root/radiance/ray/src/common/mat4.c
Revision: 1.6
Committed: Tue Jun 18 12:01:16 1991 UTC (34 years ago) by greg
Changes since 1.5: +2 -13 lines
changed setident4() into a macro
1 /* Copyright (c) 1990 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * mat4.c - routines dealing with 4 X 4 homogeneous transformation matrices.
9 *
10 * 10/19/85
11 */
12
13 #include "mat4.h"
14
15 MAT4 m4ident = MAT4IDENT;
16
17 static MAT4 m4tmp; /* for efficiency */
18
19
20 multmat4(m4a, m4b, m4c) /* multiply m4b X m4c and put into m4a */
21 MAT4 m4a;
22 register MAT4 m4b, m4c;
23 {
24 register int i, j;
25
26 for (i = 4; i--; )
27 for (j = 4; j--; )
28 m4tmp[i][j] = m4b[i][0]*m4c[0][j] +
29 m4b[i][1]*m4c[1][j] +
30 m4b[i][2]*m4c[2][j] +
31 m4b[i][3]*m4c[3][j];
32
33 copymat4(m4a, m4tmp);
34 }
35
36
37 multv3(v3a, v3b, m4) /* transform vector v3b by m4 and put into v3a */
38 FVECT v3a;
39 register FVECT v3b;
40 register MAT4 m4;
41 {
42 m4tmp[0][0] = v3b[0]*m4[0][0] + v3b[1]*m4[1][0] + v3b[2]*m4[2][0];
43 m4tmp[0][1] = v3b[0]*m4[0][1] + v3b[1]*m4[1][1] + v3b[2]*m4[2][1];
44 m4tmp[0][2] = v3b[0]*m4[0][2] + v3b[1]*m4[1][2] + v3b[2]*m4[2][2];
45
46 v3a[0] = m4tmp[0][0];
47 v3a[1] = m4tmp[0][1];
48 v3a[2] = m4tmp[0][2];
49 }
50
51
52 multp3(p3a, p3b, m4) /* transform p3b by m4 and put into p3a */
53 register FVECT p3a;
54 FVECT p3b;
55 register MAT4 m4;
56 {
57 multv3(p3a, p3b, m4); /* transform as vector */
58 p3a[0] += m4[3][0]; /* translate */
59 p3a[1] += m4[3][1];
60 p3a[2] += m4[3][2];
61 }
62
63
64 #ifdef INVMAT
65 /*
66 * invmat - computes the inverse of mat into inverse. Returns 1
67 * if there exists an inverse, 0 otherwise. It uses Gaussian Elimination
68 * method with partial pivoting.
69 */
70
71 invmat(inverse,mat)
72 MAT4 mat, inverse;
73 {
74 #define SWAP(a,b,t) (t=a,a=b,b=t)
75 #define ABS(x) (x>=0?x:-(x))
76
77 register int i,j,k;
78 register double temp;
79
80 copymat4(m4tmp, mat);
81 setident(inverse);
82
83 for(i = 0; i < 4; i++) {
84 /* Look for row with largest pivot and swap rows */
85 temp = 0; j = -1;
86 for(k = i; k < 4; k++)
87 if(ABS(m4tmp[k][i]) > temp) {
88 temp = ABS(m4tmp[k][i]);
89 j = k;
90 }
91 if(j == -1) /* No replacing row -> no inverse */
92 return(0);
93 if (j != i)
94 for(k = 0; k < 4; k++) {
95 SWAP(m4tmp[i][k],m4tmp[j][k],temp);
96 SWAP(inverse[i][k],inverse[j][k],temp);
97 }
98
99 temp = m4tmp[i][i];
100 for(k = 0; k < 4; k++) {
101 m4tmp[i][k] /= temp;
102 inverse[i][k] /= temp;
103 }
104 for(j = 0; j < 4; j++) {
105 if(j != i) {
106 temp = m4tmp[j][i];
107 for(k = 0; k < 4; k++) {
108 m4tmp[j][k] -= m4tmp[i][k]*temp;
109 inverse[j][k] -= inverse[i][k]*temp;
110 }
111 }
112 }
113 }
114 return(1);
115
116 #undef ABS
117 #undef SWAP
118 }
119 #endif
