--- ray/src/common/mesh.c 2003/03/12 17:26:58 2.3 +++ ray/src/common/mesh.c 2003/11/14 17:22:06 2.15 @@ -1,22 +1,27 @@ #ifndef lint -static const char RCSid[] = "$Id: mesh.c,v 2.3 2003/03/12 17:26:58 greg Exp $"; +static const char RCSid[] = "$Id: mesh.c,v 2.15 2003/11/14 17:22:06 schorsch Exp $"; #endif /* * Mesh support routines */ -#include "standard.h" +#include + +#include "rtio.h" +#include "rtmath.h" +#include "rterror.h" + #include "octree.h" #include "object.h" +#include "otypes.h" #include "mesh.h" -#include "lookup.h" /* An encoded mesh vertex */ typedef struct { int fl; - uint4 xyz[3]; - int4 norm; - uint4 uv[2]; + uint32 xyz[3]; + int32 norm; + uint16 uv[2]; } MCVERT; #define MPATCHBLKSIZ 128 /* patch allocation block size */ @@ -68,7 +73,7 @@ register MCVERT *v1, *v2; MESH * -getmesh(mname, flags) /* get mesh data */ +getmesh(mname, flags) /* get new mesh data reference */ char *mname; int flags; { @@ -78,13 +83,10 @@ int flags; flags &= IO_LEGAL; for (ms = mlist; ms != NULL; ms = ms->next) if (!strcmp(mname, ms->name)) { - if ((ms->ldflags & flags) == flags) { - ms->nref++; - return(ms); /* loaded */ - } - break; /* load the rest */ + ms->nref++; /* increase reference count */ + break; } - if (ms == NULL) { + if (ms == NULL) { /* load first time */ ms = (MESH *)calloc(1, sizeof(MESH)); if (ms == NULL) error(SYSTEM, "out of memory in getmesh"); @@ -94,7 +96,7 @@ int flags; ms->next = mlist; mlist = ms; } - if ((pathname = getpath(mname, getlibpath(), R_OK)) == NULL) { + if ((pathname = getpath(mname, getrlibpath(), R_OK)) == NULL) { sprintf(errmsg, "cannot find mesh file \"%s\"", mname); error(USER, errmsg); } @@ -128,55 +130,72 @@ int flags; ins->msh = NULL; o->os = (char *)ins; } - if (ins->msh == NULL || (ins->msh->ldflags & flags) != flags) + if (ins->msh == NULL) ins->msh = getmesh(o->oargs.sarg[0], flags); + else if ((flags &= ~ins->msh->ldflags)) + readmesh(ins->msh, + getpath(o->oargs.sarg[0], getrlibpath(), R_OK), + flags); return(ins); } int -getmeshtrivid(tvid, mp, ti) /* get triangle vertex ID's */ -int4 tvid[3]; -register MESH *mp; -OBJECT ti; +getmeshtrivid(tvid, mo, mp, ti) /* get triangle vertex ID's */ +int32 tvid[3]; +OBJECT *mo; +MESH *mp; +OBJECT ti; { int pn = ti >> 10; + MESHPATCH *pp; if (pn >= mp->npatches) return(0); + pp = &mp->patch[pn]; ti &= 0x3ff; if (!(ti & 0x200)) { /* local triangle */ struct PTri *tp; - if (ti >= mp->patch[pn].ntris) + if (ti >= pp->ntris) return(0); - tp = &mp->patch[pn].tri[ti]; + tp = &pp->tri[ti]; tvid[0] = tvid[1] = tvid[2] = pn << 8; tvid[0] |= tp->v1; tvid[1] |= tp->v2; tvid[2] |= tp->v3; + if (pp->trimat != NULL) + *mo = pp->trimat[ti]; + else + *mo = pp->solemat; + if (*mo != OVOID) + *mo += mp->mat0; return(1); } ti &= ~0x200; if (!(ti & 0x100)) { /* single link vertex */ struct PJoin1 *tp1; - if (ti >= mp->patch[pn].nj1tris) + if (ti >= pp->nj1tris) return(0); - tp1 = &mp->patch[pn].j1tri[ti]; + tp1 = &pp->j1tri[ti]; tvid[0] = tp1->v1j; tvid[1] = tvid[2] = pn << 8; tvid[1] |= tp1->v2; tvid[2] |= tp1->v3; + if ((*mo = tp1->mat) != OVOID) + *mo += mp->mat0; return(1); } ti &= ~0x100; { /* double link vertex */ struct PJoin2 *tp2; - if (ti >= mp->patch[pn].nj2tris) + if (ti >= pp->nj2tris) return(0); - tp2 = &mp->patch[pn].j2tri[ti]; + tp2 = &pp->j2tri[ti]; tvid[0] = tp2->v1j; tvid[1] = tp2->v2j; tvid[2] = pn << 8 | tp2->v3; + if ((*mo = tp2->mat) != OVOID) + *mo += mp->mat0; } return(1); } @@ -185,8 +204,8 @@ OBJECT ti; int getmeshvert(vp, mp, vid, what) /* get triangle vertex from ID */ MESHVERT *vp; -register MESH *mp; -int4 vid; +MESH *mp; +int32 vid; int what; { int pn = vid >> 8; @@ -219,39 +238,61 @@ int what; for (i = 0; i < 2; i++) vp->uv[i] = mp->uvlim[0][i] + (mp->uvlim[1][i] - mp->uvlim[0][i])* - (pp->uv[vid][i] + .5)*(1./4294967296.); + (pp->uv[vid][i] + .5)*(1./65536.); vp->fl |= MT_UV; } return(vp->fl); } +OBJREC * +getmeshpseudo(mp, mo) /* get mesh pseudo object for material */ +MESH *mp; +OBJECT mo; +{ + if (mo < mp->mat0 || mo >= mp->mat0 + mp->nmats) + error(INTERNAL, "modifier out of range in getmeshpseudo"); + if (mp->pseudo == NULL) { + register int i; + mp->pseudo = (OBJREC *)calloc(mp->nmats, sizeof(OBJREC)); + if (mp->pseudo == NULL) + error(SYSTEM, "out of memory in getmeshpseudo"); + for (i = mp->nmats; i--; ) { + mp->pseudo[i].omod = mp->mat0 + i; + mp->pseudo[i].otype = OBJ_FACE; + mp->pseudo[i].oname = "M-Tri"; + } + } + return(&mp->pseudo[mo - mp->mat0]); +} + + int -getmeshtri(tv, mp, ti, what) /* get triangle vertices */ +getmeshtri(tv, mo, mp, ti, wha) /* get triangle vertices */ MESHVERT tv[3]; +OBJECT *mo; MESH *mp; OBJECT ti; -int what; +int wha; { - int4 tvid[3]; + int32 tvid[3]; - if (!getmeshtrivid(tvid, mp, ti)) + if (!getmeshtrivid(tvid, mo, mp, ti)) return(0); - getmeshvert(&tv[0], mp, tvid[0], what); - getmeshvert(&tv[1], mp, tvid[1], what); - getmeshvert(&tv[2], mp, tvid[2], what); + getmeshvert(&tv[0], mp, tvid[0], wha); + getmeshvert(&tv[1], mp, tvid[1], wha); + getmeshvert(&tv[2], mp, tvid[2], wha); return(tv[0].fl & tv[1].fl & tv[2].fl); } -int4 +int32 addmeshvert(mp, vp) /* find/add a mesh vertex */ register MESH *mp; MESHVERT *vp; { - LUTAB *ltp; LUENT *lvp; MCVERT cv; register int i; @@ -264,7 +305,7 @@ MESHVERT *vp; return(-1); if (vp->v[i] >= mp->mcube.cuorg[i] + mp->mcube.cusize) return(-1); - cv.xyz[i] = (uint4)(4294967296. * + cv.xyz[i] = (uint32)(4294967296. * (vp->v[i] - mp->mcube.cuorg[i]) / mp->mcube.cusize); } @@ -276,30 +317,25 @@ MESHVERT *vp; return(-1); if (vp->uv[i] >= mp->uvlim[1][i]) return(-1); - cv.uv[i] = (uint4)(4294967296. * + cv.uv[i] = (uint32)(65536. * (vp->uv[i] - mp->uvlim[0][i]) / (mp->uvlim[1][i] - mp->uvlim[0][i])); } cv.fl = vp->fl; - ltp = (LUTAB *)mp->cdata; /* get lookup table */ - if (ltp == NULL) { - ltp = (LUTAB *)calloc(1, sizeof(LUTAB)); - if (ltp == NULL) + if (mp->lut.tsiz == 0) { + mp->lut.hashf = cvhash; + mp->lut.keycmp = cvcmp; + mp->lut.freek = free; + if (!lu_init(&mp->lut, 50000)) goto nomem; - ltp->hashf = cvhash; - ltp->keycmp = cvcmp; - ltp->freek = free; - if (!lu_init(ltp, 50000)) - goto nomem; - mp->cdata = (char *)ltp; } /* find entry */ - lvp = lu_find(ltp, (char *)&cv); + lvp = lu_find(&mp->lut, (char *)&cv); if (lvp == NULL) goto nomem; if (lvp->key == NULL) { - lvp->key = (char *)malloc(sizeof(MCVERT)+sizeof(int4)); - bcopy((void *)&cv, (void *)lvp->key, sizeof(MCVERT)); + lvp->key = (char *)malloc(sizeof(MCVERT)+sizeof(int32)); + memcpy((void *)lvp->key, (void *)&cv, sizeof(MCVERT)); } if (lvp->data == NULL) { /* new vertex */ register MESHPATCH *pp; @@ -315,7 +351,7 @@ MESHVERT *vp; (void *)mp->patch, (mp->npatches + MPATCHBLKSIZ)* sizeof(MESHPATCH)); - bzero((void *)(mp->patch + mp->npatches), + memset((void *)(mp->patch + mp->npatches), '\0', MPATCHBLKSIZ*sizeof(MESHPATCH)); } if (mp->npatches++ >= 1L<<22) @@ -323,7 +359,7 @@ MESHVERT *vp; } pp = &mp->patch[mp->npatches-1]; if (pp->xyz == NULL) { - pp->xyz = (uint4 (*)[3])calloc(256, 3*sizeof(int4)); + pp->xyz = (uint32 (*)[3])calloc(256, 3*sizeof(int32)); if (pp->xyz == NULL) goto nomem; } @@ -331,7 +367,7 @@ MESHVERT *vp; pp->xyz[pp->nverts][i] = cv.xyz[i]; if (cv.fl & MT_N) { if (pp->norm == NULL) { - pp->norm = (int4 *)calloc(256, sizeof(int4)); + pp->norm = (int32 *)calloc(256, sizeof(int32)); if (pp->norm == NULL) goto nomem; } @@ -339,8 +375,8 @@ MESHVERT *vp; } if (cv.fl & MT_UV) { if (pp->uv == NULL) { - pp->uv = (uint4 (*)[2])calloc(256, - 2*sizeof(uint4)); + pp->uv = (uint16 (*)[2])calloc(256, + 2*sizeof(uint16)); if (pp->uv == NULL) goto nomem; } @@ -349,9 +385,9 @@ MESHVERT *vp; } pp->nverts++; lvp->data = lvp->key + sizeof(MCVERT); - *(int4 *)lvp->data = (mp->npatches-1) << 8 | (pp->nverts-1); + *(int32 *)lvp->data = (mp->npatches-1) << 8 | (pp->nverts-1); } - return(*(int4 *)lvp->data); + return(*(int32 *)lvp->data); nomem: error(SYSTEM, "out of memory in addmeshvert"); return(-1); @@ -359,11 +395,12 @@ nomem: OBJECT -addmeshtri(mp, tv) /* add a new mesh triangle */ +addmeshtri(mp, tv, mo) /* add a new mesh triangle */ MESH *mp; MESHVERT tv[3]; +OBJECT mo; { - int4 vid[3], t; + int32 vid[3], t; int pn[3], i; register MESHPATCH *pp; @@ -375,6 +412,13 @@ MESHVERT tv[3]; return(OVOID); pn[i] = vid[i] >> 8; } + /* normalize material index */ + if (mo != OVOID) { + if ((mo -= mp->mat0) >= mp->nmats) + mp->nmats = mo+1; + else if (mo < 0) + error(INTERNAL, "modifier range error in addmeshtri"); + } /* assign triangle */ if (pn[0] == pn[1] && pn[1] == pn[2]) { /* local case */ pp = &mp->patch[pn[0]]; @@ -388,6 +432,18 @@ MESHVERT tv[3]; pp->tri[pp->ntris].v1 = vid[0] & 0xff; pp->tri[pp->ntris].v2 = vid[1] & 0xff; pp->tri[pp->ntris].v3 = vid[2] & 0xff; + if (pp->ntris == 0) + pp->solemat = mo; + else if (pp->trimat == NULL && mo != pp->solemat) { + pp->trimat = (int16 *)malloc( + 512*sizeof(int16)); + if (pp->trimat == NULL) + goto nomem; + for (i = pp->ntris; i--; ) + pp->trimat[i] = pp->solemat; + } + if (pp->trimat != NULL) + pp->trimat[pp->ntris] = mo; return(pn[0] << 10 | pp->ntris++); } } @@ -410,6 +466,7 @@ MESHVERT tv[3]; pp->j1tri[pp->nj1tris].v1j = vid[0]; pp->j1tri[pp->nj1tris].v2 = vid[1] & 0xff; pp->j1tri[pp->nj1tris].v3 = vid[2] & 0xff; + pp->j1tri[pp->nj1tris].mat = mo; return(pn[1] << 10 | 0x200 | pp->nj1tris++); } } @@ -426,6 +483,7 @@ MESHVERT tv[3]; pp->j2tri[pp->nj2tris].v1j = vid[0]; pp->j2tri[pp->nj2tris].v2j = vid[1]; pp->j2tri[pp->nj2tris].v3 = vid[2] & 0xff; + pp->j2tri[pp->nj2tris].mat = mo; return(pn[2] << 10 | 0x300 | pp->nj2tris++); nomem: error(SYSTEM, "out of memory in addmeshtri"); @@ -433,6 +491,75 @@ nomem: } +char * +checkmesh(mp) /* validate mesh data */ +register MESH *mp; +{ + static char embuf[128]; + int nouvbounds = 1; + register int i; + /* basic checks */ + if (mp == NULL) + return("NULL mesh pointer"); + if (!mp->ldflags) + return("unassigned mesh"); + if (mp->name == NULL) + return("missing mesh name"); + if (mp->nref <= 0) + return("unreferenced mesh"); + /* check boundaries */ + if (mp->ldflags & IO_BOUNDS) { + if (mp->mcube.cusize <= FTINY) + return("illegal octree bounds in mesh"); + nouvbounds = (mp->uvlim[1][0] - mp->uvlim[0][0] <= FTINY || + mp->uvlim[1][1] - mp->uvlim[0][1] <= FTINY); + } + /* check octree */ + if (mp->ldflags & IO_TREE) { + if (isempty(mp->mcube.cutree)) + error(WARNING, "empty mesh octree"); + } + /* check scene data */ + if (mp->ldflags & IO_SCENE) { + if (!(mp->ldflags & IO_BOUNDS)) + return("unbounded scene in mesh"); + if (mp->mat0 < 0 || mp->mat0+mp->nmats > nobjects) + return("bad mesh modifier range"); + for (i = mp->mat0+mp->nmats; i-- > mp->mat0; ) { + int otyp = objptr(i)->otype; + if (!ismodifier(otyp)) { + sprintf(embuf, + "non-modifier in mesh (%s \"%s\")", + ofun[otyp].funame, objptr(i)->oname); + return(embuf); + } + } + if (mp->npatches <= 0) + error(WARNING, "no patches in mesh"); + for (i = 0; i < mp->npatches; i++) { + register MESHPATCH *pp = &mp->patch[i]; + if (pp->nverts <= 0) + error(WARNING, "no vertices in patch"); + else { + if (pp->xyz == NULL) + return("missing patch vertex list"); + if (nouvbounds && pp->uv != NULL) + return("unreferenced uv coordinates"); + } + if (pp->ntris + pp->nj1tris + pp->nj2tris <= 0) + error(WARNING, "no triangles in patch"); + if (pp->ntris > 0 && pp->tri == NULL) + return("missing patch triangle list"); + if (pp->nj1tris > 0 && pp->j1tri == NULL) + return("missing patch joiner triangle list"); + if (pp->nj2tris > 0 && pp->j2tri == NULL) + return("missing patch double-joiner list"); + } + } + return(NULL); /* seems OK */ +} + + static void tallyoctree(ot, ecp, lcp, ocp) /* tally octree size */ OCTREE ot; @@ -488,11 +615,12 @@ FILE *fp; t2cnt += pp->nj2tris; } fprintf(fp, "Mesh statistics:\n"); + fprintf(fp, "\t%ld materials\n", ms->nmats); fprintf(fp, "\t%d patches (%.2f MBytes)\n", ms->npatches, (ms->npatches*sizeof(MESHPATCH) + - vcnt*3*sizeof(uint4) + - nscnt*sizeof(int4) + - uvscnt*2*sizeof(uint4) + + vcnt*3*sizeof(uint32) + + nscnt*sizeof(int32) + + uvscnt*2*sizeof(uint16) + tcnt*sizeof(struct PTri) + t1cnt*sizeof(struct PJoin1) + t2cnt*sizeof(struct PJoin2))/(1024.*1024.)); @@ -511,7 +639,7 @@ FILE *fp; void freemesh(ms) /* free mesh data */ -MESH *ms; +register MESH *ms; { MESH mhead; MESH *msp; @@ -537,8 +665,7 @@ MESH *ms; /* free mesh data */ freestr(ms->name); octfree(ms->mcube.cutree); - if (ms->cdata != NULL) - lu_done((LUTAB *)ms->cdata); + lu_done(&ms->lut); if (ms->npatches > 0) { register MESHPATCH *pp = ms->patch + ms->npatches; while (pp-- > ms->patch) { @@ -557,6 +684,8 @@ MESH *ms; } free((void *)ms->patch); } + if (ms->pseudo != NULL) + free((void *)ms->pseudo); free((void *)ms); }
