| 1 |
/* Copyright (c) 1992 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Fast malloc for memory hogs and VM environments.
| 9 |
* Performs a minimum of searching through free lists.
| 10 |
* malloc(), realloc() and free() use buckets
| 11 |
* containing blocks in powers of two, similar to CIT routines.
| 12 |
* bfree() puts memory from any source into malloc free lists.
| 13 |
* bmalloc() doesn't keep track of free lists -- it's usually
| 14 |
* just a buffered call to sbrk(2). However, bmalloc will
| 15 |
* call mscrounge() if sbrk fails.
| 16 |
* mscrounge() returns whatever free memory it can find to satisfy the
| 17 |
* request along with the number of bytes (modified).
| 18 |
* mcompact() takes the same arguments as mscrounge() (and is in fact
| 19 |
* called by mscrounge() under dire circumstances), but it uses
| 20 |
* memory compaction to return a larger block. (MCOMP)
| 21 |
| 22 |
* Greg Ward Lawrence Berkeley Laboratory
| 23 |
| 24 |
| 25 |
#include <errno.h>
| 26 |
| 27 |
#ifdef MSTATS
| 28 |
#include <stdio.h>
| 29 |
static unsigned b_nsbrked = 0;
| 30 |
static unsigned b_nalloced = 0;
| 31 |
static unsigned b_nfreed = 0;
| 32 |
static unsigned b_nscrounged = 0;
| 33 |
static unsigned b_ncompacted = 0;
| 34 |
static unsigned m_nalloced = 0;
| 35 |
static unsigned m_nfreed = 0;
| 36 |
static unsigned m_nwasted = 0;
| 37 |
#else
| 38 |
#define NULL 0
| 39 |
#endif
| 40 |
| 41 |
#ifndef ALIGN
| 42 |
#define ALIGN int /* align type */
| 43 |
#endif
| 44 |
#define BYTES_WORD sizeof(ALIGN)
| 45 |
| 46 |
#ifndef MAXINCR
| 47 |
#define MAXINCR (1<<16) /* largest sbrk(2) increment */
| 48 |
#endif
| 49 |
/* malloc free lists */
| 50 |
typedef union m_head {
| 51 |
union m_head *next;
| 52 |
struct {
| 53 |
short magic;
| 54 |
short bucket;
| 55 |
} a;
| 56 |
ALIGN dummy;
| 57 |
} M_HEAD;
| 58 |
| 59 |
#define MAGIC 0x1a2 /* magic number for allocated memory */
| 60 |
| 61 |
#define FIRSTBUCKET 3
| 62 |
#define NBUCKETS 30
| 63 |
| 64 |
static M_HEAD *free_list[NBUCKETS];
| 65 |
| 66 |
static ALIGN dummy_mem;
| 67 |
| 68 |
#define DUMMYLOC ((char *)&dummy_mem)
| 69 |
| 70 |
#ifdef MCOMP /* memory compaction routines */
| 71 |
static char seedtab[1024]; /* seed for compaction table */
| 72 |
| 73 |
static struct mblk {
| 74 |
char *ptr; /* pointer to memory block */
| 75 |
unsigned siz; /* size of memory block */
| 76 |
} cptab = {seedtab, sizeof(seedtab)};
| 77 |
| 78 |
#define mtab(mb) ((struct mblk *)(mb)->ptr)
| 79 |
#define mtablen(mb) ((mb)->siz/sizeof(struct mblk))
| 80 |
| 81 |
| 82 |
static int
| 83 |
mbcmp(m1, m2) /* compare memory block locations */
| 84 |
register struct mblk *m1, *m2;
| 85 |
| 86 |
/* put empty blocks at end */
| 87 |
if (m1->siz == 0)
| 88 |
return(m2->siz == 0 ? 0 : 1);
| 89 |
if (m2->siz == 0)
| 90 |
return(-1);
| 91 |
/* otherwise, ascending order */
| 92 |
return(m1->ptr - m2->ptr);
| 93 |
| 94 |
| 95 |
| 96 |
int
| 97 |
compactfree() /* compact free lists (moving to table) */
| 98 |
| 99 |
register struct mblk *tp;
| 100 |
register int bucket;
| 101 |
unsigned n, bsiz, ncomp;
| 102 |
/* fill table from free lists */
| 103 |
tp = mtab(&cptab); n = mtablen(&cptab);
| 104 |
bucket = NBUCKETS-1; bsiz = 1<<(NBUCKETS-1);
| 105 |
ncomp = 0;
| 106 |
for ( ; ; ) {
| 107 |
while (tp->siz) { /* find empty slot */
| 108 |
if (--n == 0)
| 109 |
goto loopexit;
| 110 |
tp++;
| 111 |
| 112 |
while (free_list[bucket] == NULL) { /* find block */
| 113 |
if (--bucket < FIRSTBUCKET)
| 114 |
goto loopexit;
| 115 |
bsiz >>= 1;
| 116 |
| 117 |
tp->ptr = (char *)free_list[bucket];
| 118 |
ncomp += (tp->siz = bsiz + sizeof(M_HEAD));
| 119 |
free_list[bucket] = free_list[bucket]->next;
| 120 |
| 121 |
loopexit:
| 122 |
if (ncomp == 0)
| 123 |
return(0); /* nothing new to compact */
| 124 |
#ifdef MSTATS
| 125 |
b_ncompacted += ncomp;
| 126 |
#endif
| 127 |
tp = mtab(&cptab); n = mtablen(&cptab); /* sort table */
| 128 |
qsort((char *)tp, n, sizeof(struct mblk), mbcmp);
| 129 |
ncomp = 0; /* collect blocks */
| 130 |
while (--n && tp[1].siz) {
| 131 |
if (tp[0].ptr + tp[0].siz == tp[1].ptr) {
| 132 |
tp[1].ptr = tp[0].ptr;
| 133 |
tp[1].siz += tp[0].siz;
| 134 |
ncomp += tp[0].siz;
| 135 |
tp[0].siz = 0;
| 136 |
| 137 |
tp++;
| 138 |
| 139 |
return(ncomp);
| 140 |
| 141 |
| 142 |
| 143 |
char *
| 144 |
mcompact(np) /* compact free lists to satisfy request */
| 145 |
unsigned *np;
| 146 |
| 147 |
struct mblk *tab;
| 148 |
unsigned tablen;
| 149 |
register struct mblk *bp, *big;
| 150 |
| 151 |
for ( ; ; ) {
| 152 |
/* compact free lists */
| 153 |
compactfree();
| 154 |
/* find largest block */
| 155 |
tab = mtab(&cptab); tablen = mtablen(&cptab);
| 156 |
big = tab;
| 157 |
bp = tab + tablen;
| 158 |
while (--bp > tab)
| 159 |
if (bp->siz > big->siz)
| 160 |
big = bp;
| 161 |
if (big->siz >= *np) { /* big enough? */
| 162 |
*np = big->siz;
| 163 |
big->siz = 0; /* remove from table */
| 164 |
return(big->ptr); /* return it */
| 165 |
| 166 |
if (mtablen(big) < tablen+1) {
| 167 |
*np = 0; /* cannot grow table */
| 168 |
return(NULL); /* report failure */
| 169 |
| 170 |
/* enlarge table, free old one */
| 171 |
mtab(big)[0].ptr = cptab.ptr;
| 172 |
mtab(big)[0].siz = cptab.siz;
| 173 |
cptab.ptr = big->ptr;
| 174 |
cptab.siz = big->siz;
| 175 |
big->siz = 0; /* clear and copy */
| 176 |
#ifdef BSD
| 177 |
bcopy((char *)tab, (char *)(mtab(&cptab)+1),
| 178 |
tablen*sizeof(struct mblk));
| 179 |
bzero((char *)(mtab(&cptab)+tablen+1),
| 180 |
(mtablen(&cptab)-tablen-1)*sizeof(struct mblk));
| 181 |
#else
| 182 |
(void)memcpy((char *)(mtab(&cptab)+1), (char *)tab,
| 183 |
| 184 |
memset((char *)(mtab(&cptab)+tablen+1), 0,
| 185 |
| 186 |
#endif
| 187 |
} /* next round */
| 188 |
| 189 |
#endif /* MCOMP */
| 190 |
| 191 |
| 192 |
char *
| 193 |
mscrounge(np) /* search free lists to satisfy request */
| 194 |
register unsigned *np;
| 195 |
| 196 |
char *p;
| 197 |
| 198 |
register unsigned bsiz;
| 199 |
| 200 |
for (bucket = FIRSTBUCKET, bsiz = 1<<FIRSTBUCKET;
| 201 |
bucket < NBUCKETS; bucket++, bsiz <<= 1)
| 202 |
if (free_list[bucket] != NULL && bsiz+sizeof(M_HEAD) >= *np) {
| 203 |
*np = bsiz+sizeof(M_HEAD);
| 204 |
p = (char *)free_list[bucket];
| 205 |
| 206 |
#ifdef MSTATS
| 207 |
b_nscrounged += *np;
| 208 |
#endif
| 209 |
return(p);
| 210 |
| 211 |
#ifdef MCOMP
| 212 |
return(mcompact(np)); /* try compaction */
| 213 |
#else
| 214 |
*np = 0;
| 215 |
return(NULL);
| 216 |
#endif
| 217 |
| 218 |
| 219 |
| 220 |
char *
| 221 |
bmalloc(n) /* allocate a block of n bytes, sans header */
| 222 |
register unsigned n;
| 223 |
| 224 |
extern char *sbrk();
| 225 |
static unsigned pagesz = 0;
| 226 |
static unsigned amnt;
| 227 |
static char *bpos;
| 228 |
static unsigned nrem;
| 229 |
unsigned thisamnt;
| 230 |
register char *p;
| 231 |
| 232 |
if (pagesz == 0) { /* initialize */
| 233 |
pagesz = amnt = getpagesize();
| 234 |
nrem = (int)sbrk(0); /* page align break */
| 235 |
nrem = pagesz - (nrem&(pagesz-1));
| 236 |
bpos = sbrk(nrem);
| 237 |
if ((int)bpos == -1)
| 238 |
return(NULL);
| 239 |
#ifdef MSTATS
| 240 |
b_nsbrked += nrem;
| 241 |
#endif
| 242 |
bpos += nrem & (BYTES_WORD-1); /* align pointer */
| 243 |
nrem &= ~(BYTES_WORD-1);
| 244 |
| 245 |
| 246 |
n = (n+(BYTES_WORD-1))&~(BYTES_WORD-1); /* word align rqst. */
| 247 |
| 248 |
if (n > nrem) { /* need more core */
| 249 |
if (n > amnt) { /* big chunk */
| 250 |
thisamnt = (n+(pagesz-1))&~(pagesz-1);
| 251 |
if (thisamnt <= MAXINCR) /* increase amnt */
| 252 |
amnt = thisamnt;
| 253 |
} else
| 254 |
thisamnt = amnt;
| 255 |
p = sbrk(thisamnt);
| 256 |
if ((int)p == -1) { /* uh-oh, ENOMEM */
| 257 |
thisamnt = n; /* search free lists */
| 258 |
p = mscrounge(&thisamnt);
| 259 |
if (p == NULL) /* we're really out */
| 260 |
return(NULL);
| 261 |
| 262 |
#ifdef MSTATS
| 263 |
else b_nsbrked += thisamnt;
| 264 |
#endif
| 265 |
if (p != bpos+nrem) { /* not an increment */
| 266 |
bfree(bpos, nrem); /* free what we have */
| 267 |
bpos = p;
| 268 |
nrem = thisamnt;
| 269 |
} else /* otherwise tack on */
| 270 |
nrem += thisamnt;
| 271 |
| 272 |
p = bpos;
| 273 |
bpos += n; /* advance */
| 274 |
nrem -= n;
| 275 |
#ifdef MSTATS
| 276 |
b_nalloced += n;
| 277 |
#endif
| 278 |
return(p);
| 279 |
| 280 |
| 281 |
| 282 |
bfree(p, n) /* free n bytes of random memory */
| 283 |
register char *p;
| 284 |
| 285 |
| 286 |
| 287 |
| 288 |
| 289 |
if (n < 1<<FIRSTBUCKET)
| 290 |
return;
| 291 |
#ifdef MSTATS
| 292 |
b_nfreed += n;
| 293 |
#endif
| 294 |
/* align pointer */
| 295 |
bsiz = BYTES_WORD - ((unsigned)p&(BYTES_WORD-1));
| 296 |
if (bsiz < BYTES_WORD) {
| 297 |
p += bsiz;
| 298 |
n -= bsiz;
| 299 |
| 300 |
/* fill big buckets first */
| 301 |
for (bucket = NBUCKETS-1, bsiz = 1<<(NBUCKETS-1);
| 302 |
bucket >= FIRSTBUCKET; bucket--, bsiz >>= 1)
| 303 |
if (n >= bsiz+sizeof(M_HEAD)) {
| 304 |
((M_HEAD *)p)->next = free_list[bucket];
| 305 |
free_list[bucket] = (M_HEAD *)p;
| 306 |
p += bsiz+sizeof(M_HEAD);
| 307 |
n -= bsiz+sizeof(M_HEAD);
| 308 |
| 309 |
| 310 |
| 311 |
| 312 |
char *
| 313 |
malloc(n) /* allocate n bytes of memory */
| 314 |
unsigned n;
| 315 |
| 316 |
extern int errno;
| 317 |
register M_HEAD *mp;
| 318 |
| 319 |
| 320 |
/* don't return NULL on 0 request */
| 321 |
if (n == 0)
| 322 |
return(DUMMYLOC);
| 323 |
/* find first bucket that fits */
| 324 |
| 325 |
| 326 |
if (bsiz >= n)
| 327 |
break;
| 328 |
if (bucket >= NBUCKETS) {
| 329 |
errno = EINVAL;
| 330 |
return(NULL);
| 331 |
| 332 |
if (free_list[bucket] == NULL) { /* need more core */
| 333 |
mp = (M_HEAD *)bmalloc(bsiz+sizeof(M_HEAD));
| 334 |
if (mp == NULL)
| 335 |
return(NULL);
| 336 |
} else { /* got it */
| 337 |
mp = free_list[bucket];
| 338 |
free_list[bucket] = mp->next;
| 339 |
| 340 |
#ifdef MSTATS
| 341 |
m_nalloced += bsiz + sizeof(M_HEAD);
| 342 |
m_nwasted += bsiz + sizeof(M_HEAD) - n;
| 343 |
#endif
| 344 |
mp->a.magic = MAGIC; /* tag block */
| 345 |
mp->a.bucket = bucket;
| 346 |
return((char *)(mp+1));
| 347 |
| 348 |
| 349 |
| 350 |
char *
| 351 |
realloc(op, n) /* reallocate memory using malloc() */
| 352 |
register char *op;
| 353 |
unsigned n;
| 354 |
| 355 |
char *p;
| 356 |
register unsigned on;
| 357 |
/* get old size */
| 358 |
if (op != NULL && op != DUMMYLOC && ((M_HEAD *)op-1)->a.magic == MAGIC)
| 359 |
on = 1 << ((M_HEAD *)op-1)->a.bucket;
| 360 |
else
| 361 |
on = 0;
| 362 |
if (n <= on && (n > on>>1 || on == 1<<FIRSTBUCKET))
| 363 |
return(op); /* same bucket */
| 364 |
if ((p = malloc(n)) == NULL)
| 365 |
return(n<=on ? op : NULL);
| 366 |
if (on) {
| 367 |
#ifdef BSD
| 368 |
bcopy(op, p, n>on ? on : n);
| 369 |
#else
| 370 |
(void)memcpy(p, op, n>on ? on : n);
| 371 |
#endif
| 372 |
free(op);
| 373 |
| 374 |
return(p);
| 375 |
| 376 |
| 377 |
| 378 |
free(p) /* free memory allocated by malloc */
| 379 |
char *p;
| 380 |
| 381 |
| 382 |
| 383 |
| 384 |
if (p == NULL | p == DUMMYLOC)
| 385 |
return(1);
| 386 |
mp = (M_HEAD *)p - 1;
| 387 |
if (mp->a.magic != MAGIC) /* sanity check */
| 388 |
return(0);
| 389 |
bucket = mp->a.bucket;
| 390 |
if (bucket < FIRSTBUCKET | bucket >= NBUCKETS)
| 391 |
return(0);
| 392 |
mp->next = free_list[bucket];
| 393 |
free_list[bucket] = mp;
| 394 |
#ifdef MSTATS
| 395 |
m_nfreed += (1 << bucket) + sizeof(M_HEAD);
| 396 |
#endif
| 397 |
return(1);
| 398 |
| 399 |
| 400 |
| 401 |
#ifdef MSTATS
| 402 |
printmemstats(fp) /* print memory statistics to stream */
| 403 |
FILE *fp;
| 404 |
| 405 |
register int i;
| 406 |
int n;
| 407 |
| 408 |
unsigned int total = 0;
| 409 |
| 410 |
fprintf(fp, "Memory statistics:\n");
| 411 |
fprintf(fp, "\tbmalloc: %d bytes from sbrk\n", b_nsbrked);
| 412 |
fprintf(fp, "\tbmalloc: %d bytes allocated\n", b_nalloced);
| 413 |
fprintf(fp, "\tbmalloc: %d bytes freed\n", b_nfreed);
| 414 |
fprintf(fp, "\tbmalloc: %d bytes scrounged\n", b_nscrounged);
| 415 |
fprintf(fp, "\tbmalloc: %d bytes compacted\n", b_ncompacted);
| 416 |
fprintf(fp, "\tmalloc: %d bytes allocated\n", m_nalloced);
| 417 |
fprintf(fp, "\tmalloc: %d bytes wasted (%.1f%%)\n", m_nwasted,
| 418 |
100.0*m_nwasted/m_nalloced);
| 419 |
fprintf(fp, "\tmalloc: %d bytes freed\n", m_nfreed);
| 420 |
for (i = NBUCKETS-1; i >= FIRSTBUCKET; i--) {
| 421 |
n = 0;
| 422 |
for (mp = free_list[i]; mp != NULL; mp = mp->next)
| 423 |
n++;
| 424 |
if (n) {
| 425 |
fprintf(fp, "\t%d * %u\n", n, 1<<i);
| 426 |
total += n * ((1<<i) + sizeof(M_HEAD));
| 427 |
| 428 |
| 429 |
fprintf(fp, "\t %u total bytes in free list\n", total);
| 430 |
| 431 |
#endif
