--- ray/src/common/malloc.c 1991/07/17 11:35:47 1.13 +++ ray/src/common/malloc.c 1992/02/08 13:16:01 2.4 @@ -1,4 +1,4 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -15,6 +15,9 @@ static char SCCSid[] = "$SunId$ LBL"; * call mscrounge() if sbrk fails. * mscrounge() returns whatever free memory it can find to satisfy the * request along with the number of bytes (modified). + * mcompact() takes the same arguments as mscrounge() (and is in fact + * called by mscrounge() under dire circumstances), but it uses + * memory compaction to return a larger block. (MCOMP) * * Greg Ward Lawrence Berkeley Laboratory */ @@ -23,9 +26,11 @@ static char SCCSid[] = "$SunId$ LBL"; #ifdef MSTATS #include +static unsigned b_nsbrked = 0; static unsigned b_nalloced = 0; static unsigned b_nfreed = 0; static unsigned b_nscrounged = 0; +static unsigned b_ncompacted = 0; static unsigned m_nalloced = 0; static unsigned m_nfreed = 0; static unsigned m_nwasted = 0; @@ -38,10 +43,8 @@ static unsigned m_nwasted = 0; #endif #define BYTES_WORD sizeof(ALIGN) +#ifndef MAXINCR #define MAXINCR (1<<16) /* largest sbrk(2) increment */ - -#ifdef NOVMEM -#define getpagesize() 1024 #endif /* malloc free lists */ typedef union m_head { @@ -64,8 +67,129 @@ static ALIGN dummy_mem; #define DUMMYLOC ((char *)&dummy_mem) +#ifdef MCOMP /* memory compaction routines */ +static char seedtab[1024]; /* seed for compaction table */ +static struct mblk { + char *ptr; /* pointer to memory block */ + unsigned siz; /* size of memory block */ +} cptab = {seedtab, sizeof(seedtab)}; + +#define mtab(mb) ((struct mblk *)(mb)->ptr) +#define mtablen(mb) ((mb)->siz/sizeof(struct mblk)) + + +static int +mbcmp(m1, m2) /* compare memory block locations */ +register struct mblk *m1, *m2; +{ + /* put empty blocks at end */ + if (m1->siz == 0) + return(m2->siz == 0 ? 0 : 1); + if (m2->siz == 0) + return(-1); + /* otherwise, ascending order */ + return(m1->ptr - m2->ptr); +} + + +int +compactfree() /* compact free lists (moving to table) */ +{ + register struct mblk *tp; + register int bucket; + unsigned n, bsiz, ncomp; + /* fill table from free lists */ + tp = mtab(&cptab); n = mtablen(&cptab); + bucket = NBUCKETS-1; bsiz = 1<<(NBUCKETS-1); + ncomp = 0; + for ( ; ; ) { + while (tp->siz) { /* find empty slot */ + if (--n == 0) + goto loopexit; + tp++; + } + while (free_list[bucket] == NULL) { /* find block */ + if (--bucket < FIRSTBUCKET) + goto loopexit; + bsiz >>= 1; + } + tp->ptr = (char *)free_list[bucket]; + ncomp += (tp->siz = bsiz + sizeof(M_HEAD)); + free_list[bucket] = free_list[bucket]->next; + } +loopexit: + if (ncomp == 0) + return(0); /* nothing new to compact */ +#ifdef MSTATS + b_ncompacted += ncomp; +#endif + tp = mtab(&cptab); n = mtablen(&cptab); /* sort table */ + qsort((char *)tp, n, sizeof(struct mblk), mbcmp); + ncomp = 0; /* collect blocks */ + while (--n && tp[1].siz) { + if (tp[0].ptr + tp[0].siz == tp[1].ptr) { + tp[1].ptr = tp[0].ptr; + tp[1].siz += tp[0].siz; + ncomp += tp[0].siz; + tp[0].siz = 0; + } + tp++; + } + return(ncomp); +} + + char * +mcompact(np) /* compact free lists to satisfy request */ +unsigned *np; +{ + struct mblk *tab; + unsigned tablen; + register struct mblk *bp, *big; + + for ( ; ; ) { + /* compact free lists */ + compactfree(); + /* find largest block */ + tab = mtab(&cptab); tablen = mtablen(&cptab); + big = tab; + bp = tab + tablen; + while (--bp > tab) + if (bp->siz > big->siz) + big = bp; + if (big->siz >= *np) { /* big enough? */ + *np = big->siz; + big->siz = 0; /* remove from table */ + return(big->ptr); /* return it */ + } + if (mtablen(big) < tablen+1) { + *np = 0; /* cannot grow table */ + return(NULL); /* report failure */ + } + /* enlarge table, free old one */ + mtab(big)[0].ptr = cptab.ptr; + mtab(big)[0].siz = cptab.siz; + cptab.ptr = big->ptr; + cptab.siz = big->siz; + big->siz = 0; /* clear and copy */ +#ifdef BSD + bcopy((char *)tab, (char *)(mtab(&cptab)+1), + tablen*sizeof(struct mblk)); + bzero((char *)(mtab(&cptab)+tablen+1), + (mtablen(&cptab)-tablen-1)*sizeof(struct mblk)); +#else + (void)memcpy((char *)(mtab(&cptab)+1), (char *)tab, + tablen*sizeof(struct mblk)); + memset((char *)(mtab(&cptab)+tablen+1), 0, + (mtablen(&cptab)-tablen-1)*sizeof(struct mblk)); +#endif + } /* next round */ +} +#endif /* MCOMP */ + + +char * mscrounge(np) /* search free lists to satisfy request */ register unsigned *np; { @@ -84,8 +208,12 @@ register unsigned *np; #endif return(p); } +#ifdef MCOMP + return(mcompact(np)); /* try compaction */ +#else *np = 0; return(NULL); +#endif } @@ -105,9 +233,14 @@ register unsigned n; pagesz = amnt = getpagesize(); nrem = (int)sbrk(0); /* page align break */ nrem = pagesz - (nrem&(pagesz-1)); - bpos = sbrk(nrem); /* word aligned! */ + bpos = sbrk(nrem); if ((int)bpos == -1) return(NULL); +#ifdef MSTATS + b_nsbrked += nrem; +#endif + bpos += nrem & (BYTES_WORD-1); /* align pointer */ + nrem &= ~(BYTES_WORD-1); } n = (n+(BYTES_WORD-1))&~(BYTES_WORD-1); /* word align rqst. */ @@ -126,6 +259,9 @@ register unsigned n; if (p == NULL) /* we're really out */ return(NULL); } +#ifdef MSTATS + else b_nsbrked += thisamnt; +#endif if (p != bpos+nrem) { /* not an increment */ bfree(bpos, nrem); /* free what we have */ bpos = p; @@ -150,6 +286,8 @@ register unsigned n; register int bucket; register unsigned bsiz; + if (n < 1<a.magic != MAGIC) /* sanity check */ return(0); bucket = mp->a.bucket; + if (bucket < FIRSTBUCKET | bucket >= NBUCKETS) + return(0); mp->next = free_list[bucket]; free_list[bucket] = mp; #ifdef MSTATS @@ -258,21 +398,6 @@ char *p; } -#ifndef NOVMEM -#ifndef BSD -#include -int -getpagesize() /* use SYSV var structure to get page size */ -{ - struct var v; - - uvar(&v); - return(1 << v.v_pageshift); -} -#endif -#endif - - #ifdef MSTATS printmemstats(fp) /* print memory statistics to stream */ FILE *fp; @@ -283,9 +408,11 @@ FILE *fp; unsigned int total = 0; fprintf(fp, "Memory statistics:\n"); + fprintf(fp, "\tbmalloc: %d bytes from sbrk\n", b_nsbrked); fprintf(fp, "\tbmalloc: %d bytes allocated\n", b_nalloced); fprintf(fp, "\tbmalloc: %d bytes freed\n", b_nfreed); fprintf(fp, "\tbmalloc: %d bytes scrounged\n", b_nscrounged); + fprintf(fp, "\tbmalloc: %d bytes compacted\n", b_ncompacted); fprintf(fp, "\tmalloc: %d bytes allocated\n", m_nalloced); fprintf(fp, "\tmalloc: %d bytes wasted (%.1f%%)\n", m_nwasted, 100.0*m_nwasted/m_nalloced);
