root/Development/ray/src/common/malloc.c
Revision: 2.3
Committed: Fri Feb 7 15:10:32 1992 UTC (33 years, 10 months ago) by greg
Changes since 2.2: +7 -2 lines
bug fix for HP snakes and sbrk() that isn't word aligned
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Fast malloc for memory hogs and VM environments.
9 * Performs a minimum of searching through free lists.
10 * malloc(), realloc() and free() use buckets
11 * containing blocks in powers of two, similar to CIT routines.
12 * bfree() puts memory from any source into malloc free lists.
13 * bmalloc() doesn't keep track of free lists -- it's usually
14 * just a buffered call to sbrk(2). However, bmalloc will
15 * call mscrounge() if sbrk fails.
16 * mscrounge() returns whatever free memory it can find to satisfy the
17 * request along with the number of bytes (modified).
18 * mcompact() takes the same arguments as mscrounge() (and is in fact
19 * called by mscrounge() under dire circumstances), but it uses
20 * memory compaction to return a larger block. (MCOMP)
21 *
22 * Greg Ward Lawrence Berkeley Laboratory
23 */
24
25 #include <errno.h>
26
27 #ifdef MSTATS
28 #include <stdio.h>
29 static unsigned b_nsbrked = 0;
30 static unsigned b_nalloced = 0;
31 static unsigned b_nfreed = 0;
32 static unsigned b_nscrounged = 0;
33 static unsigned b_ncompacted = 0;
34 static unsigned m_nalloced = 0;
35 static unsigned m_nfreed = 0;
36 static unsigned m_nwasted = 0;
37 #else
38 #define NULL 0
39 #endif
40
41 #ifndef ALIGN
42 #define ALIGN int /* align type */
43 #endif
44 #define BYTES_WORD sizeof(ALIGN)
45
46 #ifndef MAXINCR
47 #define MAXINCR (1<<16) /* largest sbrk(2) increment */
48 #endif
49 /* malloc free lists */
50 typedef union m_head {
51 union m_head *next;
52 struct {
53 short magic;
54 short bucket;
55 } a;
56 ALIGN dummy;
57 } M_HEAD;
58
59 #define MAGIC 0x1a2 /* magic number for allocated memory */
60
61 #define FIRSTBUCKET 3
62 #define NBUCKETS 30
63
64 static M_HEAD *free_list[NBUCKETS];
65
66 static ALIGN dummy_mem;
67
68 #define DUMMYLOC ((char *)&dummy_mem)
69
70 #ifdef MCOMP /* memory compaction routines */
71 static char seedtab[1024]; /* seed for compaction table */
72
73 static struct mblk {
74 char *ptr; /* pointer to memory block */
75 unsigned siz; /* size of memory block */
76 } cptab = {seedtab, sizeof(seedtab)};
77
78 #define mtab(mb) ((struct mblk *)(mb)->ptr)
79 #define mtablen(mb) ((mb)->siz/sizeof(struct mblk))
80
81
82 static int
83 mbcmp(m1, m2) /* compare memory block locations */
84 register struct mblk *m1, *m2;
85 {
86 /* put empty blocks at end */
87 if (m1->siz == 0)
88 return(m2->siz == 0 ? 0 : 1);
89 if (m2->siz == 0)
90 return(-1);
91 /* otherwise, ascending order */
92 return(m1->ptr - m2->ptr);
93 }
94
95
96 int
97 compactfree() /* compact free lists (moving to table) */
98 {
99 register struct mblk *tp;
100 register int bucket;
101 unsigned n, bsiz, ncomp;
102 /* fill table from free lists */
103 tp = mtab(&cptab); n = mtablen(&cptab);
104 bucket = NBUCKETS-1; bsiz = 1<<(NBUCKETS-1);
105 ncomp = 0;
106 for ( ; ; ) {
107 while (tp->siz) { /* find empty slot */
108 if (--n == 0)
109 goto loopexit;
110 tp++;
111 }
112 while (free_list[bucket] == NULL) { /* find block */
113 if (--bucket < FIRSTBUCKET)
114 goto loopexit;
115 bsiz >>= 1;
116 }
117 tp->ptr = (char *)free_list[bucket];
118 ncomp += (tp->siz = bsiz + sizeof(M_HEAD));
119 free_list[bucket] = free_list[bucket]->next;
120 }
121 loopexit:
122 if (ncomp == 0)
123 return(0); /* nothing new to compact */
124 #ifdef MSTATS
125 b_ncompacted += ncomp;
126 #endif
127 tp = mtab(&cptab); n = mtablen(&cptab); /* sort table */
128 qsort((char *)tp, n, sizeof(struct mblk), mbcmp);
129 ncomp = 0; /* collect blocks */
130 while (--n && tp[1].siz) {
131 if (tp[0].ptr + tp[0].siz == tp[1].ptr) {
132 tp[1].ptr = tp[0].ptr;
133 tp[1].siz += tp[0].siz;
134 ncomp += tp[0].siz;
135 tp[0].siz = 0;
136 }
137 tp++;
138 }
139 return(ncomp);
140 }
141
142
143 char *
144 mcompact(np) /* compact free lists to satisfy request */
145 unsigned *np;
146 {
147 struct mblk *tab;
148 unsigned tablen;
149 register struct mblk *bp, *big;
150
151 for ( ; ; ) {
152 /* compact free lists */
153 compactfree();
154 /* find largest block */
155 tab = mtab(&cptab); tablen = mtablen(&cptab);
156 big = tab;
157 bp = tab + tablen;
158 while (--bp > tab)
159 if (bp->siz > big->siz)
160 big = bp;
161 if (big->siz >= *np) { /* big enough? */
162 *np = big->siz;
163 big->siz = 0; /* remove from table */
164 return(big->ptr); /* return it */
165 }
166 if (mtablen(big) < tablen+1) {
167 *np = 0; /* cannot grow table */
168 return(NULL); /* report failure */
169 }
170 /* enlarge table, free old one */
171 mtab(big)[0].ptr = cptab.ptr;
172 mtab(big)[0].siz = cptab.siz;
173 cptab.ptr = big->ptr;
174 cptab.siz = big->siz;
175 big->siz = 0; /* clear and copy */
176 #ifdef BSD
177 bcopy((char *)tab, (char *)(mtab(&cptab)+1),
178 tablen*sizeof(struct mblk));
179 bzero((char *)(mtab(&cptab)+tablen+1),
180 (mtablen(&cptab)-tablen-1)*sizeof(struct mblk));
181 #else
182 (void)memcpy((char *)(mtab(&cptab)+1), (char *)tab,
183 tablen*sizeof(struct mblk));
184 memset((char *)(mtab(&cptab)+tablen+1), 0,
185 (mtablen(&cptab)-tablen-1)*sizeof(struct mblk));
186 #endif
187 } /* next round */
188 }
189 #endif /* MCOMP */
190
191
192 char *
193 mscrounge(np) /* search free lists to satisfy request */
194 register unsigned *np;
195 {
196 char *p;
197 register int bucket;
198 register unsigned bsiz;
199
200 for (bucket = FIRSTBUCKET, bsiz = 1<<FIRSTBUCKET;
201 bucket < NBUCKETS; bucket++, bsiz <<= 1)
202 if (free_list[bucket] != NULL && bsiz+sizeof(M_HEAD) >= *np) {
203 *np = bsiz+sizeof(M_HEAD);
204 p = (char *)free_list[bucket];
205 free_list[bucket] = free_list[bucket]->next;
206 #ifdef MSTATS
207 b_nscrounged += *np;
208 #endif
209 return(p);
210 }
211 #ifdef MCOMP
212 return(mcompact(np)); /* try compaction */
213 #else
214 *np = 0;
215 return(NULL);
216 #endif
217 }
218
219
220 char *
221 bmalloc(n) /* allocate a block of n bytes, sans header */
222 register unsigned n;
223 {
224 extern char *sbrk();
225 static unsigned pagesz = 0;
226 static unsigned amnt;
227 static char *bpos;
228 static unsigned nrem;
229 unsigned thisamnt;
230 register char *p;
231
232 if (pagesz == 0) { /* initialize */
233 pagesz = amnt = getpagesize();
234 nrem = (int)sbrk(0); /* page align break */
235 nrem = pagesz - (nrem&(pagesz-1));
236 bpos = sbrk(nrem);
237 if ((int)bpos == -1)
238 return(NULL);
239 #ifdef MSTATS
240 b_nsbrked += nrem;
241 #endif
242 thisamnt = BYTES_WORD - ((unsigned)bpos&(BYTES_WORD-1));
243 if (thisamnt < BYTES_WORD) { /* align pointer */
244 bpos += thisamnt;
245 nrem -= thisamnt;
246 }
247 }
248
249 n = (n+(BYTES_WORD-1))&~(BYTES_WORD-1); /* word align rqst. */
250
251 if (n > nrem) { /* need more core */
252 if (n > amnt) { /* big chunk */
253 thisamnt = (n+(pagesz-1))&~(pagesz-1);
254 if (thisamnt <= MAXINCR) /* increase amnt */
255 amnt = thisamnt;
256 } else
257 thisamnt = amnt;
258 p = sbrk(thisamnt);
259 if ((int)p == -1) { /* uh-oh, ENOMEM */
260 thisamnt = n; /* search free lists */
261 p = mscrounge(&thisamnt);
262 if (p == NULL) /* we're really out */
263 return(NULL);
264 }
265 #ifdef MSTATS
266 else b_nsbrked += thisamnt;
267 #endif
268 if (p != bpos+nrem) { /* not an increment */
269 bfree(bpos, nrem); /* free what we have */
270 bpos = p;
271 nrem = thisamnt;
272 } else /* otherwise tack on */
273 nrem += thisamnt;
274 }
275 p = bpos;
276 bpos += n; /* advance */
277 nrem -= n;
278 #ifdef MSTATS
279 b_nalloced += n;
280 #endif
281 return(p);
282 }
283
284
285 bfree(p, n) /* free n bytes of random memory */
286 register char *p;
287 register unsigned n;
288 {
289 register int bucket;
290 register unsigned bsiz;
291
292 if (n < 1<<FIRSTBUCKET)
293 return;
294 #ifdef MSTATS
295 b_nfreed += n;
296 #endif
297 /* align pointer */
298 bsiz = BYTES_WORD - ((unsigned)p&(BYTES_WORD-1));
299 if (bsiz < BYTES_WORD) {
300 p += bsiz;
301 n -= bsiz;
302 }
303 /* fill big buckets first */
304 for (bucket = NBUCKETS-1, bsiz = 1<<(NBUCKETS-1);
305 bucket >= FIRSTBUCKET; bucket--, bsiz >>= 1)
306 if (n >= bsiz+sizeof(M_HEAD)) {
307 ((M_HEAD *)p)->next = free_list[bucket];
308 free_list[bucket] = (M_HEAD *)p;
309 p += bsiz+sizeof(M_HEAD);
310 n -= bsiz+sizeof(M_HEAD);
311 }
312 }
313
314
315 char *
316 malloc(n) /* allocate n bytes of memory */
317 unsigned n;
318 {
319 extern int errno;
320 register M_HEAD *mp;
321 register int bucket;
322 register unsigned bsiz;
323 /* don't return NULL on 0 request */
324 if (n == 0)
325 return(DUMMYLOC);
326 /* find first bucket that fits */
327 for (bucket = FIRSTBUCKET, bsiz = 1<<FIRSTBUCKET;
328 bucket < NBUCKETS; bucket++, bsiz <<= 1)
329 if (bsiz >= n)
330 break;
331 if (bucket >= NBUCKETS) {
332 errno = EINVAL;
333 return(NULL);
334 }
335 if (free_list[bucket] == NULL) { /* need more core */
336 mp = (M_HEAD *)bmalloc(bsiz+sizeof(M_HEAD));
337 if (mp == NULL)
338 return(NULL);
339 } else { /* got it */
340 mp = free_list[bucket];
341 free_list[bucket] = mp->next;
342 }
343 #ifdef MSTATS
344 m_nalloced += bsiz + sizeof(M_HEAD);
345 m_nwasted += bsiz + sizeof(M_HEAD) - n;
346 #endif
347 mp->a.magic = MAGIC; /* tag block */
348 mp->a.bucket = bucket;
349 return((char *)(mp+1));
350 }
351
352
353 char *
354 realloc(op, n) /* reallocate memory using malloc() */
355 register char *op;
356 unsigned n;
357 {
358 char *p;
359 register unsigned on;
360 /* get old size */
361 if (op != NULL && op != DUMMYLOC && ((M_HEAD *)op-1)->a.magic == MAGIC)
362 on = 1 << ((M_HEAD *)op-1)->a.bucket;
363 else
364 on = 0;
365 if (n <= on && (n > on>>1 || on == 1<<FIRSTBUCKET))
366 return(op); /* same bucket */
367 if ((p = malloc(n)) == NULL)
368 return(NULL);
369 if (on) {
370 #ifdef BSD
371 bcopy(op, p, n>on ? on : n);
372 #else
373 (void)memcpy(p, op, n>on ? on : n);
374 #endif
375 free(op);
376 }
377 return(p);
378 }
379
380
381 free(p) /* free memory allocated by malloc */
382 char *p;
383 {
384 register M_HEAD *mp;
385 register int bucket;
386
387 if (p == NULL | p == DUMMYLOC)
388 return(1);
389 mp = (M_HEAD *)p - 1;
390 if (mp->a.magic != MAGIC) /* sanity check */
391 return(0);
392 bucket = mp->a.bucket;
393 if (bucket < FIRSTBUCKET | bucket >= NBUCKETS)
394 return(0);
395 mp->next = free_list[bucket];
396 free_list[bucket] = mp;
397 #ifdef MSTATS
398 m_nfreed += (1 << bucket) + sizeof(M_HEAD);
399 #endif
400 return(1);
401 }
402
403
404 #ifdef MSTATS
405 printmemstats(fp) /* print memory statistics to stream */
406 FILE *fp;
407 {
408 register int i;
409 int n;
410 register M_HEAD *mp;
411 unsigned int total = 0;
412
413 fprintf(fp, "Memory statistics:\n");
414 fprintf(fp, "\tbmalloc: %d bytes from sbrk\n", b_nsbrked);
415 fprintf(fp, "\tbmalloc: %d bytes allocated\n", b_nalloced);
416 fprintf(fp, "\tbmalloc: %d bytes freed\n", b_nfreed);
417 fprintf(fp, "\tbmalloc: %d bytes scrounged\n", b_nscrounged);
418 fprintf(fp, "\tbmalloc: %d bytes compacted\n", b_ncompacted);
419 fprintf(fp, "\tmalloc: %d bytes allocated\n", m_nalloced);
420 fprintf(fp, "\tmalloc: %d bytes wasted (%.1f%%)\n", m_nwasted,
421 100.0*m_nwasted/m_nalloced);
422 fprintf(fp, "\tmalloc: %d bytes freed\n", m_nfreed);
423 for (i = NBUCKETS-1; i >= FIRSTBUCKET; i--) {
424 n = 0;
425 for (mp = free_list[i]; mp != NULL; mp = mp->next)
426 n++;
427 if (n) {
428 fprintf(fp, "\t%d * %u\n", n, 1<<i);
429 total += n * ((1<<i) + sizeof(M_HEAD));
430 }
431 }
432 fprintf(fp, "\t %u total bytes in free list\n", total);
433 }
434 #endif
