root/radiance/ray/src/common/lookup.h
Revision: 2.13
Committed: Tue May 25 06:30:46 2004 UTC (21 years, 1 month ago) by greg
Added argument for client data to lu_doall()
1 /* RCSid $Id: lookup.h,v 2.12 2004/03/28 20:33:12 schorsch Exp $ */
2 /*
3 * Header file for general associative table lookup routines
4 */
5 #ifndef _RAD_LOOKUP_H_
6 #define _RAD_LOOKUP_H_
7
8 #include <string.h> /* strcmp() */
9
10 #ifdef __cplusplus
11 extern "C" {
12 #endif
13
14 typedef void lut_free_t(void *p);
15 typedef unsigned long lut_hashf_t(void*);
16 typedef int lut_keycmpf_t(const void*, const void*);
17
18 typedef struct {
19 char *key; /* key name */
20 unsigned long hval; /* key hash value (for efficiency) */
21 char *data; /* pointer to client data */
22 } LUENT;
23
24 typedef struct {
25 lut_hashf_t *hashf; /* key hash function */
26 lut_keycmpf_t *keycmp; /* key comparison function */
27 lut_free_t *freek; /* free a key */
28 lut_free_t *freed; /* free the data */
29 int tsiz; /* current table size */
30 LUENT *tabl; /* table, if allocated */
31 int ndel; /* number of deleted entries */
32 } LUTAB;
33
34
35 /*
36 * The lu_init routine is called to initialize a table. The number of
37 * elements passed is not a limiting factor, as a table can grow to
38 * any size permitted by memory. However, access will be more efficient
39 * if this number strikes a reasonable balance between default memory use
40 * and the expected (minimum) table size. The value returned is the
41 * actual allocated table size (or zero if there was insufficient memory).
42 *
43 * The hashf, keycmp, freek and freed member functions must be assigned
44 * separately. If the hash value is sufficient to guarantee equality
45 * between keys, then the keycmp pointer may be NULL. Otherwise, it
46 * should return 0 if the two passed keys match. If it is not necessary
47 * (or possible) to free the key and/or data values, then the freek and/or
48 * freed member functions may be NULL.
49 *
50 * It isn't fully necessary to call lu_init to initialize the LUTAB structure.
51 * If tsiz is 0, then the first call to lu_find will allocate a minimal table.
52 * The LU_SINIT macro provides a convenient static declaration for character
53 * string keys.
54 *
55 * The lu_find routine returns the entry corresponding to the given
56 * key. If the entry does not exist, the corresponding key field will
57 * be NULL. If the entry has been previously deleted but not yet freed,
58 * then only the data field will be NULL. It is the caller's
59 * responsibility to (allocate and) assign the key and data fields when
60 * creating a new entry. The only case where lu_find returns NULL is when
61 * the system has run out of memory.
62 *
63 * The lu_delete routine frees an entry's data (if any) by calling
64 * the freed member function, but does not free the key field. This
65 * will be freed later during (or instead of) table reallocation.
66 * It is therefore an error to reuse or do anything with the key
67 * field after calling lu_delete.
68 *
69 * The lu_doall routine loops through every filled table entry, calling
70 * the given function once on each entry. If a NULL pointer is passed
71 * for this function, then lu_doall simply returns the total number of
72 * active entries. Otherwise, it returns the sum of all the function
73 * evaluations.
74 *
75 * The lu_done routine calls the given free function once for each
76 * assigned table entry (i.e. each entry with an assigned key value).
77 * The user must define these routines to free the key and the data
78 * in the LU_TAB structure. The final action of lu_done is to free the
79 * allocated table itself.
80 */
81
82 typedef int lut_doallf_t(LUENT *e, void *p);
83
84 extern lut_keycmpf_t lu_strcmp;
85 extern int lu_init(LUTAB *tbl, int nel);
86 extern unsigned long lu_shash(void *s);
87 extern LUENT *lu_find(LUTAB *tbl, char *key);
88 extern void lu_delete(LUTAB *tbl, char *key);
89 extern int lu_doall(LUTAB *tbl, lut_doallf_t *f, void *p);
90 extern void lu_done(LUTAB *tbl);
91
92 #define LU_SINIT(fk,fd) {lu_shash,lu_strcmp,fk,fd,0,NULL,0}
93
94 #ifdef __cplusplus
95 }
96 #endif
97 #endif /* _RAD_LOOKUP_H_ */
98
