perf: made mesh self-consistency tests much more thorough
fix(mesh): reverted previous change (2.30) to better accommodate dense meshes
Fixed segmentation error when running parallel processes on meshes with materials
Added missing free() call
Realized I didn't need to minimize array size in every patch to avoid overflow
Made mesh building more robust to long triangles
Very minor improvement should not affect behavior
Made error messages more consistent when library file not found
Simplified nextmeshtri() logic considerably
Fixed potential bugs in new routine -- still untested
Added routine for cycling through all triangles
Minor change to avoid compiler warning
Removed C++ comments
Removed spurious warning about triangle-less patches
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Added prototypes and includes from patch by Randolph Fritz. Added more required includes and reduced other compile warnings.
Fixed potential bug in reference counting of mesh'es and instance's
Bug fix in mesh uv coordinate range checking
