root/radiance/ray/src/common/mat4.h
Mon Jul 14 22:23:59 2003 UTC (20 years, 9 months ago) by schorsch
CVS Tags: HEAD, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.11: +5 -4 lines
Changes since 2.10: +1 -5 lines
Changes since 2.9: +1 -3 lines
Sat Jun 7 12:50:20 2003 UTC (20 years, 10 months ago) by schorsch
Fri Jun 6 16:38:47 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.6: +11 -9 lines
*** empty log message ***
Tue May 13 17:58:32 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.4: +2 -57 lines
Changes since 2.3: +74 -4 lines
Fri Nov 10 17:04:18 1995 UTC (28 years, 5 months ago) by greg
removed memcpy() declaration
Fri Mar 5 15:14:03 1993 UTC (31 years, 2 months ago) by greg
portability improvements
Tue Nov 12 16:54:56 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.3 , to selected 2.11
Wed Oct 23 12:19:27 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.2 , to selected 2.11
added FLOAT definition for vectors and matrices
Tue Jun 18 12:01:18 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.1: +7 -0 lines
changed setident4() into a macro
Sat Dec 15 14:18:18 1990 UTC (33 years, 4 months ago) by greg
Diff to selected 2.11
