root/radiance/ray/src/common/malloc.c
Revision: 2.15
Committed: Tue May 13 17:58:32 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.14: +0 -0 lines
5 * Fast malloc for memory hogs and VM environments.
6 * Performs a minimum of searching through free lists.
7 * malloc(), realloc() and free() use buckets
8 * containing blocks in powers of two, similar to CIT routines.
9 * bfree() puts memory from any source into malloc free lists.
10 * bmalloc() doesn't keep track of free lists -- it's usually
11 * just a buffered call to sbrk(2). However, bmalloc will
12 * call mscrounge() if sbrk fails.
13 * mscrounge() returns whatever free memory it can find to satisfy the
14 * request along with the number of bytes (modified).
15 * mcompact() takes the same arguments as mscrounge() (and is in fact
16 * called by mscrounge() under dire circumstances), but it uses
17 * memory compaction to return a larger block. (MCOMP)
18 *
19 * Greg Ward Lawrence Berkeley Laboratory
20 */
21
22 #include "copyright.h"
23
24 #include <errno.h>
25
26 #ifndef BSD
27 #define bcopy(s,d,n) (void)memcpy(d,s,n)
28 #define bzero(d,n) (void)memset(d,0,n)
29 #endif
30
31 #ifdef MSTATS
32 #include <stdio.h>
33 static unsigned b_nsbrked = 0;
34 static unsigned b_nalloced = 0;
35 static unsigned b_nfreed = 0;
36 static unsigned b_nscrounged = 0;
37 static unsigned b_ncompacted = 0;
38 static unsigned m_nalloced = 0;
39 static unsigned m_nfreed = 0;
40 static unsigned m_nwasted = 0;
41 #else
42 #define NULL 0
43 #endif
44
45 #ifndef ALIGNT
46 #define ALIGNT int /* align type */
47 #endif
48 #define BYTES_WORD sizeof(ALIGNT)
49
50 #ifndef MAXINCR
51 #define MAXINCR (1<<16) /* largest sbrk(2) increment */
52 #endif
53 /* malloc free lists */
54 typedef union m_head {
55 union m_head *next;
56 struct {
57 short magic;
58 short bucket;
59 } a;
60 ALIGNT dummy;
61 } M_HEAD;
62
63 #define MAGIC 0x1a2 /* magic number for allocated memory */
64
65 #define FIRSTBUCKET 3
66 #define NBUCKETS 30
67
68 static M_HEAD *free_list[NBUCKETS];
69
70 static ALIGNT dummy_mem;
71
72 static char *memlim[2];
73
74 #define DUMMYLOC ((char *)&dummy_mem)
75
76 #define BADPTR(p) ((p) < memlim[0] | (p) >= memlim[1])
77
78 #ifdef MCOMP /* memory compaction routines */
79 static char seedtab[1024]; /* seed for compaction table */
80
81 static struct mblk {
82 char *ptr; /* pointer to memory block */
83 unsigned siz; /* size of memory block */
84 } cptab = {seedtab, sizeof(seedtab)};
85
86 #define mtab(mb) ((struct mblk *)(mb)->ptr)
87 #define mtablen(mb) ((mb)->siz/sizeof(struct mblk))
88
89
90 static int
91 mbcmp(m1, m2) /* compare memory block locations */
92 register struct mblk *m1, *m2;
93 {
94 /* put empty blocks at end */
95 if (m1->siz == 0)
96 return(m2->siz == 0 ? 0 : 1);
97 if (m2->siz == 0)
98 return(-1);
99 /* otherwise, ascending order */
100 return(m1->ptr - m2->ptr);
101 }
102
103
104 int
105 compactfree() /* compact free lists (moving to table) */
106 {
107 register struct mblk *tp;
108 register int bucket;
109 unsigned n, bsiz, ncomp;
110 /* fill table from free lists */
111 tp = mtab(&cptab); n = mtablen(&cptab);
112 bucket = NBUCKETS-1; bsiz = 1<<(NBUCKETS-1);
113 ncomp = 0;
114 for ( ; ; ) {
115 while (tp->siz) { /* find empty slot */
116 if (--n == 0)
117 goto loopexit;
118 tp++;
119 }
120 while (free_list[bucket] == NULL) { /* find block */
121 if (--bucket < FIRSTBUCKET)
122 goto loopexit;
123 bsiz >>= 1;
124 }
125 tp->ptr = (char *)free_list[bucket];
126 ncomp += (tp->siz = bsiz + sizeof(M_HEAD));
127 free_list[bucket] = free_list[bucket]->next;
128 }
129 loopexit:
130 if (ncomp == 0)
131 return(0); /* nothing new to compact */
132 #ifdef MSTATS
133 b_ncompacted += ncomp;
134 #endif
135 tp = mtab(&cptab); n = mtablen(&cptab); /* sort table */
136 qsort((char *)tp, n, sizeof(struct mblk), mbcmp);
137 ncomp = 0; /* collect blocks */
138 while (--n && tp[1].siz) {
139 if (tp[0].ptr + tp[0].siz == tp[1].ptr) {
140 tp[1].ptr = tp[0].ptr;
141 tp[1].siz += tp[0].siz;
142 ncomp += tp[0].siz;
143 tp[0].siz = 0;
144 }
145 tp++;
146 }
147 return(ncomp);
148 }
149
150
151 char *
152 mcompact(np) /* compact free lists to satisfy request */
153 unsigned *np;
154 {
155 struct mblk *tab;
156 unsigned tablen;
157 register struct mblk *bp, *big;
158
159 for ( ; ; ) {
160 /* compact free lists */
161 while (compactfree())
162 ;
163 /* find largest block */
164 tab = mtab(&cptab); tablen = mtablen(&cptab);
165 big = tab;
166 bp = tab + tablen;
167 while (--bp > tab)
168 if (bp->siz > big->siz)
169 big = bp;
170 if (big->siz >= *np) { /* big enough? */
171 *np = big->siz;
172 big->siz = 0; /* remove from table */
173 return(big->ptr); /* return it */
174 }
175 if (mtablen(big) <= tablen) {
176 *np = 0; /* cannot grow table */
177 return(NULL); /* report failure */
178 }
179 /* enlarge table, free old one */
180 mtab(big)[0].ptr = cptab.ptr;
181 mtab(big)[0].siz = cptab.siz;
182 cptab.ptr = big->ptr;
183 cptab.siz = big->siz;
184 big->siz = 0; /* clear and copy */
185 bcopy((char *)tab, (char *)(mtab(&cptab)+1),
186 tablen*sizeof(struct mblk));
187 bzero((char *)(mtab(&cptab)+tablen+1),
188 (mtablen(&cptab)-tablen-1)*sizeof(struct mblk));
189 } /* next round */
190 }
191 #endif /* MCOMP */
192
193
194 char *
195 mscrounge(np) /* search free lists to satisfy request */
196 register unsigned *np;
197 {
198 char *p;
199 register int bucket;
200 register unsigned bsiz;
201
202 for (bucket = FIRSTBUCKET, bsiz = 1<<FIRSTBUCKET;
203 bucket < NBUCKETS; bucket++, bsiz <<= 1)
204 if (free_list[bucket] != NULL && bsiz+sizeof(M_HEAD) >= *np) {
205 *np = bsiz+sizeof(M_HEAD);
206 p = (char *)free_list[bucket];
207 free_list[bucket] = free_list[bucket]->next;
208 #ifdef MSTATS
209 b_nscrounged += *np;
210 #endif
211 return(p);
212 }
213 #ifdef MCOMP
214 return(mcompact(np)); /* try compaction */
215 #else
216 *np = 0;
217 return(NULL);
218 #endif
219 }
220
221
222 char *
223 bmalloc(n) /* allocate a block of n bytes, sans header */
224 register unsigned n;
225 {
226 extern char *sbrk();
227 static unsigned pagesz = 0;
228 static unsigned amnt;
229 static char *bpos;
230 static unsigned nrem;
231 unsigned thisamnt;
232 register char *p;
233
234 if (pagesz == 0) { /* initialize */
235 pagesz = amnt = getpagesize();
236 nrem = (int)sbrk(0); /* page align break */
237 nrem = pagesz - (nrem&(pagesz-1));
238 bpos = sbrk(nrem);
239 if ((int)bpos == -1)
240 return(NULL);
241 #ifdef MSTATS
242 b_nsbrked += nrem;
243 #endif
244 bpos += nrem & (BYTES_WORD-1); /* align pointer */
245 nrem &= ~(BYTES_WORD-1);
246 memlim[0] = bpos;
247 memlim[1] = bpos + nrem;
248 }
249
250 n = (n+(BYTES_WORD-1))&~(BYTES_WORD-1); /* word align rqst. */
251
252 if (n > nrem) { /* need more core */
253 tryagain:
254 if (n > amnt) { /* big chunk */
255 thisamnt = (n+(pagesz-1))&~(pagesz-1);
256 if (thisamnt <= MAXINCR) /* increase amnt */
257 amnt = thisamnt;
258 } else
259 thisamnt = amnt;
260 p = sbrk(thisamnt);
261 if ((int)p == -1) { /* uh-oh, ENOMEM */
262 errno = 0; /* call cavalry */
263 if (thisamnt >= n+pagesz) {
264 amnt = pagesz; /* minimize request */
265 goto tryagain;
266 }
267 thisamnt = n;
268 p = mscrounge(&thisamnt); /* search free lists */
269 if (p == NULL) { /* we're really out */
270 errno = ENOMEM;
271 return(NULL);
272 }
273 }
274 #ifdef MSTATS
275 else b_nsbrked += thisamnt;
276 #endif
277 if (p != bpos+nrem) { /* not an increment */
278 bfree(bpos, nrem); /* free what we have */
279 bpos = p;
280 nrem = thisamnt;
281 } else /* otherwise tack on */
282 nrem += thisamnt;
283 if (bpos < memlim[0])
284 memlim[0] = bpos;
285 if (bpos + nrem > memlim[1])
286 memlim[1] = bpos + nrem;
287 }
288 p = bpos;
289 bpos += n; /* advance */
290 nrem -= n;
291 #ifdef MSTATS
292 b_nalloced += n;
293 #endif
294 return(p);
295 }
296
297
298 bfree(p, n) /* free n bytes of random memory */
299 register char *p;
300 register unsigned n;
301 {
302 register int bucket;
303 register unsigned bsiz;
304
305 if (n < 1<<FIRSTBUCKET || p == NULL)
306 return;
307 #ifdef MSTATS
308 b_nfreed += n;
309 #endif
310 /* align pointer */
311 bsiz = BYTES_WORD - ((unsigned)p&(BYTES_WORD-1));
312 if (bsiz < BYTES_WORD) {
313 p += bsiz;
314 n -= bsiz;
315 }
316 if (p < memlim[0])
317 memlim[0] = p;
318 if (p + n > memlim[1])
319 memlim[1] = p + n;
320 /* fill big buckets first */
321 for (bucket = NBUCKETS-1, bsiz = 1<<(NBUCKETS-1);
322 bucket >= FIRSTBUCKET; bucket--, bsiz >>= 1)
323 if (n >= bsiz+sizeof(M_HEAD)) {
324 ((M_HEAD *)p)->next = free_list[bucket];
325 free_list[bucket] = (M_HEAD *)p;
326 p += bsiz+sizeof(M_HEAD);
327 n -= bsiz+sizeof(M_HEAD);
328 }
329 }
330
331
332 char *
333 malloc(n) /* allocate n bytes of memory */
334 unsigned n;
335 {
336 register M_HEAD *mp;
337 register int bucket;
338 register unsigned bsiz;
339 /* don't return NULL on 0 request */
340 if (n == 0)
341 return(DUMMYLOC);
342 /* find first bucket that fits */
343 for (bucket = FIRSTBUCKET, bsiz = 1<<FIRSTBUCKET;
344 bucket < NBUCKETS; bucket++, bsiz <<= 1)
345 if (bsiz >= n)
346 break;
347 if (bucket >= NBUCKETS) {
348 errno = EINVAL;
349 return(NULL);
350 }
351 if (free_list[bucket] == NULL) { /* need more core */
352 mp = (M_HEAD *)bmalloc(bsiz+sizeof(M_HEAD));
353 if (mp == NULL)
354 return(NULL);
355 } else { /* got it */
356 mp = free_list[bucket];
357 free_list[bucket] = mp->next;
358 }
359 #ifdef MSTATS
360 m_nalloced += bsiz + sizeof(M_HEAD);
361 m_nwasted += bsiz + sizeof(M_HEAD) - n;
362 #endif
363 mp->a.magic = MAGIC; /* tag block */
364 mp->a.bucket = bucket;
365 return((char *)(mp+1));
366 }
367
368
369 char *
370 realloc(op, n) /* reallocate memory using malloc() */
371 register char *op;
372 unsigned n;
373 {
374 char *p;
375 register unsigned on;
376 /* get old size */
377 if (op != DUMMYLOC && !BADPTR(op) &&
378 ((M_HEAD *)op-1)->a.magic == MAGIC)
379 on = 1 << ((M_HEAD *)op-1)->a.bucket;
380 else
381 on = 0;
382 if (n <= on && (n > on>>1 || on == 1<<FIRSTBUCKET))
383 return(op); /* same bucket */
384 if ((p = malloc(n)) == NULL)
385 return(n<=on ? op : NULL);
386 if (on) {
387 bcopy(op, p, n>on ? on : n);
388 free(op);
389 }
390 return(p);
391 }
392
393
394 free(p) /* free memory allocated by malloc */
395 char *p;
396 {
397 register M_HEAD *mp;
398 register int bucket;
399
400 if (p == DUMMYLOC)
401 return(1);
402 if (BADPTR(p))
403 goto invalid;
404 mp = (M_HEAD *)p - 1;
405 if (mp->a.magic != MAGIC) /* sanity check */
406 goto invalid;
407 bucket = mp->a.bucket;
408 if (bucket < FIRSTBUCKET | bucket >= NBUCKETS)
409 goto invalid;
410 mp->next = free_list[bucket];
411 free_list[bucket] = mp;
412 #ifdef MSTATS
413 m_nfreed += (1 << bucket) + sizeof(M_HEAD);
414 #endif
415 return(1);
416 invalid:
417 errno = EINVAL;
418 return(0);
419 }
420
421
422 #ifdef MSTATS
423 printmemstats(fp) /* print memory statistics to stream */
424 FILE *fp;
425 {
426 register int i;
427 int n;
428 register M_HEAD *mp;
429 unsigned int total = 0;
430
431 fprintf(fp, "Memory statistics:\n");
432 fprintf(fp, "\tbmalloc: %d bytes from sbrk\n", b_nsbrked);
433 fprintf(fp, "\tbmalloc: %d bytes allocated\n", b_nalloced);
434 fprintf(fp, "\tbmalloc: %d bytes freed\n", b_nfreed);
435 fprintf(fp, "\tbmalloc: %d bytes scrounged\n", b_nscrounged);
436 fprintf(fp, "\tbmalloc: %d bytes compacted\n", b_ncompacted);
437 fprintf(fp, "\tmalloc: %d bytes allocated\n", m_nalloced);
438 fprintf(fp, "\tmalloc: %d bytes wasted (%.1f%%)\n", m_nwasted,
439 100.0*m_nwasted/m_nalloced);
440 fprintf(fp, "\tmalloc: %d bytes freed\n", m_nfreed);
441 for (i = NBUCKETS-1; i >= FIRSTBUCKET; i--) {
442 n = 0;
443 for (mp = free_list[i]; mp != NULL; mp = mp->next)
444 n++;
445 if (n) {
446 fprintf(fp, "\t%d * %u\n", n, 1<<i);
447 total += n * ((1<<i) + sizeof(M_HEAD));
448 }
449 }
450 fprintf(fp, "\t %u total bytes in free list\n", total);
451 }
452 #endif
