root/radiance/ray/src/common/malloc.c
Revision: 2.4
Committed: Sat Feb 8 13:16:01 1992 UTC (32 years, 3 months ago) by greg
Changes since 2.3: +2 -5 lines
faster initial sbrk() pointer alignment
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Fast malloc for memory hogs and VM environments.
9 * Performs a minimum of searching through free lists.
10 * malloc(), realloc() and free() use buckets
11 * containing blocks in powers of two, similar to CIT routines.
12 * bfree() puts memory from any source into malloc free lists.
13 * bmalloc() doesn't keep track of free lists -- it's usually
14 * just a buffered call to sbrk(2). However, bmalloc will
15 * call mscrounge() if sbrk fails.
16 * mscrounge() returns whatever free memory it can find to satisfy the
17 * request along with the number of bytes (modified).
18 * mcompact() takes the same arguments as mscrounge() (and is in fact
19 * called by mscrounge() under dire circumstances), but it uses
20 * memory compaction to return a larger block. (MCOMP)
21 *
22 * Greg Ward Lawrence Berkeley Laboratory
23 */
24
25 #include <errno.h>
26
27 #ifdef MSTATS
28 #include <stdio.h>
29 static unsigned b_nsbrked = 0;
30 static unsigned b_nalloced = 0;
31 static unsigned b_nfreed = 0;
32 static unsigned b_nscrounged = 0;
33 static unsigned b_ncompacted = 0;
34 static unsigned m_nalloced = 0;
35 static unsigned m_nfreed = 0;
36 static unsigned m_nwasted = 0;
37 #else
38 #define NULL 0
39 #endif
40
41 #ifndef ALIGN
42 #define ALIGN int /* align type */
43 #endif
44 #define BYTES_WORD sizeof(ALIGN)
45
46 #ifndef MAXINCR
47 #define MAXINCR (1<<16) /* largest sbrk(2) increment */
48 #endif
49 /* malloc free lists */
50 typedef union m_head {
51 union m_head *next;
52 struct {
53 short magic;
54 short bucket;
55 } a;
56 ALIGN dummy;
57 } M_HEAD;
58
59 #define MAGIC 0x1a2 /* magic number for allocated memory */
60
61 #define FIRSTBUCKET 3
62 #define NBUCKETS 30
63
64 static M_HEAD *free_list[NBUCKETS];
65
66 static ALIGN dummy_mem;
67
68 #define DUMMYLOC ((char *)&dummy_mem)
69
70 #ifdef MCOMP /* memory compaction routines */
71 static char seedtab[1024]; /* seed for compaction table */
72
73 static struct mblk {
74 char *ptr; /* pointer to memory block */
75 unsigned siz; /* size of memory block */
76 } cptab = {seedtab, sizeof(seedtab)};
77
78 #define mtab(mb) ((struct mblk *)(mb)->ptr)
79 #define mtablen(mb) ((mb)->siz/sizeof(struct mblk))
80
81
82 static int
83 mbcmp(m1, m2) /* compare memory block locations */
84 register struct mblk *m1, *m2;
85 {
86 /* put empty blocks at end */
87 if (m1->siz == 0)
88 return(m2->siz == 0 ? 0 : 1);
89 if (m2->siz == 0)
90 return(-1);
91 /* otherwise, ascending order */
92 return(m1->ptr - m2->ptr);
93 }
94
95
96 int
97 compactfree() /* compact free lists (moving to table) */
98 {
99 register struct mblk *tp;
100 register int bucket;
101 unsigned n, bsiz, ncomp;
102 /* fill table from free lists */
103 tp = mtab(&cptab); n = mtablen(&cptab);
104 bucket = NBUCKETS-1; bsiz = 1<<(NBUCKETS-1);
105 ncomp = 0;
106 for ( ; ; ) {
107 while (tp->siz) { /* find empty slot */
108 if (--n == 0)
109 goto loopexit;
110 tp++;
111 }
112 while (free_list[bucket] == NULL) { /* find block */
113 if (--bucket < FIRSTBUCKET)
114 goto loopexit;
115 bsiz >>= 1;
116 }
117 tp->ptr = (char *)free_list[bucket];
118 ncomp += (tp->siz = bsiz + sizeof(M_HEAD));
119 free_list[bucket] = free_list[bucket]->next;
120 }
121 loopexit:
122 if (ncomp == 0)
123 return(0); /* nothing new to compact */
124 #ifdef MSTATS
125 b_ncompacted += ncomp;
126 #endif
127 tp = mtab(&cptab); n = mtablen(&cptab); /* sort table */
128 qsort((char *)tp, n, sizeof(struct mblk), mbcmp);
129 ncomp = 0; /* collect blocks */
130 while (--n && tp[1].siz) {
131 if (tp[0].ptr + tp[0].siz == tp[1].ptr) {
132 tp[1].ptr = tp[0].ptr;
133 tp[1].siz += tp[0].siz;
134 ncomp += tp[0].siz;
135 tp[0].siz = 0;
136 }
137 tp++;
138 }
139 return(ncomp);
140 }
141
142
143 char *
144 mcompact(np) /* compact free lists to satisfy request */
145 unsigned *np;
146 {
147 struct mblk *tab;
148 unsigned tablen;
149 register struct mblk *bp, *big;
150
151 for ( ; ; ) {
152 /* compact free lists */
153 compactfree();
154 /* find largest block */
155 tab = mtab(&cptab); tablen = mtablen(&cptab);
156 big = tab;
157 bp = tab + tablen;
158 while (--bp > tab)
159 if (bp->siz > big->siz)
160 big = bp;
161 if (big->siz >= *np) { /* big enough? */
162 *np = big->siz;
163 big->siz = 0; /* remove from table */
164 return(big->ptr); /* return it */
165 }
166 if (mtablen(big) < tablen+1) {
167 *np = 0; /* cannot grow table */
168 return(NULL); /* report failure */
169 }
170 /* enlarge table, free old one */
171 mtab(big)[0].ptr = cptab.ptr;
172 mtab(big)[0].siz = cptab.siz;
173 cptab.ptr = big->ptr;
174 cptab.siz = big->siz;
175 big->siz = 0; /* clear and copy */
176 #ifdef BSD
177 bcopy((char *)tab, (char *)(mtab(&cptab)+1),
178 tablen*sizeof(struct mblk));
179 bzero((char *)(mtab(&cptab)+tablen+1),
180 (mtablen(&cptab)-tablen-1)*sizeof(struct mblk));
181 #else
182 (void)memcpy((char *)(mtab(&cptab)+1), (char *)tab,
183 tablen*sizeof(struct mblk));
184 memset((char *)(mtab(&cptab)+tablen+1), 0,
185 (mtablen(&cptab)-tablen-1)*sizeof(struct mblk));
186 #endif
187 } /* next round */
188 }
189 #endif /* MCOMP */
190
191
192 char *
193 mscrounge(np) /* search free lists to satisfy request */
194 register unsigned *np;
195 {
196 char *p;
197 register int bucket;
198 register unsigned bsiz;
199
200 for (bucket = FIRSTBUCKET, bsiz = 1<<FIRSTBUCKET;
201 bucket < NBUCKETS; bucket++, bsiz <<= 1)
202 if (free_list[bucket] != NULL && bsiz+sizeof(M_HEAD) >= *np) {
203 *np = bsiz+sizeof(M_HEAD);
204 p = (char *)free_list[bucket];
205 free_list[bucket] = free_list[bucket]->next;
206 #ifdef MSTATS
207 b_nscrounged += *np;
208 #endif
209 return(p);
210 }
211 #ifdef MCOMP
212 return(mcompact(np)); /* try compaction */
213 #else
214 *np = 0;
215 return(NULL);
216 #endif
217 }
218
219
220 char *
221 bmalloc(n) /* allocate a block of n bytes, sans header */
222 register unsigned n;
223 {
224 extern char *sbrk();
225 static unsigned pagesz = 0;
226 static unsigned amnt;
227 static char *bpos;
228 static unsigned nrem;
229 unsigned thisamnt;
230 register char *p;
231
232 if (pagesz == 0) { /* initialize */
233 pagesz = amnt = getpagesize();
234 nrem = (int)sbrk(0); /* page align break */
235 nrem = pagesz - (nrem&(pagesz-1));
236 bpos = sbrk(nrem);
237 if ((int)bpos == -1)
238 return(NULL);
239 #ifdef MSTATS
240 b_nsbrked += nrem;
241 #endif
242 bpos += nrem & (BYTES_WORD-1); /* align pointer */
243 nrem &= ~(BYTES_WORD-1);
244 }
245
246 n = (n+(BYTES_WORD-1))&~(BYTES_WORD-1); /* word align rqst. */
247
248 if (n > nrem) { /* need more core */
249 if (n > amnt) { /* big chunk */
250 thisamnt = (n+(pagesz-1))&~(pagesz-1);
251 if (thisamnt <= MAXINCR) /* increase amnt */
252 amnt = thisamnt;
253 } else
254 thisamnt = amnt;
255 p = sbrk(thisamnt);
256 if ((int)p == -1) { /* uh-oh, ENOMEM */
257 thisamnt = n; /* search free lists */
258 p = mscrounge(&thisamnt);
259 if (p == NULL) /* we're really out */
260 return(NULL);
261 }
262 #ifdef MSTATS
263 else b_nsbrked += thisamnt;
264 #endif
265 if (p != bpos+nrem) { /* not an increment */
266 bfree(bpos, nrem); /* free what we have */
267 bpos = p;
268 nrem = thisamnt;
269 } else /* otherwise tack on */
270 nrem += thisamnt;
271 }
272 p = bpos;
273 bpos += n; /* advance */
274 nrem -= n;
275 #ifdef MSTATS
276 b_nalloced += n;
277 #endif
278 return(p);
279 }
280
281
282 bfree(p, n) /* free n bytes of random memory */
283 register char *p;
284 register unsigned n;
285 {
286 register int bucket;
287 register unsigned bsiz;
288
289 if (n < 1<<FIRSTBUCKET)
290 return;
291 #ifdef MSTATS
292 b_nfreed += n;
293 #endif
294 /* align pointer */
295 bsiz = BYTES_WORD - ((unsigned)p&(BYTES_WORD-1));
296 if (bsiz < BYTES_WORD) {
297 p += bsiz;
298 n -= bsiz;
299 }
300 /* fill big buckets first */
301 for (bucket = NBUCKETS-1, bsiz = 1<<(NBUCKETS-1);
302 bucket >= FIRSTBUCKET; bucket--, bsiz >>= 1)
303 if (n >= bsiz+sizeof(M_HEAD)) {
304 ((M_HEAD *)p)->next = free_list[bucket];
305 free_list[bucket] = (M_HEAD *)p;
306 p += bsiz+sizeof(M_HEAD);
307 n -= bsiz+sizeof(M_HEAD);
308 }
309 }
310
311
312 char *
313 malloc(n) /* allocate n bytes of memory */
314 unsigned n;
315 {
316 extern int errno;
317 register M_HEAD *mp;
318 register int bucket;
319 register unsigned bsiz;
320 /* don't return NULL on 0 request */
321 if (n == 0)
322 return(DUMMYLOC);
323 /* find first bucket that fits */
324 for (bucket = FIRSTBUCKET, bsiz = 1<<FIRSTBUCKET;
325 bucket < NBUCKETS; bucket++, bsiz <<= 1)
326 if (bsiz >= n)
327 break;
328 if (bucket >= NBUCKETS) {
329 errno = EINVAL;
330 return(NULL);
331 }
332 if (free_list[bucket] == NULL) { /* need more core */
333 mp = (M_HEAD *)bmalloc(bsiz+sizeof(M_HEAD));
334 if (mp == NULL)
335 return(NULL);
336 } else { /* got it */
337 mp = free_list[bucket];
338 free_list[bucket] = mp->next;
339 }
340 #ifdef MSTATS
341 m_nalloced += bsiz + sizeof(M_HEAD);
342 m_nwasted += bsiz + sizeof(M_HEAD) - n;
343 #endif
344 mp->a.magic = MAGIC; /* tag block */
345 mp->a.bucket = bucket;
346 return((char *)(mp+1));
347 }
348
349
350 char *
351 realloc(op, n) /* reallocate memory using malloc() */
352 register char *op;
353 unsigned n;
354 {
355 char *p;
356 register unsigned on;
357 /* get old size */
358 if (op != NULL && op != DUMMYLOC && ((M_HEAD *)op-1)->a.magic == MAGIC)
359 on = 1 << ((M_HEAD *)op-1)->a.bucket;
360 else
361 on = 0;
362 if (n <= on && (n > on>>1 || on == 1<<FIRSTBUCKET))
363 return(op); /* same bucket */
364 if ((p = malloc(n)) == NULL)
365 return(NULL);
366 if (on) {
367 #ifdef BSD
368 bcopy(op, p, n>on ? on : n);
369 #else
370 (void)memcpy(p, op, n>on ? on : n);
371 #endif
372 free(op);
373 }
374 return(p);
375 }
376
377
378 free(p) /* free memory allocated by malloc */
379 char *p;
380 {
381 register M_HEAD *mp;
382 register int bucket;
383
384 if (p == NULL | p == DUMMYLOC)
385 return(1);
386 mp = (M_HEAD *)p - 1;
387 if (mp->a.magic != MAGIC) /* sanity check */
388 return(0);
389 bucket = mp->a.bucket;
390 if (bucket < FIRSTBUCKET | bucket >= NBUCKETS)
391 return(0);
392 mp->next = free_list[bucket];
393 free_list[bucket] = mp;
394 #ifdef MSTATS
395 m_nfreed += (1 << bucket) + sizeof(M_HEAD);
396 #endif
397 return(1);
398 }
399
400
401 #ifdef MSTATS
402 printmemstats(fp) /* print memory statistics to stream */
403 FILE *fp;
404 {
405 register int i;
406 int n;
407 register M_HEAD *mp;
408 unsigned int total = 0;
409
410 fprintf(fp, "Memory statistics:\n");
411 fprintf(fp, "\tbmalloc: %d bytes from sbrk\n", b_nsbrked);
412 fprintf(fp, "\tbmalloc: %d bytes allocated\n", b_nalloced);
413 fprintf(fp, "\tbmalloc: %d bytes freed\n", b_nfreed);
414 fprintf(fp, "\tbmalloc: %d bytes scrounged\n", b_nscrounged);
415 fprintf(fp, "\tbmalloc: %d bytes compacted\n", b_ncompacted);
416 fprintf(fp, "\tmalloc: %d bytes allocated\n", m_nalloced);
417 fprintf(fp, "\tmalloc: %d bytes wasted (%.1f%%)\n", m_nwasted,
418 100.0*m_nwasted/m_nalloced);
419 fprintf(fp, "\tmalloc: %d bytes freed\n", m_nfreed);
420 for (i = NBUCKETS-1; i >= FIRSTBUCKET; i--) {
421 n = 0;
422 for (mp = free_list[i]; mp != NULL; mp = mp->next)
423 n++;
424 if (n) {
425 fprintf(fp, "\t%d * %u\n", n, 1<<i);
426 total += n * ((1<<i) + sizeof(M_HEAD));
427 }
428 }
429 fprintf(fp, "\t %u total bytes in free list\n", total);
430 }
431 #endif
