root/radiance/ray/src/common/malloc.c
Revision: 1.16
Committed: Tue Oct 8 16:00:06 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.15: +1 -18 lines
took out getpagesize()
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Fast malloc for memory hogs and VM environments.
9 * Performs a minimum of searching through free lists.
10 * malloc(), realloc() and free() use buckets
11 * containing blocks in powers of two, similar to CIT routines.
12 * bfree() puts memory from any source into malloc free lists.
13 * bmalloc() doesn't keep track of free lists -- it's usually
14 * just a buffered call to sbrk(2). However, bmalloc will
15 * call mscrounge() if sbrk fails.
16 * mscrounge() returns whatever free memory it can find to satisfy the
17 * request along with the number of bytes (modified).
18 * mcompact() takes the same arguments as mscrounge() (and is in fact
19 * called by mscrounge() under dire circumstances), but it uses
20 * memory compaction to return a larger block. (MCOMP)
21 *
22 * Greg Ward Lawrence Berkeley Laboratory
23 */
24
25 #include <errno.h>
26
27 #ifdef MSTATS
28 #include <stdio.h>
29 static unsigned b_nsbrked = 0;
30 static unsigned b_nalloced = 0;
31 static unsigned b_nfreed = 0;
32 static unsigned b_nscrounged = 0;
33 static unsigned b_ncompacted = 0;
34 static unsigned m_nalloced = 0;
35 static unsigned m_nfreed = 0;
36 static unsigned m_nwasted = 0;
37 #else
38 #define NULL 0
39 #endif
40
41 #ifndef ALIGN
42 #define ALIGN int /* align type */
43 #endif
44 #define BYTES_WORD sizeof(ALIGN)
45
46 #ifndef MAXINCR
47 #define MAXINCR (1<<16) /* largest sbrk(2) increment */
48 #endif
49 /* malloc free lists */
50 typedef union m_head {
51 union m_head *next;
52 struct {
53 short magic;
54 short bucket;
55 } a;
56 ALIGN dummy;
57 } M_HEAD;
58
59 #define MAGIC 0x1a2 /* magic number for allocated memory */
60
61 #define FIRSTBUCKET 3
62 #define NBUCKETS 30
63
64 static M_HEAD *free_list[NBUCKETS];
65
66 static ALIGN dummy_mem;
67
68 #define DUMMYLOC ((char *)&dummy_mem)
69
70 #ifdef MCOMP /* memory compaction routines */
71 static char seedtab[1024]; /* seed for compaction table */
72
73 static struct mblk {
74 char *ptr; /* pointer to memory block */
75 unsigned siz; /* size of memory block */
76 } cptab = {seedtab, sizeof(seedtab)};
77
78 #define mtab(mb) ((struct mblk *)(mb)->ptr)
79 #define mtablen(mb) ((mb)->siz/sizeof(struct mblk))
80
81
82 static int
83 mbcmp(m1, m2) /* compare memory block locations */
84 register struct mblk *m1, *m2;
85 {
86 /* put empty blocks at end */
87 if (m1->siz == 0)
88 return(m2->siz == 0 ? 0 : 1);
89 if (m2->siz == 0)
90 return(-1);
91 /* otherwise, ascending order */
92 return(m1->ptr - m2->ptr);
93 }
94
95
96 int
97 compactfree() /* compact free lists (moving to table) */
98 {
99 register struct mblk *tp;
100 register int bucket;
101 unsigned n, bsiz, ncomp;
102 /* fill table from free lists */
103 tp = mtab(&cptab); n = mtablen(&cptab);
104 bucket = NBUCKETS-1; bsiz = 1<<(NBUCKETS-1);
105 ncomp = 0;
106 for ( ; ; ) {
107 while (tp->siz) { /* find empty slot */
108 if (--n == 0)
109 goto loopexit;
110 tp++;
111 }
112 while (free_list[bucket] == NULL) { /* find block */
113 if (--bucket < FIRSTBUCKET)
114 goto loopexit;
115 bsiz >>= 1;
116 }
117 tp->ptr = (char *)free_list[bucket];
118 ncomp += (tp->siz = bsiz + sizeof(M_HEAD));
119 free_list[bucket] = free_list[bucket]->next;
120 }
121 loopexit:
122 if (ncomp == 0)
123 return(0); /* nothing new to compact */
124 #ifdef MSTATS
125 b_ncompacted += ncomp;
126 #endif
127 tp = mtab(&cptab); n = mtablen(&cptab); /* sort table */
128 qsort((char *)tp, n, sizeof(struct mblk), mbcmp);
129 ncomp = 0; /* collect blocks */
130 while (--n && tp[1].siz) {
131 if (tp[0].ptr + tp[0].siz == tp[1].ptr) {
132 tp[1].ptr = tp[0].ptr;
133 tp[1].siz += tp[0].siz;
134 ncomp += tp[0].siz;
135 tp[0].siz = 0;
136 }
137 tp++;
138 }
139 return(ncomp);
140 }
141
142
143 char *
144 mcompact(np) /* compact free lists to satisfy request */
145 unsigned *np;
146 {
147 struct mblk *tab;
148 unsigned tablen;
149 register struct mblk *bp, *big;
150
151 for ( ; ; ) {
152 /* compact free lists */
153 compactfree();
154 /* find largest block */
155 tab = mtab(&cptab); tablen = mtablen(&cptab);
156 big = tab;
157 bp = tab + tablen;
158 while (--bp > tab)
159 if (bp->siz > big->siz)
160 big = bp;
161 if (big->siz >= *np) { /* big enough? */
162 *np = big->siz;
163 big->siz = 0; /* remove from table */
164 return(big->ptr); /* return it */
165 }
166 if (mtablen(big) < tablen+1) {
167 *np = 0; /* cannot grow table */
168 return(NULL); /* report failure */
169 }
170 /* enlarge table, free old one */
171 mtab(big)[0].ptr = cptab.ptr;
172 mtab(big)[0].siz = cptab.siz;
173 cptab.ptr = big->ptr;
174 cptab.siz = big->siz;
175 big->siz = 0; /* clear and copy */
176 #ifdef BSD
177 bcopy((char *)tab, (char *)(mtab(&cptab)+1),
178 tablen*sizeof(struct mblk));
179 bzero((char *)(mtab(&cptab)+tablen+1),
180 (mtablen(&cptab)-tablen-1)*sizeof(struct mblk));
181 #else
182 (void)memcpy((char *)(mtab(&cptab)+1), (char *)tab,
183 tablen*sizeof(struct mblk));
184 memset((char *)(mtab(&cptab)+tablen+1), 0,
185 (mtablen(&cptab)-tablen-1)*sizeof(struct mblk));
186 #endif
187 } /* next round */
188 }
189 #endif /* MCOMP */
190
191
192 char *
193 mscrounge(np) /* search free lists to satisfy request */
194 register unsigned *np;
195 {
196 char *p;
197 register int bucket;
198 register unsigned bsiz;
199
200 for (bucket = FIRSTBUCKET, bsiz = 1<<FIRSTBUCKET;
201 bucket < NBUCKETS; bucket++, bsiz <<= 1)
202 if (free_list[bucket] != NULL && bsiz+sizeof(M_HEAD) >= *np) {
203 *np = bsiz+sizeof(M_HEAD);
204 p = (char *)free_list[bucket];
205 free_list[bucket] = free_list[bucket]->next;
206 #ifdef MSTATS
207 b_nscrounged += *np;
208 #endif
209 return(p);
210 }
211 #ifdef MCOMP
212 return(mcompact(np)); /* try compaction */
213 #else
214 *np = 0;
215 return(NULL);
216 #endif
217 }
218
219
220 char *
221 bmalloc(n) /* allocate a block of n bytes, sans header */
222 register unsigned n;
223 {
224 extern char *sbrk();
225 static unsigned pagesz = 0;
226 static unsigned amnt;
227 static char *bpos;
228 static unsigned nrem;
229 unsigned thisamnt;
230 register char *p;
231
232 if (pagesz == 0) { /* initialize */
233 pagesz = amnt = getpagesize();
234 nrem = (int)sbrk(0); /* page align break */
235 nrem = pagesz - (nrem&(pagesz-1));
236 bpos = sbrk(nrem); /* word aligned! */
237 if ((int)bpos == -1)
238 return(NULL);
239 #ifdef MSTATS
240 b_nsbrked += nrem;
241 #endif
242 }
243
244 n = (n+(BYTES_WORD-1))&~(BYTES_WORD-1); /* word align rqst. */
245
246 if (n > nrem) { /* need more core */
247 if (n > amnt) { /* big chunk */
248 thisamnt = (n+(pagesz-1))&~(pagesz-1);
249 if (thisamnt <= MAXINCR) /* increase amnt */
250 amnt = thisamnt;
251 } else
252 thisamnt = amnt;
253 p = sbrk(thisamnt);
254 if ((int)p == -1) { /* uh-oh, ENOMEM */
255 thisamnt = n; /* search free lists */
256 p = mscrounge(&thisamnt);
257 if (p == NULL) /* we're really out */
258 return(NULL);
259 }
260 #ifdef MSTATS
261 else b_nsbrked += thisamnt;
262 #endif
263 if (p != bpos+nrem) { /* not an increment */
264 bfree(bpos, nrem); /* free what we have */
265 bpos = p;
266 nrem = thisamnt;
267 } else /* otherwise tack on */
268 nrem += thisamnt;
269 }
270 p = bpos;
271 bpos += n; /* advance */
272 nrem -= n;
273 #ifdef MSTATS
274 b_nalloced += n;
275 #endif
276 return(p);
277 }
278
279
280 bfree(p, n) /* free n bytes of random memory */
281 register char *p;
282 register unsigned n;
283 {
284 register int bucket;
285 register unsigned bsiz;
286
287 if (n < 1<<FIRSTBUCKET)
288 return;
289 #ifdef MSTATS
290 b_nfreed += n;
291 #endif
292 /* align pointer */
293 bsiz = BYTES_WORD - ((unsigned)p&(BYTES_WORD-1));
294 if (bsiz < BYTES_WORD) {
295 p += bsiz;
296 n -= bsiz;
297 }
298 /* fill big buckets first */
299 for (bucket = NBUCKETS-1, bsiz = 1<<(NBUCKETS-1);
300 bucket >= FIRSTBUCKET; bucket--, bsiz >>= 1)
301 if (n >= bsiz+sizeof(M_HEAD)) {
302 ((M_HEAD *)p)->next = free_list[bucket];
303 free_list[bucket] = (M_HEAD *)p;
304 p += bsiz+sizeof(M_HEAD);
305 n -= bsiz+sizeof(M_HEAD);
306 }
307 }
308
309
310 char *
311 malloc(n) /* allocate n bytes of memory */
312 unsigned n;
313 {
314 extern int errno;
315 register M_HEAD *mp;
316 register int bucket;
317 register unsigned bsiz;
318 /* don't return NULL on 0 request */
319 if (n == 0)
320 return(DUMMYLOC);
321 /* find first bucket that fits */
322 for (bucket = FIRSTBUCKET, bsiz = 1<<FIRSTBUCKET;
323 bucket < NBUCKETS; bucket++, bsiz <<= 1)
324 if (bsiz >= n)
325 break;
326 if (bucket >= NBUCKETS) {
327 errno = EINVAL;
328 return(NULL);
329 }
330 if (free_list[bucket] == NULL) { /* need more core */
331 mp = (M_HEAD *)bmalloc(bsiz+sizeof(M_HEAD));
332 if (mp == NULL)
333 return(NULL);
334 } else { /* got it */
335 mp = free_list[bucket];
336 free_list[bucket] = mp->next;
337 }
338 #ifdef MSTATS
339 m_nalloced += bsiz + sizeof(M_HEAD);
340 m_nwasted += bsiz + sizeof(M_HEAD) - n;
341 #endif
342 mp->a.magic = MAGIC; /* tag block */
343 mp->a.bucket = bucket;
344 return((char *)(mp+1));
345 }
346
347
348 char *
349 realloc(op, n) /* reallocate memory using malloc() */
350 register char *op;
351 unsigned n;
352 {
353 char *p;
354 register unsigned on;
355 /* get old size */
356 if (op != NULL && op != DUMMYLOC && ((M_HEAD *)op-1)->a.magic == MAGIC)
357 on = 1 << ((M_HEAD *)op-1)->a.bucket;
358 else
359 on = 0;
360 if (n <= on && (n > on>>1 || on == 1<<FIRSTBUCKET))
361 return(op); /* same bucket */
362 if ((p = malloc(n)) == NULL)
363 return(NULL);
364 if (on) {
365 #ifdef BSD
366 bcopy(op, p, n>on ? on : n);
367 #else
368 (void)memcpy(p, op, n>on ? on : n);
369 #endif
370 free(op);
371 }
372 return(p);
373 }
374
375
376 free(p) /* free memory allocated by malloc */
377 char *p;
378 {
379 register M_HEAD *mp;
380 register int bucket;
381
382 if (p == NULL || p == DUMMYLOC)
383 return(1);
384 mp = (M_HEAD *)p - 1;
385 if (mp->a.magic != MAGIC) /* sanity check */
386 return(0);
387 bucket = mp->a.bucket;
388 mp->next = free_list[bucket];
389 free_list[bucket] = mp;
390 #ifdef MSTATS
391 m_nfreed += (1 << bucket) + sizeof(M_HEAD);
392 #endif
393 return(1);
394 }
395
396
397 #ifdef MSTATS
398 printmemstats(fp) /* print memory statistics to stream */
399 FILE *fp;
400 {
401 register int i;
402 int n;
403 register M_HEAD *mp;
404 unsigned int total = 0;
405
406 fprintf(fp, "Memory statistics:\n");
407 fprintf(fp, "\tbmalloc: %d bytes from sbrk\n", b_nsbrked);
408 fprintf(fp, "\tbmalloc: %d bytes allocated\n", b_nalloced);
409 fprintf(fp, "\tbmalloc: %d bytes freed\n", b_nfreed);
410 fprintf(fp, "\tbmalloc: %d bytes scrounged\n", b_nscrounged);
411 fprintf(fp, "\tbmalloc: %d bytes compacted\n", b_ncompacted);
412 fprintf(fp, "\tmalloc: %d bytes allocated\n", m_nalloced);
413 fprintf(fp, "\tmalloc: %d bytes wasted (%.1f%%)\n", m_nwasted,
414 100.0*m_nwasted/m_nalloced);
415 fprintf(fp, "\tmalloc: %d bytes freed\n", m_nfreed);
416 for (i = NBUCKETS-1; i >= FIRSTBUCKET; i--) {
417 n = 0;
418 for (mp = free_list[i]; mp != NULL; mp = mp->next)
419 n++;
420 if (n) {
421 fprintf(fp, "\t%d * %u\n", n, 1<<i);
422 total += n * ((1<<i) + sizeof(M_HEAD));
423 }
424 }
425 fprintf(fp, "\t %u total bytes in free list\n", total);
426 }
427 #endif
