root/radiance/ray/src/common/malloc.c
Revision: 2.12
Committed: Sat Feb 22 02:07:22 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.11: +63 -9 lines
5 * Fast malloc for memory hogs and VM environments.
6 * Performs a minimum of searching through free lists.
7 * malloc(), realloc() and free() use buckets
8 * containing blocks in powers of two, similar to CIT routines.
9 * bfree() puts memory from any source into malloc free lists.
10 * bmalloc() doesn't keep track of free lists -- it's usually
11 * just a buffered call to sbrk(2). However, bmalloc will
12 * call mscrounge() if sbrk fails.
13 * mscrounge() returns whatever free memory it can find to satisfy the
14 * request along with the number of bytes (modified).
15 * mcompact() takes the same arguments as mscrounge() (and is in fact
16 * called by mscrounge() under dire circumstances), but it uses
17 * memory compaction to return a larger block. (MCOMP)
18 *
19 * Greg Ward Lawrence Berkeley Laboratory
20 */
21
22 /* ====================================================================
23 * The Radiance Software License, Version 1.0
24 *
25 * Copyright (c) 1990 - 2002 The Regents of the University of California,
26 * through Lawrence Berkeley National Laboratory. All rights reserved.
27 *
28 * Redistribution and use in source and binary forms, with or without
29 * modification, are permitted provided that the following conditions
30 * are met:
31 *
32 * 1. Redistributions of source code must retain the above copyright
33 * notice, this list of conditions and the following disclaimer.
34 *
35 * 2. Redistributions in binary form must reproduce the above copyright
36 * notice, this list of conditions and the following disclaimer in
37 * the documentation and/or other materials provided with the
38 * distribution.
39 *
40 * 3. The end-user documentation included with the redistribution,
41 * if any, must include the following acknowledgment:
42 * "This product includes Radiance software
43 * (http://radsite.lbl.gov/)
44 * developed by the Lawrence Berkeley National Laboratory
45 * (http://www.lbl.gov/)."
46 * Alternately, this acknowledgment may appear in the software itself,
47 * if and wherever such third-party acknowledgments normally appear.
48 *
49 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
50 * and "The Regents of the University of California" must
51 * not be used to endorse or promote products derived from this
52 * software without prior written permission. For written
53 * permission, please contact [email protected].
54 *
55 * 5. Products derived from this software may not be called "Radiance",
56 * nor may "Radiance" appear in their name, without prior written
57 * permission of Lawrence Berkeley National Laboratory.
58 *
59 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
60 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
61 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
62 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
63 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
64 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
65 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
66 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
67 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
68 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
69 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
70 * SUCH DAMAGE.
71 * ====================================================================
72 *
73 * This software consists of voluntary contributions made by many
74 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
75 * information on Lawrence Berkeley National Laboratory, please see
76 * <http://www.lbl.gov/>.
77 */
78
79 #include <errno.h>
80
81 #ifndef BSD
82 #define bcopy(s,d,n) (void)memcpy(d,s,n)
83 #define bzero(d,n) (void)memset(d,0,n)
84 #endif
85
86 #ifdef MSTATS
87 #include <stdio.h>
88 static unsigned b_nsbrked = 0;
89 static unsigned b_nalloced = 0;
90 static unsigned b_nfreed = 0;
91 static unsigned b_nscrounged = 0;
92 static unsigned b_ncompacted = 0;
93 static unsigned m_nalloced = 0;
94 static unsigned m_nfreed = 0;
95 static unsigned m_nwasted = 0;
96 #else
97 #define NULL 0
98 #endif
99
100 #ifndef ALIGNT
101 #define ALIGNT int /* align type */
102 #endif
103 #define BYTES_WORD sizeof(ALIGNT)
104
105 #ifndef MAXINCR
106 #define MAXINCR (1<<16) /* largest sbrk(2) increment */
107 #endif
108 /* malloc free lists */
109 typedef union m_head {
110 union m_head *next;
111 struct {
112 short magic;
113 short bucket;
114 } a;
115 ALIGNT dummy;
116 } M_HEAD;
117
118 #define MAGIC 0x1a2 /* magic number for allocated memory */
119
120 #define FIRSTBUCKET 3
121 #define NBUCKETS 30
122
123 static M_HEAD *free_list[NBUCKETS];
124
125 static ALIGNT dummy_mem;
126
127 static char *memlim[2];
128
129 #define DUMMYLOC ((char *)&dummy_mem)
130
131 #define BADPTR(p) ((p) < memlim[0] | (p) >= memlim[1])
132
133 #ifdef MCOMP /* memory compaction routines */
134 static char seedtab[1024]; /* seed for compaction table */
135
136 static struct mblk {
137 char *ptr; /* pointer to memory block */
138 unsigned siz; /* size of memory block */
139 } cptab = {seedtab, sizeof(seedtab)};
140
141 #define mtab(mb) ((struct mblk *)(mb)->ptr)
142 #define mtablen(mb) ((mb)->siz/sizeof(struct mblk))
143
144
145 static int
146 mbcmp(m1, m2) /* compare memory block locations */
147 register struct mblk *m1, *m2;
148 {
149 /* put empty blocks at end */
150 if (m1->siz == 0)
151 return(m2->siz == 0 ? 0 : 1);
152 if (m2->siz == 0)
153 return(-1);
154 /* otherwise, ascending order */
155 return(m1->ptr - m2->ptr);
156 }
157
158
159 int
160 compactfree() /* compact free lists (moving to table) */
161 {
162 register struct mblk *tp;
163 register int bucket;
164 unsigned n, bsiz, ncomp;
165 /* fill table from free lists */
166 tp = mtab(&cptab); n = mtablen(&cptab);
167 bucket = NBUCKETS-1; bsiz = 1<<(NBUCKETS-1);
168 ncomp = 0;
169 for ( ; ; ) {
170 while (tp->siz) { /* find empty slot */
171 if (--n == 0)
172 goto loopexit;
173 tp++;
174 }
175 while (free_list[bucket] == NULL) { /* find block */
176 if (--bucket < FIRSTBUCKET)
177 goto loopexit;
178 bsiz >>= 1;
179 }
180 tp->ptr = (char *)free_list[bucket];
181 ncomp += (tp->siz = bsiz + sizeof(M_HEAD));
182 free_list[bucket] = free_list[bucket]->next;
183 }
184 loopexit:
185 if (ncomp == 0)
186 return(0); /* nothing new to compact */
187 #ifdef MSTATS
188 b_ncompacted += ncomp;
189 #endif
190 tp = mtab(&cptab); n = mtablen(&cptab); /* sort table */
191 qsort((char *)tp, n, sizeof(struct mblk), mbcmp);
192 ncomp = 0; /* collect blocks */
193 while (--n && tp[1].siz) {
194 if (tp[0].ptr + tp[0].siz == tp[1].ptr) {
195 tp[1].ptr = tp[0].ptr;
196 tp[1].siz += tp[0].siz;
197 ncomp += tp[0].siz;
198 tp[0].siz = 0;
199 }
200 tp++;
201 }
202 return(ncomp);
203 }
204
205
206 char *
207 mcompact(np) /* compact free lists to satisfy request */
208 unsigned *np;
209 {
210 struct mblk *tab;
211 unsigned tablen;
212 register struct mblk *bp, *big;
213
214 for ( ; ; ) {
215 /* compact free lists */
216 while (compactfree())
217 ;
218 /* find largest block */
219 tab = mtab(&cptab); tablen = mtablen(&cptab);
220 big = tab;
221 bp = tab + tablen;
222 while (--bp > tab)
223 if (bp->siz > big->siz)
224 big = bp;
225 if (big->siz >= *np) { /* big enough? */
226 *np = big->siz;
227 big->siz = 0; /* remove from table */
228 return(big->ptr); /* return it */
229 }
230 if (mtablen(big) <= tablen) {
231 *np = 0; /* cannot grow table */
232 return(NULL); /* report failure */
233 }
234 /* enlarge table, free old one */
235 mtab(big)[0].ptr = cptab.ptr;
236 mtab(big)[0].siz = cptab.siz;
237 cptab.ptr = big->ptr;
238 cptab.siz = big->siz;
239 big->siz = 0; /* clear and copy */
240 bcopy((char *)tab, (char *)(mtab(&cptab)+1),
241 tablen*sizeof(struct mblk));
242 bzero((char *)(mtab(&cptab)+tablen+1),
243 (mtablen(&cptab)-tablen-1)*sizeof(struct mblk));
244 } /* next round */
245 }
246 #endif /* MCOMP */
247
248
249 char *
250 mscrounge(np) /* search free lists to satisfy request */
251 register unsigned *np;
252 {
253 char *p;
254 register int bucket;
255 register unsigned bsiz;
256
257 for (bucket = FIRSTBUCKET, bsiz = 1<<FIRSTBUCKET;
258 bucket < NBUCKETS; bucket++, bsiz <<= 1)
259 if (free_list[bucket] != NULL && bsiz+sizeof(M_HEAD) >= *np) {
260 *np = bsiz+sizeof(M_HEAD);
261 p = (char *)free_list[bucket];
262 free_list[bucket] = free_list[bucket]->next;
263 #ifdef MSTATS
264 b_nscrounged += *np;
265 #endif
266 return(p);
267 }
268 #ifdef MCOMP
269 return(mcompact(np)); /* try compaction */
270 #else
271 *np = 0;
272 return(NULL);
273 #endif
274 }
275
276
277 char *
278 bmalloc(n) /* allocate a block of n bytes, sans header */
279 register unsigned n;
280 {
281 extern char *sbrk();
282 static unsigned pagesz = 0;
283 static unsigned amnt;
284 static char *bpos;
285 static unsigned nrem;
286 unsigned thisamnt;
287 register char *p;
288
289 if (pagesz == 0) { /* initialize */
290 pagesz = amnt = getpagesize();
291 nrem = (int)sbrk(0); /* page align break */
292 nrem = pagesz - (nrem&(pagesz-1));
293 bpos = sbrk(nrem);
294 if ((int)bpos == -1)
295 return(NULL);
296 #ifdef MSTATS
297 b_nsbrked += nrem;
298 #endif
299 bpos += nrem & (BYTES_WORD-1); /* align pointer */
300 nrem &= ~(BYTES_WORD-1);
301 memlim[0] = bpos;
302 memlim[1] = bpos + nrem;
303 }
304
305 n = (n+(BYTES_WORD-1))&~(BYTES_WORD-1); /* word align rqst. */
306
307 if (n > nrem) { /* need more core */
308 tryagain:
309 if (n > amnt) { /* big chunk */
310 thisamnt = (n+(pagesz-1))&~(pagesz-1);
311 if (thisamnt <= MAXINCR) /* increase amnt */
312 amnt = thisamnt;
313 } else
314 thisamnt = amnt;
315 p = sbrk(thisamnt);
316 if ((int)p == -1) { /* uh-oh, ENOMEM */
317 errno = 0; /* call cavalry */
318 if (thisamnt >= n+pagesz) {
319 amnt = pagesz; /* minimize request */
320 goto tryagain;
321 }
322 thisamnt = n;
323 p = mscrounge(&thisamnt); /* search free lists */
324 if (p == NULL) { /* we're really out */
325 errno = ENOMEM;
326 return(NULL);
327 }
328 }
329 #ifdef MSTATS
330 else b_nsbrked += thisamnt;
331 #endif
332 if (p != bpos+nrem) { /* not an increment */
333 bfree(bpos, nrem); /* free what we have */
334 bpos = p;
335 nrem = thisamnt;
336 } else /* otherwise tack on */
337 nrem += thisamnt;
338 if (bpos < memlim[0])
339 memlim[0] = bpos;
340 if (bpos + nrem > memlim[1])
341 memlim[1] = bpos + nrem;
342 }
343 p = bpos;
344 bpos += n; /* advance */
345 nrem -= n;
346 #ifdef MSTATS
347 b_nalloced += n;
348 #endif
349 return(p);
350 }
351
352
353 bfree(p, n) /* free n bytes of random memory */
354 register char *p;
355 register unsigned n;
356 {
357 register int bucket;
358 register unsigned bsiz;
359
360 if (n < 1<<FIRSTBUCKET || p == NULL)
361 return;
362 #ifdef MSTATS
363 b_nfreed += n;
364 #endif
365 /* align pointer */
366 bsiz = BYTES_WORD - ((unsigned)p&(BYTES_WORD-1));
367 if (bsiz < BYTES_WORD) {
368 p += bsiz;
369 n -= bsiz;
370 }
371 if (p < memlim[0])
372 memlim[0] = p;
373 if (p + n > memlim[1])
374 memlim[1] = p + n;
375 /* fill big buckets first */
376 for (bucket = NBUCKETS-1, bsiz = 1<<(NBUCKETS-1);
377 bucket >= FIRSTBUCKET; bucket--, bsiz >>= 1)
378 if (n >= bsiz+sizeof(M_HEAD)) {
379 ((M_HEAD *)p)->next = free_list[bucket];
380 free_list[bucket] = (M_HEAD *)p;
381 p += bsiz+sizeof(M_HEAD);
382 n -= bsiz+sizeof(M_HEAD);
383 }
384 }
385
386
387 char *
388 malloc(n) /* allocate n bytes of memory */
389 unsigned n;
390 {
391 register M_HEAD *mp;
392 register int bucket;
393 register unsigned bsiz;
394 /* don't return NULL on 0 request */
395 if (n == 0)
396 return(DUMMYLOC);
397 /* find first bucket that fits */
398 for (bucket = FIRSTBUCKET, bsiz = 1<<FIRSTBUCKET;
399 bucket < NBUCKETS; bucket++, bsiz <<= 1)
400 if (bsiz >= n)
401 break;
402 if (bucket >= NBUCKETS) {
403 errno = EINVAL;
404 return(NULL);
405 }
406 if (free_list[bucket] == NULL) { /* need more core */
407 mp = (M_HEAD *)bmalloc(bsiz+sizeof(M_HEAD));
408 if (mp == NULL)
409 return(NULL);
410 } else { /* got it */
411 mp = free_list[bucket];
412 free_list[bucket] = mp->next;
413 }
414 #ifdef MSTATS
415 m_nalloced += bsiz + sizeof(M_HEAD);
416 m_nwasted += bsiz + sizeof(M_HEAD) - n;
417 #endif
418 mp->a.magic = MAGIC; /* tag block */
419 mp->a.bucket = bucket;
420 return((char *)(mp+1));
421 }
422
423
424 char *
425 realloc(op, n) /* reallocate memory using malloc() */
426 register char *op;
427 unsigned n;
428 {
429 char *p;
430 register unsigned on;
431 /* get old size */
432 if (op != DUMMYLOC && !BADPTR(op) &&
433 ((M_HEAD *)op-1)->a.magic == MAGIC)
434 on = 1 << ((M_HEAD *)op-1)->a.bucket;
435 else
436 on = 0;
437 if (n <= on && (n > on>>1 || on == 1<<FIRSTBUCKET))
438 return(op); /* same bucket */
439 if ((p = malloc(n)) == NULL)
440 return(n<=on ? op : NULL);
441 if (on) {
442 bcopy(op, p, n>on ? on : n);
443 free(op);
444 }
445 return(p);
446 }
447
448
449 free(p) /* free memory allocated by malloc */
450 char *p;
451 {
452 register M_HEAD *mp;
453 register int bucket;
454
455 if (p == DUMMYLOC)
456 return(1);
457 if (BADPTR(p))
458 goto invalid;
459 mp = (M_HEAD *)p - 1;
460 if (mp->a.magic != MAGIC) /* sanity check */
461 goto invalid;
462 bucket = mp->a.bucket;
463 if (bucket < FIRSTBUCKET | bucket >= NBUCKETS)
464 goto invalid;
465 mp->next = free_list[bucket];
466 free_list[bucket] = mp;
467 #ifdef MSTATS
468 m_nfreed += (1 << bucket) + sizeof(M_HEAD);
469 #endif
470 return(1);
471 invalid:
472 errno = EINVAL;
473 return(0);
474 }
475
476
477 #ifdef MSTATS
478 printmemstats(fp) /* print memory statistics to stream */
479 FILE *fp;
480 {
481 register int i;
482 int n;
483 register M_HEAD *mp;
484 unsigned int total = 0;
485
486 fprintf(fp, "Memory statistics:\n");
487 fprintf(fp, "\tbmalloc: %d bytes from sbrk\n", b_nsbrked);
488 fprintf(fp, "\tbmalloc: %d bytes allocated\n", b_nalloced);
489 fprintf(fp, "\tbmalloc: %d bytes freed\n", b_nfreed);
490 fprintf(fp, "\tbmalloc: %d bytes scrounged\n", b_nscrounged);
491 fprintf(fp, "\tbmalloc: %d bytes compacted\n", b_ncompacted);
492 fprintf(fp, "\tmalloc: %d bytes allocated\n", m_nalloced);
493 fprintf(fp, "\tmalloc: %d bytes wasted (%.1f%%)\n", m_nwasted,
494 100.0*m_nwasted/m_nalloced);
495 fprintf(fp, "\tmalloc: %d bytes freed\n", m_nfreed);
496 for (i = NBUCKETS-1; i >= FIRSTBUCKET; i--) {
497 n = 0;
498 for (mp = free_list[i]; mp != NULL; mp = mp->next)
499 n++;
500 if (n) {
501 fprintf(fp, "\t%d * %u\n", n, 1<<i);
502 total += n * ((1<<i) + sizeof(M_HEAD));
503 }
504 }
505 fprintf(fp, "\t %u total bytes in free list\n", total);
506 }
507 #endif
