root/radiance/ray/src/common/malloc.c
Revision: 2.6
Committed: Fri Sep 4 09:57:43 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.5: +27 -6 lines
additional paranoia -- check pointer bounds before accessing
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Fast malloc for memory hogs and VM environments.
9 * Performs a minimum of searching through free lists.
10 * malloc(), realloc() and free() use buckets
11 * containing blocks in powers of two, similar to CIT routines.
12 * bfree() puts memory from any source into malloc free lists.
13 * bmalloc() doesn't keep track of free lists -- it's usually
14 * just a buffered call to sbrk(2). However, bmalloc will
15 * call mscrounge() if sbrk fails.
16 * mscrounge() returns whatever free memory it can find to satisfy the
17 * request along with the number of bytes (modified).
18 * mcompact() takes the same arguments as mscrounge() (and is in fact
19 * called by mscrounge() under dire circumstances), but it uses
20 * memory compaction to return a larger block. (MCOMP)
21 *
22 * Greg Ward Lawrence Berkeley Laboratory
23 */
24
25 #include <errno.h>
26
27 extern int errno;
28
29 #ifdef MSTATS
30 #include <stdio.h>
31 static unsigned b_nsbrked = 0;
32 static unsigned b_nalloced = 0;
33 static unsigned b_nfreed = 0;
34 static unsigned b_nscrounged = 0;
35 static unsigned b_ncompacted = 0;
36 static unsigned m_nalloced = 0;
37 static unsigned m_nfreed = 0;
38 static unsigned m_nwasted = 0;
39 #else
40 #define NULL 0
41 #endif
42
43 #ifndef ALIGN
44 #define ALIGN int /* align type */
45 #endif
46 #define BYTES_WORD sizeof(ALIGN)
47
48 #ifndef MAXINCR
49 #define MAXINCR (1<<16) /* largest sbrk(2) increment */
50 #endif
51 /* malloc free lists */
52 typedef union m_head {
53 union m_head *next;
54 struct {
55 short magic;
56 short bucket;
57 } a;
58 ALIGN dummy;
59 } M_HEAD;
60
61 #define MAGIC 0x1a2 /* magic number for allocated memory */
62
63 #define FIRSTBUCKET 3
64 #define NBUCKETS 30
65
66 static M_HEAD *free_list[NBUCKETS];
67
68 static ALIGN dummy_mem;
69
70 static char *memlim[2];
71
72 #define DUMMYLOC ((char *)&dummy_mem)
73
74 #define BADPTR(p) ((p) < memlim[0] | (p) >= memlim[1])
75
76 #ifdef MCOMP /* memory compaction routines */
77 static char seedtab[1024]; /* seed for compaction table */
78
79 static struct mblk {
80 char *ptr; /* pointer to memory block */
81 unsigned siz; /* size of memory block */
82 } cptab = {seedtab, sizeof(seedtab)};
83
84 #define mtab(mb) ((struct mblk *)(mb)->ptr)
85 #define mtablen(mb) ((mb)->siz/sizeof(struct mblk))
86
87
88 static int
89 mbcmp(m1, m2) /* compare memory block locations */
90 register struct mblk *m1, *m2;
91 {
92 /* put empty blocks at end */
93 if (m1->siz == 0)
94 return(m2->siz == 0 ? 0 : 1);
95 if (m2->siz == 0)
96 return(-1);
97 /* otherwise, ascending order */
98 return(m1->ptr - m2->ptr);
99 }
100
101
102 int
103 compactfree() /* compact free lists (moving to table) */
104 {
105 register struct mblk *tp;
106 register int bucket;
107 unsigned n, bsiz, ncomp;
108 /* fill table from free lists */
109 tp = mtab(&cptab); n = mtablen(&cptab);
110 bucket = NBUCKETS-1; bsiz = 1<<(NBUCKETS-1);
111 ncomp = 0;
112 for ( ; ; ) {
113 while (tp->siz) { /* find empty slot */
114 if (--n == 0)
115 goto loopexit;
116 tp++;
117 }
118 while (free_list[bucket] == NULL) { /* find block */
119 if (--bucket < FIRSTBUCKET)
120 goto loopexit;
121 bsiz >>= 1;
122 }
123 tp->ptr = (char *)free_list[bucket];
124 ncomp += (tp->siz = bsiz + sizeof(M_HEAD));
125 free_list[bucket] = free_list[bucket]->next;
126 }
127 loopexit:
128 if (ncomp == 0)
129 return(0); /* nothing new to compact */
130 #ifdef MSTATS
131 b_ncompacted += ncomp;
132 #endif
133 tp = mtab(&cptab); n = mtablen(&cptab); /* sort table */
134 qsort((char *)tp, n, sizeof(struct mblk), mbcmp);
135 ncomp = 0; /* collect blocks */
136 while (--n && tp[1].siz) {
137 if (tp[0].ptr + tp[0].siz == tp[1].ptr) {
138 tp[1].ptr = tp[0].ptr;
139 tp[1].siz += tp[0].siz;
140 ncomp += tp[0].siz;
141 tp[0].siz = 0;
142 }
143 tp++;
144 }
145 return(ncomp);
146 }
147
148
149 char *
150 mcompact(np) /* compact free lists to satisfy request */
151 unsigned *np;
152 {
153 struct mblk *tab;
154 unsigned tablen;
155 register struct mblk *bp, *big;
156
157 for ( ; ; ) {
158 /* compact free lists */
159 compactfree();
160 /* find largest block */
161 tab = mtab(&cptab); tablen = mtablen(&cptab);
162 big = tab;
163 bp = tab + tablen;
164 while (--bp > tab)
165 if (bp->siz > big->siz)
166 big = bp;
167 if (big->siz >= *np) { /* big enough? */
168 *np = big->siz;
169 big->siz = 0; /* remove from table */
170 return(big->ptr); /* return it */
171 }
172 if (mtablen(big) < tablen+1) {
173 *np = 0; /* cannot grow table */
174 return(NULL); /* report failure */
175 }
176 /* enlarge table, free old one */
177 mtab(big)[0].ptr = cptab.ptr;
178 mtab(big)[0].siz = cptab.siz;
179 cptab.ptr = big->ptr;
180 cptab.siz = big->siz;
181 big->siz = 0; /* clear and copy */
182 #ifdef BSD
183 bcopy((char *)tab, (char *)(mtab(&cptab)+1),
184 tablen*sizeof(struct mblk));
185 bzero((char *)(mtab(&cptab)+tablen+1),
186 (mtablen(&cptab)-tablen-1)*sizeof(struct mblk));
187 #else
188 (void)memcpy((char *)(mtab(&cptab)+1), (char *)tab,
189 tablen*sizeof(struct mblk));
190 memset((char *)(mtab(&cptab)+tablen+1), 0,
191 (mtablen(&cptab)-tablen-1)*sizeof(struct mblk));
192 #endif
193 } /* next round */
194 }
195 #endif /* MCOMP */
196
197
198 char *
199 mscrounge(np) /* search free lists to satisfy request */
200 register unsigned *np;
201 {
202 char *p;
203 register int bucket;
204 register unsigned bsiz;
205
206 for (bucket = FIRSTBUCKET, bsiz = 1<<FIRSTBUCKET;
207 bucket < NBUCKETS; bucket++, bsiz <<= 1)
208 if (free_list[bucket] != NULL && bsiz+sizeof(M_HEAD) >= *np) {
209 *np = bsiz+sizeof(M_HEAD);
210 p = (char *)free_list[bucket];
211 free_list[bucket] = free_list[bucket]->next;
212 #ifdef MSTATS
213 b_nscrounged += *np;
214 #endif
215 return(p);
216 }
217 #ifdef MCOMP
218 return(mcompact(np)); /* try compaction */
219 #else
220 *np = 0;
221 return(NULL);
222 #endif
223 }
224
225
226 char *
227 bmalloc(n) /* allocate a block of n bytes, sans header */
228 register unsigned n;
229 {
230 extern char *sbrk();
231 static unsigned pagesz = 0;
232 static unsigned amnt;
233 static char *bpos;
234 static unsigned nrem;
235 unsigned thisamnt;
236 register char *p;
237
238 if (pagesz == 0) { /* initialize */
239 pagesz = amnt = getpagesize();
240 nrem = (int)sbrk(0); /* page align break */
241 nrem = pagesz - (nrem&(pagesz-1));
242 bpos = sbrk(nrem);
243 if ((int)bpos == -1)
244 return(NULL);
245 #ifdef MSTATS
246 b_nsbrked += nrem;
247 #endif
248 bpos += nrem & (BYTES_WORD-1); /* align pointer */
249 nrem &= ~(BYTES_WORD-1);
250 memlim[0] = bpos;
251 memlim[1] = bpos + nrem;
252 }
253
254 n = (n+(BYTES_WORD-1))&~(BYTES_WORD-1); /* word align rqst. */
255
256 if (n > nrem) { /* need more core */
257 if (n > amnt) { /* big chunk */
258 thisamnt = (n+(pagesz-1))&~(pagesz-1);
259 if (thisamnt <= MAXINCR) /* increase amnt */
260 amnt = thisamnt;
261 } else
262 thisamnt = amnt;
263 p = sbrk(thisamnt);
264 if ((int)p == -1) { /* uh-oh, ENOMEM */
265 thisamnt = n; /* search free lists */
266 p = mscrounge(&thisamnt);
267 if (p == NULL) /* we're really out */
268 return(NULL);
269 }
270 #ifdef MSTATS
271 else b_nsbrked += thisamnt;
272 #endif
273 if (p != bpos+nrem) { /* not an increment */
274 bfree(bpos, nrem); /* free what we have */
275 bpos = p;
276 nrem = thisamnt;
277 } else /* otherwise tack on */
278 nrem += thisamnt;
279 if (bpos < memlim[0])
280 memlim[0] = bpos;
281 if (bpos + nrem > memlim[1])
282 memlim[1] = bpos + nrem;
283 }
284 p = bpos;
285 bpos += n; /* advance */
286 nrem -= n;
287 #ifdef MSTATS
288 b_nalloced += n;
289 #endif
290 return(p);
291 }
292
293
294 bfree(p, n) /* free n bytes of random memory */
295 register char *p;
296 register unsigned n;
297 {
298 register int bucket;
299 register unsigned bsiz;
300
301 if (n < 1<<FIRSTBUCKET)
302 return;
303 #ifdef MSTATS
304 b_nfreed += n;
305 #endif
306 /* align pointer */
307 bsiz = BYTES_WORD - ((unsigned)p&(BYTES_WORD-1));
308 if (bsiz < BYTES_WORD) {
309 p += bsiz;
310 n -= bsiz;
311 }
312 if (p < memlim[0])
313 memlim[0] = p;
314 if (p + n > memlim[1])
315 memlim[1] = p + n;
316 /* fill big buckets first */
317 for (bucket = NBUCKETS-1, bsiz = 1<<(NBUCKETS-1);
318 bucket >= FIRSTBUCKET; bucket--, bsiz >>= 1)
319 if (n >= bsiz+sizeof(M_HEAD)) {
320 ((M_HEAD *)p)->next = free_list[bucket];
321 free_list[bucket] = (M_HEAD *)p;
322 p += bsiz+sizeof(M_HEAD);
323 n -= bsiz+sizeof(M_HEAD);
324 }
325 }
326
327
328 char *
329 malloc(n) /* allocate n bytes of memory */
330 unsigned n;
331 {
332 register M_HEAD *mp;
333 register int bucket;
334 register unsigned bsiz;
335 /* don't return NULL on 0 request */
336 if (n == 0)
337 return(DUMMYLOC);
338 /* find first bucket that fits */
339 for (bucket = FIRSTBUCKET, bsiz = 1<<FIRSTBUCKET;
340 bucket < NBUCKETS; bucket++, bsiz <<= 1)
341 if (bsiz >= n)
342 break;
343 if (bucket >= NBUCKETS) {
344 errno = EINVAL;
345 return(NULL);
346 }
347 if (free_list[bucket] == NULL) { /* need more core */
348 mp = (M_HEAD *)bmalloc(bsiz+sizeof(M_HEAD));
349 if (mp == NULL)
350 return(NULL);
351 } else { /* got it */
352 mp = free_list[bucket];
353 free_list[bucket] = mp->next;
354 }
355 #ifdef MSTATS
356 m_nalloced += bsiz + sizeof(M_HEAD);
357 m_nwasted += bsiz + sizeof(M_HEAD) - n;
358 #endif
359 mp->a.magic = MAGIC; /* tag block */
360 mp->a.bucket = bucket;
361 return((char *)(mp+1));
362 }
363
364
365 char *
366 realloc(op, n) /* reallocate memory using malloc() */
367 register char *op;
368 unsigned n;
369 {
370 char *p;
371 register unsigned on;
372 /* get old size */
373 if (op != DUMMYLOC && !BADPTR(op) &&
374 ((M_HEAD *)op-1)->a.magic == MAGIC)
375 on = 1 << ((M_HEAD *)op-1)->a.bucket;
376 else
377 on = 0;
378 if (n <= on && (n > on>>1 || on == 1<<FIRSTBUCKET))
379 return(op); /* same bucket */
380 if ((p = malloc(n)) == NULL)
381 return(n<=on ? op : NULL);
382 if (on) {
383 #ifdef BSD
384 bcopy(op, p, n>on ? on : n);
385 #else
386 (void)memcpy(p, op, n>on ? on : n);
387 #endif
388 free(op);
389 }
390 return(p);
391 }
392
393
394 free(p) /* free memory allocated by malloc */
395 char *p;
396 {
397 register M_HEAD *mp;
398 register int bucket;
399
400 if (p == DUMMYLOC)
401 return(1);
402 if (BADPTR(p))
403 goto invalid;
404 mp = (M_HEAD *)p - 1;
405 if (mp->a.magic != MAGIC) /* sanity check */
406 goto invalid;
407 bucket = mp->a.bucket;
408 if (bucket < FIRSTBUCKET | bucket >= NBUCKETS)
409 goto invalid;
410 mp->next = free_list[bucket];
411 free_list[bucket] = mp;
412 #ifdef MSTATS
413 m_nfreed += (1 << bucket) + sizeof(M_HEAD);
414 #endif
415 return(1);
416 invalid:
417 errno = EINVAL;
418 return(0);
419 }
420
421
422 #ifdef MSTATS
423 printmemstats(fp) /* print memory statistics to stream */
424 FILE *fp;
425 {
426 register int i;
427 int n;
428 register M_HEAD *mp;
429 unsigned int total = 0;
430
431 fprintf(fp, "Memory statistics:\n");
432 fprintf(fp, "\tbmalloc: %d bytes from sbrk\n", b_nsbrked);
433 fprintf(fp, "\tbmalloc: %d bytes allocated\n", b_nalloced);
434 fprintf(fp, "\tbmalloc: %d bytes freed\n", b_nfreed);
435 fprintf(fp, "\tbmalloc: %d bytes scrounged\n", b_nscrounged);
436 fprintf(fp, "\tbmalloc: %d bytes compacted\n", b_ncompacted);
437 fprintf(fp, "\tmalloc: %d bytes allocated\n", m_nalloced);
438 fprintf(fp, "\tmalloc: %d bytes wasted (%.1f%%)\n", m_nwasted,
439 100.0*m_nwasted/m_nalloced);
440 fprintf(fp, "\tmalloc: %d bytes freed\n", m_nfreed);
441 for (i = NBUCKETS-1; i >= FIRSTBUCKET; i--) {
442 n = 0;
443 for (mp = free_list[i]; mp != NULL; mp = mp->next)
444 n++;
445 if (n) {
446 fprintf(fp, "\t%d * %u\n", n, 1<<i);
447 total += n * ((1<<i) + sizeof(M_HEAD));
448 }
449 }
450 fprintf(fp, "\t %u total bytes in free list\n", total);
451 }
452 #endif
