1 |
/* Copyright (c) 1992 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Fast malloc for memory hogs and VM environments. |
9 |
* Performs a minimum of searching through free lists. |
10 |
* malloc(), realloc() and free() use buckets |
11 |
* containing blocks in powers of two, similar to CIT routines. |
12 |
* bfree() puts memory from any source into malloc free lists. |
13 |
* bmalloc() doesn't keep track of free lists -- it's usually |
14 |
* just a buffered call to sbrk(2). However, bmalloc will |
15 |
* call mscrounge() if sbrk fails. |
16 |
* mscrounge() returns whatever free memory it can find to satisfy the |
17 |
* request along with the number of bytes (modified). |
18 |
* mcompact() takes the same arguments as mscrounge() (and is in fact |
19 |
* called by mscrounge() under dire circumstances), but it uses |
20 |
* memory compaction to return a larger block. (MCOMP) |
21 |
22 |
* Greg Ward Lawrence Berkeley Laboratory |
23 |
24 |
25 |
#include <errno.h> |
26 |
27 |
#ifndef BSD |
28 |
#define bcopy(s,d,n) (void)memcpy(d,s,n) |
29 |
#define bzero(d,n) (void)memset(d,0,n) |
30 |
#endif |
31 |
32 |
#ifdef MSTATS |
33 |
#include <stdio.h> |
34 |
static unsigned b_nsbrked = 0; |
35 |
static unsigned b_nalloced = 0; |
36 |
static unsigned b_nfreed = 0; |
37 |
static unsigned b_nscrounged = 0; |
38 |
static unsigned b_ncompacted = 0; |
39 |
static unsigned m_nalloced = 0; |
40 |
static unsigned m_nfreed = 0; |
41 |
static unsigned m_nwasted = 0; |
42 |
#else |
43 |
#define NULL 0 |
44 |
#endif |
45 |
46 |
#ifndef ALIGN |
47 |
#define ALIGN int /* align type */ |
48 |
#endif |
49 |
#define BYTES_WORD sizeof(ALIGN) |
50 |
51 |
#ifndef MAXINCR |
52 |
#define MAXINCR (1<<16) /* largest sbrk(2) increment */ |
53 |
#endif |
54 |
/* malloc free lists */ |
55 |
typedef union m_head { |
56 |
union m_head *next; |
57 |
struct { |
58 |
short magic; |
59 |
short bucket; |
60 |
} a; |
61 |
ALIGN dummy; |
62 |
} M_HEAD; |
63 |
64 |
#define MAGIC 0x1a2 /* magic number for allocated memory */ |
65 |
66 |
#define FIRSTBUCKET 3 |
67 |
#define NBUCKETS 30 |
68 |
69 |
static M_HEAD *free_list[NBUCKETS]; |
70 |
71 |
static ALIGN dummy_mem; |
72 |
73 |
static char *memlim[2]; |
74 |
75 |
#define DUMMYLOC ((char *)&dummy_mem) |
76 |
77 |
#define BADPTR(p) ((p) < memlim[0] | (p) >= memlim[1]) |
78 |
79 |
#ifdef MCOMP /* memory compaction routines */ |
80 |
static char seedtab[1024]; /* seed for compaction table */ |
81 |
82 |
static struct mblk { |
83 |
char *ptr; /* pointer to memory block */ |
84 |
unsigned siz; /* size of memory block */ |
85 |
} cptab = {seedtab, sizeof(seedtab)}; |
86 |
87 |
#define mtab(mb) ((struct mblk *)(mb)->ptr) |
88 |
#define mtablen(mb) ((mb)->siz/sizeof(struct mblk)) |
89 |
90 |
91 |
static int |
92 |
mbcmp(m1, m2) /* compare memory block locations */ |
93 |
register struct mblk *m1, *m2; |
94 |
95 |
/* put empty blocks at end */ |
96 |
if (m1->siz == 0) |
97 |
return(m2->siz == 0 ? 0 : 1); |
98 |
if (m2->siz == 0) |
99 |
return(-1); |
100 |
/* otherwise, ascending order */ |
101 |
return(m1->ptr - m2->ptr); |
102 |
103 |
104 |
105 |
int |
106 |
compactfree() /* compact free lists (moving to table) */ |
107 |
108 |
register struct mblk *tp; |
109 |
register int bucket; |
110 |
unsigned n, bsiz, ncomp; |
111 |
/* fill table from free lists */ |
112 |
tp = mtab(&cptab); n = mtablen(&cptab); |
113 |
bucket = NBUCKETS-1; bsiz = 1<<(NBUCKETS-1); |
114 |
ncomp = 0; |
115 |
for ( ; ; ) { |
116 |
while (tp->siz) { /* find empty slot */ |
117 |
if (--n == 0) |
118 |
goto loopexit; |
119 |
tp++; |
120 |
121 |
while (free_list[bucket] == NULL) { /* find block */ |
122 |
if (--bucket < FIRSTBUCKET) |
123 |
goto loopexit; |
124 |
bsiz >>= 1; |
125 |
126 |
tp->ptr = (char *)free_list[bucket]; |
127 |
ncomp += (tp->siz = bsiz + sizeof(M_HEAD)); |
128 |
free_list[bucket] = free_list[bucket]->next; |
129 |
130 |
loopexit: |
131 |
if (ncomp == 0) |
132 |
return(0); /* nothing new to compact */ |
133 |
#ifdef MSTATS |
134 |
b_ncompacted += ncomp; |
135 |
#endif |
136 |
tp = mtab(&cptab); n = mtablen(&cptab); /* sort table */ |
137 |
qsort((char *)tp, n, sizeof(struct mblk), mbcmp); |
138 |
ncomp = 0; /* collect blocks */ |
139 |
while (--n && tp[1].siz) { |
140 |
if (tp[0].ptr + tp[0].siz == tp[1].ptr) { |
141 |
tp[1].ptr = tp[0].ptr; |
142 |
tp[1].siz += tp[0].siz; |
143 |
ncomp += tp[0].siz; |
144 |
tp[0].siz = 0; |
145 |
146 |
tp++; |
147 |
148 |
return(ncomp); |
149 |
150 |
151 |
152 |
char * |
153 |
mcompact(np) /* compact free lists to satisfy request */ |
154 |
unsigned *np; |
155 |
156 |
struct mblk *tab; |
157 |
unsigned tablen; |
158 |
register struct mblk *bp, *big; |
159 |
160 |
for ( ; ; ) { |
161 |
/* compact free lists */ |
162 |
while (compactfree()) |
163 |
164 |
/* find largest block */ |
165 |
tab = mtab(&cptab); tablen = mtablen(&cptab); |
166 |
big = tab; |
167 |
bp = tab + tablen; |
168 |
while (--bp > tab) |
169 |
if (bp->siz > big->siz) |
170 |
big = bp; |
171 |
if (big->siz >= *np) { /* big enough? */ |
172 |
*np = big->siz; |
173 |
big->siz = 0; /* remove from table */ |
174 |
return(big->ptr); /* return it */ |
175 |
176 |
if (mtablen(big) <= tablen) { |
177 |
*np = 0; /* cannot grow table */ |
178 |
return(NULL); /* report failure */ |
179 |
180 |
/* enlarge table, free old one */ |
181 |
mtab(big)[0].ptr = cptab.ptr; |
182 |
mtab(big)[0].siz = cptab.siz; |
183 |
cptab.ptr = big->ptr; |
184 |
cptab.siz = big->siz; |
185 |
big->siz = 0; /* clear and copy */ |
186 |
bcopy((char *)tab, (char *)(mtab(&cptab)+1), |
187 |
tablen*sizeof(struct mblk)); |
188 |
bzero((char *)(mtab(&cptab)+tablen+1), |
189 |
(mtablen(&cptab)-tablen-1)*sizeof(struct mblk)); |
190 |
} /* next round */ |
191 |
192 |
#endif /* MCOMP */ |
193 |
194 |
195 |
char * |
196 |
mscrounge(np) /* search free lists to satisfy request */ |
197 |
register unsigned *np; |
198 |
199 |
char *p; |
200 |
201 |
register unsigned bsiz; |
202 |
203 |
for (bucket = FIRSTBUCKET, bsiz = 1<<FIRSTBUCKET; |
204 |
bucket < NBUCKETS; bucket++, bsiz <<= 1) |
205 |
if (free_list[bucket] != NULL && bsiz+sizeof(M_HEAD) >= *np) { |
206 |
*np = bsiz+sizeof(M_HEAD); |
207 |
p = (char *)free_list[bucket]; |
208 |
209 |
#ifdef MSTATS |
210 |
b_nscrounged += *np; |
211 |
#endif |
212 |
return(p); |
213 |
214 |
#ifdef MCOMP |
215 |
return(mcompact(np)); /* try compaction */ |
216 |
#else |
217 |
*np = 0; |
218 |
return(NULL); |
219 |
#endif |
220 |
221 |
222 |
223 |
char * |
224 |
bmalloc(n) /* allocate a block of n bytes, sans header */ |
225 |
register unsigned n; |
226 |
227 |
extern char *sbrk(); |
228 |
static unsigned pagesz = 0; |
229 |
static unsigned amnt; |
230 |
static char *bpos; |
231 |
static unsigned nrem; |
232 |
unsigned thisamnt; |
233 |
register char *p; |
234 |
235 |
if (pagesz == 0) { /* initialize */ |
236 |
pagesz = amnt = getpagesize(); |
237 |
nrem = (int)sbrk(0); /* page align break */ |
238 |
nrem = pagesz - (nrem&(pagesz-1)); |
239 |
bpos = sbrk(nrem); |
240 |
if ((int)bpos == -1) |
241 |
return(NULL); |
242 |
#ifdef MSTATS |
243 |
b_nsbrked += nrem; |
244 |
#endif |
245 |
bpos += nrem & (BYTES_WORD-1); /* align pointer */ |
246 |
nrem &= ~(BYTES_WORD-1); |
247 |
memlim[0] = bpos; |
248 |
memlim[1] = bpos + nrem; |
249 |
250 |
251 |
n = (n+(BYTES_WORD-1))&~(BYTES_WORD-1); /* word align rqst. */ |
252 |
253 |
if (n > nrem) { /* need more core */ |
254 |
tryagain: |
255 |
if (n > amnt) { /* big chunk */ |
256 |
thisamnt = (n+(pagesz-1))&~(pagesz-1); |
257 |
if (thisamnt <= MAXINCR) /* increase amnt */ |
258 |
amnt = thisamnt; |
259 |
} else |
260 |
thisamnt = amnt; |
261 |
p = sbrk(thisamnt); |
262 |
if ((int)p == -1) { /* uh-oh, ENOMEM */ |
263 |
errno = 0; /* call cavalry */ |
264 |
if (thisamnt >= n+pagesz) { |
265 |
amnt = pagesz; /* minimize request */ |
266 |
goto tryagain; |
267 |
268 |
thisamnt = n; |
269 |
p = mscrounge(&thisamnt); /* search free lists */ |
270 |
if (p == NULL) { /* we're really out */ |
271 |
errno = ENOMEM; |
272 |
return(NULL); |
273 |
274 |
275 |
#ifdef MSTATS |
276 |
else b_nsbrked += thisamnt; |
277 |
#endif |
278 |
if (p != bpos+nrem) { /* not an increment */ |
279 |
bfree(bpos, nrem); /* free what we have */ |
280 |
bpos = p; |
281 |
nrem = thisamnt; |
282 |
} else /* otherwise tack on */ |
283 |
nrem += thisamnt; |
284 |
if (bpos < memlim[0]) |
285 |
memlim[0] = bpos; |
286 |
if (bpos + nrem > memlim[1]) |
287 |
288 |
289 |
p = bpos; |
290 |
bpos += n; /* advance */ |
291 |
nrem -= n; |
292 |
#ifdef MSTATS |
293 |
b_nalloced += n; |
294 |
#endif |
295 |
return(p); |
296 |
297 |
298 |
299 |
bfree(p, n) /* free n bytes of random memory */ |
300 |
register char *p; |
301 |
302 |
303 |
304 |
305 |
306 |
if (n < 1<<FIRSTBUCKET) |
307 |
return; |
308 |
#ifdef MSTATS |
309 |
b_nfreed += n; |
310 |
#endif |
311 |
312 |
bsiz = BYTES_WORD - ((unsigned)p&(BYTES_WORD-1)); |
313 |
if (bsiz < BYTES_WORD) { |
314 |
p += bsiz; |
315 |
n -= bsiz; |
316 |
317 |
if (p < memlim[0]) |
318 |
memlim[0] = p; |
319 |
if (p + n > memlim[1]) |
320 |
memlim[1] = p + n; |
321 |
/* fill big buckets first */ |
322 |
for (bucket = NBUCKETS-1, bsiz = 1<<(NBUCKETS-1); |
323 |
bucket >= FIRSTBUCKET; bucket--, bsiz >>= 1) |
324 |
if (n >= bsiz+sizeof(M_HEAD)) { |
325 |
((M_HEAD *)p)->next = free_list[bucket]; |
326 |
free_list[bucket] = (M_HEAD *)p; |
327 |
p += bsiz+sizeof(M_HEAD); |
328 |
n -= bsiz+sizeof(M_HEAD); |
329 |
330 |
331 |
332 |
333 |
char * |
334 |
malloc(n) /* allocate n bytes of memory */ |
335 |
unsigned n; |
336 |
337 |
register M_HEAD *mp; |
338 |
339 |
340 |
/* don't return NULL on 0 request */ |
341 |
if (n == 0) |
342 |
return(DUMMYLOC); |
343 |
/* find first bucket that fits */ |
344 |
345 |
346 |
if (bsiz >= n) |
347 |
break; |
348 |
if (bucket >= NBUCKETS) { |
349 |
errno = EINVAL; |
350 |
return(NULL); |
351 |
352 |
if (free_list[bucket] == NULL) { /* need more core */ |
353 |
mp = (M_HEAD *)bmalloc(bsiz+sizeof(M_HEAD)); |
354 |
if (mp == NULL) |
355 |
return(NULL); |
356 |
} else { /* got it */ |
357 |
mp = free_list[bucket]; |
358 |
free_list[bucket] = mp->next; |
359 |
360 |
#ifdef MSTATS |
361 |
m_nalloced += bsiz + sizeof(M_HEAD); |
362 |
m_nwasted += bsiz + sizeof(M_HEAD) - n; |
363 |
#endif |
364 |
mp->a.magic = MAGIC; /* tag block */ |
365 |
mp->a.bucket = bucket; |
366 |
return((char *)(mp+1)); |
367 |
368 |
369 |
370 |
char * |
371 |
realloc(op, n) /* reallocate memory using malloc() */ |
372 |
register char *op; |
373 |
unsigned n; |
374 |
375 |
char *p; |
376 |
register unsigned on; |
377 |
/* get old size */ |
378 |
if (op != DUMMYLOC && !BADPTR(op) && |
379 |
((M_HEAD *)op-1)->a.magic == MAGIC) |
380 |
on = 1 << ((M_HEAD *)op-1)->a.bucket; |
381 |
else |
382 |
on = 0; |
383 |
if (n <= on && (n > on>>1 || on == 1<<FIRSTBUCKET)) |
384 |
return(op); /* same bucket */ |
385 |
if ((p = malloc(n)) == NULL) |
386 |
return(n<=on ? op : NULL); |
387 |
if (on) { |
388 |
bcopy(op, p, n>on ? on : n); |
389 |
free(op); |
390 |
391 |
return(p); |
392 |
393 |
394 |
395 |
free(p) /* free memory allocated by malloc */ |
396 |
char *p; |
397 |
398 |
399 |
400 |
401 |
if (p == DUMMYLOC) |
402 |
return(1); |
403 |
if (BADPTR(p)) |
404 |
goto invalid; |
405 |
mp = (M_HEAD *)p - 1; |
406 |
if (mp->a.magic != MAGIC) /* sanity check */ |
407 |
goto invalid; |
408 |
bucket = mp->a.bucket; |
409 |
if (bucket < FIRSTBUCKET | bucket >= NBUCKETS) |
410 |
goto invalid; |
411 |
mp->next = free_list[bucket]; |
412 |
free_list[bucket] = mp; |
413 |
#ifdef MSTATS |
414 |
m_nfreed += (1 << bucket) + sizeof(M_HEAD); |
415 |
#endif |
416 |
return(1); |
417 |
invalid: |
418 |
errno = EINVAL; |
419 |
return(0); |
420 |
421 |
422 |
423 |
#ifdef MSTATS |
424 |
printmemstats(fp) /* print memory statistics to stream */ |
425 |
FILE *fp; |
426 |
427 |
register int i; |
428 |
int n; |
429 |
430 |
unsigned int total = 0; |
431 |
432 |
fprintf(fp, "Memory statistics:\n"); |
433 |
fprintf(fp, "\tbmalloc: %d bytes from sbrk\n", b_nsbrked); |
434 |
fprintf(fp, "\tbmalloc: %d bytes allocated\n", b_nalloced); |
435 |
fprintf(fp, "\tbmalloc: %d bytes freed\n", b_nfreed); |
436 |
fprintf(fp, "\tbmalloc: %d bytes scrounged\n", b_nscrounged); |
437 |
fprintf(fp, "\tbmalloc: %d bytes compacted\n", b_ncompacted); |
438 |
fprintf(fp, "\tmalloc: %d bytes allocated\n", m_nalloced); |
439 |
fprintf(fp, "\tmalloc: %d bytes wasted (%.1f%%)\n", m_nwasted, |
440 |
100.0*m_nwasted/m_nalloced); |
441 |
fprintf(fp, "\tmalloc: %d bytes freed\n", m_nfreed); |
442 |
for (i = NBUCKETS-1; i >= FIRSTBUCKET; i--) { |
443 |
n = 0; |
444 |
for (mp = free_list[i]; mp != NULL; mp = mp->next) |
445 |
n++; |
446 |
if (n) { |
447 |
fprintf(fp, "\t%d * %u\n", n, 1<<i); |
448 |
total += n * ((1<<i) + sizeof(M_HEAD)); |
449 |
450 |
451 |
fprintf(fp, "\t %u total bytes in free list\n", total); |
452 |
453 |
#endif |
