - pp->tri[pp->ntris].v3 = vid[2] & 0xff; - - return(pn[0] << 10 | pp->ntris++); + if (pp->ntris < 512) { + pp->tri[pp->ntris].v1 = vid[0] & 0xff; + pp->tri[pp->ntris].v2 = vid[1] & 0xff; + pp->tri[pp->ntris].v3 = vid[2] & 0xff; + if (pp->ntris == 0) + pp->solemat = mo; + else if (pp->trimat == NULL && mo != pp->solemat) { + pp->trimat = (int2 *)malloc( + 512*sizeof(int2)); + if (pp->trimat == NULL) + goto nomem; + for (i = pp->ntris; i--; ) + pp->trimat[i] = pp->solemat; + } + if (pp->trimat != NULL) + pp->trimat[pp->ntris] = mo; + return(pn[0] << 10 | pp->ntris++); + } } if (pn[0] == pn[1]) { - t = vid[2]; vid[2] = vid[0]; vid[0] = t; - i = pn[2]; pn[2] = pn[0]; pn[0] = i; + t = vid[2]; vid[2] = vid[1]; vid[1] = vid[0]; vid[0] = t; + i = pn[2]; pn[2] = pn[1]; pn[1] = pn[0]; pn[0] = i; } else if (pn[0] == pn[2]) { - t = vid[0]; vid[0] = vid[1]; vid[1] = t; - i = pn[0]; pn[0] = pn[1]; pn[1] = i; + t = vid[0]; vid[0] = vid[1]; vid[1] = vid[2]; vid[2] = t; + i = pn[0]; pn[0] = pn[1]; pn[1] = pn[2]; pn[2] = i; } if (pn[1] == pn[2]) { /* single link */ pp = &mp->patch[pn[1]]; @@ -407,13 +455,13 @@ MESHVERT tv[3]; if (pp->j1tri == NULL) goto nomem; } - if (pp->nj1tris >= 256) - goto toomany; - pp->j1tri[pp->nj1tris].v1j = pn[0] << 8 | (vid[0] & 0xff); - pp->j1tri[pp->nj1tris].v2 = vid[1] & 0xff; - pp->j1tri[pp->nj1tris].v3 = vid[2] & 0xff; - - return(pn[1] << 10 | 0x200 | pp->nj1tris++); + if (pp->nj1tris < 256) { + pp->j1tri[pp->nj1tris].v1j = vid[0]; + pp->j1tri[pp->nj1tris].v2 = vid[1] & 0xff; + pp->j1tri[pp->nj1tris].v3 = vid[2] & 0xff; + pp->j1tri[pp->nj1tris].mat = mo; + return(pn[1] << 10 | 0x200 | pp->nj1tris++); + } } /* double link */ pp = &mp->patch[pn[2]]; @@ -424,21 +472,87 @@ MESHVERT tv[3]; goto nomem; } if (pp->nj2tris >= 256) - goto toomany; - pp->j2tri[pp->nj2tris].v1j = pn[0] << 8 | (vid[0] & 0xff); - pp->j2tri[pp->nj2tris].v2j = pn[1] << 8 | (vid[1] & 0xff); + error(INTERNAL, "too many patch triangles in addmeshtri"); + pp->j2tri[pp->nj2tris].v1j = vid[0]; + pp->j2tri[pp->nj2tris].v2j = vid[1]; pp->j2tri[pp->nj2tris].v3 = vid[2] & 0xff; - + pp->j2tri[pp->nj2tris].mat = mo; return(pn[2] << 10 | 0x300 | pp->nj2tris++); nomem: error(SYSTEM, "out of memory in addmeshtri"); return(OVOID); -toomany: - error(CONSISTENCY, "too many patch triangles in addmeshtri"); - return(OVOID); } +char * +checkmesh(mp) /* validate mesh data */ +register MESH *mp; +{ + static char embuf[128]; + int nouvbounds = 1; + register int i; + /* basic checks */ + if (mp == NULL) + return("NULL mesh pointer"); + if (!mp->ldflags) + return("unassigned mesh"); + if (mp->name == NULL) + return("missing mesh name"); + if (mp->nref <= 0) + return("unreferenced mesh"); + /* check boundaries */ + if (mp->ldflags & IO_BOUNDS) { + if (mp->mcube.cusize <= FTINY) + return("illegal octree bounds in mesh"); + nouvbounds = (mp->uvlim[1][0] - mp->uvlim[0][0] <= FTINY || + mp->uvlim[1][1] - mp->uvlim[0][1] <= FTINY); + } + /* check octree */ + if (mp->ldflags & IO_TREE) { + if (isempty(mp->mcube.cutree)) + error(WARNING, "empty mesh octree"); + } + /* check scene data */ + if (mp->ldflags & IO_SCENE) { + if (!(mp->ldflags & IO_BOUNDS)) + return("unbounded scene in mesh"); + if (mp->mat0 < 0 || mp->mat0+mp->nmats > nobjects) + return("bad mesh modifier range"); + for (i = mp->mat0+mp->nmats; i-- > mp->mat0; ) { + int otyp = objptr(i)->otype; + if (!ismodifier(otyp)) { + sprintf(embuf, + "non-modifier in mesh (%s \"%s\")", + ofun[otyp].funame, objptr(i)->oname); + return(embuf); + } + } + if (mp->npatches <= 0) + error(WARNING, "no patches in mesh"); + for (i = 0; i < mp->npatches; i++) { + register MESHPATCH *pp = &mp->patch[i]; + if (pp->nverts <= 0) + error(WARNING, "no vertices in patch"); + else { + if (pp->xyz == NULL) + return("missing patch vertex list"); + if (nouvbounds && pp->uv != NULL) + return("unreferenced uv coordinates"); + } + if (pp->ntris + pp->nj1tris + pp->nj2tris <= 0) + error(WARNING, "no triangles in patch"); + if (pp->ntris > 0 && pp->tri == NULL) + return("missing patch triangle list"); + if (pp->nj1tris > 0 && pp->j1tri == NULL) + return("missing patch joiner triangle list"); + if (pp->nj2tris > 0 && pp->j2tri == NULL) + return("missing patch double-joiner list"); + } + } + return(NULL); /* seems OK */ +} + + static void tallyoctree(ot, ecp, lcp, ocp) /* tally octree size */ OCTREE ot; @@ -494,6 +608,7 @@ FILE *fp; t2cnt += pp->nj2tris; } fprintf(fp, "Mesh statistics:\n"); + fprintf(fp, "\t%d materials\n", ms->nmats); fprintf(fp, "\t%d patches (%.2f MBytes)\n", ms->npatches, (ms->npatches*sizeof(MESHPATCH) + vcnt*3*sizeof(uint4) + @@ -517,7 +632,7 @@ FILE *fp; void freemesh(ms) /* free mesh data */ -MESH *ms; +register MESH *ms; { MESH mhead; MESH *msp; @@ -543,8 +658,7 @@ MESH *ms; /* free mesh data */ freestr(ms->name); octfree(ms->mcube.cutree); - if (ms->cdata != NULL) - lu_done((LUTAB *)ms->cdata); + lu_done(&ms->lut); if (ms->npatches > 0) { register MESHPATCH *pp = ms->patch + ms->npatches; while (pp-- > ms->patch) { @@ -563,6 +677,8 @@ MESH *ms; } free((void *)ms->patch); } + if (ms->pseudo != NULL) + free((void *)ms->pseudo); free((void *)ms); }
