--- ray/src/common/mat4.c 1989/12/22 09:24:07 1.3 +++ ray/src/common/mat4.c 1991/11/12 16:54:53 2.1 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1990 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -10,28 +10,16 @@ static char SCCSid[] = "$SunId$ LBL"; * 10/19/85 */ +#include "mat4.h" -static double m4tmp[4][4]; /* for efficiency */ +MAT4 m4ident = MAT4IDENT; -#define copymat4(m4a,m4b) bcopy((char *)m4b,(char *)m4a,sizeof(m4tmp)) +static MAT4 m4tmp; /* for efficiency */ -setident4(m4) -double m4[4][4]; -{ - static double ident[4][4] = { - 1.,0.,0.,0., - 0.,1.,0.,0., - 0.,0.,1.,0., - 0.,0.,0.,1., - }; - copymat4(m4, ident); -} - - multmat4(m4a, m4b, m4c) /* multiply m4b X m4c and put into m4a */ -double m4a[4][4]; -register double m4b[4][4], m4c[4][4]; +MAT4 m4a; +register MAT4 m4b, m4c; { register int i, j; @@ -47,9 +35,9 @@ register double m4b[4][4], m4c[4][4]; multv3(v3a, v3b, m4) /* transform vector v3b by m4 and put into v3a */ -double v3a[3]; -register double v3b[3]; -register double m4[4][4]; +FVECT v3a; +register FVECT v3b; +register MAT4 m4; { m4tmp[0][0] = v3b[0]*m4[0][0] + v3b[1]*m4[1][0] + v3b[2]*m4[2][0]; m4tmp[0][1] = v3b[0]*m4[0][1] + v3b[1]*m4[1][1] + v3b[2]*m4[2][1]; @@ -62,9 +50,9 @@ register double m4[4][4]; multp3(p3a, p3b, m4) /* transform p3b by m4 and put into p3a */ -register double p3a[3]; -double p3b[3]; -register double m4[4][4]; +register FVECT p3a; +FVECT p3b; +register MAT4 m4; { multv3(p3a, p3b, m4); /* transform as vector */ p3a[0] += m4[3][0]; /* translate */ @@ -73,7 +61,6 @@ register double m4[4][4]; } -#ifdef INVMAT /* * invmat - computes the inverse of mat into inverse. Returns 1 * if there exists an inverse, 0 otherwise. It uses Gaussian Elimination @@ -81,7 +68,7 @@ register double m4[4][4]; */ invmat(inverse,mat) -double mat[4][4],inverse[4][4]; +MAT4 mat, inverse; { #define SWAP(a,b,t) (t=a,a=b,b=t) #define ABS(x) (x>=0?x:-(x)) @@ -90,7 +77,7 @@ double mat[4][4],inverse[4][4]; register double temp; copymat4(m4tmp, mat); - setident(inverse); + setident4(inverse); for(i = 0; i < 4; i++) { /* Look for row with largest pivot and swap rows */ @@ -128,4 +115,3 @@ double mat[4][4],inverse[4][4]; #undef ABS #undef SWAP } -#endif
