--- ray/src/common/malloc.c 1990/09/25 18:56:37 1.2 +++ ray/src/common/malloc.c 1990/09/26 06:23:10 1.3 @@ -8,10 +8,13 @@ static char SCCSid[] = "$SunId$ LBL"; * Fast malloc for memory hogs and VM environments. * Performs a minimum of searching through free lists. * bmalloc() doesn't keep track of free lists -- it's basically - * just a buffered call to sbrk(). - * bfree() puts memory from any source into malloc() free lists. + * just a buffered call to sbrk(2). However, bmalloc will + * call mscrounge() if sbrk fails. + * bfree() puts memory from any source into malloc free lists. * malloc(), realloc() and free() use buckets * containing blocks in powers of two, similar to CIT routines. + * mscrounge() returns whatever memory it can find to satisfy the + * request along with the number of bytes (modified). * * Greg Ward Lawrence Berkeley Laboratory */ @@ -23,10 +26,11 @@ static char SCCSid[] = "$SunId$ LBL"; #endif #define BYTES_WORD sizeof(ALIGN) +#define MAXINCR (1<<18) /* largest sbrk(2) increment */ + #ifdef NOVMEM #define getpagesize() BYTES_WORD #endif - /* malloc free lists */ typedef union m_head { union m_head *next; @@ -41,14 +45,36 @@ static M_HEAD *free_list[NBUCKETS]; char * +mscrounge(np) /* search free lists trying to satisfy request */ +register unsigned *np; +{ + char *p; + register int bucket; + register unsigned bsiz; + + for (bucket = FIRSTBUCKET, bsiz = 1<= *np) { + *np = bsiz+sizeof(M_HEAD); + p = (char *)free_list[bucket]; + free_list[bucket] = free_list[bucket]->next; + return(p); + } + *np = 0; + return(NULL); +} + + +char * bmalloc(n) /* allocate a block of n bytes, sans header */ register unsigned n; { extern char *sbrk(); - static int pagesz = 0; - static int amnt; + static unsigned pagesz = 0; + static unsigned amnt; static char *bpos; - static int nrem; + static unsigned nrem; + unsigned thisamnt; register char *p; if (pagesz == 0) { /* initialize */ @@ -63,17 +89,25 @@ register unsigned n; n = (n+(BYTES_WORD-1))&~(BYTES_WORD-1); /* word align rqst. */ if (n > nrem) { /* need more core */ - if (n > amnt) /* increase amount */ - amnt = (n+(pagesz-1))&~(pagesz-1); - p = sbrk(amnt); - if ((int)p == -1) - return(NULL); - if (p != bpos+nrem) { /* someone called sbrk()! */ + if (n > amnt) { /* big chunk */ + thisamnt = (n+(pagesz-1))&~(pagesz-1); + if (thisamnt <= MAXINCR) /* increase amnt */ + amnt = thisamnt; + } else + thisamnt = amnt; + p = sbrk(thisamnt); + if ((int)p == -1) { /* uh-oh */ + thisamnt = n; /* search free lists */ + p = mscrounge(&thisamnt); + if (p == NULL) /* we're really out */ + return(NULL); + } + if (p != bpos+nrem) { /* not an increment */ bfree(bpos, nrem); bpos = p; - nrem = amnt; + nrem = thisamnt; } else - nrem += amnt; + nrem += thisamnt; } p = bpos; bpos += n; /* advance */
