root/Development/ray/src/common/malloc.c
Tue Feb 25 02:47:21 2003 UTC (22 years, 9 months ago) by greg
Changes since 2.12: +1 -56 lines
Diff to previous 2.12
Sat Feb 22 02:07:22 2003 UTC (22 years, 9 months ago) by greg
Changes since 2.11: +63 -9 lines
Mon Aug 24 15:31:29 1998 UTC (27 years, 3 months ago) by gwlarson
added defensive measure to bfree() for NULL pointer
Fri Nov 10 17:04:15 1995 UTC (30 years, 1 month ago) by greg
Changes since 2.9: +0 -1 lines
removed memcpy() declaration
Tue Oct 24 09:45:07 1995 UTC (30 years, 1 month ago) by greg
modest improvement in compaction algorithm
Thu Oct 8 12:27:02 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.7: +11 -5 lines
slight improvement to behavior on sbrk() failure
Fri Sep 4 18:36:05 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.6: +7 -12 lines
minor aesthetic changes
Fri Sep 4 09:57:43 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.5: +27 -6 lines
additional paranoia -- check pointer bounds before accessing
Mon Jun 29 22:39:51 1992 UTC (33 years, 5 months ago) by greg
reduced conditions for failure of realloc()
Sat Feb 8 13:16:01 1992 UTC (33 years, 10 months ago) by greg
Changes since 2.3: +2 -5 lines
faster initial sbrk() pointer alignment
Fri Feb 7 15:10:32 1992 UTC (33 years, 10 months ago) by greg
Changes since 2.2: +7 -2 lines
bug fix for HP snakes and sbrk() that isn't word aligned
Fri Dec 13 10:28:42 1991 UTC (34 years ago) by greg
additional paranoia in free()
Tue Nov 12 16:54:29 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.16
Tue Oct 8 16:00:06 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.15: +1 -18 lines
Diff to previous 1.15
took out getpagesize()
Mon Aug 26 10:49:08 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.14: +2 -0 lines
Diff to previous 1.14
fixed potential bug in bfree()
Mon Aug 26 10:12:24 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.13: +138 -0 lines
Diff to previous 1.13
added memory compaction
Wed Jul 17 11:35:47 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.12: +15 -12 lines
Diff to previous 1.12
fixed realloc() so as not to free op if malloc fails
Tue Apr 2 09:36:21 1991 UTC (34 years, 8 months ago) by greg
Changes since 1.11: +17 -7 lines
Diff to previous 1.11
Added magic number for sanity checking
Tue Dec 4 20:46:46 1990 UTC (35 years ago) by greg
Diff to previous 1.10
increased default allocation amount for NOVMEM
Tue Nov 13 14:39:05 1990 UTC (35 years, 1 month ago) by greg
Changes since 1.9: +7 -3 lines
Diff to previous 1.9
added check for zero request
Wed Oct 3 21:01:59 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.8: +60 -1 lines
Diff to previous 1.8
added memory statistics gathering (-DMSTATS)
Wed Oct 3 16:20:38 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.7: +3 -7 lines
Diff to previous 1.7
minor change to getpagesize()
Tue Oct 2 12:00:03 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.6: +0 -3 lines
Diff to previous 1.6
made sure malloc(0) doesn't return NULL -- Xlib bug
Wed Sep 26 19:35:46 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.5: +16 -8 lines
Diff to previous 1.5
fixed pointer alignment in bfree() and added new checks
Wed Sep 26 13:46:52 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.4: +9 -6 lines
Diff to previous 1.4
got back old version of realloc() from 1.3
Wed Sep 26 08:26:11 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.3: +31 -33 lines
Diff to previous 1.3
minor improvements to bfree() and realloc()
Wed Sep 26 06:23:10 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.2: +48 -14 lines
Diff to previous 1.2
added mscrounge()
Tue Sep 25 18:56:37 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.1: +14 -12 lines
minor cleanup changes
Tue Sep 25 17:14:04 1990 UTC (35 years, 2 months ago) by greg
