root/radiance/ray/src/common/malloc.c
Revision: 1.14
Committed: Mon Aug 26 10:12:24 1991 UTC (33 years, 8 months ago) by greg
Changes since 1.13: +138 -0 lines
added memory compaction
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Fast malloc for memory hogs and VM environments.
9 * Performs a minimum of searching through free lists.
10 * malloc(), realloc() and free() use buckets
11 * containing blocks in powers of two, similar to CIT routines.
12 * bfree() puts memory from any source into malloc free lists.
13 * bmalloc() doesn't keep track of free lists -- it's usually
14 * just a buffered call to sbrk(2). However, bmalloc will
15 * call mscrounge() if sbrk fails.
16 * mscrounge() returns whatever free memory it can find to satisfy the
17 * request along with the number of bytes (modified).
18 * mcompact() takes the same arguments as mscrounge() (and is in fact
19 * called by mscrounge() under dire circumstances), but it uses
20 * memory compaction to return a larger block. (MCOMP)
21 *
22 * Greg Ward Lawrence Berkeley Laboratory
23 */
24
25 #include <errno.h>
26
27 #ifdef MSTATS
28 #include <stdio.h>
29 static unsigned b_nsbrked = 0;
30 static unsigned b_nalloced = 0;
31 static unsigned b_nfreed = 0;
32 static unsigned b_nscrounged = 0;
33 static unsigned b_ncompacted = 0;
34 static unsigned m_nalloced = 0;
35 static unsigned m_nfreed = 0;
36 static unsigned m_nwasted = 0;
37 #else
38 #define NULL 0
39 #endif
40
41 #ifndef ALIGN
42 #define ALIGN int /* align type */
43 #endif
44 #define BYTES_WORD sizeof(ALIGN)
45
46 #define MAXINCR (1<<16) /* largest sbrk(2) increment */
47
48 #ifdef NOVMEM
49 #define getpagesize() 1024
50 #endif
51 /* malloc free lists */
52 typedef union m_head {
53 union m_head *next;
54 struct {
55 short magic;
56 short bucket;
57 } a;
58 ALIGN dummy;
59 } M_HEAD;
60
61 #define MAGIC 0x1a2 /* magic number for allocated memory */
62
63 #define FIRSTBUCKET 3
64 #define NBUCKETS 30
65
66 static M_HEAD *free_list[NBUCKETS];
67
68 static ALIGN dummy_mem;
69
70 #define DUMMYLOC ((char *)&dummy_mem)
71
72 #ifdef MCOMP /* memory compaction routines */
73 static char seedtab[1024]; /* seed for compaction table */
74
75 static struct mblk {
76 char *ptr; /* pointer to memory block */
77 unsigned siz; /* size of memory block */
78 } cptab = {seedtab, sizeof(seedtab)};
79
80 #define mtab(mb) ((struct mblk *)(mb)->ptr)
81 #define mtablen(mb) ((mb)->siz/sizeof(struct mblk))
82
83
84 static int
85 mbcmp(m1, m2) /* compare memory block locations */
86 register struct mblk *m1, *m2;
87 {
88 /* put empty blocks at end */
89 if (m1->siz == 0)
90 return(m2->siz == 0 ? 0 : 1);
91 if (m2->siz == 0)
92 return(-1);
93 /* otherwise, ascending order */
94 return(m1->ptr - m2->ptr);
95 }
96
97
98 int
99 compactfree() /* compact free lists (moving to table) */
100 {
101 register struct mblk *tp;
102 register int bucket;
103 unsigned n, bsiz, ncomp;
104 /* fill table from free lists */
105 tp = mtab(&cptab); n = mtablen(&cptab);
106 bucket = NBUCKETS-1; bsiz = 1<<(NBUCKETS-1);
107 ncomp = 0;
108 for ( ; ; ) {
109 while (tp->siz) { /* find empty slot */
110 if (--n == 0)
111 goto loopexit;
112 tp++;
113 }
114 while (free_list[bucket] == NULL) { /* find block */
115 if (--bucket < FIRSTBUCKET)
116 goto loopexit;
117 bsiz >>= 1;
118 }
119 tp->ptr = (char *)free_list[bucket];
120 ncomp += (tp->siz = bsiz + sizeof(M_HEAD));
121 free_list[bucket] = free_list[bucket]->next;
122 }
123 loopexit:
124 if (ncomp == 0)
125 return(0); /* nothing new to compact */
126 #ifdef MSTATS
127 b_ncompacted += ncomp;
128 #endif
129 tp = mtab(&cptab); n = mtablen(&cptab); /* sort table */
130 qsort((char *)tp, n, sizeof(struct mblk), mbcmp);
131 ncomp = 0; /* collect blocks */
132 while (--n && tp[1].siz) {
133 if (tp[0].ptr + tp[0].siz == tp[1].ptr) {
134 tp[1].ptr = tp[0].ptr;
135 tp[1].siz += tp[0].siz;
136 ncomp += tp[0].siz;
137 tp[0].siz = 0;
138 }
139 tp++;
140 }
141 return(ncomp);
142 }
143
144
145 char *
146 mcompact(np) /* compact free lists to satisfy request */
147 unsigned *np;
148 {
149 struct mblk *tab;
150 unsigned tablen;
151 register struct mblk *bp, *big;
152
153 for ( ; ; ) {
154 /* compact free lists */
155 compactfree();
156 /* find largest block */
157 tab = mtab(&cptab); tablen = mtablen(&cptab);
158 big = tab;
159 bp = tab + tablen;
160 while (--bp > tab)
161 if (bp->siz > big->siz)
162 big = bp;
163 if (big->siz >= *np) { /* big enough? */
164 *np = big->siz;
165 big->siz = 0; /* remove from table */
166 return(big->ptr); /* return it */
167 }
168 if (mtablen(big) < tablen+1) {
169 *np = 0; /* cannot grow table */
170 return(NULL); /* report failure */
171 }
172 /* enlarge table, free old one */
173 mtab(big)[0].ptr = cptab.ptr;
174 mtab(big)[0].siz = cptab.siz;
175 cptab.ptr = big->ptr;
176 cptab.siz = big->siz;
177 big->siz = 0; /* clear and copy */
178 #ifdef BSD
179 bcopy((char *)tab, (char *)(mtab(&cptab)+1),
180 tablen*sizeof(struct mblk));
181 bzero((char *)(mtab(&cptab)+tablen+1),
182 (mtablen(&cptab)-tablen-1)*sizeof(struct mblk));
183 #else
184 (void)memcpy((char *)(mtab(&cptab)+1), (char *)tab,
185 tablen*sizeof(struct mblk));
186 memset((char *)(mtab(&cptab)+tablen+1), 0,
187 (mtablen(&cptab)-tablen-1)*sizeof(struct mblk));
188 #endif
189 } /* next round */
190 }
191 #endif /* MCOMP */
192
193
194 char *
195 mscrounge(np) /* search free lists to satisfy request */
196 register unsigned *np;
197 {
198 char *p;
199 register int bucket;
200 register unsigned bsiz;
201
202 for (bucket = FIRSTBUCKET, bsiz = 1<<FIRSTBUCKET;
203 bucket < NBUCKETS; bucket++, bsiz <<= 1)
204 if (free_list[bucket] != NULL && bsiz+sizeof(M_HEAD) >= *np) {
205 *np = bsiz+sizeof(M_HEAD);
206 p = (char *)free_list[bucket];
207 free_list[bucket] = free_list[bucket]->next;
208 #ifdef MSTATS
209 b_nscrounged += *np;
210 #endif
211 return(p);
212 }
213 #ifdef MCOMP
214 return(mcompact(np)); /* try compaction */
215 #else
216 *np = 0;
217 return(NULL);
218 #endif
219 }
220
221
222 char *
223 bmalloc(n) /* allocate a block of n bytes, sans header */
224 register unsigned n;
225 {
226 extern char *sbrk();
227 static unsigned pagesz = 0;
228 static unsigned amnt;
229 static char *bpos;
230 static unsigned nrem;
231 unsigned thisamnt;
232 register char *p;
233
234 if (pagesz == 0) { /* initialize */
235 pagesz = amnt = getpagesize();
236 nrem = (int)sbrk(0); /* page align break */
237 nrem = pagesz - (nrem&(pagesz-1));
238 bpos = sbrk(nrem); /* word aligned! */
239 if ((int)bpos == -1)
240 return(NULL);
241 #ifdef MSTATS
242 b_nsbrked += nrem;
243 #endif
244 }
245
246 n = (n+(BYTES_WORD-1))&~(BYTES_WORD-1); /* word align rqst. */
247
248 if (n > nrem) { /* need more core */
249 if (n > amnt) { /* big chunk */
250 thisamnt = (n+(pagesz-1))&~(pagesz-1);
251 if (thisamnt <= MAXINCR) /* increase amnt */
252 amnt = thisamnt;
253 } else
254 thisamnt = amnt;
255 p = sbrk(thisamnt);
256 if ((int)p == -1) { /* uh-oh, ENOMEM */
257 thisamnt = n; /* search free lists */
258 p = mscrounge(&thisamnt);
259 if (p == NULL) /* we're really out */
260 return(NULL);
261 }
262 #ifdef MSTATS
263 else b_nsbrked += thisamnt;
264 #endif
265 if (p != bpos+nrem) { /* not an increment */
266 bfree(bpos, nrem); /* free what we have */
267 bpos = p;
268 nrem = thisamnt;
269 } else /* otherwise tack on */
270 nrem += thisamnt;
271 }
272 p = bpos;
273 bpos += n; /* advance */
274 nrem -= n;
275 #ifdef MSTATS
276 b_nalloced += n;
277 #endif
278 return(p);
279 }
280
281
282 bfree(p, n) /* free n bytes of random memory */
283 register char *p;
284 register unsigned n;
285 {
286 register int bucket;
287 register unsigned bsiz;
288
289 #ifdef MSTATS
290 b_nfreed += n;
291 #endif
292 /* align pointer */
293 bsiz = BYTES_WORD - ((unsigned)p&(BYTES_WORD-1));
294 if (bsiz < BYTES_WORD) {
295 p += bsiz;
296 n -= bsiz;
297 }
298 /* fill big buckets first */
299 for (bucket = NBUCKETS-1, bsiz = 1<<(NBUCKETS-1);
300 bucket >= FIRSTBUCKET; bucket--, bsiz >>= 1)
301 if (n >= bsiz+sizeof(M_HEAD)) {
302 ((M_HEAD *)p)->next = free_list[bucket];
303 free_list[bucket] = (M_HEAD *)p;
304 p += bsiz+sizeof(M_HEAD);
305 n -= bsiz+sizeof(M_HEAD);
306 }
307 }
308
309
310 char *
311 malloc(n) /* allocate n bytes of memory */
312 unsigned n;
313 {
314 extern int errno;
315 register M_HEAD *mp;
316 register int bucket;
317 register unsigned bsiz;
318 /* don't return NULL on 0 request */
319 if (n == 0)
320 return(DUMMYLOC);
321 /* find first bucket that fits */
322 for (bucket = FIRSTBUCKET, bsiz = 1<<FIRSTBUCKET;
323 bucket < NBUCKETS; bucket++, bsiz <<= 1)
324 if (bsiz >= n)
325 break;
326 if (bucket >= NBUCKETS) {
327 errno = EINVAL;
328 return(NULL);
329 }
330 if (free_list[bucket] == NULL) { /* need more core */
331 mp = (M_HEAD *)bmalloc(bsiz+sizeof(M_HEAD));
332 if (mp == NULL)
333 return(NULL);
334 } else { /* got it */
335 mp = free_list[bucket];
336 free_list[bucket] = mp->next;
337 }
338 #ifdef MSTATS
339 m_nalloced += bsiz + sizeof(M_HEAD);
340 m_nwasted += bsiz + sizeof(M_HEAD) - n;
341 #endif
342 mp->a.magic = MAGIC; /* tag block */
343 mp->a.bucket = bucket;
344 return((char *)(mp+1));
345 }
346
347
348 char *
349 realloc(op, n) /* reallocate memory using malloc() */
350 register char *op;
351 unsigned n;
352 {
353 char *p;
354 register unsigned on;
355 /* get old size */
356 if (op != NULL && op != DUMMYLOC && ((M_HEAD *)op-1)->a.magic == MAGIC)
357 on = 1 << ((M_HEAD *)op-1)->a.bucket;
358 else
359 on = 0;
360 if (n <= on && (n > on>>1 || on == 1<<FIRSTBUCKET))
361 return(op); /* same bucket */
362 if ((p = malloc(n)) == NULL)
363 return(NULL);
364 if (on) {
365 #ifdef BSD
366 bcopy(op, p, n>on ? on : n);
367 #else
368 (void)memcpy(p, op, n>on ? on : n);
369 #endif
370 free(op);
371 }
372 return(p);
373 }
374
375
376 free(p) /* free memory allocated by malloc */
377 char *p;
378 {
379 register M_HEAD *mp;
380 register int bucket;
381
382 if (p == NULL || p == DUMMYLOC)
383 return(1);
384 mp = (M_HEAD *)p - 1;
385 if (mp->a.magic != MAGIC) /* sanity check */
386 return(0);
387 bucket = mp->a.bucket;
388 mp->next = free_list[bucket];
389 free_list[bucket] = mp;
390 #ifdef MSTATS
391 m_nfreed += (1 << bucket) + sizeof(M_HEAD);
392 #endif
393 return(1);
394 }
395
396
397 #ifndef NOVMEM
398 #ifndef BSD
399 #include <sys/var.h>
400 int
401 getpagesize() /* use SYSV var structure to get page size */
402 {
403 struct var v;
404
405 uvar(&v);
406 return(1 << v.v_pageshift);
407 }
408 #endif
409 #endif
410
411
412 #ifdef MSTATS
413 printmemstats(fp) /* print memory statistics to stream */
414 FILE *fp;
415 {
416 register int i;
417 int n;
418 register M_HEAD *mp;
419 unsigned int total = 0;
420
421 fprintf(fp, "Memory statistics:\n");
422 fprintf(fp, "\tbmalloc: %d bytes from sbrk\n", b_nsbrked);
423 fprintf(fp, "\tbmalloc: %d bytes allocated\n", b_nalloced);
424 fprintf(fp, "\tbmalloc: %d bytes freed\n", b_nfreed);
425 fprintf(fp, "\tbmalloc: %d bytes scrounged\n", b_nscrounged);
426 fprintf(fp, "\tbmalloc: %d bytes compacted\n", b_ncompacted);
427 fprintf(fp, "\tmalloc: %d bytes allocated\n", m_nalloced);
428 fprintf(fp, "\tmalloc: %d bytes wasted (%.1f%%)\n", m_nwasted,
429 100.0*m_nwasted/m_nalloced);
430 fprintf(fp, "\tmalloc: %d bytes freed\n", m_nfreed);
431 for (i = NBUCKETS-1; i >= FIRSTBUCKET; i--) {
432 n = 0;
433 for (mp = free_list[i]; mp != NULL; mp = mp->next)
434 n++;
435 if (n) {
436 fprintf(fp, "\t%d * %u\n", n, 1<<i);
437 total += n * ((1<<i) + sizeof(M_HEAD));
438 }
439 }
440 fprintf(fp, "\t %u total bytes in free list\n", total);
441 }
442 #endif
