root/radiance/ray/src/common/mesh.c
Fri Feb 18 00:40:25 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.22: +4 -11 lines
Diff to previous 2.22
Wed Dec 15 17:27:52 2010 UTC (14 years, 6 months ago) by greg
Diff to previous 2.21
Minor change to avoid compiler warning
Sat May 1 21:49:42 2010 UTC (15 years, 1 month ago) by greg
Diff to previous 2.20
Removed C++ comments
Tue May 25 22:04:13 2004 UTC (21 years, 1 month ago) by greg
Diff to previous 2.19
Sun Mar 28 20:33:12 2004 UTC (21 years, 3 months ago) by schorsch
Changes since 2.18: +12 -5 lines
Diff to previous 2.18
Tue Mar 16 19:56:27 2004 UTC (21 years, 3 months ago) by greg
Changes since 2.17: +1 -3 lines
Diff to previous 2.17
Removed spurious warning about triangle-less patches
Thu Feb 12 18:55:50 2004 UTC (21 years, 4 months ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16
Fri Jan 30 00:08:31 2004 UTC (21 years, 4 months ago) by greg
Changes since 2.15: +8 -9 lines
Diff to previous 2.15
Fri Nov 14 17:22:06 2003 UTC (21 years, 7 months ago) by schorsch
Diff to previous 2.14
Thu Sep 18 16:53:52 2003 UTC (21 years, 9 months ago) by greg
Changes since 2.13: +7 -7 lines
Diff to previous 2.13
Mon Jul 21 22:30:17 2003 UTC (21 years, 11 months ago) by schorsch
Diff to previous 2.12
Thu Jul 17 09:21:29 2003 UTC (21 years, 11 months ago) by schorsch
Thu Jul 10 03:47:00 2003 UTC (21 years, 11 months ago) by greg
Thu Jul 10 03:30:11 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.9: +11 -12 lines
Fixed potential bug in reference counting of mesh'es and instance's
Mon Jun 30 14:59:11 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.8: +5 -3 lines
Fri Jun 20 00:25:49 2003 UTC (22 years ago) by greg
Changes since 2.7: +23 -23 lines
Tue May 13 17:58:32 2003 UTC (22 years, 1 month ago) by greg
Wed Apr 23 00:52:33 2003 UTC (22 years, 2 months ago) by greg
Fri Apr 18 22:10:20 2003 UTC (22 years, 2 months ago) by greg
Bug fix in mesh uv coordinate range checking
Fri Mar 14 21:27:45 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.3: +159 -37 lines
Wed Mar 12 17:26:58 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.2: +0 -0 lines
Wed Mar 12 04:59:04 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.1: +27 -33 lines
Tue Mar 11 17:08:55 2003 UTC (22 years, 3 months ago) by greg
