| 1 |
/* Copyright (c) 1994 Regents of the University of California */
| 2 |
| 3 |
/* SCCSid "$SunId$ LBL" */
| 4 |
| 5 |
| 6 |
* Header file for general associative table lookup routines
| 7 |
| 8 |
| 9 |
typedef struct {
| 10 |
char *key; /* key name */
| 11 |
long hval; /* key hash value (for efficiency) */
| 12 |
char *data; /* pointer to client data */
| 13 |
} LUENT;
| 14 |
| 15 |
typedef struct {
| 16 |
long (*hashf)(); /* key hash function */
| 17 |
int (*keycmp)(); /* key comparison function */
| 18 |
void (*freek)(); /* free a key */
| 19 |
void (*freed)(); /* free the data */
| 20 |
int tsiz; /* current table size */
| 21 |
LUENT *tabl; /* table, if allocated */
| 22 |
int ndel; /* number of deleted entries */
| 23 |
} LUTAB;
| 24 |
| 25 |
#undef strcmp
| 26 |
#define LU_SINIT(fk,fd) {lu_shash,strcmp,(void (*)())(fk),\
| 27 |
(void (*)())(fd),0,NULL,0}
| 28 |
| 29 |
| 30 |
* The lu_init routine is called to initialize a table. The number of
| 31 |
* elements passed is not a limiting factor, as a table can grow to
| 32 |
* any size permitted by memory. However, access will be more efficient
| 33 |
* if this number strikes a reasonable balance between default memory use
| 34 |
* and the expected (minimum) table size. The value returned is the
| 35 |
* actual allocated table size (or zero if there was insufficient memory).
| 36 |
| 37 |
* The hashf, keycmp, freek and freed member functions must be assigned
| 38 |
* separately. If the hash value is sufficient to guarantee equality
| 39 |
* between keys, then the keycmp pointer may be NULL. Otherwise, it
| 40 |
* should return 0 if the two passed keys match. If it is not necessary
| 41 |
* (or possible) to free the key and/or data values, then the freek and/or
| 42 |
* freed member functions may be NULL.
| 43 |
| 44 |
* It isn't fully necessary to call lu_init to initialize the LUTAB structure.
| 45 |
* If tsiz is 0, then the first call to lu_find will allocate a minimal table.
| 46 |
* The LU_SINIT macro provides a convenient static declaration for character
| 47 |
* string keys.
| 48 |
| 49 |
* The lu_find routine returns the entry corresponding to the given
| 50 |
* key. If the entry does not exist, the corresponding key field will
| 51 |
* be NULL. If the entry has been previously deleted but not yet freed,
| 52 |
* then only the data field will be NULL. It is the caller's
| 53 |
* responsibility to (allocate and) assign the key and data fields when
| 54 |
* creating a new entry. The only case where lu_find returns NULL is when
| 55 |
* the system has run out of memory.
| 56 |
| 57 |
* The lu_delete routine frees an entry's data (if any) by calling
| 58 |
* the freed member function, but does not free the key field. This
| 59 |
* will be freed later during (or instead of) table reallocation.
| 60 |
* It is therefore an error to reuse or do anything with the key
| 61 |
* field after calling lu_delete.
| 62 |
| 63 |
* The lu_done routine calls the given free function once for each
| 64 |
* assigned table entry (i.e. each entry with an assigned key value).
| 65 |
* The user must define these routines to free the key and the data
| 66 |
* in the LU_TAB structure. The final action of lu_done is to free the
| 67 |
* allocated table itself.
| 68 |
| 69 |
| 70 |
extern int lu_init();
| 71 |
extern LUENT *lu_find();
| 72 |
extern void lu_delete();
| 73 |
extern void lu_done();
| 74 |
extern long lu_shash();
| 75 |
| 76 |
extern int strcmp();
